path: root/drivers/regulator
2011-03-27regulator: Add MODULE_DEVICE_TABLE to max8997 and max8998Axel Lin
The device table is required to load modules based on modaliases. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: MyungJoo Ham <myungjoo.ham@smasung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: fix tps6524x section mismatchRandy Dunlap
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Fix section mismatch that is caused by init code calling exit code: pmic_remove() cannot be marked as __devexit. WARNING: drivers/regulator/tps6524x-regulator.o(.devinit.text+0x205): Section mismatch in reference from the function pmic_probe() to the function .devexit.text:pmic_remove() The function __devinit pmic_probe() references a function __devexit pmic_remove(). This is often seen when error handling in the init function uses functionality in the exit path. The fix is often to remove the __devexit annotation of pmic_remove() so it may be used outside an exit section. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Cyril Chemparathy <cyril@ti.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: Remove more wm831x-specific IRQ operationsMark Brown
These are the last users in the tree. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: add ab8500 enable and raise time delaysLinus Walleij
This uses the new infrastructure to provide proper delays when enabling or setting the voltage of one specific regulator. Cc: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: provide consumer interface for fall/rise timeLinus Walleij
This exposes the functionality for rise/fall fime when setting voltage to the consumers. Cc: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: add set_voltage_time_sel infrastructureLinus Walleij
This makes it possible to set the stabilization time for voltage regulators in the same manner as enable_time(). The interface only supports regulators that implements fixed selectors. Cc: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: initialization for ab8500 regulatorsBengt Jonsson
The regulators on the AB8500 have a lot of custom hardware control settings pertaining to 8 external signals, settings which are board-specific and need be provided from the platform at startup. Initialization added for regulators Vana, VextSupply1, VextSupply2, VextSupply3, Vaux1, Vaux2, Vaux3, VTVout, Vintcore12, Vaudio, Vdmic, Vamic1, Vamic2, VrefDDR. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Reviewed-by: Rickard Andersson <rickard.andersson@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: add support for USB voltage regulatorBengt Jonsson
Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: switch the ab3100 to use enable_time()Linus Walleij
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> This switches the ab3100 core to use the enable_time() infrastructure from the regulator core. Cc: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26Regulator: add suspend-finish API for regulator core.MyungJoo Ham
The regulator core had suspend-prepare that turns off the regulators when entering a system-wide suspend. However, it did not have suspend-finish that pairs with suspend-prepare and the regulator core has assumed that the regulator devices and their drivers support autonomous recover at resume. This patch adds regulator_suspend_finish that pairs with the previously-existed regulator_suspend_prepare. The function regulator_suspend_finish turns on the regulators that have always_on set or positive use_count so that we can reset the regulator states appropriately at resume. In regulator_suspend_finish, if has_full_constraints, it disables unnecessary regulators. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> -- Updates v3 comments corrected (Thanks to Igor) v2 disable unnecessary regulators (Thanks to Mark) Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: fix typo in KconfigIgor Grinberg
Fix typo: s/TPS695x0/TPS659x0/ Signed-off-by: Igor Grinberg <grinberg@compulab.co.il> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-26regulator: Convert WM831x regulators to genirqMark Brown
2011-03-26regulator: If we fail when setting up a supply say which supplyMark Brown
Makes it a bit easier to identify if it's a problem with the supplies, the usual error would be omitting the supply name entirely. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-03-23regulator: Add a subdriver for TI TPS6105x regulator portions v2Linus Walleij
This adds a subdriver for the regulator found inside the TPS61050 and TPS61052 chips. Cc: Samuel Ortiz <samuel.ortiz@intel.com> Cc: Ola Lilja <ola.o.lilja@stericsson.com> Cc: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23regulator: MAX8997/8966 supportMyungJoo Ham
