i2c_driver does not need to set an owner because i2c_register_driver()
will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
The act88600/act8846/act8865 regulators have a number of input supplies
supplying the individual regulators. This may even be recursively like on
most Rockchip boards using the act8846 where REG4 is most of the time
connected to the inl1-supply.
Therefore add the ability to specify the input supplies for the individual inputs.
The input-names are taken from the datasheets of act8600, act8846 and act8865.
On the act8600 some regulators do not have separate input supplies.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
This patch adds act8600 support to the act8865 driver.
VBUS and USB charger supported by this chip can be added later
Tested on MIPS Creator CI20
Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com>
It reverts commit a4b4e0461ec5 ("of: Add standard property for poweroff capability").
As discussed on the mailing list, it makes more sense to rename back to the
old established property name, without the vendor prefix. Problem being that
the word "source" usually tends to be used for inputs and that is out of control
of the OS. The poweroff capability is an output which simply turns the
system-power off. Also, this property might be used by drivers which power-off
the system and power back on subsequent RTC alarms. This seems to suggest to
remove "poweroff" from the property name and to choose "system-power-controller"
as the more generic name. This patchs adds the required renaming changes and
defines an helper function which checks if this property is set.
Signed-off-by: Romain Perier <romain.perier@gmail.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
Acked-by: Johan Hovold <johan@kernel.org>
When the property "poweroff-source" is found in the
devicetree, the function pm_power_off is defined. This function sends the
rights bit fields to the global off control register. shutdown/poweroff
commands are now supported for hardware components which use these PMU.
act8846_matches and act8865_matches are defined only when OF is
enabled. Move references to them to the act8865_pdata_from_dt()
function to avoid a build error when OF is disabled.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
Add device id and definition of registers and regulators to support
the act8846 PMU.
Tested-by: Wenyou Yang <wenyou.yang@atmel.com>
Reviewed-by: Axel Lin <axel.lin@ingics.com>
This patch prepares support for other devices in the act88xx family of
PMUs manufactured by Active-Semi.
http://www.active-semi.com/products/power-management-units/act88xx/
act8865_pdata_from_dt() populates the array pdata->regulators with all
the regulators and then assigns the field init_data only for the ones
actually found in the DT.
The patch changes the value assigned to pdata->num_regulators to match
the size of the array.
Simply use ret variable instead.
Also remove unneeded initialize for ret variable.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
The driver loops through all available regulators (ACT8865_REG_NUM)
and accesses pdata->regulators[i].platform_data without checking the
actual value of num_regulators in platform data, potentially causing a
invalid memory access.
Fix this and look up the regulator init_data by id in platform data.
Tested-by Wenyou.Yang <wenyou.yang@atmel.com>
Now we are using devm_regulator_register(), so we don't need the *rdev[] array
to store return value of devm_regulator_register. Use a *rdev variable is
enough for checking return status.
Acked-by: Wenyou Yang <Wenyou.yang@atmel.com>
kzalloc prints its own OOM message upon failure.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Add of_node_put to decrement the ref count.
of_find_node_by_name walks the allnodes list, and can thus walk
outside of the parent node. Use of_get_child_by_name instead.
Fix below build error when !OF:
CC [M] drivers/regulator/act8865-regulator.o
drivers/regulator/act8865-regulator.c: In function 'act8865_pmic_probe':
drivers/regulator/act8865-regulator.c:306:18: error: 'act8865_matches' undeclared (first use in this function)
drivers/regulator/act8865-regulator.c:306:18: note: each undeclared identifier is reported only once for each function it appears in
drivers/regulator/act8865-regulator.c:306:18: error: negative width in bit-field '<anonymous>'
make[2]: *** [drivers/regulator/act8865-regulator.o] Error 1
make[1]: *** [drivers/regulator] Error 2
make: *** [drivers] Error 2
As Mark pointed out, the driver should register all regulators
regardless of how many are used in the system in order to aid diagnostics.
But in the previous patch, only register the regulators that are used.
Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
Which cause to allocate more needless memory.
There is no suspend enable/disable settings mentioned in datasheet,
so just don't implement .set_suspend_[en|dis]able callbacks.
This is not required because current code use devm_regulator_register() to
register regulators.
