path: root/drivers/regulator/db8500-prcmu.c
2013-03-01regulator: db8500-prcmu - remove incorrect __exit markupDmitry Torokhov
Even if bus is not hot-pluggable, the devices can be unbound from the driver via sysfs, so we should not be using __exit annotations on remove() methods. The only exception is drivers registered with platform_driver_probe() which specifically disables sysfs bind/unbind attributes. Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-11-20regulator: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-07-09mfd: Register db8500-prcmu devices using the newly DT:ed MFD APILee Jones
Now the MFD API is Device Tree aware we can use it for platform registration again, even when booting with DT enabled. To aid in Device Node pointer allocation we provide each cell with the associative compatible string. Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-06-17regulator: Change db8500-prcmu match names to reflect Device TreeLee Jones
The 'name' field in 'struct of_regulator_match' expects to match with its corresponding regulator device node in the Device Tree. This patch renames each of the regulators in the db8500-prcum regulator driver so this is true. Signed-off-by: Lee Jones <lee.jones@linaro.org> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-05-18regulator: Enable Device Tree for the db8500-prcmu regulator driverLee Jones
Here we use the previous regulator register code separated from probe to register each of the regulators mentioned in Device Tree. Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-05-18regulator: db8500-prcmu: Separate regulator registration from probeLee Jones
This will provide us with a convenient way to register regulators when booting with Device Tree both enabled & disabled and will save us a great deal of code duplication in time. Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-09regulator: core: Use a struct to pass in regulator runtime configurationMark Brown
Rather than adding new arguments to regulator_register() every time we want to add a new bit of dynamic information at runtime change the function to take these via a struct. By doing this we avoid needing to do further changes like the recent addition of device tree support which required each regulator driver to be updated to take an additional parameter. The regulator_desc which should (mostly) be static data is still passed separately as most drivers are able to configure this statically at build time. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-01-20regulators/db8500: split off shared dbx500 codeBengt Jonsson
As we progress with DB5500 and future voltage domain regulators based on very similar hardware as found in the DB8500 PRCMU, it makes sense to split off the generic parts and introduce some generic debug code for the DBx500 regulators. This patch accoplish a basic abstraction of the DBx500 voltage domain regulators. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23regulator: pass additional of_node to regulator_register()Rajendra Nayak
With device tree support for regulators, its needed that the regulator_dev->dev device has the right of_node attached. To be able to do this add an additional parameter to the regulator_register() api, wherein the dt-adapted driver can then pass this additional info onto the regulator core. Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31regulator: Add module.h to drivers/regulator users as requiredPaul Gortmaker
Another group of drivers that are taking advantage of the implicit presence of module.h -- and will break when we pull the carpet out from under them during a cleanup. Fix 'em now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-24mfd: Move to the new db500 PRCMU APIMattias Nilsson
Now that we have a shared API between the DB8500 and DB5500 PRCMU's, switch to using this neutral API instead. We delete the parts of db8500-prcmu.h that is now PRCMU-neutral, and calls will be diverted to respective driver. Common registers are in dbx500-prcmu-regs.h and common accessors and defines in <linux/mfd/dbx500-prcmu.h> This way we get a a lot more abstraction and code reuse. Signed-off-by: Mattias Nilsson <mattias.i.nilsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-08regulator: db8500-prcmu: small fixesAxel Lin
Small cleanups for better readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-26regulator: Use device platform_data to retrieve db8500 platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-24mach-ux500: voltage domain regulators for DB8500Bengt Jonsson
The DB8500 has ePOD:s (electronic power domains) which are possible to switch on/off to deactivate silicon blocks on the DB8500 SoC by cutting their power without retention. We model these as simple regulators with one bit on/off settings. Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Martin Persson <martin.persson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
