path: root/drivers/regulator/db8500-prcmu.c
2011-07-08regulator: db8500-prcmu: small fixesAxel Lin
Small cleanups for better readability. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-26regulator: Use device platform_data to retrieve db8500 platform bitsSamuel Ortiz
With the addition of a platform device mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-24mach-ux500: voltage domain regulators for DB8500Bengt Jonsson
The DB8500 has ePOD:s (electronic power domains) which are possible to switch on/off to deactivate silicon blocks on the DB8500 SoC by cutting their power without retention. We model these as simple regulators with one bit on/off settings. Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Sundar Iyer <sundar.iyer@stericsson.com> Signed-off-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com> Signed-off-by: Martin Persson <martin.persson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
