[ Upstream commit b8a039d37792067c1a380dc710361905724b9b2f ]
RK808 can leverage a couple of GPIOs to tweak the ramp rate during DVS
(Dynamic Voltage Scaling). These GPIOs are entirely optional but a
dev_warn() appeared when cleaning this driver to use a more up-to-date
gpiod API. At least reduce the log level to 'info' as it is totally
fine to not populate these GPIO on a hardware design.
This change is trivial but it is worth not polluting the logs during
bringup phase by having real warnings and errors sorted out
correctly.
Fixes: a13eaf02e2d6 ("regulator: rk808: make better use of the gpiod API")
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Link: https://lore.kernel.org/r/20191203164709.11127-1-miquel.raynal@bootlin.com
Signed-off-by: Mark Brown <broonie@kernel.org>
[ Upstream commit e69b394703e032e56a140172440ec4f9890b536d ]
selector 0xB (1011) should be 2.6V rather than 2.7V, fit ix.
Table 5-4. LDOA1 Output Voltage Options
VID Bits VOUT VID Bits VOUT VID Bits VOUT VID Bits VOUT
0000 1.35 0100 1.8 1000 2.3 1100 2.85
0001 1.5 0101 1.9 1001 2.4 1101 3.0
0010 1.6 0110 2.0 1010 2.5 1110 3.3
0011 1.7 0111 2.1 1011 2.6 1111 Not Used
Fixes: d2a2e729a666 ("regulator: tps65086: Add regulator driver for the TPS65086 PMIC")
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Acked-by: Andrew F. Davis <afd@ti.com>
[ Upstream commit c25d47888f0fb3d836d68322d4aea2caf31a75a6 ]
The wm831x_dcdc_ilim entries needs to be uA because it is used to compare
with min_uA and max_uA.
While at it also make the array const and change to use unsigned int.
Fixes: e4ee831f949a ("regulator: Add WM831x DC-DC buck convertor support")
Acked-by: Charles Keepax <ckeepax@opensource.cirrus.com>
[ Upstream commit a5455c9159414748bed4678184bf69989a4f7ba3 ]
Fix off-by-one while iterating current_limits array.
The valid index should be 0 ~ n_current_limits -1.
Fixes: c90456e36d9c ("regulator: pv88090: new regulator driver")
[ Upstream commit 3c413f594c4f9df40061445667ca11a12bc8ee34 ]
Fixes: 99cf3af5e2d5 ("regulator: pv88080: new regulator driver")
[ Upstream commit 7cd415f875591bc66c5ecb49bf84ef97e80d7b0e ]
Fixes: f307a7e9b7af ("regulator: pv88060: new regulator driver")
[ Upstream commit 62a1923cc8fe095912e6213ed5de27abbf1de77e ]
platform device aliases were missing, preventing
autoloading of module.
Fixes: 811b700630ff ("regulator: rn5t618: add driver for Ricoh RN5T618 regulators")
Signed-off-by: Andreas Kemnade <andreas@kemnade.info>
Link: https://lore.kernel.org/r/20191211221600.29438-1-andreas@kemnade.info
commit 99c4f70df3a6446c56ca817c2d0f9c12d85d4e7c upstream.
The USB regulator was removed for AB8500 in
commit 41a06aa738ad ("regulator: ab8500: Remove USB regulator").
It was then added for AB8505 in
commit 547f384f33db ("regulator: ab8500: add support for ab8505").
However, there was never an entry added for it in
ab8505_regulator_match. This causes all regulators after it
to be initialized with the wrong device tree data, eventually
leading to an out-of-bounds array read.
Given that it is not used anywhere in the kernel, it seems
likely that similar arguments against supporting it exist for
AB8505 (it is controlled by hardware).
Therefore, simply remove it like for AB8500 instead of adding
an entry in ab8505_regulator_match.
Fixes: 547f384f33db ("regulator: ab8500: add support for ab8505")
Cc: Linus Walleij <linus.walleij@linaro.org>
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
Link: https://lore.kernel.org/r/20191106173125.14496-1-stephan@gerhold.net
max8907_regulator_probe()
[ Upstream commit 472b39c3d1bba0616eb0e9a8fa3ad0f56927c7d7 ]
Inside function max8907_regulator_probe(), variable val could
be uninitialized if regmap_read() fails. However, val is used
later in the if statement to decide the content written to
"pmic", which is potentially unsafe.
