Signed-off-by: Haoran.Wang <elven.wang@nxp.com>
Signed-off-by: Robin Gong <yibin.gong@nxp.com>
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
(cherry picked from commit 37f67d291e74a3428310cb5c98f556411042f810)
add pf1550 regulator rpmsg driver to control pf1550 on the m4 side
by rpmsg.
Add basic pf1550 regulator driver.
Add PMIC 'MAX17135' module drivers to 4.1.y kernel. These are necessary
to supply power for E-ink panel display functions.
Signed-off-by: Robby Cai <r63905@freescale.com>
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"New Drivers
- RK805 Power Management IC (PMIC)
- ROHM BD9571MWV-M MFD Power Management IC (PMIC)
- Texas Instruments TPS68470 Power Management IC (PMIC) & LEDs
New Device Support:
- Add support for HiSilicon Hi6421v530 to hi6421-pmic-core
- Add support for X-Powers AXP806 to axp20x
- Add support for X-Powers AXP813 to axp20x
- Add support for Intel Sunrise Point LPSS to intel-lpss-pci
New Functionality:
- Amend API to provide register layout; atmel-smc
Fix-ups:
- DT re-work; omap, nokia
- Header file location change {I2C => MFD}; dm355evm_msp, tps65010
- Fix chip ID formatting issue(s); rk808
- Optionally register touchscreen devices; da9052-core
- Documentation improvements; twl-core
- Constification; rtsx_pcr, ab8500-core, da9055-i2c, da9052-spi
- Drop unnecessary static declaration; max8925-i2c
- Kconfig changes (missing deps and remove module support)
- Slim down oversized licence statement; hi6421-pmic-core
- Use managed resources (devm_*); lp87565
- Supply proper error checking/handling; t7l66xb
Bug Fixes:
- Fix counter duplication issue; da9052-core
- Fix potential NULL deference issue; max8998
- Leave SPI-NOR write-protection bit alone; lpc_ich
- Ensure device is put into reset during suspend; intel-lpss
- Correct register offset variable size; omap-usb-tll"
* tag 'mfd-next-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (61 commits)
mfd: intel_soc_pmic: Differentiate between Bay and Cherry Trail CRC variants
mfd: intel_soc_pmic: Export separate mfd-cell configs for BYT and CHT
dt-bindings: mfd: Add bindings for ZII RAVE devices
mfd: omap-usb-tll: Fix register offsets
mfd: da9052: Constify spi_device_id
mfd: intel-lpss: Put I2C and SPI controllers into reset state on suspend
mfd: da9055: Constify i2c_device_id
mfd: intel-lpss: Add missing PCI ID for Intel Sunrise Point LPSS devices
mfd: t7l66xb: Handle return value of clk_prepare_enable
mfd: Add ROHM BD9571MWV-M PMIC DT bindings
mfd: intel_soc_pmic_chtwc: Turn Kconfig option into a bool
mfd: lp87565: Convert to use devm_mfd_add_devices()
mfd: Add support for TPS68470 device
mfd: lpc_ich: Do not touch SPI-NOR write protection bit on Haswell/Broadwell
mfd: syscon: atmel-smc: Add helper to retrieve register layout
mfd: axp20x: Use correct platform device ID for many PEK
dt-bindings: mfd: axp20x: Introduce bindings for AXP813
mfd: axp20x: Add support for AXP813 PMIC
dt-bindings: mfd: axp20x: Add AXP806 to supported list of chips
mfd: Add ROHM BD9571MWV-M MFD PMIC driver
'regulator/topic/stm32-vref' into regulator-next
Add regulator driver for STM32 voltage reference buffer which can be
used as voltage reference for ADCs, DACs and external components through
dedicated VREF+ pin.
Signed-off-by: Fabrice Gasnier <fabrice.gasnier@st.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
Extend the driver to support Ricoh RC5T619.
Support the additional regulators and slightly different voltage ranges.
Signed-off-by: Pierre-Hugues Husson <phh@phh.me>
Add support for the rk805 regulator. The regulator module consists
of 4 DCDCs, 3 LDOs.
The output voltages are configurable and are meant to supply power
to the main processor and other components.
