path: root/drivers/remoteproc
2018-06-21remoteproc: qcom: Fix potential device node leaksTobias Jordan
[ Upstream commit 278d744c46fd4f1925aec77752d18a0e4a9cbec3 ] Add missing of_node_put()s at two places for device nodes returned by of_parse_phandle(). Fixes: 051fb70fd4ea ("remoteproc: qcom: Driver for the self-authenticating Hexagon v5") Signed-off-by: Tobias Jordan <Tobias.Jordan@elektrobit.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-05-30remoteproc: imx_rproc: Fix an error handling path in 'imx_rproc_probe()'Christophe JAILLET
[ Upstream commit de6f83f85be94e0b7d0d324c29ccc9d78a6bb4e7 ] If 'of_device_get_match_data()' fails, we must undo the previous 'rproc_alloc()' call. Fixes: a0ff4aa6f010 ("remoteproc: imx_rproc: add a NXP/Freescale imx_rproc driver") Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-11remoteproc: imx_rproc: fix return value check in imx_rproc_addr_init()Wei Yongjun
In case of error, the function devm_ioremap() returns NULL pointer not ERR_PTR(). The IS_ERR() test in the return value check should be replaced with NULL test. Reviewed-by: Oleksij Rempel <o.rempel@pengutronix.de> Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-10-10remoteproc: qcom: fix RPMSG_QCOM_GLINK_SMEM dependenciesArnd Bergmann
When RPMSG_QCOM_GLINK_SMEM=m and one driver causes the qcom_common.c file to be compiled as built-in, we get a link error: drivers/remoteproc/qcom_common.o: In function `glink_subdev_remove': qcom_common.c:(.text+0x130): undefined reference to `qcom_glink_smem_unregister' qcom_common.c:(.text+0x130): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `qcom_glink_smem_unregister' drivers/remoteproc/qcom_common.o: In function `glink_subdev_probe': qcom_common.c:(.text+0x160): undefined reference to `qcom_glink_smem_register' qcom_common.c:(.text+0x160): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `qcom_glink_smem_register' Out of the three PIL driver instances, QCOM_ADSP_PIL already has a Kconfig dependency to prevent this from happening, but the other two do not. This adds the same dependency there. Fixes: eea07023e6d9 ("remoteproc: qcom: adsp: Allow defining GLINK edge") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-10-10remoteproc: imx_rproc: fix a couple off by one bugsDan Carpenter
The priv->mem[] array has IMX7D_RPROC_MEM_MAX elements so the > should be >= to avoid writing one element beyond the end of the array. Fixes: a0ff4aa6f010 ("remoteproc: imx_rproc: add a NXP/Freescale imx_rproc driver") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-09-09Merge tag 'rpmsg-v4.14' of git://github.com/andersson/remoteprocLinus Torvalds
Pull rpmsg updates from Bjorn Andersson: "This extends the Qualcomm GLINK implementation to support the additional features used for communicating with modem and DSP coprocessors in modern Qualcomm platforms. In addition to this there's support for placing virtio RPMSG buffers in non-System RAM" * tag 'rpmsg-v4.14' of git://github.com/andersson/remoteproc: (29 commits) rpmsg: glink: initialize ret to zero to ensure error status check is correct rpmsg: glink: fix null pointer dereference on a null intent dt-bindings: soc: qcom: Extend GLINK to cover SMEM remoteproc: qcom: adsp: Allow defining GLINK edge rpmsg: glink: Export symbols from common code rpmsg: glink: Release idr lock before returning on error rpmsg: glink: Handle remote rx done command rpmsg: glink: Request for intents when unavailable rpmsg: glink: Use the intents passed by remote rpmsg: glink: Receive and store the remote intent buffers rpmsg: glink: Add announce_create ops and preallocate intents rpmsg: glink: Add rx done command rpmsg: glink: Make RX FIFO peak accessor to take an offset rpmsg: glink: Use the local intents when receiving data rpmsg: glink: Add support for TX intents rpmsg: glink: Fix idr_lock from mutex to spinlock rpmsg: glink: Add support for transport version negotiation rpmsg: glink: Introduce glink smem based transport rpmsg: glink: Do a mbox_free_channel in remove rpmsg: glink: Return -EAGAIN when there is no FIFO space ...