This patch supports PMIC/Regulator part of MAX8997/MAX8966 MFD. In this initial release, selecting voltages or current-limit and switching on/off the regulators are supported. Controlling voltages for DVS with GPIOs is not implemented fully and requires more considerations: it controls multiple bucks (selection of 1, 2, and 5) at the same time with SET1~3 gpios. Thus, when DVS-GPIO is activated, we lose the ability to control the voltage of a single buck regulator independently; i.e., contolling a buck affects other two bucks. Therefore, using the conventional regulator framework directly might be problematic. However, in this driver, we try to choose a setting without such side effect of affecting other regulators and then try to choose a setting with the minimum side effect (the sum of voltage changes in other regulators). On the other hand, controlling all the three bucks simultenously based on the voltage set table may help build cpufreq and similar system more robust; i.e., all the three voltages are consistent every time without glitches during transition. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: Adopt mfd_data in 88pm860x regulatorHaojian Zhuang
Copy 88pm860x platform data into different mfd_data structure for regulator driver. So move the identification of device node from regulator driver to mfd driver. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to mc13xxx driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Note that mfd-core no longer makes a copy of platform_data, but the mc13xxx-core driver creates the pdata structures on the stack. In order to get around that, the various ARM mach types that set the pdata have been changed to hold the variable in static (global) memory. Also note that __initdata references in aforementioned pdata structs have been dropped. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to ab3100 driversAndres Salomon
The cell's platform_data is now accessed with a helper function; change clients to use that, and remove the now-unused data_size. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23regulator: twl: add clk32kg to twl-regulatorBalaji T K
In OMAP4 Blaze and Panda, 32KHz clock to WLAN is supplied from Phoenix TWL6030. The 32KHz clock state (ON/OFF) is configured in CLK32KG_CFG_[GRP, TRANS, STATE] register. This follows the same register programming model as other regulators in TWL6030. So add CLK32KG as pseudo regulator. Signed-off-by: Balaji T K <balajitk@ti.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-02-25regulator, mc13xxx: Remove pointless test for unsigned less than zeroJesper Juhl
The variable 'val' is a 'unsigned int', so it can never be less than zero. This fact makes the "val < 0" part of the test done in BUG_ON() in mc13xxx_regulator_get_voltage() rather pointles since it can never have any effect. This patch removes the pointless test. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-02-25regulator: Fix warning with CONFIG_BUG disabledMark Brown
2011-01-14regulator: Support MAX8998/LP3974 DVS-GPIOMyungJoo Ham
The previous driver did not support BUCK1-DVS3, BUCK1-DVS4, and BUCK2-DVS2 modes. This patch adds such modes and an option to block setting buck1/2 voltages out of the preset values. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-01-14mfd: Support LP3974 RTCMyungJoo Ham
The first releases of LP3974 have a large delay in RTC registers, which requires 2 seconds of delay after writing to a rtc register (recommended by National Semiconductor's engineers) before reading it. If "rtc_delay" field of the platform data is true, the rtc driver assumes that such delays are required. Although we have not seen LP3974s without requiring such delays, we assume that such LP3974s will be released soon (or they have done so already) and they are supported by "lp3974" without setting "rtc_delay" at the platform data. This patch adds delays with msleep when writing values to RTC registers if the platform data has rtc_delay set. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (348 commits) ALSA: hda - Fix NULL-derefence with a single mic in STAC auto-mic detection ALSA: hda - Add missing NID 0x19 fixup for Sony VAIO ALSA: hda - Fix ALC275 enable hardware EQ for SONY VAIO ALSA: oxygen: fix Xonar DG input ALSA: hda - Fix EAPD on Lenovo NB ALC269 to low ALSA: hda - Fix missing EAPD for Acer 4930G ALSA: hda: Disable 4/6 channels on some NVIDIA GPUs. ALSA: hda - Add static_hdmi_pcm option to HDMI codec parser ALSA: hda - Don't refer ELD when unplugged ASoC: tpa6130a2: Fix compiler warning ASoC: tlv320dac33: Add DAPM selection for LOM invert ASoC: DMIC codec: Adding a generic DMIC codec ALSA: snd-usb-us122l: Fix missing NULL checks ALSA: snd-usb-us122l: Fix MIDI output ASoC: soc-cache: Fix invalid memory access during snd_soc_lzo_cache_sync() ASoC: Fix section mismatch in wm8995.c ALSA: oxygen: add S/PDIF source selection for Claro cards ALSA: oxygen: fix CD/MIDI for X-Meridian (2G) ASoC: fix migor audio build ALSA: include delay.h for msleep in Xonar DG support ...