Signed-off-by: Yizhuo <yzhai003@ucr.edu>
Link: https://lore.kernel.org/r/20191003175813.16415-1-yzhai003@ucr.edu
This reverts commit 8b8c8d69b1a31004517d4c71a490f47bdf3405a2 which is
commit 55576cf1853798e86f620766e23b604c9224c19c upstream.
It's causing "odd" interactions with older kernels, so it probably isn't
a good idea to cause timing changes there. This has been reported to
cause oopses on Pixel devices.
Reported-by: Siddharth Kapoor <ksiddharth@google.com>
Cc: Mark Brown <broonie@kernel.org>
Cc: Lee Jones <lee.jones@linaro.org>
[ Upstream commit cd07e3701fa6a4c68f8493ee1d12caa18d46ec6a ]
tps65910_reg_set_bits() may fail. The fix checks if it fails, and if so,
returns with its error code.
Signed-off-by: Kangjie Lu <kjlu@umn.edu>
[ Upstream commit 966e927bf8cc6a44f8b72582a1d6d3ffc73b12ad ]
If palmas_smps_read() fails, we should not use the read data in "reg"
which may contain random value. The fix inserts a check for the return
value of palmas_smps_read(): If it fails, we return the error code
upstream and stop using "reg".
could be uninitialized
[ Upstream commit 1252b283141f03c3dffd139292c862cae10e174d ]
In function pfuze100_regulator_probe(), variable "val" could be
initialized if regmap_read() fails. However, "val" is used to
decide the control flow later in the if statement, which is
potentially unsafe.
Link: https://lore.kernel.org/r/20190929170957.14775-1-yzhai003@ucr.edu
[ Upstream commit f64db548799e0330897c3203680c2ee795ade518 ]
ti_abb_wait_txdone() may return -ETIMEDOUT when ti_abb_check_txdone()
returns true in the latest iteration of the while loop because the timeout
value is abb->settling_time + 1. Similarly, ti_abb_clear_all_txdone() may
return -ETIMEDOUT when ti_abb_check_txdone() returns false in the latest
iteration of the while loop. Fix it.
Acked-by: Nishanth Menon <nm@ti.com>
Link: https://lore.kernel.org/r/20190929095848.21960-1-axel.lin@ingics.com
The kernel has no way of knowing when we have finished instantiating
drivers, between deferred probe and systems that build key drivers as
modules we might be doing this long after userspace has booted. This has
always been a bit of an issue with regulator_init_complete since it can
power off hardware that's not had it's driver loaded which can result in
user visible effects, the main case is powering off displays. Practically
speaking it's not been an issue in real systems since most systems that
use the regulator API are embedded and build in key drivers anyway but
with Arm laptops coming on the market it's becoming more of an issue so
let's do something about it.
In the absence of any better idea just defer the powering off for 30s
after late_initcall(), this is obviously a hack but it should mask the
issue for now and it's no more arbitrary than late_initcall() itself.
Ideally we'd have some heuristics to detect if we're on an affected
system and tune or skip the delay appropriately, and there may be some
need for a command line option to be added.
Link: https://lore.kernel.org/r/20190904124250.25844-1-broonie@kernel.org
Tested-by: Lee Jones <lee.jones@linaro.org>
Cc: stable@vger.kernel.org
[ Upstream commit 1e2cc8c5e0745b545d4974788dc606d678b6e564 ]
According to the datasheet https://www.ti.com/lit/ds/symlink/lm3632a.pdf
Table 20. VPOS Bias Register Field Descriptions VPOS[5:0]
Sets the Positive Display Bias (LDO) Voltage (50 mV per step)
000000: 4 V
000001: 4.05 V
000010: 4.1 V
011101: 5.45 V
011110: 5.5 V (Default)
011111: 5.55 V
100111: 5.95 V
101000: 6 V
Note: Codes 101001 to 111111 map to 6 V
The LM3632_LDO_VSEL_MAX should be 0b101000 (0x28), so the maximum voltage
can match the datasheet.