2017-09-01remoteproc: Introduce rproc handle accessor for childrenBjorn Andersson
In certain circumstances rpmsg devices needs to acquire a handle to the ancestor remoteproc instance, e.g. to invoke rproc_report_crash() when a fatal error is detected. Introduce an interface that walks the device tree in search for a remoteproc instance and return this. Tested-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-09-01remoteproc: qcom: Make ssr_notifiers localBjorn Andersson
The ssr_notifiers variable should be local, so add the missing static storage classifier. Fixes: 1e140df04965 ("remoteproc: qcom: Add support for SSR notifications") Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-09-01remoteproc: qcom: adsp: Allow defining GLINK edgeBjorn Andersson
Introduce the GLINK subdev, which allows the definition of a GLINK edge as child of a remoteproc. Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-30remoteproc: Stop subdevices in reverse orderBjorn Andersson
Subdevices might depend on earlier registered subdevices for communication purposes, as such they should be stopped in reverse order so that said communication channel is removed after the dependent subdevice is stopped. Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-30remoteproc: imx_rproc: add a NXP/Freescale imx_rproc driverOleksij Rempel
Provide a basic driver to control Cortex M4 co-processor found on NXP i.MX7D and i.MX6SX. Currently it is able to resolve addresses between M4 and main CPU, start and stop the co-processor. Other functionality is not provided or test. This driver was tested on NXP i.MX7D and expected to work on i.MX6SX as well. Signed-off-by: Oleksij Rempel <o.rempel@pengutronix.de> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-29remoteproc: qcom: Use PTR_ERR_OR_ZEROHimanshu Jha
Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR Signed-off-by: Himanshu Jha <himanshujha199640@gmail.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-27remoteproc: st: explicitly request exclusive reset controlPhilipp Zabel
Commit a53e35db70d1 ("reset: Ensure drivers are explicit when requesting reset lines") started to transition the reset control request API calls to explicitly state whether the driver needs exclusive or shared reset control behavior. Convert all drivers requesting exclusive resets to the explicit API call so the temporary transition helpers can be removed. No functional changes. Cc: Patrice Chotard <patrice.chotard@st.com> Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Cc: linux-remoteproc@vger.kernel.org Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-27remoteproc: qcom: explicitly request exclusive reset controlPhilipp Zabel
Commit a53e35db70d1 ("reset: Ensure drivers are explicit when requesting reset lines") started to transition the reset control request API calls to explicitly state whether the driver needs exclusive or shared reset control behavior. Convert all drivers requesting exclusive resets to the explicit API call so the temporary transition helpers can be removed. No functional changes. Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Cc: linux-remoteproc@vger.kernel.org Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-27remoteproc/keystone: explicitly request exclusive reset controlPhilipp Zabel
Commit a53e35db70d1 ("reset: Ensure drivers are explicit when requesting reset lines") started to transition the reset control request API calls to explicitly state whether the driver needs exclusive or shared reset control behavior. Convert all drivers requesting exclusive resets to the explicit API call so the temporary transition helpers can be removed. No functional changes. Cc: Ohad Ben-Cohen <ohad@wizery.com> Cc: Bjorn Andersson <bjorn.andersson@linaro.org> Cc: linux-remoteproc@vger.kernel.org Acked-by: Suman Anna <s-anna@ti.com> Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-24remoteproc/keystone: Add support for Keystone 66AK2G SOCsSuman Anna
Add support to the keystone remoteproc driver for managing the DSP present in the Keystone 2 66AK2G SoC. The 66AK2G SoC has a Power Management Micro Controller (PMMC) that manages the individual device's power, clock and reset functionalities. The keystone remoteproc driver already uses standard frameworks for reset and clock control, so it doesn't require any significant modifications other than a new compatible suitable for 66AK2G DSP. The binding document is also updated to reflect the modified property values used by the 66AK2G DSP node as compared to the values used by existing Keystone 2 DSPs. Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-24remoteproc/davinci: Add device tree support for OMAP-L138 DSPSuman Anna
The Davinci remoteproc driver currently supports the DSP remoteproc device created in legacy-style on OMAP-L13x SoCs. The driver has been enhanced to support the DSP remoteproc device created through Device Tree now. The current DT support handles the C674x DSP processor subsystem on OMAP-L138 SoCs. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-24remoteproc/davinci: Add support to parse internal memoriesSuman Anna
