path: root/drivers/rapidio
2010-06-16fix typos concerning "associate"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-30rapidio: fix new kernel-doc warningsRandy Dunlap
Fix a bunch of new rapidio kernel-doc warnings: Warning(include/linux/rio.h:123): No description found for parameter 'comp_tag' Warning(include/linux/rio.h:123): No description found for parameter 'phys_efptr' Warning(include/linux/rio.h:123): No description found for parameter 'em_efptr' Warning(include/linux/rio.h:123): No description found for parameter 'pwcback' Warning(include/linux/rio.h:247): No description found for parameter 'set_domain' Warning(include/linux/rio.h:247): No description found for parameter 'get_domain' Warning(drivers/rapidio/rio-scan.c:1133): No description found for parameter 'rdev' Warning(drivers/rapidio/rio-scan.c:1133): Excess function parameter 'port' description in 'rio_init_em' Warning(drivers/rapidio/rio.c:349): No description found for parameter 'rdev' Warning(drivers/rapidio/rio.c:349): Excess function parameter 'mport' description in 'rio_request_inb_pwrite' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'port' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'local' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'destid' Warning(drivers/rapidio/rio.c:393): No description found for parameter 'hopcount' Warning(drivers/rapidio/rio.c:393): Excess function parameter 'rdev' description in 'rio_mport_get_physefb' Warning(drivers/rapidio/rio.c:845): Excess function parameter 'local' description in 'rio_std_route_clr_table' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: use default route value for CPS switchesAlexandre Bounine
Fix to use correct default value for routing table entries. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add switch domain routinesAlexandre Bounine
Add switch specific domain routines required for 16-bit routing support in switches with hierarchical implementation of routing tables. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: modify initialization of switch operationsAlexandre Bounine
Modify the way how RapidIO switch operations are declared. Multiple assignments through the linker script replaced by single initialization call. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add debug configuration optionAlexandre Bounine
Add debug configuration option for RapidIO subsystem. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Cc: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: fix typos and minor editsAlexandre Bounine
2010-05-27rapidio: add enabling SRIO port RX and TXThomas Moll
Add the functionality to enable Input receiver and Output transmitter of every port, to allow non-maintenance traffic. Signed-off-by: Thomas Moll <thomas.moll@sysgo.com> Signed-off-by: Alexandre Bounine <abounine@tundra.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add Port-Write handling for EMAlexandre Bounine
Add RapidIO Port-Write message handling in the context of Error Management Extensions Specification Rev.1.3. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add switch locking during discoveryAlexandre Bounine
Add switch access locking during RapidIO discovery. Access lock is required when reading switch routing table contents due to indexed mechanism of RT addressing. Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-27rapidio: add IDT CPS/TSI switchesAlexandre Bounine
Extentions to RapidIO switch support: 1. modify switch route operation declarations to allow using single switch-specific file for family of switches that share the same route table operations. 2. add standard route table operations for switches that that support route table manipulation registers as defined in the Rev.1.3 of RapidIO specification. 3. add clear-route-table operation for switches 4. add CPSxx and TSIxxx families of RapidIO switches Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Tested-by: Thomas Moll <thomas.moll@sysgo.com> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: Li Yang <leoli@freescale.com> Cc: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15rio: warn_unused_result warnings fixYang Li
Adding failure path for the following two cases. warning: ignoring return value of 'device_add', declared with attribute warn_unused_result warning: ignoring return value of 'sysfs_create_bin_file', declared with attribute warn_unused_result Signed-off-by: Li Yang <leoli@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-05-19rapidio: fix section mismatch warningsLi Yang
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24rapidio: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: mporter@kernel.crashing.org Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
2009-01-06rapidio: remove excess kernel-doc notationRandy Dunlap
Remove excess kernel-doc notation from rio header and driver: Warning(include/linux/rio_drv.h:399): Excess function parameter or struct member 'buffer' description in 'rio_get_inb_message' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-16rapidio: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-30rapidio section noiseAl Viro
