By default, regulator set is disabled by kernel, but if enable the function
we can easily set regulator in sysfs, it's useful for unit test of pfuze
regulator.
Signed-off-by: Robin Gong <b38343@freescale.com>
Remove usless code in pfuze100 regulator driver
Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
Configure register 33&40&47 to set standby voltage of SW1A/1B/1C
Signed-off-by: Robin Gong <B38343@freescale.com>
add new regulator driver for pfuze100 based on mfd structure
Signed-off-by: Jason Liu <jason.hui@linaro.org>
- Added V3P3 regulator to max17135
- Added calls to enable/disable V3P3 regulator from EPDC driver
- Improved Kconfig detail for max17135 MFD and HWMON entries
Signed-off-by: Danny Nold <dannynold@freescale.com>
Fix build warnings regarding initialization from incompatible pointer type.
Add Anatop regulator driver.
1.add new regulator driver for new pmic core driver
2.add Kconfig and Makefile
In set_voltage function, all voltages are not in microvolts.
Hence set_voltage function was failing. Change all voltages in
the function to be in microvolts.
Signed-off-by: Ranjani Vaidyanathan <ra5478@freescale.com>
- Ported MAX17135 MFD core driver to 2.6.38
- Ported MAX17135 HWMON temperature sensor driver to 2.6.38
- Ported MAX17135 regulator driver to 2.6.38
Fix da9053 backlight Kconfig error
porting da9052 regulator driver
Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com>
Acked-by: Lily Zhang <r58066@freescale.com>
Add DA9053 original source code
commit d04156bca629740a661fd0738cd69ba1f08b2b20 upstream.
Also add a default case in tps65910_list_voltage_dcdc to silence
'volt' may be used uninitialized in this function warning.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Cc: Johan Hovold <jhovold@gmail.com>
The ramp_delay variable can be set lower than the desired value.
This patch fixes it.
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: KyungMin Park <kyungmin.park@samsung.com>
Small cleanups for better readability.
The platform_data (pdata) may be pointing to __initdata section, which
may be free'd from the memory. The dependency on pdata in non-init
functions is removed in this patch to allow platform to declare
__initdata for platform data.
Currently, ramp_delay variable is used uninitialzed in
max8997_set_voltage_ldobuck which gets called through
regulator_register calls.
To fix the problem, in max8997_pmic_probe, ramp_delay initialization
code is moved before calls to regulator_register.
Cc: Liam Girdwood <lrg@ti.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: MyungJoo Ham <myungjoo.ham@samsung.com>
Cc: Kyungmin Park <kyungmin.park@samsung.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Tushar Behera <tushar.behera@linaro.org>
Acked-by: MyungJoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
In the case of get_voltage callback is NULL, current implementation in
_regulator_get_voltage will return -EINVAL.
Also returns proper error if ret is negative value.
Adding support for the twl6025. Major difference in the twl6025 is the
group functionality has been removed from the chip so this affects how
regulators are enabled and disabled.
The names of the regulators also changed.
The DCDCs of the 6025 are software controllable as well.
Since V1
Use the features variable passed via platform data instead of calling
global function.
Change the very switch like if statements to be a more readable
switch statement.
Since V2
twl6025 doesn't use remap so remove it from the macros.
Since V3
enable/disable functions for 4030/6030 were seperated upstream so rebase
on top of this. Change DCDC reference to SMPS as this is used in TRM.
Change list_voltage slightly to have less code.
Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk>
TWL6030: regulator is disabled via VREG_STATE
TWL4030: regulator is disabled via VREG_GRP
Since there is nothing common, split twlreg_enable similar to other regulator_ops
Signed-off-by: Balaji T K <balajitk@ti.com>
TWL6030: regulator is enabled via VREG_STATE
TWL4030: regulator is enabled via VREG_GRP
The tps65911 chip introduces new features, including changes in
the regulator module.
- VDD1 and VDD2 remain unchanged.
- VDD3 is now named VDDCTRL and has a wider voltage range.
- LDOs are now named LDO1...8 and voltage ranges are sequential,
making LDOs easier to handle.
Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk>
We use val as array index,
thus the valid value rangae for val should be 0 .. n_voltages-1.
Voltage values should be expressed in microvolts, not in milivolts.
MAX8997_REG_BUCK1DVS/MAX8997_REG_BUCK2DVS/MAX8997_REG_BUCK5DVS macros
In current implementation, the original macro implementation assumes the caller
pass the parameter starting from 1 (to match the register names in datasheet).
Thus we have unneeded plus one then minus one operations
when using MAX8997_REG_BUCK1DVS/MAX8997_REG_BUCK2DVS/MAX8997_REG_BUCK5DVS macros.
This patch removes these macros to avoid unneeded plus one then minus one operations
without reducing readability.
Acked-by: Kyungmin Park <kyungmin.park@samsung.com>
When applying the set_voltage() requests from consumers skip over those
consumers that haven't set anything, otherwise we'll come out with a
maximum voltage of zero.
If either a regulator driver can't tell us what the optimum mode is (or
doesn't have modes in the first place) or the system doesn't allow DRMS
changes then it's more helpful for users to just say that we're in the
optimal mode, even if it's from a selection of one.