The DSP subsystem on OMAP-L13x SoCs has various internal RAM memories that can accessed from the ARM side. These memories can be configured to be used as either RAM or Cache. The Davinci remoteproc driver has been enhanced to parse and store the kernel mappings for these internal RAM memories. These mappings can then be used to support direct loading of text/data into these memories from the remoteproc driver. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-24remoteproc/davinci: Switch to platform_get_resource_byname()Suman Anna
The davinci remoteproc driver currently uses the platform_get_resource() API for retrieving the IOMEM resources. Switch this function to use the platform_get_resource_byname() API instead in preparation for adding the DT support so that the binding can be agnostic of the IOMEM resource order. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-24remoteproc: make device_type constBhumika Goyal
Make this const as it is only stored in the type field of a device structure, which is const. Done using Coccinelle. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-08-02remoteproc: qcom: Add support for SSR notificationsBjorn Andersson
This adds the remoteproc part of subsystem restart, which is responsible for emitting notifications to other processors in the system about a dying remoteproc instance. These notifications are propagated to the various communication systems in the various remote processors to shut down communication links that was left in a dangling state as the remoteproc was stopped (or crashed). Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-07-26remoteproc: Merge __rproc_boot() with rproc_boot()Suman Anna
The additional arguments in the internal __rproc_boot() function were dropped in commit 2bfc311a57f5 ("remoteproc: Drop wait in __rproc_boot()"). The exported rproc_boot() is now just a wrapper around this internal function, so merge them together. While at this, also remove the declaration for the previously cleaned up rproc_boot_nowait() function. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-27remoteproc/keystone: Fix circular dependencies for ARM configsSuman Anna
Drop the dependency on RESET_CONTROLLER for the Keystone remoteproc driver to resolve some circular dependencies around different choices for RESET_CONTROLLER on common ARM configs. This dependency is inherent as the RESET_CONTROLLER will be enabled due to the enabled ARCH_HAS_RESET_CONTROLLER for ARCH_KEYSTONE. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-27remoteproc: Drop redundant REMOTEPROC dependency from driver KconfigsSuman Anna
All the remoteproc platform driver Kconfig symbols are defined and included under an if REMOTEPROC condition, so the dependency on REMOTEPROC is implicit and they do not need an explicit 'depends on REMOTEPROC' line. So, clean these up. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-27remoteproc: Drop VIRTUALIZATION dependency from REMOTEPROCSuman Anna
A dependency to VIRTUALIZATION has been added to REMOTEPROC in v3.10 kernel in commit b9777859ec01 ("remoteproc: fix kconfig dependencies for VIRTIO") to resolve Kconfig warnings due to the inclusion of the virtio configuration file from the ARM's KVM config file. The KVM config was fixed properly in the subsequent release in commit 8bd4ffd6b3a9 ("ARM: kvm: don't include drivers/virtio/Kconfig"). So, drop this unneeded VIRTUALIZATION dependency from REMOTEPROC. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-26remoteproc/keystone: Ensure the DSPs are in reset in probeAndrew F. Davis
The DSPs are expected to be in reset when the driver probes a device. If the DSPs are out of reset in probe, the system may crash when the firmware is being loaded. So, add a check to make sure the DSP resets are asserted, and if not, throw a eye-catchy warning and assert the resets specifically. Signed-off-by: Andrew F. Davis <afd@ti.com> [s-anna@ti.com: replace warning with a WARN] Signed-off-by: Suman Anna <s-anna@ti.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-26remoteproc/keystone: Add a remoteproc driver for Keystone 2 DSPsSuman Anna