functions calling devinit and called only from devinit Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10rapidio: fix device reference countingEugene Surovegin
Fix RapidIO device reference counting. Signed-of-by: Eugene Surovegin <ebs@ebshome.net> Cc: Matt Porter <mporter@kernel.crashing.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29[RAPIDIO] Auto-probe the RapidIO system sizeZhang Wei
The RapidIO system size will auto probe in RIO setup. The route table and rionet_active in rionet.c are changed to be allocated dynamically according to the size of the system. Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-04-29[RAPIDIO] Add RapidIO multi mport supportZhang Wei
The original RapidIO driver suppose there is only one mpc85xx RIO controller in system. So, some data structures are defined as mpc85xx_rio global, such as 'regs_win', 'dbell_ring', 'msg_tx_ring'. Now, I changed them to mport's private members. And you can define multi RIO OF-nodes in dts file for multi RapidIO controller in one processor, such as PCI/PCI-Ex host controllers in Freescale's silicon. And the mport operation function declaration should be changed to know which RapidIO controller is target. Signed-off-by: Zhang Wei <wei.zhang@freescale.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-03-03docbook: fix rapidio source filesRandy Dunlap
Fix docbook problems in rapidio source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-31Merge branch 'linux-2.6'Paul Mackerras
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-23[RAPIDIO] Fix compile error and warningKumar Gala
drivers/rapidio/rio.c: In function 'rio_get_asm': drivers/rapidio/rio.c:413: error: implicit declaration of function 'in_interrupt' drivers/rapidio/rio.c: In function 'rio_init_mports': drivers/rapidio/rio.c:480: warning: format '%8.8lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' drivers/rapidio/rio.c:480: warning: format '%8.8lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-11[PATCH] rapidio: fix multi-switch enumerationAlexandre Bounine
This patch contains two fixes for RapisIO enumeration logic: 1. Fix enumeration in configurations with multiple switches. The patch adds: a. Enumeration of an empty switch. Empty switch is a switch that does not have any endpoint devices attached to it (except host device or previous switch in a chain). New code assigns a phony destination ID associated with the switch and sets up corresponding routes. b. Adds a second pass to the enumeration to setup routes to devices discovered after switch was scanned. 2. Fix enumeration failure when riohdid parameter has non-zero value. Current version fails to setup response path to the host when it has destination ID other that 0. Signed-off-by: Alexandre Bounine <alexandreb@tundra.com> Acked-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03Fix several typos in drivers/Matt LaPlante
2006-06-27[PATCH] spin/rwlock init cleanupsIngo Molnar
locking init cleanups: - convert " = SPIN_LOCK_UNLOCKED" to spin_lock_init() or DEFINE_SPINLOCK() - convert rwlocks in a similar manner this patch was generated automatically. Motivation: - cleanliness - lockdep needs control of lock initialization, which the open-coded variants do not give - it's also useful for -rt and for lock debugging in general Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-13[PATCH] Add rio_bus_type probe and remove methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-08[PATCH] fix more missing includesTim Schmielau
Include fixes for 2.6.14-git11. Should allow to remove sched.h from module.h on i386, x86_64, arm, ia64, ppc, ppc64, and s390. Probably more to come since I haven't yet checked the other archs. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] rapidio: message interface updatesMatt Porter
Updates the RIO messaging interface to pass a device instance into the event registeration and callbacks. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] rapidio: core updatesMatt Porter
Addresses issues raised with the 2.6.12-rc6-mm1 RIO support. Fix dma_mask init, shrink some code, general cleanup. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core enumMatt Porter
Adds RapidIO enumeration/discovery. The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] RapidIO support: core baseMatt Porter
Adds a RapidIO subsystem to the kernel. RIO is a switched fabric interconnect used in higher-end embedded applications. The curious can look at the specs over at http://www.rapidio.org The core code implements enumeration/discovery, management of devices/resources, and interfaces for RIO drivers. There's a lot more to do to take advantages of all the hardware features. However, this should provide a good base for folks with RIO hardware to start contributing. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
