commit 1d701d3dd8caf6660ff33c3c23a115b4649c5cdb upstream.
Fix to return a negative error code from the st_rproc_state() error
handling case instead of 0, as done elsewhere in this function.
Fixes: 63edb0310a5c ("remoteproc: Supply controller driver for ST's Remote Processors")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
In order to be able to lock a rproc driver implementations only when
used by a client, we must differ between the dereference operation of a
client and the implementation itself.
This patch brings no functional change.
syscon_regmap_lookup_by_phandle() returns either a valid pointer to
struct regmap or ERR_PTR() error value, check for NULL is invalid and
on error path may lead to oops, the change corrects the check.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Ludovic Barre <ludovic.barre@st.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
