This change removes the read/write callback functions in favor of common
regmap accessors inside the header file. This change also makes use of
regmap_read/write for single register access which maps better onto what this
driver actually needs.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
(Cherry-pick from mainline
3f7e82759c692df473675ed06fb90b20f1f225c3)
Change-Id: Ida79b196acf65ed14ff9fd2cc1f7c0048f99ba2b
Reviewed-on: http://git-master/r/105922
Reviewed-by: Rhyland Klein <rklein@nvidia.com>
GVS: Gerrit_Virtual_Submit
Settling time is require when there is dcdc rail's voltage change.
Returning proper delay time for dcdc voltage change to settle down
the output voltage to new value.
(cherry picked from commit 18039e0f16d50c8243fe0388a587c25a3b155ece)
Change-Id: Ibd67d2661dd1d5b014754c221d44963baeb13726
Reviewed-on: http://git-master/r/90518
There is settling time for each rails when it is switched to
ON. Implementing enable time for returning proper settling time
of regulator rails when it is enabled.
Filling the on-time for each rail as per tps65910/tps65911
datasheets.
(cherry picked from commit 0651eed5e094a079a0a9fccd80a41cb3e7f2aa99)
Change-Id: Ibdb05171cfb4c4e7a064c8f65193647997e8e9a8
Reviewed-on: http://git-master/r/90517
We actually clear LDO_ST_ON_BIT for standby mode in tps65910_set_mode.
Fix the logic in tps65910_get_mode.
Supply state (EEPROM bits):
ST[1:0] = 00 : Off
ST[1:0] = 01 : On high power (ACTIVE)
ST[1:0] = 10 : Off
ST[1:0] = 11 : On low power (SLEEP)
Acked-by: Laxman Dewangan <ldewangan@nvidia.com>
(cherry picked from commit 585993932ccc44ab6a8c6dc590a2f3d6b2facb41)
Change-Id: I1cb46d05396a286ba34c84b1836b9070f0f78003
Reviewed-on: http://git-master/r/90516
This change improves readability.
Cherry-picked from mainline
94732b97c39859427cf99c34fc9de9750be7e5a5
Change-Id: Ie3eb5462a99cceab40ba0e26e4e3cdb93c5f3f0f
Reviewed-on: http://git-master/r/90515
Keep the rails OFF in sleep mode only when the rails are
controlled by external sleep control.
The devices tps65910 and tps65911, both has the sleep input.
The tps65911's sleep input is not same as tps65910's EN3 and hence
taking care of SLEEP input as separate external sleep control input.
cherry picked from mainline commit
87ae88a17396fe3f91c34ab44f460e5680eb6f61
Change-Id: I05645082ad5268a4553891db6b35af33650b7a95
Reviewed-on: http://git-master/r/89125
As per datasheet, the voltage output is defined as
from SEL[6:0] = 3 to 64 (dec)
Vout= (SEL[6:0] × 12.5 mV + 562.5 mV)
The list_voltage returns the vout as
600mV + selector * 12.5mV
and so equivalent VSEL is selector + 3.
Adding 3 on selector when configuring VSEL register for
VDDCTRL output.
c4632aed3e5b134c55b54af19db49662959384c1
Change-Id: Ifc514a87803191cf796ffc0d75d979476e712dde
Reviewed-on: http://git-master/r/88830
Fix the module desciption and also update Kconfig to include supporting
tps65911 chip.
commit 02c38f3e8e9b0cd76bdb835b0fd8d627ddf5e19b
Change-Id: Iee8eaf208ae2d448f4c022b2c3908f8519191180
Reviewed-on: http://git-master/r/85124
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
The VIO regulator register specify the voltage configuration
on bit3:2 of its register. And hence only these bits should
be modified when setting voltage and used when reading voltage
from register setting.
commit 83e0323211e33b117ce585bab64636ca1fff807a
Change-Id: Ica9d50dd62ccab15a02c8769e8b1279fb32d4a03
Reviewed-on: http://git-master/r/85122
Add support for sleep controls of different regulator through
external inputs EN1, EN2 or EN3.
Each regulator's output will be active when its external
input is high and turns to OFF/Low power mode when its
external input is low.
The configuration parameters for sleep control is provided through
board specific platform data.
