path: root/drivers/remoteproc/omap_remoteproc.c
2013-01-03Drivers: misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-04Merge tag 'remoteproc-for-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc update from Ohad Ben-Cohen: - Remoteproc Recovery - by Fernando Guzman Lugo When a remote processor crash is detected, this mechanism will remove all virtio children devices, wait until their drivers let go, hard reset the remote processor and reload the firmware (resulting in the relevant virtio children devices re-added). Essentially the entire software stack is reset, together with the relevant hardware, so users don't have to reset the entire phone. - STE Modem driver is added - by Sjur Brændeland - OMAP DSP boot address support is added - by Juan Gutierrez - A handful of fixes/cleanups - Sjur Brændeland, Dan Carpenter, Emil Goode * tag 'remoteproc-for-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: Fix use of format specifyer remoteproc: fix a potential NULL-dereference on cleanup remoteproc: select VIRTIO to avoid build breakage remoteproc: return -EFAULT on copy_from_user failure remoteproc: snprintf() can return more than was printed remoteproc: Add STE modem driver remtoteproc: maintain max notifyid remoteproc: create a 'recovery' debugfs entry remoteproc: add actual recovery implementation remoteproc: add rproc_report_crash function to notify rproc crashes remoteproc: Add dependency to HAS_DMA remoteproc/omap: set bootaddr support
2012-09-19ARM: omap: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the omap include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Kevin Hilman <khilman@ti.com> Cc: "Benoît Cousson" <b-cousson@ti.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Kyungmin Park <kyungmin.park@samsung.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Omar Ramirez Luna <omar.ramirez@ti.com> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Cc: Liam Girdwood <lrg@ti.com> Cc: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Cc: Jean Pihet <j-pihet@ti.com> Cc: J Keerthy <j-keerthy@ti.com> Cc: linux-omap@vger.kernel.org
2012-09-11remoteproc/omap: set bootaddr supportJuan Gutierrez
Some remote processors (like OMAP4's DSP) require we explicitly set a boot address from which they'd start executing code when taken out of reset. Support for this is now being added to the omap-specific remoteproc driver through a set_bootaddr function in the platform data which, if needed, must be set according to the backend remote processor. For OMAP4's dsp we can use the following control function: .set_bootaddr = omap_ctrl_write_dsp_boot_addr Signed-off-by: Juan Gutierrez <jgutierrez@ti.com> Signed-off-by: Suman Anna <s-anna@ti.com> [ohad: slight changes to the commit log] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-07-26Merge tag 'remoteproc-for-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc update from Ohad Ben-Cohen: - custom binary format support from Sjur Brændeland - groundwork for recovery and runtime pm support - some cleanups and API simplifications Fix up conflicts in drivers/remoteproc/remoteproc_core.c due to clashes with earlier cleanups by Sjur Brændeland (with part of the cleanups moved into the new remoteproc_elf_loader.c file). * tag 'remoteproc-for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: MAINTAINERS: add remoteproc's git remoteproc: Support custom firmware handlers remoteproc: Move Elf related functions to separate file remoteproc: Add function rproc_get_boot_addr remoteproc: Pass struct fw to load_segments and find_rsc_table. remoteproc: adopt the driver core's alloc/add/del/put naming remoteproc: remove the get_by_name/put API remoteproc: support non-iommu carveout assignment remoteproc: simplify unregister/free interfaces remoteproc: remove the now-redundant kref remoteproc: maintain a generic child device for each rproc remoteproc: allocate vrings on demand, free when not needed
2012-07-06remoteproc: adopt the driver core's alloc/add/del/put namingOhad Ben-Cohen
To make remoteproc's API more intuitive for developers, we adopt the driver core's naming, i.e. alloc -> add -> del -> put. We'll also add register/unregister when their first user shows up. Otherwise - there's no functional change here. Suggested by Russell King <linux@arm.linux.org.uk>. Cc: Russell King <linux@arm.linux.org.uk> Cc: Fernando Guzman Lugo <fernando.lugo@ti.com> Cc: Sjur Brændeland <sjur.brandeland@stericsson.com> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-07-06remoteproc: simplify unregister/free interfacesOhad Ben-Cohen
Simplify the unregister/free interfaces, and make them easier to understand and use, by moving to a symmetric and consistent alloc() -> register() -> unregister() -> free() flow. To create and register an rproc instance, one needed to invoke rproc_alloc() followed by rproc_register(). To unregister and free an rproc instance, one now needs to invoke rproc_unregister() followed by rproc_free(). Cc: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-07-06remoteproc: maintain a generic child device for each rprocOhad Ben-Cohen