2011-01-13Merge branch 'topic/asoc' into for-linusTakashi Iwai
2011-01-12regulator: missing index in PTR_ERR() in isl6271a_probe()roel kluin
The index is missing so the return is wrong. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Assign return value of mc13xxx_reg_rmw to retAxel Lin
Otherwise, we will not return error if write to MC13892_SWITCHERS5 failed. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Yong Shen <yong.shen@linaro.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Add initial per-regulator debugfs supportMark Brown
We only expose the use and open counts to userspace, providing a tiny bit of insight into what the API is up to. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Make regulator_has_full_constraints a boolMark Brown
It's a boolean value so use the type. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Clean up logging a bitMark Brown
The recent introduction of standard regulator API logging macros means that all our log messages have at least the function name in them and logging that the constraints are for the regulator API is probably a bit much. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Optimise out noop voltage changesMark Brown
If a consumer sets the same voltage range as is currently configured for that consumer there's no need to run through setting the voltage again. This pattern may occur with some CPUfreq implementations where the same voltage range is used for multiple frequencies. Reported-by: Saravana Kannan <skannan@codeaurora.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Add API to re-apply voltage to hardwareMark Brown
When cooperating with an external control source the regulator setup may be changed underneath the API. Currently consumers can just redo the regulator_set_voltage() to restore a previously set configuration but provide an explicit API for doing this as optimsations in the regulator_set_voltage() implementation will shortly prevent that. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Staticise non-exported functions in mc13892Mark Brown
No point exposing functions that aren't used elsewhere to the global namespace and sparse warns about doing so. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Only notify voltage changes when they succeedMark Brown
Currently we notify a voltage change whenever we exit set_voltage(), even if the change failed for some reason (eg, a constraints issue). This shouldn't cause any substantial ill effects but is wasteful as listeners get notified on noops. Fix this by moving the notification into _do_set_voltage() and only notifying if we don't return an error. Reported-by: Saravana Kannan <skannan@codeaurora.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Provide a selector based set_voltage_sel() operationMark Brown
Many regulator drivers implement voltage setting by looping through a table of possible values, normally because the set of available voltages can't be mapped onto selectors with simple calcuation. Factor out these loops by providing a variant of set_voltage() which takes a selector rather than a voltage range as an argument and implementing a loop through the available selectors in the core. This is not going to be suitable for use with all devices as when the regulator voltage can be mapped onto selector values with a simple calculation the linear scan through the available values will be more expensive than just doing the calculation, especially for regulators that provide fine grained voltage control. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Factor out voltage set operation into a separate functionMark Brown
Push all the callers of the chip set_voltage() operation out into a single function to facilitiate future refactoring. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: Convert WM8994 to use get_voltage_sel()Mark Brown
2011-01-12regulator: Convert WM835x to use get_voltage_sel()Mark Brown
2011-01-12regulator: Allow modular build of mc13xxx-coreMark Brown
Since the MFD core for this device and the regulator drivers for these devices can be built modular we should also support modular build of the shared code for the regulator drivers, otherwise we try to link built in code against modular code with unfortunate results. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulator: support PMIC mc13892Yong Shen
add support for mc13892, tested on mx51 babbage board Signed-off-by: Arnaud Patard <arnaud.patard@rtp-net.org> Signed-off-by: Yong Shen <yong.shen@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12make mc13783 regulator code genericYong Shen
move some common functions and micros of mc13783 regulaor driver to a seperate file, which makes it possible for mc13892 to share code. Signed-off-by: Yong Shen <yong.shen@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12Change the register name definitions for mc13783Yong Shen
To make mc13783 and mc13892 share code, the register names should be changed to fit the new macro definitions in the comming patch. Signed-off-by: Yong Shen <yong.shen@linaro.org> Acked-by: Sascha Hauer <s.hauer@pengutronix.de> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Removed macros for initialization of ab8500 regulatorsBengt Jonsson
This patch removes the macros for initializing the regulators. The purpose is to remove one layer of abstraction and make the code easier to read. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Added verbose debug messages to ab8500 regulatorsBengt Jonsson
The verbose debug outputs register writes and reads that can be used to debug the driver. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Modified ab8500 error handlingBengt Jonsson
Error handling is updated to catch NULL pointer errors. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Updated ab8500 variable names, macro names and commentsBengt Jonsson
The regulator enumeration is used for putting the regulator data in correct place in the info array. This should be matched in the board configuration. Variable names are updated to be more consistent, comments are corrected and macros have been edited to be consistent. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Added ab8500 v2 supportBengt Jonsson
The AUX3 regulator voltage setting is changed in ab8500 v2 compared to ab8500 v1. This patch adds v2 support while keeping support for v1. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Clean out unused code in ab8500 regulatorsBengt Jonsson
The find_regulator function was unused so it has been removed. The ab8500 pointer in the regulator info structure was unused and so it has also been removed. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Fixed errors in ab8500 register mappingBengt Jonsson
For INTCORE and TVOUT regulators, the low power register bit is included in the mask so that enable will set the regulator in normal (high power) mode. ANAMIC1, ANAMIC2, DMIC regulator settings are swapped with each other so that the correct regulator gets enabled/disabled. ANA regulator register address is corrected. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-01-12regulators: Moved define for number of regulators in ab8500Bengt Jonsson
The define for number of regulators is moved from ab8500-core to ab8500-regulator so that the regulator driver can be updated independently of ab8500-core. This also changes the platform configuration structure of ab8500-core so that it contains a pointer to the regulator_init_data array plus number of regulators instead of an fixed size array of pointers to regulator_init_data. Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
