[ Upstream commit e07ff9434167981c993a26d2edbbcb8e13801dbb ]
The s5m8767_pmic_probe() function calls s5m8767_get_register() to
read data without checking the return code, which produces a compile-time
warning when that data is accessed:
drivers/regulator/s5m8767.c: In function 's5m8767_pmic_probe':
drivers/regulator/s5m8767.c:924:7: error: 'enable_reg' may be used uninitialized in this function [-Werror=maybe-uninitialized]
drivers/regulator/s5m8767.c:944:30: error: 'enable_val' may be used uninitialized in this function [-Werror=maybe-uninitialized]
This changes the s5m8767_get_register() function to return a -EINVAL
not just for an invalid register number but also for an invalid
regulator number, as both would result in returning uninitialized
data. The s5m8767_pmic_probe() function is then changed accordingly
to fail on a read error, as all the other callers of s5m8767_get_register()
already do.
In practice this probably cannot happen, as we don't call
s5m8767_get_register() with invalid arguments, but the gcc
warning seems valid in principle, in terms writing safe
error checking.
Fixes: 9c4c60554acf ("regulator: s5m8767: Convert to use regulator_[enable|disable|is_enabled]_regmap")
Signed-off-by: Mark Brown <broonie@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
'regulator/topic/max77693', 'regulator/topic/max77802', 'regulator/topic/power-off' and 'regulator/topic/rk808' into regulator-next
The of_get_regulator_init_data() function is used to extract the regulator
init_data but information on how to extract certain data is defined in the
static regulator descriptor (e.g: how to map the hardware operating modes).
Add a const struct regulator_desc * parameter to the function signature so
the parsing logic could use the information in the struct regulator_desc.
of_get_regulator_init_data() relies on of_get_regulation_constraints() to
actually extract the init_data so it has to pass the struct regulator_desc
but that is modified on a later patch.
Signed-off-by: Javier Martinez Canillas <javier.martinez@collabora.co.uk>
This patch sets ena_gpio_initialized for all drivers which set a
ena_gpio from parsed DT properties. Drivers using pdata may get zero
initialized pdata and therefore copy a 0 into the regulator_config
ena_gpio field.
Signed-off-by: Markus Pargmann <mpa@pengutronix.de>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
'size' is not used in the function. Remove it.
Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
GPIO 0 is a valid GPIO so allow using it as external control for
regulator.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Don't store pointer to regulator_dev returned by
devm_regulator_register() in state container. It isn't used anywhere
outside of probe.
During registration of regulators if external control for regulator was
set in DTS the ena_gpio and ena_gpio_flags fields of regulator_config
were set to proper values.
However the same regulator_config was used in next iterations of loop so
the ena_gpio fields carried over to next regulators.
The issue was not observed as ena_gpio is supported only for Buck9
regulator which is often the last regulator parsed from DTS.
Be sure to clear ena_gpio config fields before registering the
regulator.
Fixes: ee1e0994ab1bd (regulator: s5m8767: Use GPIO for controlling Buck9/eMMC)
'regulator/topic/st-pwm', 'regulator/topic/ti-abb', 'regulator/topic/tps51632', 'regulator/topic/tps62360', 'regulator/topic/tps6507x', 'regulator/topic/tps65090' and 'regulator/topic/tps65217' into regulator-next
Since commit ca5d1b3524b4d
"regulator: helpers: Modify helpers enabling multi-bit control",
we can set enable_val setting for device that use multiple bits for control.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by Krzysztof Kozlowski <k.kozlowski@samsung.com>
kzalloc prints its own OOM message upon failure.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Add of_node_put to decrement the ref count.
of_find_node_by_name walks the allnodes list, and can thus walk
outside of the parent node. Use of_get_child_by_name instead.
Add support for GPIO control (enable/disable) over Buck9. The Buck9
Converter is used as a supply for eMMC Host Controller.
BUCK9EN GPIO of S5M8767 chip may be used by application processor to
enable or disable the Buck9. This has two benefits:
- It is faster than toggling it over I2C bus.
- It allows disabling the regulator during suspend to RAM; The AP will
enable it during resume; Without the patch the regulator supplying
eMMC must be defined as fixed-regulator.
Acked-by: Lee Jones <lee.jones@linaro.org>
depend on it.
regulator/clk: Fix s2mps11 build
This patch fixes a build failure that appeared in v3.13-rc4 due to an
RTC/MFD update merged via -mm.
Replace calls to sec_reg* helpers with direct usage of regmap API. The
sec_reg* helpers are error-prone as they mix u8 with unsigned int and
order of some of parameters (val and mask in sec_reg_update()).
Also the helpers do not give any way of useful abstraction as they just
call corresponding regmap function.
This patch replaces:
- sec_reg_read() with regmap_read(),
- sec_reg_write() with regmap_write(),
- sec_reg_update() with regmap_update_bits().