Fixes: 3a8d1a73a037 ("regulator: add LM363X driver")
Link: https://lore.kernel.org/r/20190626132632.32629-1-axel.lin@ingics.com
commit 16da0eb5ab6ef2dd1d33431199126e63db9997cc upstream.
On S2MPS11 device, the buck7 and buck8 regulator voltages start at 750
mV, not 600 mV. Using wrong minimal value caused shifting of these
regulator values by 150 mV (e.g. buck7 usually configured to v1.35 V was
reported as 1.2 V).
On most of the boards these regulators are left in default state so this
was only affecting reported voltage. However if any driver wanted to
change them, then effectively it would set voltage 150 mV higher than
intended.
Cc: <stable@vger.kernel.org>
Fixes: cb74685ecb39 ("regulator: s2mps11: Add samsung s2mps11 regulator driver")
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
[ Upstream commit f01a7beb6791f1c419424c1a6958b7d0a289c974 ]
The act8600_sudcdc_voltage_ranges setting does not match the datasheet.
The problems in below entry:
REGULATOR_LINEAR_RANGE(19000000, 191, 255, 400000),
1. The off-by-one min_sel causes wrong volatage calculation.
The min_sel should be 192.
2. According to the datasheet[1] Table 7. (on page 43):
The selector 248 (0b11111000) ~ 255 (0b11111111) are 41.400V.
Also fix off-by-one for ACT8600_SUDCDC_VOLTAGE_NUM.
[1] https://active-semi.com/wp-content/uploads/ACT8600_Datasheet.pdf
Fixes: df3a950e4e73 ("regulator: act8865: Add act8600 support")
commit 28c4f730d2a44f2591cb104091da29a38dac49fe upstream.
The step values for some of the LDOs appears to be incorrect, resulting
in incorrect voltages (or at least, ones which are different from the
Samsung 3.4 vendor kernel).
Signed-off-by: Stuart Menefy <stuart.menefy@mathembedded.com>
Reviewed-by: Krzysztof Kozlowski <krzk@kernel.org>
commit 56b5d4ea778c1b0989c5cdb5406d4a488144c416 upstream.
LDO35 uses 25 mV step, not 50 mV. Bucks 7 and 8 use 12.5 mV step
instead of 6.25 mV. Wrong step caused over-voltage (LDO35) or
under-voltage (buck7 and 8) if regulators were used (e.g. on Exynos5420
Arndale Octa board).
commit fb6de923ca3358a91525552b4907d4cb38730bdd upstream.
dev_set_drvdata() needs to be called before device_register()
exposes device to userspace. Otherwise kernel crashes after it
gets null pointer from dev_get_drvdata() when userspace tries
to access sysfs entries.
[Removed backtrace for length -- broonie]
Signed-off-by: Yu Zhao <yuzhao@google.com>
[ Upstream commit 0b01fd3d40fe6402e5fa3b491ef23109feb1aaa5 ]
If is_enabled() is not defined, regulator core will assume
this regulator is already enabled, then it can NOT be really
enabled after disabled.
Based on Li Jun's patch from the NXP kernel tree.
Signed-off-by: Anson Huang <Anson.Huang@nxp.com>
'of_regulator_match()'
[ Upstream commit 30966861a7a2051457be8c49466887d78cc47e97 ]
If an unlikely failure in 'of_get_regulator_init_data()' occurs, we must
release the reference on the current 'child' node before returning.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit ed8cffda27dea6fd3dafb3ee881c5a786edac9ca ]
Re-order error handling code and gotos to avoid leaks in error handling
paths.
Fixes: 9f946099fe19 ("regulator: gpio: fix parsing of gpio list")
[ Upstream commit 9bf944548169f6153c3d3778cf983cb5db251a0e ]
Set the initial voltage selector for vddpcie in case it's disabled
by default.
