[ Upstream commit 6d8e294bf5f0e85c34e8b14b064e2965f53f38b0 ]
When inserting random PFNs for debugging the CEC through
(debugfs)/ras/cec/pfn, depending on the return value of pfn_set(),
multiple values get inserted per a single write.
That is because simple_attr_write() interprets a retval of 0 as
success and claims the whole input. However, pfn_set() returns the
cec_add_elem() value, which, if > 0 and smaller than the whole input
length, makes glibc continue issuing the write syscall until there's
input left:
pfn_set
simple_attr_write
debugfs_attr_write
full_proxy_write
vfs_write
ksys_write
do_syscall_64
entry_SYSCALL_64_after_hwframe
leading to those repeated calls.
Return 0 to fix that.
Cc: linux-edac <linux-edac@vger.kernel.org>
commit f3c74b38a55aefe1004200d15a83f109b510068c upstream.
Switch to using Donald Knuth's binary search algorithm (The Art of
Computer Programming, vol. 3, section 6.2.1). This should've been done
from the very beginning but the author must've been smoking something
very potent at the time.
The problem with the current one was that it would return the wrong
element index in certain situations:
https://lkml.kernel.org/r/CAM_iQpVd02zkVJ846cj-Fg1yUNuz6tY5q1Vpj4LrXmE06dPYYg@mail.gmail.com
and the noodling code after the loop was fishy at best.
So switch to using Knuth's binary search. The final result is much
cleaner and straightforward.
Fixes: 011d82611172 ("RAS: Add a Corrected Errors Collector")
Reported-by: Cong Wang <xiyou.wangcong@gmail.com>
Cc: <stable@vger.kernel.org>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
parse_cec_param() compares a string with "cec_disable" using only 7
characters of the 11-character-long string.
The proper solution for this would be:
#define CEC_DISABLE "cec_disable"
strncmp(str, CEC_DISABLE, strlen(CEC_DISABLE))
but when comparing a string against a string constant strncmp() has no
advantage over strcmp() because the comparison is guaranteed to be bound by
the string constant. So just replace str strncmp() with strcmp().
[ tglx: Made it use strcmp and updated the changelog ]
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Cc: stable@vger.kernel.org
Link: http://lkml.kernel.org/r/20170903075440.30250-1-nicolas.iooss_linux@m4x.org
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux
Pull arm64 updates from Will Deacon:
- RAS reporting via GHES/APEI (ACPI)
- Indirect ftrace trampolines for modules
- Improvements to kernel fault reporting
- Page poisoning
- Sigframe cleanups and preparation for SVE context
- Core dump fixes
- Sparse fixes (mainly relating to endianness)
- xgene SoC PMU v3 driver
- Misc cleanups and non-critical fixes
* tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (75 commits)
arm64: fix endianness annotation for 'struct jit_ctx' and friends
arm64: cpuinfo: constify attribute_group structures.
arm64: ptrace: Fix incorrect get_user() use in compat_vfp_set()
arm64: ptrace: Remove redundant overrun check from compat_vfp_set()
arm64: ptrace: Avoid setting compat FP[SC]R to garbage if get_user fails
arm64: fix endianness annotation for __apply_alternatives()/get_alt_insn()
arm64: fix endianness annotation in get_kaslr_seed()
arm64: add missing conversion to __wsum in ip_fast_csum()
arm64: fix endianness annotation in acpi_parking_protocol.c
arm64: use readq() instead of readl() to read 64bit entry_point
arm64: fix endianness annotation for reloc_insn_movw() & reloc_insn_imm()
arm64: fix endianness annotation for aarch64_insn_write()
arm64: fix endianness annotation in aarch64_insn_read()
arm64: fix endianness annotation in call_undef_hook()
arm64: fix endianness annotation for debug-monitors.c
ras: mark stub functions as 'inline'
arm64: pass endianness info to sparse
arm64: ftrace: fix !CONFIG_ARM64_MODULE_PLTS kernels
arm64: signal: Allow expansion of the signal frame
acpi: apei: check for pending errors when probing GHES entries
Check the correct variable when handling a potential error from
debugfs_create_file(). Most likely a copy-paste botch.
[ Rewrite commit message. ]
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Link: http://lkml.kernel.org/r/20170623062440.6726-1-christophe.jaillet@wanadoo.fr
Currently there are trace events for the various RAS
errors with the exception of ARM processor type errors.
Add a new trace event for such errors so that the user
will know when they occur. These trace events are
consistent with the ARM processor error section type
defined in UEFI 2.6 spec section N.2.4.4.
Signed-off-by: Tyler Baicar <tbaicar@codeaurora.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Reviewed-by: Xie XiuQi <xiexiuqi@huawei.com>
The UEFI spec includes non-standard section type support in the
Common Platform Error Record. This is defined in section N.2.3 of
UEFI version 2.5.
Currently if the CPER section's type (UUID) does not match any
section type that the kernel knows how to parse, a trace event is
not generated.
Generate a trace event which contains the raw error data for
non-standard section type error records.
CC: Jonathan (Zhixiong) Zhang <zjzhang@codeaurora.org>
Tested-by: Shiju Jose <shiju.jose@huawei.com>
Make parse_ras_param() static as it is used locally only.
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Link: http://lkml.kernel.org/r/20170516161034.2973-1-weiyj.lk@gmail.com
Introduce a simple data structure for collecting correctable errors
along with accessors. More detailed description in the code itself.
The error decoding is done with the decoding chain now and
mce_first_notifier() gets to see the error first and the CEC decides
whether to log it and then the rest of the chain doesn't hear about it -
basically the main reason for the CE collector - or to continue running
the notifiers.
When the CEC hits the action threshold, it will try to soft-offine the
page containing the ECC and then the whole decoding chain gets to see
the error.
Link: http://lkml.kernel.org/r/20170327093304.10683-5-bp@alien8.de
This is an x86-specific module and would benefit from being
closer to the arch code. Move it there. Update copyright while
at it.
Link: http://lkml.kernel.org/r/1439396985-12812-14-git-send-email-bp@alien8.de
Text taken a previous patch from "Gong Chen" <gong.chen@linux.intel.com>.
Cc: Gong Chen <gong.chen@linux.intel.com>
Link: http://lkml.kernel.org/r/1439396985-12812-11-git-send-email-bp@alien8.de
Add trace interface to elaborate all H/W error related information.
Signed-off-by: Chen, Gong <gong.chen@linux.intel.com>
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Tony Luck <tony.luck@intel.com>
Implement a new debugfs interface for RAS susbsystem.
A file named daemon_active is added there accordingly.
This file is used to track if user space daemon accesses
perf/trace interface or not. One can track which daemon
opens it via "lsof /path/to/debugfs/ras/daemon_active".
Link: http://lkml.kernel.org/r/1402475691-30045-5-git-send-email-gong.chen@linux.intel.com
To avoid confuision and conflict of usage for RAS related trace event,
add an unified RAS trace event stub.
Start a RAS subsystem menu which will be fleshed out in time, when more
features get added to it.
Link: http://lkml.kernel.org/r/1402475691-30045-2-git-send-email-gong.chen@linux.intel.com
