path: root/drivers/regulator/lp3971.c
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-22lp3971: Fix BUCK_VOL_CHANGE_SHIFT logicAxel Lin
Given x=0,1,2, current implementation of BUCK_VOL_CHANGE_SHIFT(x) returns 0,4,8. The correct return value should be 0,4,6. This patch fix the logic. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-22lp3971: Fix setting val for LDO2 and LDO4Axel Lin
In lp3971_ldo_set_voltage function, it requires val to left shift 4 bits for LDO2 and LDO4. This patch fix this issue. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-22regulator: handle kcalloc() failureDan Carpenter
Return -ENOMEM if kcalloc() fails Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03Regulators: lp3971 - fail if platform data was not suppliedDmitry Torokhov
There is no point in completing probe if platform data is missing so let's abort loading early. Also, use kcalloc when allocating several instances of the same data structure and mark setup_regulators() as __devinit since it is only called from lp3971_i2c_probe() which is __devinit. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-03-03regulator/lp3971: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-02-12regulator/lp3971: vol_map out of bounds in lp3971_{ldo,dcdc}_set_voltage()Roel Kluin
After `for (val = LDO_VOL_MIN_IDX; val <= LDO_VOL_MAX_IDX; val++)', if no break occurs, val reaches LDO_VOL_MIN_IDX + 1, which is out of bounds for ldo45_voltage_map[] and ldo123_voltage_map[]. Similarly BUCK_TARGET_VOL_MAX_IDX + 1 is out of bounds for buck_voltage_map[]. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-12-17drivers/regulator: use PTR_ERR to get error codeJulia Lawall
IS_ERR returns only 1 or 0. The callsite of setup_regulators expects a negative integer in an error case. Thus, PTR_ERR has to be used to extract it. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E,E1; @@ *E = IS_ERR(...) ... when != E = E1 *return E; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator/lp3971: drop unnecessary initializationWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15regulator: lp3971 - fix driver link error when built-in.Liam Girdwood
lp3971_i2c_remove' referenced in section `.data' of drivers/built-in.o: defined in discarded section `.devexit.text' of drivers/built-in.o Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-06-15LP3971 PMIC regulator driver (updated and combined version)Marek Szyprowski
This patch adds regulator drivers for National Semiconductors LP3971 PMIC. This LP3971 PMIC controller has 3 DC/DC voltage converters and 5 low drop-out (LDO) regulators. LP3971 PMIC controller uses I2C interface. Reviewed-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