This fixes the below warning:
20c8000.anatop:regulator-vddpcie: Failed to read a valid default voltage selector.
anatop_regulator: probe of 20c8000.anatop:regulator-vddpcie failed with error -22
Cc: Liam Girdwood <lgirdwood@gmail.com>
Cc: Shawn Guo <shawnguo@kernel.org>
Cc: Sascha Hauer <kernel@pengutronix.de>
Cc: Robin Gong <yibin.gong@nxp.com>
Cc: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Richard Zhu <hongxing.zhu@nxp.com>
Signed-off-by: Dong Aisheng <aisheng.dong@nxp.com>
[ Upstream commit fd086045559d90cd7854818b4c60a7119eda6231 ]
Commit 26988efe11b1 ("regulator: core: Allow to get voltage count and
list from parent") introduces the propagation of the parent voltage
count and list for regulators that don't provide this information
themselves. The goal is to support simple switch regulators, however as
a side effect normal continuous regulators can leak details of their
supplies and provide consumers with inconsistent information.
Limit the propagation of the voltage count and list to switch
regulators.
Fixes: 26988efe11b1 ("regulator: core: Allow to get voltage count and
list from parent")
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Reviewed-by: Javier Martinez Canillas <javier@osg.samsung.com>
Tested-by: Javier Martinez Canillas <javier@osg.samsung.com>
commit fc1111b885437f374ed54aadda44d8b241ebd2a3 upstream.
The device tree nodes all correctly describe the regulators as
syr827 or syr828, but the I2C device id is currently set to the
wildcard value of syr82x in the driver. This causes udev to fail
to match the driver module with the modalias data from sysfs.
Fix this by replacing the I2C device ids with ones that match the
device tree descriptions, with syr827 and syr828. Tested on
Firefly rk3288 board. The syr82x id was not used anywhere.
Fixes: e80c47bd738b (regulator: fan53555: Export I2C module alias information)
Signed-off-by: Guillaume Tucker <guillaume.tucker@collabora.com>
[ Upstream commit 3827b64dba27ebadb4faf51f2c91143e01ba1f6d ]
After commit 66d228a2bf03 ("regulator: core: Don't use regulators as
supplies until the parent is bound"), input supplies aren't resolved
if the input supplies parent device has not been bound. This prevent
regulators to hold an invalid reference if its supply parent device
driver probe is deferred.
But this causes issues on some boards where a PMIC's regulator use as
input supply a regulator from another PMIC whose driver is registered
after the driver for the former.
In this case the regulators for the first PMIC will fail to resolve
input supplies on regulators registration (since the other PMIC wasn't
probed yet). And when the core attempts to resolve again latter when
the other PMIC registers its own regulators, it will fail again since
the parent device isn't bound yet.
This will cause some parent supplies to never be resolved and wrongly
be disabled on boot due taking them as unused.
To solve this problem, also attempt to resolve the pending regulators
input supplies before disabling the unused regulators.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
commit 6308f1787fb85bc98b7241a08a9f7f33b47f8b61 upstream.
When we check for additional DT properties in the current node we
use the device_node passed in with the configuration data, this
will not point to the correct DT node, use the one passed in
for this purpose.
Reported-by: Steven Kipisz <s-kipisz2@ti.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
Tested-by: Steven Kipisz <s-kipisz2@ti.com>
commit 1c47f7c316de38c30b481e1886cc6352c9efdcc1 upstream.
The three load switches are called SWA1, SWB1, and SWB2. The
node names describing properties for these are expected to be
the same, but due to a typo they are not. Fix this here.
commit c90722b54a4f5e21ac59301ed9a6dbaa439bdb16 upstream.
Commit 43530b69d758328d3ffe6ab98fd640463e8e3667 ("regulator: Use
regmap_read/write(), regmap_update_bits functions directly") intended
to replace working inline helper functions with standard regmap
calls. However, it also inverted the set/clear logic of the "CORE ADJ
Allowed" bit. That patch was clearly never tested, since without that
bit cleared, the core VDCDC1 voltage output does not react to I2C
configuration changes.
This patch fixes the issue by clearing the bit as in the original,
correct implementation. Note for stable back porting that, due to
subsequent driver churn, this patch will not apply on every kernel
version.
Fixes: 43530b69d758 ("regulator: Use regmap_read/write(), regmap_update_bits functions directly")
Signed-off-by: Richard Cochran <rcochran@linutronix.de>
commit 75f88115391156b3f0fecbbae76bf870c89bcab8 upstream.
Set the correct voltage select register for LDO2.