Signed-off-by: Elaine Zhang <zhangqing@rock-chips.com>
Signed-off-by: Joseph Chen <chenjh@rock-chips.com>
Acked-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
The MT6380 is a regulator found those boards with MediaTek MT7622 SoC
It is connected as a slave to the SoC using MediaTek PMIC wrapper which
is the common interface connecting with Mediatek made various PMICs.
Signed-off-by: Chenglin Xu <chenglin.xu@mediatek.com>
Signed-off-by: Sean Wang <sean.wang@mediatek.com>
'regulator/topic/lp8755', 'regulator/topic/lp87565', 'regulator/topic/max8997' and 'regulator/topic/palmas' into regulator-next
add the driver for hi6421v530 voltage regulator
Signed-off-by: Wang Xiaoyin <hw.wangxiaoyin@hisilicon.com>
Signed-off-by: Guodong Xu <guodong.xu@linaro.org>
Regulator support for the DA9061 is added into the DA9062 regulator driver.
The regulators for DA9061 differ from those of DA9062.
A new DA9061 enumeration list for the LDOs and Bucks supported by this
device is added. Regulator information added: the old regulator
information for DA9062 is renamed from local_regulator_info[] to
local_da9062_regulator_info[] and a new array is added to support
local_da9061_regulator_info[].
The probe() function switches on the da9062_compatible_types enumeration
and configures the correct da9062_regulator_info array and number of
regulator entries.
Kconfig is updated to reflect support for DA9061 and DA9062 regulators.
Signed-off-by: Steve Twiss <stwiss.opensource@diasemi.com>
The regulators set consists of 4 BUCKs. The output
voltages are configurable and are meant to supply power to the
main processor and other components. The ramp delay is configurable
for all BUCKs. The BUCKs can be configured in single phase or
multiphase modes.
Signed-off-by: Keerthy <j-keerthy@ti.com>
'regulator/topic/pfuze100', 'regulator/topic/settle', 'regulator/topic/tps65132' and 'regulator/topic/twl6030' into regulator-next
'regulator/topic/arizona', 'regulator/topic/bd9571mvw-m' and 'regulator/topic/const' into regulator-next
Add driver for the regulator block in the ROHM BD9571MWV-W MFD PMIC.
This block supports three voltage monitors, VD18, VD25, VD33 for the
1V8, 2V5, 3V3 voltage rails and a single voltage regulator for the
DVFS rail.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
The CS47L24 Arizona codec and most Madera codecs do not have a LDO1
regulator. Split the LDO1 and MICSUPP regulators into separate KConfig
options so the LDO1 is only built into the kernel if needed.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
Add regulator driver for the device TI TPS65132 which is single
inductor - dual output power supply device. TPS65132 device is
designed to support general positive/negative driven applications
like TFT display panels.
TPS65132 regulator driver supports to enable/disable and set voltage
on its output.
Signed-off-by: Venkat Reddy Talla <vreddytalla@nvidia.com>
The output voltage of a voltage controlled regulator can be controlled
through the voltage of another regulator. The current version of this
driver assumes that the output voltage is a linear function of the control
voltage.
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Acked-by: Rob Herring <robh@kernel.org>
Many Motorola phones like droid 4 are using a custom PMIC called CPCAP
or 6556002. This PMIC is used with several SoCs, I've noticed at least
omap3, omap4 and Tegra2 based Motorola phones and tablets using it.