Add symbols for hard-coded values of BUCK_RAMP field in DVS_RAMP
register. This simplifies a little the code as register update is called
only once.
Rename old regmap field of "struct sec_pmic_dev" to "regmap_pmic" and
add new regmap for RTC.
On S5M8767A registers were not properly updated and read due to usage of
the same regmap as the PMIC. This could be observed in various hangs,
e.g. in infinite loop during waiting for UDR field change.
On this chip family the RTC has different I2C address than PMIC so
additional regmap is needed.
Reviewed-by: Mark Brown <broonie@linaro.org>
Acked-by: Sangbeom Kim <sbkim73@samsung.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Cc: Lee Jones <lee.jones@linaro.org>
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Marek Szyprowski <m.szyprowski@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Voltage setting for BUCK7 and BUCK8 was not supported by s5m8767 driver.
If they were configured in DTS then the driver probing would fail with
EINVAL:
[ 0.288474] VCC_SUB_1.35V: failed to apply 1350000uV constraint
[ 0.288671] s5m8767-pmic s5m8767-pmic: regulator init failed for 35
[ 0.294931] s5m8767-pmic: probe of s5m8767-pmic failed with error -22
This patch adds support for BUCK7 and BUCK8 regulators using standard
regmap get/set voltage sel functions.
Reviewed-by: Sachin Kamat <sachin.kamat@linaro.org>
Replace hard-coded value for mask used in BUCKX_CTRL registers (for
BUCKX_EN field) with a symbol. This also removes two local variables.
The s5m8767 regulator driver parse always the voltage table of buck2/3/4.
If gpio_dvs feature isn't used and dts haven't included the voltage table
of buck2/3/4, s5m8767 regulator driver return error and file probe state.
This patch check only voltage table of buck on s5m8767_pmic_dt_parse_pdata()
if buck[2-4]_gpiodvs is true.
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Signed-off-by: YoungJun Cho <yj44.cho@samsung.com>
This patch parse 'buck[2-4]_ramp_enable and buck_ramp_delay' platform data
from dts file.
It's safe to call regulator_unregister() with NULL, thus remove the NULL test
before regulator_unregister() calls.
Signed-off-by: Mark Brown <broonie@sirena.org.uk>
Delete successive tests to the same location.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
{ ... when forall
return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
{ ... when forall
return ...; }
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
s5m8767_pmic_dt_parse_pdata dereferenes pdata, thus check pdata earlier to
avoid NULL pointer dereference.
Use &pdev->dev rather than iodev->dev for devm_kzalloc() and
of_get_regulator_init_data(), this fixes memory leak.
This device tree support is added for PMIC block of S5m8767 multi
function driver. The usage detail is added in the device tree
documentation section. This change is tested on exynos5250 based
arndale platform by regulator voltage set/get API's.
Reviewed-by: Thomas Abraham <thomas.abraham@linaro.org>
Signed-off-by: Amit Daniel Kachhap <amit.daniel@samsung.com>
Tested-by: Sachin Kamat <sachin.kamat@linaro.org>
It looks pointless to pass max_vol to s5m8767_convert_voltage_to_sel().
Compare selected voltage to desc->max is enough to ensure selected voltage
is in supported range.
The function sec_reg_read invokes regmap_read which expects unsigned int *
as the destination address. The existing driver is passing address of local
variable "val" which is u8. This causes the stack corruption and following
dump is observed during probe.
Hence change "val" from u8 to unsigned int.
Unable to handle kernel paging request at virtual address 02410020
pgd = c0004000
[02410020] *pgd=00000000
Internal error: Oops: 80000005 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 Not tainted (3.6.0-00696-g98a28b18-dirty #27)
PC is at 0x2410020
LR is at _regulator_get_voltage+0x3c/0x70
pc : [<02410020>] lr : [<c02395d4>] psr: 20000013
sp : cf839b68 ip : 00000000 fp : cf92d410
r10: 0000cfd0 r9 : c06d9878 r8 : 0000f0a0
r7 : cf839b70 r6 : cf92d400 r5 : 00000011 r4 : cf000000
r3 : 02410020 r2 : 00000000 r1 : 00000048 r0 : cf000000
Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
[<c02395d4>] (_regulator_get_voltage+0x3c/0x70) from [<c023ad80>] (print_constraints+0x50/0x36c)
[<c023ad80>] (print_constraints+0x50/0x36c) from [<c023e504>] (set_machine_constraints+0xe8/0x2b0)
[<c023e504>] (set_machine_constraints+0xe8/0x2b0) from [<c023e9c8>] (regulator_register+0x2fc/0x604)
[<c023e9c8>] (regulator_register+0x2fc/0x604) from [<c049d628>] (s5m8767_pmic_probe+0x688/0x718)
[<c049d628>] (s5m8767_pmic_probe+0x688/0x718) from [<c029915c>] (platform_drv_probe+0x18/0x1c)
[<c029915c>] (platform_drv_probe+0x18/0x1c) from [<c0297dd0>] (really_probe+0x68/0x1f4)
[<c0297dd0>] (really_probe+0x68/0x1f4) from [<c0298070>] (driver_probe_device+0x30/0x48)
Signed-off-by: Inderpal Singh <inderpal.singh@linaro.org>
This patch modifies the DVS register read function to select correct DVS1
register. This change is required because the GPIO select pin is 000 in
unintialized state and hence selects the DVS1 register.