The Texas Instrument's Keystone 2 family of SoCs has 1 or more TMS320C66x DSP Core Subsystems (C66x CorePacs). Each subsystem has a C66x Fixed/Floating-Point DSP Core, with 32KB of L1P and L1D SRAMs, that can be configured and partitioned as either RAM and/or Cache, and 1 MB of L2 SRAM. The CorePac also includes an Internal DMA (IDMA), External Memory Controller (EMC), Extended Memory Controller (XMC) with a Memory Protection and Address Extension (MPAX) unit, a Bandwidth Management (BWM) unit, an Interrupt Controller (INTC) and a Powerdown Controller (PDC). A new remoteproc module is added to perform the device management of these DSP devices. The driver expects the firmware names to be of the form "keystone-dsp<X>-fw", where X is the corresponding DSP number, and uses the standard remoteproc core ELF loader. The support is limited to images only using the DSP internal memories at the moment. This remoteproc driver is also designed to work with virtio, and uses the IPC Generation registers for performing the virtio signalling and getting notified of exceptions. The driver currently supports the 66AK2H/66AK2K, 66AK2L and 66AK2E SoCs. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Sam Nelson <sam.nelson@ti.com> Signed-off-by: Andrew F. Davis <afd@ti.com> Acked-by: Santosh Shilimkar <ssantosh@kernel.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-25remoteproc/davinci: fix unbalanced reset between start and stop opsSuman Anna
The davinci remoteproc driver is currently de-asserting the reset in its rproc .start() ops, but is not asserting the reset in its .stop() ops. This leaves the remote processor to not boot properly when using the sysfs 'state' variable between multiple start and stop operations. On the other hand, a reset is being asserted unconditionally in the driver remove function to alleviate some of these issues. Move this reset assertion logic into the .stop() ops implementation to fix the sysfs state-machine and the unbalanced reset. The logic from remove is still effective since .stop() ops will be invoked during the remove due to the enabled 'auto-boot' support. The probe already has support for asserting the reset in case the DSP is not in reset for some reason. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-25remoteproc/davinci: simplify the reset functionSuman Anna
The reset_assert() function is used to make sure the DSP remote processor is in a reset state regardless of its previous state. The driver relies on davinci_clk_reset_{assert,deassert}() functions for reset management which take in a clock parameter. The assert_reset() performs a clk_get()/clk_put() cycle to acquire the clock handle to use with this function. This is totally unnecessary and the code can be simplified to use the clock acquired during probe and directly use the reset functions, so simplify this logic. Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-06-25remoteproc/davinci: Update Kconfig to depend on DMA_CMASuman Anna
The davinci remoteproc driver requires a CMA pool for allocating memory for virtio vrings/buffers and other sections of the firmware image. The allocations are done using the DMA API. The CMA option is currently selected automatically on systems with MMU when davinci remoteproc is enabled, switch this to a saner depends on dependency convention. The dependency is also updated to use the DMA_CMA kconfig symbol that is used for CMA allocations using the DMA API, the CMA dependency is inherited implicitly. Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Suman Anna <s-anna@ti.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-05-30remoteproc: fix spelling mistake: "Resouce" -> "Resource"Colin Ian King
Trivial fix to spelling mistake in dev_err message Signed-off-by: Colin Ian King <colin.king@canonical.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-05-26remoteproc: Modify recovery path to use rproc_{start,stop}()Sarangdhar Joshi
Replace rproc_shutdown() by rproc_stop() and rproc_boot() by rproc_start() in the recovery path, in order to avoid remoteproc resources re-allocation overhead and to assist with extracting the coredumps after stopping the remote processor. Signed-off-by: Sarangdhar Joshi <spjoshi@codeaurora.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-05-26remoteproc: Introduce rproc_{start,stop}() functionsSarangdhar Joshi
In the context of recovering from crash, rproc_trigger_recovery() does rproc_shutdown() followed by rproc_boot(). The remoteproc resources are cleaned up in rproc_shutdown() and immediately reallocated in rproc_boot() which is an unnecessary overhead. Furthermore, we want the memory regions to be accessible after stopping the remote processor, to be able to extract the memory content for a coredump. This patch factors out the code in rproc_boot() and rproc_shutdown() path and introduces rproc_{start,stop}() in order to avoid resource allocation overhead. Signed-off-by: Sarangdhar Joshi <spjoshi@codeaurora.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-05-10Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull virtio updates from Michael Tsirkin: "Fixes, cleanups, performance A bunch of changes to virtio, most affecting virtio net. Also ptr_ring batched zeroing - first of batching enhancements that seems ready." * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: s390/virtio: change maintainership tools/virtio: fix spelling mistake: "wakeus" -> "wakeups" virtio_net: tidy a couple debug statements ptr_ring: support testing different batching sizes ringtest: support test specific parameters ptr_ring: batch ring zeroing virtio: virtio_driver doc virtio_net: don't reset twice on XDP on/off virtio_net: fix support for small rings virtio_net: reduce alignment for buffers virtio_net: rework mergeable buffer handling virtio_net: allow specifying context for rx virtio: allow extra context per descriptor tools/virtio: fix build breakage virtio: add context flag to find vqs virtio: wrap find_vqs ringtest: fix an assert statement
