path: root/drivers/regulator/wm831x-dcdc.c
2011-05-27regulator: Remove some unused variables from wm831x DCDCsMark Brown
These became unused with the IRQ removal patch, I'm fairly sure that a patch was sent earlier by someone else but it doesn't seem to have been applied and I don't have a copy sitting around any more. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: Remove more wm831x-specific IRQ operationsMark Brown
These are the last users in the tree. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: Convert WM831x regulators to genirqMark Brown
2011-02-25regulator: Fix warning with CONFIG_BUG disabledMark Brown
2011-01-12regulator: Convert WM831x drivers to use get_voltage_sel()Mark Brown
2011-01-12regulator: Report actual configured voltage to set_voltage()Mark Brown
Change the interface used by set_voltage() to report the selected value to the regulator core in terms of a selector used by list_voltage(). This allows the regulator core to know the voltage that was chosen without having to do an explict get_voltage(), which would be much more expensive as it will generally access hardware. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-03Regulators: wm831x-xxx - clean up driver data after removalDmitry Torokhov
It is a good tone to reset driver data after unbinding the device. Also set up drivers owner. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-12-17regulator: Implement WM831x BuckWise DC-DC convertor DVS supportMark Brown
The BuckWise DC-DC convertors in WM831x devices support switching to a second output voltage using the logic level on one of the device pins. This is intended to allow rapid voltage switching for uses like cpufreq, replacing the I2C or SPI write used to configure the voltage of the regulator with a much faster GPIO status change. This is implemented by keeping the DVS voltage configured as the maximum voltage permitted for the regulator. If a request is made for the maximum voltage then the GPIO is used to switch to the DVS voltage, otherwise the normal ON voltage is updated and used. This follows the idiom used by most cpufreq drivers, which drop the minimum voltage as the core frequency is dropped but use a constant maximum - raising the voltage should normally be fast, but lowering it may be slower. Configuration of the DVS MFP on the device should be done externally, for example via OTP. Support is present in the hardware for monitoring the status of the transition using a second GPIO. This is not currently implemented but platform data is provided for it - the driver currently assumes that the device will be configured to transition immediately - but platform data is provided to reduce merge issues once it is. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-17regulator: Add WM831x DC-DC boost convertor supportMark Brown
The WM831x series of PMICs include a single DC-DC boost convertor. This adds basic support for this convertor. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17regulator: Add WM831x EPE supportMark Brown
The WM831x series of PMICs provide two optional outputs for controlling external devices during power sequencing, for example an external regulator. While in essence these are GPIOs the hardware presents them as DCDCs with very little control so provide support via the regulator API in that fashion. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17regulator: Add WM831x DC-DC buck convertor supportMark Brown
The WM831x series of devices all have 3 DC-DC buck convertors. This driver implements software control for these regulators via the regulator API. Use with split hardware/software control of individual regulators is not supported, though regulators not controlled by software may be controlled via the hardware control interfaces. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