1e0c66f49762fa1866ab20b1feb6e86a9aa4838f
Change-Id: Ie8256fae45c21f08b2d101efebca004cb32963a0
Reviewed-on: http://git-master/r/79181
Renaming the variables "table" to "voltage_table" and
"table_len" to "n_voltages" of regulator information
to have more meaningful.
Cherry picked from commit
7d38a3cb9b9f6a6d31b1d19e4f07a7c0b71407d5
Change-Id: I8ef3a7544bf432a3c6efb98d99cb660b6fefde38
Reviewed-on: http://git-master/r/77539
Initializing the number of voltages supported by different
rails of pmic device tps65911.
Cherry picked from mainline's commit
51ced5e288b4381705df173fb05f561dea35bfac
Change-Id: I85ec3261125291f9862f9746ef7ec97e09fa375b
Reviewed-on: http://git-master/r/77538
Adding missing regulator info for VRTC rail for device
tps65911. The regulator voltage rail index start from
VRTC which is defined as 0.
c2f8efd7641b1b10b73ffa6f216a45209a5705dd
Change-Id: I7e544ea2f0b3df677ad75bbca38b744c9a6f71da
Reviewed-on: http://git-master/r/77537
Count of selector voltage is required for regulator_set_voltage
to work via set_voltage_sel. VDD1/2 currently have it as zero,
so regulator_set_voltage won't work for VDD1/2.
Update count (n_voltages) for VDD1/2.
Output Voltage = (step value * 12.5 mV + 562.5 mV) * gain
With above expr, number of voltages that can be selected is
step value count * gain count
constant for gain count will be called VDD1_2_NUM_VOLT_COARSE
existing constant for step value count is VDD1_2_NUM_VOLTS,
use VDD1_2_NUM_VOLT_FINE instead to make clear that step value
is not the only component in deciding selectable voltage count
Signed-off-by: Afzal Mohammed <afzal@ti.com>
780dc9ba4eb682a89be48d5b814feae6722a19e0
Change-Id: I1c246a02f1c647fe3c647b3dde2a0633c2783764
Reviewed-on: http://git-master/r/77536
Create an array of fixed size for the platform to pass regulator
initalization data through.
Passing an array of pointers to init data also allows more flexible
definition of init data as well as prevents reading past the end of the
array should the platform define an incorrectly sized array.
Signed-off-by: Kyle Manna <kyle.manna@fuel7.com>
cherry picked from mainline's commit
c1fc1480249dfe059254779a4bb7ca27cf5f8038
Change-Id: Ia298bbd2828e644d24e10ab67ff76f1169cf7f51
Reviewed-on: http://git-master/r/77535
Move the regulator defintions to the header so that platform board file
can use them to configure specific regulators.
Cherry picked from mainline's commit:
72c108cc4947db2fcdd3f3e8a2b60bd65e74a1cc
Change-Id: I7659c33cab6f20c91dc4bf36e1c157e1878993ab
Reviewed-on: http://git-master/r/77534
For tps65910, the number of regulator is 13. ( ARRAY_SIZE(tps65910_regs) is 13)
For tps65911, the number of regulator is 12. ( ARRAY_SIZE(tps65911_regs) is 12)
If we are using this driver for tps65911,
we hit array access out of bounds bug in tps65910_probe() because
current implementation always assume the number of regulator is 13 and
thus it will access tps65911_regs[12].
Fix it by setting correct num_regulators for both chips in tps65910_probe(),
and allocated neccessay memory accordingly.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Also add a default case in tps65910_list_voltage_dcdc to silence
'volt' may be used uninitialized in this function warning.
Fix a memory leak if chip id is not matched.
The tps65911 chip introduces new features, including changes in
the regulator module.
- VDD1 and VDD2 remain unchanged.
- VDD3 is now named VDDCTRL and has a wider voltage range.
- LDOs are now named LDO1...8 and voltage ranges are sequential,
making LDOs easier to handle.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
The desc_id variable should not be a static variable.
The rest of the code assumes the desc_id must less than TPSxxxxx_NUM_REGULATOR.
If we set desc_id to be a static variable, checking the return value of
rdev_get_id() may return error.
Cc: Anuj Aggarwal <anuj.aggarwal@ti.com>
Cc: Graeme Gregory <gg@slimlogic.co.uk>
The regulator module consists of 3 DCDCs and 8 LDOs. The output
voltages are configurable and are meant to supply power to the
main processor and other components
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