Signed-off-by: Wadim Egorov <w.egorov@phytec.de>
commit e42a46b6f52473661ad192f76a128a68fe301df4 upstream.
It is allowed to call regulator_get with a NULL dev argument
(_regulator_get explicitly checks for it) but this causes an error later
when printing /sys/kernel/debug/regulator_summary.
Fix this by explicitly handling "deviceless" consumers in the debugfs code.
Signed-off-by: Leonard Crestez <leonard.crestez@nxp.com>
commit d0e287a401d9acf67b75180b26e2d62b7d482652 upstream.
A typo or copy-paste bug means that the register access intended for
regulator dcdce goes to dcdcb instead. This patch corrects it.
Fixes: 2ca342d391e3 (regulator: axp20x: Support AXP806 variant)
Signed-off-by: Rask Ingemann Lambertsen <rask@formelder.dk>
Acked-by: Chen-Yu Tsai <wens@csie.org>
commit 85b037442e3f0e84296ab1010fd6b057eee18496 upstream.
The handling of bypass_val_on that was added in
regulator_get_bypass_regmap is done unconditionally however
several drivers don't define a value for bypass_val_on. This
results in those drivers reporting bypass being enabled when
it is not. In regulator_set_bypass_regmap we use bypass_mask
if bypass_val_on is zero. This patch adds similar handling in
regulator_get_bypass_regmap.
Fixes: commit dd1a571daee7 ("regulator: helpers: Ensure bypass register field matches ON value")
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
commit 618c808968852609d2d9f0e5cfc351a4807ef8d0 upstream.
The maximum supported voltage for ldo_io# is 3.3V, but on cold boot
the selector comes up at 0x1f, which maps to 3.8V. This was previously
corrected by Allwinner's U-boot, which set all regulators on the PMICs
to some pre-configured voltage. With recent progress in U-boot SPL
support, this is no longer the case. In any case we should handle
this quirk in the kernel driver as well.
This invalid setting causes _regulator_get_voltage() to fail with -EINVAL
which causes regulator registration to fail when constrains are used:
[ 1.054181] vcc-pg: failed to get the current voltage(-22)
[ 1.059670] axp20x-regulator axp20x-regulator.0: Failed to register ldo_io0
[ 1.069749] axp20x-regulator: probe of axp20x-regulator.0 failed with error -22
This commits makes the axp20x regulator driver accept the 0x1f register
value, fixing this.
The datasheet does not guarantee reliable operation above 3.3V, so on
boards where this regulator is used the regulator-max-microvolt setting
must be 3.3V or less.
This is essentially the same as the commit f40d4896bf32 ("regulator:
axp20x: Fix axp22x ldo_io registration error on cold boot") for AXP22x
PMICs.
Fixes: a51f9f4622a3 ("regulator: axp20x: support AXP809 variant")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
commit d8ca5bd158f738c4fa6974ee388c381f64db7905 upstream.
The BUCK regulators 3, 4, and 5 also have a 10mV step mode,
adjust the tables and logic to reflect the data-sheet for
these regulators.
fixes: d2a2e729a666 ("regulator: tps65086: Add regulator driver for the TPS65086 PMIC")
commit 295070e9aa015abb9b92cccfbb1e43954e938133 upstream.
The regulator has never been properly enabled, it has been
dormant all the time. It's strange that MMC was working
at all, but it likely worked by the signals going through
the levelshifter and reaching the card anyways.
Fixes: 3615a34ea1a6 ("regulator: add STw481x VMMC driver")
commit 73e705bf81ce ("regulator: core: Add set_voltage_time op")
introduced a new rdev_warn() if the ramp_delay is 0.