For each registered rproc, maintain a generic remoteproc device whose parent is the low level platform-specific device (commonly a pdev, but it may certainly be any other type of device too). With this in hand, the resulting device hierarchy might then look like: omap-rproc.0 | - remoteproc0 <---- new ! | - virtio0 | - virtio1 | - rpmsg0 | - rpmsg1 | - rpmsg2 Where: - omap-rproc.0 is the low level device that's bound to the driver which invokes rproc_register() - remoteproc0 is the result of this patch, and will be added by the remoteproc framework when rproc_register() is invoked - virtio0 and virtio1 are vdevs that are registered by remoteproc when it realizes that they are supported by the firmware of the physical remote processor represented by omap-rproc.0 - rpmsg0, rpmsg1 and rpmsg2 are rpmsg devices that represent rpmsg channels, and are registerd by the rpmsg bus when it gets notified about their existence Technically, this patch: - changes 'struct rproc' to contain this generic remoteproc.x device - creates a new "remoteproc" type, to which this new generic remoteproc.x device belong to. - adds a super simple enumeration method for the indices of the remoteproc.x devices - updates all dev_* messaging to use the generic remoteproc.x device instead of the low level platform-specific device - updates all dma_* allocations to use the parent of remoteproc.x (where the platform-specific memory pools, most commonly CMA, are to be found) Adding this generic device has several merits: - we can now add remoteproc runtime PM support simply by hooking onto the new "remoteproc" type - all remoteproc log messages will now carry a common name prefix instead of having a platform-specific one - having a device as part of the rproc struct makes it possible to simplify refcounting (see subsequent patch) Thanks to Stephen Boyd <sboyd@codeaurora.org> for suggesting and discussing these ideas in one of the remoteproc review threads and to Fernando Guzman Lugo <fernando.lugo@ti.com> for trying them out with the (upcoming) runtime PM support for remoteproc. Cc: Fernando Guzman Lugo <fernando.lugo@ti.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-06-17remoteproc/omap: fix dev_err typoOhad Ben-Cohen
For some reason one of the dev_err invocations is using a wrong device so fix that. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: stable@vger.kernel.org
2012-03-06remoteproc/omap: remove the mbox_callback limitationOhad Ben-Cohen
Now that remoteproc supports any number of virtio devices, the previous sanity check in omap_rproc_mbox_callback doesn't make sense anymore. Remove that so we can start supporting multiple vdevs. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: Brian Swetland <swetland@google.com> Cc: Iliyan Malchev <malchev@google.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Mark Grosen <mgrosen@ti.com> Cc: John Williams <john.williams@petalogix.com> Cc: Michal Simek <monstr@monstr.eu> Cc: Loic PALLARDY <loic.pallardy@stericsson.com> Cc: Ludovic BARRE <ludovic.barre@stericsson.com> Cc: Omar Ramirez Luna <omar.luna@linaro.org> Cc: Guzman Lugo Fernando <fernando.lugo@ti.com> Cc: Anna Suman <s-anna@ti.com> Cc: Clark Rob <rob@ti.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Cc: Saravana Kannan <skannan@codeaurora.org> Cc: David Brown <davidb@codeaurora.org> Cc: Kieran Bingham <kieranbingham@gmail.com> Cc: Tony Lindgren <tony@atomide.com>
2012-02-08remoteproc/omap: utilize module_platform_driverOhad Ben-Cohen
Ditch some boilerplate code by employing the module_platform_driver helper. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-02-08remoteproc/omap: add a remoteproc driver for OMAP4Ohad Ben-Cohen
Add a remoteproc driver for OMAP4, so we can boot the dual-M3 and and DSP subsystems. Use the omap_device_* API to control the hardware state, and utilize the OMAP mailbox to interrupt the remote processor when a new message is pending (the mailbox payload is used to tell it which virtqueue was the message placed in). Conversely, when an inbound mailbox message arrives, tell the remoteproc core which virtqueue is triggered. Later we will also use the mailbox payload to signal omap-specific events like remote crashes (which will be used to trigger remoteproc recovery) and power management transitions. At that point we will also extend the remoteproc core to support this. Based on (but now quite far from) work done by Fernando Guzman Lugo <fernando.lugo@ti.com> and Hari Kanigeri <h-kanigeri2@ti.com>. Designed with Brian Swetland <swetland@google.com>. Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Acked-by: Tony Lindgren <tony@atomide.com> Cc: Brian Swetland <swetland@google.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Russell King <linux@arm.linux.org.uk> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Stephen Boyd <sboyd@codeaurora.org>
