path: root/drivers/remoteproc/ste_modem_rproc.c
2013-05-07Merge tag 'remoteproc-3.10' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc update from Ohad Ben-Cohen: - Some refactoring, cleanups and small improvements from Sjur Brændeland. The improvements are mainly about better supporting varios virtio properties (such as virtio's config space, status and features). I now see that I messed up while commiting one of Sjur's patches and erroneously put myself as the author, as well as letting a nasty typo sneak in. I will not fix this in order to avoid rebasing the patches. Sjur - sorry! - A new remoteproc driver for OMAP-L13x (technically a DaVinci platform) from Robert Tivy. - Extend OMAP support to OMAP5 as well, from Vincent Stehlé. - Fix Kconfig VIRTUALIZATION dependency, from Suman Anna (a non-critical fix which arrived late during the rc cycle). * tag 'remoteproc-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: remoteproc: fix kconfig dependencies for VIRTIO remoteproc/davinci: add a remoteproc driver for OMAP-L13x DSP remoteproc: support default firmware name in rproc_alloc() remoteproc/omap: support OMAP5 too remoteproc: set vring addresses in resource table remoteproc: support virtio config space. remoteproc: perserve resource table data remoteproc: calculate max_notifyid by counting vrings remoteproc: code cleanup of resource parsing remoteproc: parse STE-firmware and find resource table address remoteproc: add find_loaded_rsc_table firmware ops remoteproc: refactor rproc_elf_find_rsc_table()
2013-04-07remoteproc: calculate max_notifyid by counting vringsSjur Brændeland
Simplify handling of max_notifyid by simply counting the number of vrings. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Acked-by: Ido Yariv <ido@wizery.com> [small terminology changes] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2013-04-05remoteproc: parse STE-firmware and find resource table addressSjur Brændeland
Parse the STE firmware and scan the TOC-table to find the address of the loaded resource table. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> [rebase patch; update terminology] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2013-04-05remoteproc/ste: fix memory leak on shutdownDmitry Tarnyagin
Fixes coherent memory leakage, caused by non-deallocated firmware image chunk. Cc: stable@vger.kernel.org Signed-off-by: Dmitry Tarnyagin <dmitry.tarnyagin@stericsson.com> Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> Acked-by: Ido Yariv <ido@wizery.com> [slightly edit subject and commit log] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
2012-09-22remoteproc: Add STE modem driverSjur Brændeland
Add support for the STE modem shared memory driver. This driver hooks into the remoteproc framework in order to manage configuration and the virtio devices. This driver adds custom firmware handlers, because STE modem uses a custom firmware layout. Signed-off-by: Sjur Brændeland <sjur.brandeland@stericsson.com> cc: Linus Walleij <linus.walleij@linaro.org> cc: Alan Cox <alan@lxorguk.ukuu.org.uk> [ohad: validate mdev->ops, move setup() to probe/remove, trivial style changes] Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com>