Apparently, on omap3/twl4030 platforms with dynamic voltage
management this results in non-ending spurious messages like
[ 511.143066] VDD1: ramp_delay not set
[ 511.662322] VDD1: ramp_delay not set
[ 513.903625] VDD1: ramp_delay not set
[ 514.222198] VDD1: ramp_delay not set
[ 517.062835] VDD1: ramp_delay not set
[ 517.382568] VDD1: ramp_delay not set
[ 520.142791] VDD1: ramp_delay not set
[ 520.502593] VDD1: ramp_delay not set
[ 523.062896] VDD1: ramp_delay not set
[ 523.362701] VDD1: ramp_delay not set
[ 526.143035] VDD1: ramp_delay not set
I have observed this on GTA04 while it is reported to occur on
N900 as well: https://bugzilla.kernel.org/show_bug.cgi?id=178371
This patch makes the warning appear only in debugging mode.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux
Pull thermal managament updates from Zhang Rui:
- Enhance thermal "userspace" governor to export the reason when a
thermal event is triggered and delivered to user space. From Srinivas
Pandruvada
- Introduce a single TSENS thermal driver for the different versions of
the TSENS IP that exist, on different qcom msm/apq SoCs'. Support for
msm8916, msm8960, msm8974 and msm8996 families is also added. From
Rajendra Nayak
- Introduce hardware-tracked trip points support to the device tree
thermal sensor framework. The framework supports an arbitrary number
of trip points. Whenever the current temperature is changed, the trip
points immediately below and above the current temperature are found,
driver callback is invoked to program the hardware to get notified
when either of the two trip points are triggered. Hardware-tracked
trip points support for rockchip thermal driver is also added at the
same time. From Sascha Hauer, Caesar Wang
- Introduce a new thermal driver, which enables TMU (Thermal Monitor
Unit) on QorIQ platform. From Jia Hongtao
- Introduce a new thermal driver for Maxim MAX77620. From Laxman
Dewangan
- Introduce a new thermal driver for Intel platforms using WhiskeyCove
PMIC. From Bin Gao
- Add mt2701 chip support to MTK thermal driver. From Dawei Chien
- Enhance Tegra thermal driver to enable soctherm node and set
"critical", "hot" trips, for Tegra124, Tegra132, Tegra210. From Wei
Ni
- Add resume support for tango thermal driver. From Marc Gonzalez
- several small fixes and improvements for rockchip, qcom, imx, rcar,
mtk thermal drivers and thermal core code. From Caesar Wang, Keerthy,
Rocky Hao, Wei Yongjun, Peter Robinson, Bui Duc Phuc, Axel Lin, Hugh
Kang
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/rzhang/linux: (48 commits)
thermal: int3403: Process trip change notification
thermal: int340x: New Interface to read trip and notify
thermal: user_space gov: Add additional information in uevent
thermal: Enhance thermal_zone_device_update for events
arm64: tegra: set hot trips for Tegra210
arm64: tegra: set critical trips for Tegra210
arm64: tegra: add soctherm node for Tegra210
arm64: tegra: set hot trips for Tegra132
arm64: tegra: set critical trips for Tegra132
arm64: tegra: use tegra132-soctherm for Tegra132
arm: tegra: set hot trips for Tegra124
arm: tegra: set critical trips for Tegra124
thermal: tegra: add hw-throttle for Tegra132
thermal: tegra: add hw-throttle function
of: Add bindings of hw throttle for Tegra soctherm
thermal: mtk_thermal: Check return value of devm_thermal_zone_of_sensor_register
thermal: Add Mediatek thermal driver for mt2701.