Cc: devicetree@vger.kernel.org
Cc: Marcel Partap <mpartap@gmx.net>
Cc: Michael Scott <michael.scott@linaro.org>
Cc: Rob Herring <robh@kernel.org>
"Core framework:
- Add the MFD bindings doc to MAINTAINERS
New drivers:
- X-Powers AC100 Audio CODEC and RTC
- TI LP873x PMIC
- Rockchip RK808 PMIC
- Samsung Exynos Low Power Audio
New device support:
- Add support for STMPE1600 variant to stmpe
- Add support for PM8018 PMIC to pm8921-core
- Add support for AXP806 PMIC in axp20x
- Add support for AXP209 GPIO in axp20x
New functionality:
- Add support for Reset to all STMPE variants
- Add support for MKBP event support to cros_ec
- Add support for USB to intel_soc_pmic_bxtwc
- Add support for IRQs and Power Button to tps65217
Fix-ups:
- Clean-up defunct author emails (da9063, max14577)
- Kconfig fixups (wm8350-i2c, as37220
- Constify (altera-a10sr, sm501)
- Supply PCI IDs (intel-lpss-pci)
- Improve clocking (qcom_rpm)
- Fix IRQ probing (ucb1x00-core)
- Ensure fault log is cleared (da9052)
- Remove NO_IRQ check (ucb1x00-core)
- Supply I2C properties (intel-lpss-acpi, intel-lpss-pci)
- Non standard declaration (tps65217, max8997-irq)
- Remove unused code (lp873x, db8500-prcmu, ab8500-debugfs,
cros_ec_spi)
- Make non-modular (altera-a10sr, intel_msic, smsc-ece1099,
sun6i-prcm, twl-core)
- OF bindings (ac100, stmpe, qcom-pm8xxx, qcom-rpm, rk808, axp20x,
lp873x, exynos5433-lpass, act8945a, aspeed-scu, twl6040, arizona)
Bugfixes:
- Release OF pointer (qcom_rpm)
- Avoid double shifting in suspend/resume (88pm80x)
- Fix 'defined but not used' error (exynos-lpass)
- Fix 'sleeping whilst attomic' (atmel-hlcdc)"
* tag 'mfd-for-linus-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (69 commits)
mfd: arizona: Handle probe deferral for reset GPIO
mfd: arizona: Remove arizona_of_get_named_gpio helper function
mfd: arizona: Add DT options for max_channels_clocked and PDM speaker config
mfd: twl6040: Register child device for twl6040-pdmclk
mfd: cros_ec_spi: Remove unused variable 'request'
mfd: omap-usb-host: Return value is not 'const int'
mfd: ab8500-debugfs: Remove 'weak' function suspend_test_wake_cause_interrupt_is_mine()
mfd: ab8500-debugfs: Remove ab8500_dump_all_banks_to_mem()
mfd: db8500-prcmu: Remove unused *prcmu_set_ddr_opp() calls
mfd: ab8500-debugfs: Prevent initialised field from being over-written
mfd: max8997-irq: 'inline' should be at the beginning of the declaration
mfd: rk808: Fix RK818_IRQ_DISCHG_ILIM initializer
mfd: tps65217: Fix nonstandard declaration
mfd: lp873x: Remove unused mutex lock from struct lp873x
mfd: atmel-hlcdc: Do not sleep in atomic context
mfd: exynos-lpass: Mark PM functions as __maybe_unused
mfd: intel-lpss: Add default I2C device properties for Apollo Lake
mfd: twl-core: Make it explicitly non-modular
mfd: sun6i-prcm: Make it explicitly non-modular
mfd: smsc-ece1099: Make it explicitly non-modular
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.9 series:
Subsystem improvements:
- do away with the last users of the obsolete Kconfig options
ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB (the latter
always sounded like an item on a wishlist to Santa Claus to me). We
can now select GPIOLIB and be done with it, for all archs. After
some struggle it even work on UM. Not that it has GPIO, but if it
wants to, it can select the library.
- continued efforts to make drivers properly either tristate or bool.
- introduce a warning for drivers assigning default triggers to their
irqchip lines when probed from device tree, so we find and fix
these ambigous drivers. It is agreed that in the OF config path,
the device tree defines trigger characteristics.
- the same warning, mutatis mutandis, for ACPI-probed GPIO irqchips.
- we introduce the ability to mark certain IRQ lines as "unusable" as
they can be taken by BIOS/firmware, unrouted in silicon and
generally nasty if you use them, and such things. This is put to
good use in the STMPE driver and also in the Cherryview pin control
driver.
- a new "mockup" virtual GPIO device that can be used for testing.
The plan is to add unit tests under tools/* for exercising this
device and verify that the kernel code paths are working as they
should.
- make memory-mapped I/O-drivers depend on HAS_IOMEM. This was
implicit all the time, but when people started building UM with
allyesconfig or allmodconfig it exploded in their face.