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Due to a merge conflict we are getting this:
drivers/regulator/s5m8767.c: In function ‘s5m8767_pmic_probe’:
drivers/regulator/s5m8767.c:575:2: error: implicit declaration of function
‘s5m_reg_write’ [-Werror=implicit-function-declaration]
This is fixed by fully converting this driver to the new s5m API.
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFD bits from Samuel Ortiz:
"We have support for a few new drivers:
- Samsung s2mps11
- Wolfson Microelectronics wm5102 and wm5110
- Marvell 88PM800 and 88PM805
- TI twl6041
We also have our regular driver improvements:
- Device tree and IRQ domain support for STE AB8500
- Regmap and devm_* API conversion for TI tps6586x
- Device tree support for Samsung max77686
- devm_* API conversion for STE AB3100
Besides that, quite a lot of fixing and cleanup for mc13xxx, tps65910,
tps65090, da9052 and twl-core."
Fix up mostly trivial conflicts, with the exception of
drivers/usb/host/ehci-omap.c in particular, which had some
re-organization of the reset sequence (commit 1a49e2ac9651: "EHCI:
centralize controller initialization") that clashed with commit
2761a6394516 ("mfd: USB: Fix the omap-usb EHCI ULPI PHY reset fix
issues").
In particular, commit 2761a6394516 moved the usb_add_hcd() to the
*middle* of the reset sequence, which clashes fairly badly with the
reset sequence re-organization (although it could have been done inside
the new omap_ehci_init() function).
I left that part of commit 2761a6394516 just undone.
* tag 'mfd-3.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (110 commits)
mfd: Ensure AB8500 platform data is passed through db8500-prcmu to MFD Core
mfd: Arizone core should select MFD_CORE
mfd: Fix arizona-irq.c build by selecting REGMAP_IRQ
mfd: Add debug trace on entering and leaving arizone runtime suspend
mfd: Correct tps65090 cell names
mfd: Remove gpio support from tps6586x core driver
ARM: tegra: defconfig: Enable tps6586x gpio
gpio: tps6586x: Add gpio support through platform driver
mfd: Cache tps6586x register through regmap
mfd: Use regmap for tps6586x register access.
mfd: Use devm managed resources for tps6586x
input: Add onkey support for 88PM80X PMIC
mfd: Add support for twl6041
mfd: Fix twl6040 revision information
mfd: Matches should be NULL when populate anatop child devices
input: ab8500-ponkey: Create AB8500 domain IRQ mapping
mfd: Add missing out of memory check for pcf50633
Documentation: Describe the AB8500 Device Tree bindings
mfd: Add tps65910 32-kHz-crystal-input init
mfd: Drop modifying mc13xxx driver's id_table in probe
As Prefix of Samsung pmic changed from s5m to s2m,
To make common mfd driver for s2m and s5m series,
This patch rename header of Samsung mfd and modify mfd driver.
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com>
Previous naming rule of samsung pmic start with s5m prefix.
But It is changed by s2m.
To cover various samsung s2m and s5m series,
This patch modify function and variable name for common usage.
Previously, Samsung PMIC naming rule start with prefix of s5m.
But Naming rule is changed.
From now on, Prefix will be changed to s2m.
So, To support pmic series of s5m and s2m, change mfd file and directory name.
Convert to devm_gpio_request to save a few error handling code.
This patch properly handle the gpio_request failure, we should return error
when gpio_request fails rather than just show warning.
I think one of the reason we got -EBUSY is because current code does not free
gpios in s5m8767_pmic_remove(). So it got -EBUSY when reload the module.
Yest another reason is in current code if gpio_request() returns error,
the rest of the code still calls gpio_direction_output to config buck_gpios
and buck_ds gpios. This looks wrong to me.
In current code, .list_voltage and .set_voltage_sel callbacks for BUCK7 and
BUCK8 return -EINVAL.
This patch adds s5m8767_buck78_ops for BUCK7 and BUCK8 which does not set
.list_voltage, .get_voltage_sel and .set_voltage_sel. ( This has the same
effect of returning -EINVAL in the callbacks)
Then for all the users of s5m8767_list_voltage, we don't need to worry about
the case reg_voltage_map[reg_id] is NULL.
So we can convert s5m8767_list_voltage to regulator_list_voltage_linear.