dt-bindings: thermal: Add binding document for Mediatek thermal controller
thermal: max77620: Add thermal driver for reporting junction temp
thermal: max77620: Add DT binding doc for thermal driver
git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd
Pull MFD updates from Lee Jones:
"Core framework:
- Add the MFD bindings doc to MAINTAINERS
New drivers:
- X-Powers AC100 Audio CODEC and RTC
- TI LP873x PMIC
- Rockchip RK808 PMIC
- Samsung Exynos Low Power Audio
New device support:
- Add support for STMPE1600 variant to stmpe
- Add support for PM8018 PMIC to pm8921-core
- Add support for AXP806 PMIC in axp20x
- Add support for AXP209 GPIO in axp20x
New functionality:
- Add support for Reset to all STMPE variants
- Add support for MKBP event support to cros_ec
- Add support for USB to intel_soc_pmic_bxtwc
- Add support for IRQs and Power Button to tps65217
Fix-ups:
- Clean-up defunct author emails (da9063, max14577)
- Kconfig fixups (wm8350-i2c, as37220
- Constify (altera-a10sr, sm501)
- Supply PCI IDs (intel-lpss-pci)
- Improve clocking (qcom_rpm)
- Fix IRQ probing (ucb1x00-core)
- Ensure fault log is cleared (da9052)
- Remove NO_IRQ check (ucb1x00-core)
- Supply I2C properties (intel-lpss-acpi, intel-lpss-pci)
- Non standard declaration (tps65217, max8997-irq)
- Remove unused code (lp873x, db8500-prcmu, ab8500-debugfs,
cros_ec_spi)
- Make non-modular (altera-a10sr, intel_msic, smsc-ece1099,
sun6i-prcm, twl-core)
- OF bindings (ac100, stmpe, qcom-pm8xxx, qcom-rpm, rk808, axp20x,
lp873x, exynos5433-lpass, act8945a, aspeed-scu, twl6040, arizona)
Bugfixes:
- Release OF pointer (qcom_rpm)
- Avoid double shifting in suspend/resume (88pm80x)
- Fix 'defined but not used' error (exynos-lpass)
- Fix 'sleeping whilst attomic' (atmel-hlcdc)"
* tag 'mfd-for-linus-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/mfd: (69 commits)
mfd: arizona: Handle probe deferral for reset GPIO
mfd: arizona: Remove arizona_of_get_named_gpio helper function
mfd: arizona: Add DT options for max_channels_clocked and PDM speaker config
mfd: twl6040: Register child device for twl6040-pdmclk
mfd: cros_ec_spi: Remove unused variable 'request'
mfd: omap-usb-host: Return value is not 'const int'
mfd: ab8500-debugfs: Remove 'weak' function suspend_test_wake_cause_interrupt_is_mine()
mfd: ab8500-debugfs: Remove ab8500_dump_all_banks_to_mem()
mfd: db8500-prcmu: Remove unused *prcmu_set_ddr_opp() calls
mfd: ab8500-debugfs: Prevent initialised field from being over-written
mfd: max8997-irq: 'inline' should be at the beginning of the declaration
mfd: rk808: Fix RK818_IRQ_DISCHG_ILIM initializer
mfd: tps65217: Fix nonstandard declaration
mfd: lp873x: Remove unused mutex lock from struct lp873x
mfd: atmel-hlcdc: Do not sleep in atomic context
mfd: exynos-lpass: Mark PM functions as __maybe_unused
mfd: intel-lpss: Add default I2C device properties for Apollo Lake
mfd: twl-core: Make it explicitly non-modular
mfd: sun6i-prcm: Make it explicitly non-modular
mfd: smsc-ece1099: Make it explicitly non-modular
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"This is the bulk of GPIO changes for the v4.9 series:
Subsystem improvements:
- do away with the last users of the obsolete Kconfig options
ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB (the latter
always sounded like an item on a wishlist to Santa Claus to me). We
can now select GPIOLIB and be done with it, for all archs. After
some struggle it even work on UM. Not that it has GPIO, but if it
wants to, it can select the library.
- continued efforts to make drivers properly either tristate or bool.
- introduce a warning for drivers assigning default triggers to their
irqchip lines when probed from device tree, so we find and fix
these ambigous drivers. It is agreed that in the OF config path,
the device tree defines trigger characteristics.
- the same warning, mutatis mutandis, for ACPI-probed GPIO irqchips.
- we introduce the ability to mark certain IRQ lines as "unusable" as
they can be taken by BIOS/firmware, unrouted in silicon and
generally nasty if you use them, and such things. This is put to
good use in the STMPE driver and also in the Cherryview pin control
driver.
- a new "mockup" virtual GPIO device that can be used for testing.
The plan is to add unit tests under tools/* for exercising this
device and verify that the kernel code paths are working as they
should.
- make memory-mapped I/O-drivers depend on HAS_IOMEM. This was
implicit all the time, but when people started building UM with
allyesconfig or allmodconfig it exploded in their face.
- move some stray bits of device tree and ACPI HW description
callbacks down into their respective implementation silo. These
were causing issues when compiling on !HAS_IOMEM as well, so now
eventually UM compiles the GPIOLIB library if it wants to.
New drivers:
- new driver for the Aspeed GPIO front-end companion to the pin
controller merged through the pin control tree.