- move some stray bits of device tree and ACPI HW description
callbacks down into their respective implementation silo. These
were causing issues when compiling on !HAS_IOMEM as well, so now
eventually UM compiles the GPIOLIB library if it wants to.
New drivers:
- new driver for the Aspeed GPIO front-end companion to the pin
controller merged through the pin control tree.
- new driver for the LP873x PMIC GPIO portions.
- new driver for Technologic Systems' I2C FPGA GPIO such as TS4900,
TS-7970, TS-7990 and TS-4100.
- new driver for the Broadcom BCM63xx series including BCM6338 and
BCM6345.
- new driver for the Intel WhiskeyCove PMIC GPIO.
- new driver for the Allwinner AXP209 PMIC GPIO portions.
- new driver for Diamond Systems 48 line GPIO-MM, another of these
port-mapped I/O expansion cards.
- support the STMicroelectronics STMPE1600 variant in the STMPE
driver.
Driver improvements:
- the STMPE driver now supports rising/falling edge detection
properly for IRQs.
- the PCA954x will now fetch and enable its VCC regulator properly.
- major rework of the PCA953x driver with the goal of eventually
switching it over to use regmap and thus modernize it even more.
- switch the IOP driver to use the generic MMIO GPIO library.
- move the ages old HTC EGPIO (extended GPIO) GPIO expander driver
over to this subsystem from MFD, achieveing some separation of
concerns"
* tag 'gpio-v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (81 commits)
gpio: add missing static inline
gpio: OF: localize some gpiochip init functions
gpio: acpi: separation of concerns
gpio: OF: separation of concerns
gpio: make memory-mapped drivers depend on HAS_IOMEM
gpio: stmpe: use BIT() macro
gpio: stmpe: forbid unused lines to be mapped as IRQs
mfd/gpio: Move HTC GPIO driver to GPIO subsystem
gpio: MAINTAINERS: Add an entry for GPIO mockup driver
gpio/mockup: add virtual gpio device
gpio: Added zynq specific check for special pins on bank zero
gpio: axp209: Implement get_direction
gpio: aspeed: remove redundant return value check
gpio: loongson1: remove redundant return value check
ARM: omap2: fix missing include
gpio: tc3589x: fix up complaints on unsigned
gpio: tc3589x: add .get_direction() and small cleanup
gpio: f7188x: use gpiochip_get_data instead of container_of
gpio: tps65218: use devm_gpiochip_add_data() for gpio registration
gpio: aspeed: fix return value check in aspeed_gpio_probe()
'ib-mfd-input-4.9', 'ib-mfd-regulator-4.9', 'ib-mfd-regulator-4.9.1', 'ib-mfd-regulator-rtc-4.9', 'ib-mfd-regulator-rtc-4.9-1' and 'ib-mfd-rtc-4.9' into ibs-for-mfd-merged
Add support for the rk818 regulator. The regulator module consists
of 4 DCDCs, 9 LDOs, 1 switch and 1 BOOST converter which is used to
power OTG and HDMI5V.
Signed-off-by: Wadim Egorov <w.egorov@phytec.de>
Change the MFD config option as per latest naming
Fix typo in regulator Kconfig for the TPS80031 tristate string (trivial)
Signed-off-by: Sebastiaan Schalbroeck <schalbroeck@gmail.com>
This patch adds support for the Linear Technology LTC3676
8-output I2C voltage regulator IC.
Cc: Jaffer Kapasi <jkapasi@linear.com>
Signed-off-by: Tim Harvey <tharvey@gateworks.com>
'regulator/topic/rn5t618', 'regulator/topic/tps65218' and 'regulator/topic/twl' into regulator-next
'regulator/topic/of', 'regulator/topic/pfuze100', 'regulator/topic/pwm' and 'regulator/topic/qcom-smd' into regulator-next
The MT6323 is a regulator found on boards based on MediaTek MT7623 and
probably other SoCs. It is a so called pmic and connects as a slave to
SoC using SPI, wrapped inside the pmic-wrapper.