Still report errors if the process of picking and setting a mode changes as
this may indicate that we're stuck in a low power mode and unable to deliver
a higher current that the consumer just asked for.
fix unreachable code.
The desc_id variable should not be a static variable.
The rest of the code assumes the desc_id must less than TPSxxxxx_NUM_REGULATOR.
If we set desc_id to be a static variable, checking the return value of
rdev_get_id() may return error.
Cc: Anuj Aggarwal <anuj.aggarwal@ti.com>
Cc: Graeme Gregory <gg@slimlogic.co.uk>
mc13892_regulators array"
I check this patch again and found this actually is not a bug
because MC13xxx_DEFINE explictly defines the order of each entry in the array.
Thus revert the patch.
These became unused with the IRQ removal patch, I'm fairly sure that a
patch was sent earlier by someone else but it doesn't seem to have been
applied and I don't have a copy sitting around any more.
The regulator module consists of 3 DCDCs and 8 LDOs. The output
voltages are configurable and are meant to supply power to the
main processor and other components
mc13892_sw_regulator_set_voltage
Currently, we call mc13xxx_reg_read and mc13xxx_reg_rmw for the same register.
This can be converted to simply a mc13xxx_reg_read and a mc13xxx_reg_write,
thus save a redundant register read.
Some systems, particularly physically large systems used for early
prototyping, may experience substantial voltage drops between the regulator
and the consumers as a result of long traces in the system. With these
systems voltages may need to be set higher than requested in order to
ensure reliable system operation.
Allow systems to work around such hardware issues by allowing constraints
to supply an offset to be applied to any requested and reported voltages.
This is not ideal, especially since the voltage drop may be load dependant,
but is sufficient for most affected systems, it is not expected to be used
in production hardware. The offset is applied after all constraint
processing so constraints should be specified in terms of consumer values
not physically configured values.
supply_regulator_dev (using a struct pointer) has been deprecated in favour
of supply_regulator (using a regulator name) for quite a few releases
now with a warning generated if it is used and there are no current in tree
users so just remove the code.
In include/linux/mfd/mc13892.h, we define MC13892_VCOINCELL as 23.
Thus VCOINCELL should be defined as 23th element in mc13892_regulators array, not the first one.
This actually fixes an off-by-one bug while accessing mc13892_regulators array.
For example,
In mc13892_regulator_probe, we use MC13892_VCAM as array index of mc13892_regulators array.
mc13892_regulators[MC13892_VCAM].desc.ops->set_mode
= mc13892_vcam_set_mode;
Currently, it access mc13892_regulators[12] ,which is VAUDIO not VCAM.
Don't go looking up the rdev pointer every time, just use a local variable
like everything else.
The second parameter of regulator_mode_constrain takes a pointer.
This patch fixes below warning:
drivers/regulator/core.c: In function 'regulator_set_mode':
drivers/regulator/core.c:2014: warning: passing argument 2 of 'regulator_mode_constrain' makes pointer from integer without a cast
drivers/regulator/core.c:200: note: expected 'int *' but argument is of type 'unsigned int'
Signed-off-by: Liam Girdwood <lrg@vega.(none)>
Current set_mode logic does not support 6030. The logic for 4030 is
not reusable for 6030 as the mode setting for 6030 now uses the new
CFG_STATE register. We hence rename the old get_status as being
specific to 4030.
Signed-off-by: Nishanth Menon <nm@ti.com>
Signed-off-by: Saquib Herman <saquib@ti.com>
Current get_status logic does not support 6030 get_status.
The logic for 4030 is not reusable for 6030 as the status
check for 6030 now depends on the new CFG_STATE register.
We hence rename the old get_status as being specific to
4030 and remove the redundant check for the same.
With TWL6030, it is not enough to ensure that the regulator is the
group of P1 group (CPU/Linux), but we need to check the state as far
as APP is concerned as well.
Split the current is_enabled to 6030 and 4030 specific ones. This
split impacts few macros and variables as well, but sets up the
stage for further fixes to set_mode and get_status in subsequent
patches.
TWL6030 does not have remap register. The current implementation
causes value of remap to be written to state register, accidentally
causing the regulators which are probed to be switched on as well.
This is wrong as regulators should be controllable based on calls
to enable/disable for TWL regulator framework. Further, the values
initialized make no sense as well. We hence remove this from the
initalizers and also write to remap register only if the TWL
is 4030.
TWL6030 requires an additional register write to CFG_STATE register
to explicitly state that the regulator is in a certain state. Merely
associating the regulator with the group is not enough. Add the
required register field definitions and fix the handling for
TWL6030 enable/disable.
Otherwise, calling platform_get_drvdata in tps6105x_regulator_remove
returns NULL.
If a mode requested by a consumer is not allowed by constraints
automatically fall back to a higher power mode if possible. This
ensures that consumers get at least the output they requested while
allowing machine drivers to transparently limit lower power modes
if required.
Fix printk format warning (seen on x86_64) and change to unsigned
output format:
drivers/regulator/88pm8607.c:417: warning: format '%d' expects type 'int', but argument 3 has type 'resource_size_t'