- new driver for the LP873x PMIC GPIO portions.
- new driver for Technologic Systems' I2C FPGA GPIO such as TS4900,
TS-7970, TS-7990 and TS-4100.
- new driver for the Broadcom BCM63xx series including BCM6338 and
BCM6345.
- new driver for the Intel WhiskeyCove PMIC GPIO.
- new driver for the Allwinner AXP209 PMIC GPIO portions.
- new driver for Diamond Systems 48 line GPIO-MM, another of these
port-mapped I/O expansion cards.
- support the STMicroelectronics STMPE1600 variant in the STMPE
driver.
Driver improvements:
- the STMPE driver now supports rising/falling edge detection
properly for IRQs.
- the PCA954x will now fetch and enable its VCC regulator properly.
- major rework of the PCA953x driver with the goal of eventually
switching it over to use regmap and thus modernize it even more.
- switch the IOP driver to use the generic MMIO GPIO library.
- move the ages old HTC EGPIO (extended GPIO) GPIO expander driver
over to this subsystem from MFD, achieveing some separation of
concerns"
* tag 'gpio-v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (81 commits)
gpio: add missing static inline
gpio: OF: localize some gpiochip init functions
gpio: acpi: separation of concerns
gpio: OF: separation of concerns
gpio: make memory-mapped drivers depend on HAS_IOMEM
gpio: stmpe: use BIT() macro
gpio: stmpe: forbid unused lines to be mapped as IRQs
mfd/gpio: Move HTC GPIO driver to GPIO subsystem
gpio: MAINTAINERS: Add an entry for GPIO mockup driver
gpio/mockup: add virtual gpio device
gpio: Added zynq specific check for special pins on bank zero
gpio: axp209: Implement get_direction
gpio: aspeed: remove redundant return value check
gpio: loongson1: remove redundant return value check
ARM: omap2: fix missing include
gpio: tc3589x: fix up complaints on unsigned
gpio: tc3589x: add .get_direction() and small cleanup
gpio: f7188x: use gpiochip_get_data instead of container_of
gpio: tps65218: use devm_gpiochip_add_data() for gpio registration
gpio: aspeed: fix return value check in aspeed_gpio_probe()
'ib-mfd-input-4.9', 'ib-mfd-regulator-4.9', 'ib-mfd-regulator-4.9.1', 'ib-mfd-regulator-rtc-4.9', 'ib-mfd-regulator-rtc-4.9-1' and 'ib-mfd-rtc-4.9' into ibs-for-mfd-merged
'regulator/topic/pv88080', 'regulator/topic/rk808', 'regulator/topic/set-voltage' and 'regulator/topic/tps65218' into regulator-next
'regulator/topic/dbx500', 'regulator/topic/hi6421', 'regulator/topic/load' and 'regulator/topic/ltc3676' into regulator-next
Added one additional parameter to thermal_zone_device_update() to provide
caller with an optional capability to specify reason.
Currently this event is used by user space governor to trigger different
processing based on event code. Also it saves an additional call to read
temperature when the event is received.
The following events are cuurently defined:
- Unspecified event
- New temperature sample
- Trip point violated
- Trip point changed
- thermal device up and down
- thermal device power capability changed
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
We get 2 warnings when building kernel with W=1:
drivers/regulator/dbx500-prcmu.c:78:6: warning: no previous prototype for 'ux500_regulator_suspend_debug' [-Wmissing-prototypes]
drivers/regulator/dbx500-prcmu.c:87:6: warning: no previous prototype for 'ux500_regulator_resume_debug' [-Wmissing-prototypes]
In fact, these functions are unused in
dbx500-prcmu.c, but should be removed.
So this patch removes the unused functions.
Signed-off-by: Baoyou Xie <baoyou.xie@linaro.org>
Three files are modified, the driver, header file and the binding document.
Updates for the regulator source file include and .of_match_table entry
and node match checking in the probe() function for a compatible pv88080
silicon type. A new "HVBUCK" is added in source file and added
regsiter definition in header file for pv88080 bb silicion.
The binding documentation changes have been made to reflect these updates.
Signed-off-by: Eric Jeong <eric.jeong.opensource@diasemi.com>