Signed-off-by: Chen Zhong <chen.zhong@mediatek.com>
Signed-off-by: John Crispin <john@phrozen.org>
Extend the driver to support Ricoh RN5T567. Support the additional
DCDC and slightly different voltage range of LDORTC1.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
The CONFIG_REGULATOR_PFUZE100 option also supports PFUZE3000, so
mention that in the Kconfig text.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
'regulator/topic/max8973', 'regulator/topic/maxim', 'regulator/topic/palmas' and 'regulator/topic/pv88080' into regulator-next
The regulators set consists of 2 BUCKs and 2 LDOs. The output
for both BUCKs.
This is the driver for the Powerventure PV88080 BUCKs regulator.
It communicates via an I2C bus to the device.
Signed-off-by: James Ban <James.Ban..opensource@diasemi.com>
The driver MAX8973 supports the driver for Maxim PMIC MAX77621.
MAX77621 supports the junction temp warning at 120 degC and
140 degC which is configurable. It generates alert signal when
junction temperature crosses these threshold.
MAX77621 does not support the continuous temp monitoring of
junction temperature. It just report whether junction temperature
crossed the threshold or not.
Add support to
- Configure junction temp warning threshold via DT property
to generate alert when it crosses the threshold.
- Add support to interrupt the host from this device when alert
occurred.
- read the junction temp via thermal framework.
"This is the bulk of GPIO changes for kernel v4.6. There is quite a
lot of interesting stuff going on.
The patches to other subsystems and arch-wide are ACKed as far as
possible, though I consider things like per-arch <asm/gpio.h> as
essentially a part of the GPIO subsystem so it should not be needed.
Core changes:
- The gpio_chip is now a *real device*. Until now the gpio chips
were just piggybacking the parent device or (gasp) floating in
space outside of the device model.
We now finally make GPIO chips devices. The gpio_chip will create
a gpio_device which contains a struct device, and this gpio_device
struct is kept private. Anything that needs to be kept private
from the rest of the kernel will gradually be moved over to the
gpio_device.
- As a result of making the gpio_device a real device, we have added
resource management, so devm_gpiochip_add_data() will cut down on
overhead and reduce code lines. A huge slew of patches convert
almost all drivers in the subsystem to use this.
- Building on making the GPIO a real device, we add the first step of
a new userspace ABI: the GPIO character device. We take small
steps here, so we first add a pure *information* ABI and the tool
"lsgpio" that will list all GPIO devices on the system and all
lines on these devices.
We can now discover GPIOs properly from userspace. We still have
not come up with a way to actually *use* GPIOs from userspace.
- To encourage people to use the character device for the future, we
have it always-enabled when using GPIO. The old sysfs ABI is still
opt-in (and can be used in parallel), but is marked as deprecated.
We will keep it around for the foreseeable future, but it will not
be extended to cover ever more use cases.
Cleanup:
- Bjorn Helgaas removed a whole slew of per-architecture <asm/gpio.h>
includes.
This dates back to when GPIO was an opt-in feature and no shared
library even existed: just a header file with proper prototypes was
provided and all semantics were up to the arch to implement. These
patches make the GPIO chip even more a proper device and cleans out
leftovers of the old in-kernel API here and there.
Still some cruft is left but it's very little now.
- There is still some clamping of return values for .get() going on,
but we now return sane values in the vast majority of drivers and
the errorpath is sanitized. Some patches for powerpc, blackfin and
unicore still drop in.
- We continue to switch the ARM, MIPS, blackfin, m68k local GPIO
implementations to use gpiochip_add_data() and cut down on code
lines.
- MPC8xxx is converted to use the generic GPIO helpers.
- ATH79 is converted to use the generic GPIO helpers.
New drivers:
- WinSystems WS16C48
- Acces 104-DIO-48E
- F81866 (a F7188x variant)
- Qoric (a MPC8xxx variant)
- TS-4800
- SPI serializers (pisosr): simple 74xx shift registers connected to
SPI to obtain a dirt-cheap output-only GPIO expander.
- Texas Instruments TPIC2810
- Texas Instruments TPS65218
- Texas Instruments TPS65912
- X-Gene (ARM64) standby GPIO controller"
* tag 'gpio-v4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (194 commits)
Revert "Share upstreaming patches"
gpio: mcp23s08: Fix clearing of interrupt.
gpiolib: Fix comment referring to gpio_*() in gpiod_*()
gpio: pca953x: Fix pca953x_gpio_set_multiple() on 64-bit
gpio: xgene: Fix kconfig for standby GIPO contoller
gpio: Add generic serializer DT binding
gpio: uapi: use 0xB4 as ioctl() major
gpio: tps65912: fix bad merge
Revert "gpio: lp3943: Drop pin_used and lp3943_gpio_request/lp3943_gpio_free"
gpio: omap: drop dev field from gpio_bank structure
gpio: mpc8xxx: Slightly update the code for better readability
gpio: mpc8xxx: Remove *read_reg and *write_reg from struct mpc8xxx_gpio_chip
gpio: mpc8xxx: Fixup setting gpio direction output
gpio: mcp23s08: Add support for mcp23s18
dt-bindings: gpio: altera: Fix altr,interrupt-type property
gpio: add driver for MEN 16Z127 GPIO controller
gpio: timberdale: Switch to devm_ioremap_resource()
gpio: ts4800: Add IMX51 dependency
gpiolib: rewrite gpiodev_add_to_list
'regulator/topic/max77620', 'regulator/topic/max77686', 'regulator/topic/max77802' and 'regulator/topic/maxim' into regulator-next
'regulator/topic/fan53555', 'regulator/topic/gpio', 'regulator/topic/hi655x' and 'regulator/topic/lp872x' into regulator-next
MAXIM Semiconductor's PMIC, MAX77620 and MAX20024 have the
multiple DCDC and LDOs. This supplies the power to different
components of the system.
Also these rails has configuration for ramp time, flexible
power sequence, slew rate etc.
Add regulator driver to access these rails via regulator APIs.
Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Add the regulator driver for hi655x PMIC.
Signed-off-by: Chen Feng <puck.chen@hisilicon.com>
Signed-off-by: Fei Wang <w.f@huawei.com>
Signed-off-by: Xinwei Kong <kong.kongxinwei@hisilicon.com>
Reviewed-by: Haojian Zhuang <haojian.zhuang@linaro.org>
This patch adds support for TPS65912 PMIC regulators.
The regulators set consists of 4 DCDCs and 10 LDOs. The output
Signed-off-by: Andrew F. Davis <afd@ti.com>
The old tps65912 driver is being replaced, delete old driver.
This patch adds new regulator driver to support ACT8945A MFD
chip's regulators.
The ACT8945A has three step-down DC/DC converters and four
low-dropout regulators.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator
Pull regulator updates from Mark Brown:
"Aside from a fix for a spurious warning (which caused more problems
than it fixed in the fixing really) this is all driver updates,
including new drivers for Dialog PV88060/90 and TI LM363x and TPS65086
devices. The qcom_smd driver has had PM8916 and PMA8084 support
added"
* tag 'regulator-v4.5' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (36 commits)
regulator: core: remove some dead code
regulator: core: use dev_to_rdev
regulator: lp872x: Get rid of duplicate reference to DVS GPIO
regulator: lp872x: Add missing of_match in regulators descriptions
regulator: axp20x: Fix GPIO LDO enable value for AXP22x
regulator: lp8788: constify regulator_ops structures
regulator: wm8*: constify regulator_ops structures
regulator: da9*: constify regulator_ops structures
regulator: mt6311: Use REGCACHE_RBTREE
regulator: tps65917/palmas: Add bypass ops for LDOs with bypass capability
regulator: qcom-smd: Add support for PMA8084
regulator: qcom-smd: Add PM8916 support
soc: qcom: documentation: Update SMD/RPM Docs
regulator: pv88090: logical vs bitwise AND typo
regulator: pv88090: Fix irq leak
regulator: pv88090: new regulator driver
regulator: wm831x-ldo: Use platform_register/unregister_drivers()
regulator: wm831x-dcdc: Use platform_register/unregister_drivers()
regulator: lp8788-ldo: Use platform_register/unregister_drivers()
regulator: core: Fix nested locking of supplies
'regulator/topic/qcom-smd', 'regulator/topic/tps6105x', 'regulator/topic/tps65086' and 'regulator/topic/tps65218' into regulator-next
'regulator/topic/mt6311', 'regulator/topic/optional', 'regulator/topic/palmas' and 'regulator/topic/pv88060' into regulator-next