2017-05-02virtio: add context flag to find vqsMichael S. Tsirkin
Allows maintaining extra context per vq. For ease of use, passing in NULL is legal and disables the feature for all vqs. Includes fixes by Christian for s390, acked by Cornelia. Signed-off-by: Christian Borntraeger <borntraeger@de.ibm.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2017-03-28soc: qcom: smd: Remove standalone driverBjorn Andersson
Remove the standalone SMD implementation as we have transitioned the client drivers to use the RPMSG based one. Also remove all dependencies on QCOM_SMD from Kconfig files, in order to keep them selectable in the absence of the removed symbol. Acked-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2017-03-20remoteproc: qcom: fix QCOM_SMD dependenciesArnd Bergmann
qcom_smd_register_edge() is provided by either QCOM_SMD or RPMSG_QCOM_SMD, and if both of them are disabled, it does nothing. The check for the PIL drivers however only checks for QCOM_SMD, so it breaks with QCOM_SMD=n && RPMSG_QCOM_SMD=m: drivers/remoteproc/built-in.o: In function `smd_subdev_remove': qcom_wcnss_iris.c:(.text+0x231c): undefined reference to `qcom_smd_unregister_edge' drivers/remoteproc/built-in.o: In function `smd_subdev_probe': qcom_wcnss_iris.c:(.text+0x2344): undefined reference to `qcom_smd_register_edge' drivers/remoteproc/built-in.o: In function `smd_subdev_probe': qcom_q6v5_pil.c:(.text+0x3538): undefined reference to `qcom_smd_register_edge' qcom_q6v5_pil.c:(.text+0x3538): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `qcom_smd_register_edge' This clarifies the Kconfig dependency. Fixes: 4b48921a8f74 ("remoteproc: qcom: Use common SMD edge handler") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-03-02Merge tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
Pull vhost updates from Michael Tsirkin: "virtio, vhost: optimizations, fixes Looks like a quiet cycle for vhost/virtio, just a couple of minor tweaks. Most notable is automatic interrupt affinity for blk and scsi. Hopefully other devices are not far behind" * tag 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: virtio-console: avoid DMA from stack vhost: introduce O(1) vq metadata cache virtio_scsi: use virtio IRQ affinity virtio_blk: use virtio IRQ affinity blk-mq: provide a default queue mapping for virtio device virtio: provide a method to get the IRQ affinity mask for a virtqueue virtio: allow drivers to request IRQ affinity when creating VQs virtio_pci: simplify MSI-X setup virtio_pci: don't duplicate the msix_enable flag in struct pci_dev virtio_pci: use shared interrupts for virtqueues virtio_pci: remove struct virtio_pci_vq_info vhost: try avoiding avail index access when getting descriptor virtio_mmio: expose header to userspace
2017-02-27virtio: allow drivers to request IRQ affinity when creating VQsChristoph Hellwig
Add a struct irq_affinity pointer to the find_vqs methods, which if set is used to tell the PCI layer to create the MSI-X vectors for our I/O virtqueues with the proper affinity from the start. Compared to after the fact affinity hints this gives us an instantly working setup and allows to allocate the irq descritors node-local and avoid interconnect traffic. Last but not least this will allow blk-mq queues are created based on the interrupt affinity for storage drivers. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jason Wang <jasowang@redhat.com> Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
2017-02-22remoteproc: qcom: mdt_loader: Use signed type for offsetBjorn Andersson
In the transition from using rproc_da_to_va(), the type of the load offset became unsigned. This causes the subsequent check to let negative values less than p_memsz + mem_size through and we write outside of the buffer. Change the type back to a signed value to catch this. Fixes: 7f0dd07a9b29 ("remoteproc: qcom: mdt_loader: Refactor MDT loader") Fixes: e7fd25226295 ("remoteproc: qcom: q6v5: Decouple driver from MDT loader") Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Reported-by: Stanimir Varbanov <stanimir.varbanov@linaro.org> Acked-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: st: add virtio communication supportLoic Pallardy
This patch provides virtio communication support based on mailbox for ST co-processors. Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Ludovic Barre <ludovic.barre@st.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: st: correct probe error managementLoic Pallardy
Associated clock is prepared in st_rproc_parse_dt function. it should be unprepared in case of error during probing. Signed-off-by: Loic Pallardy <loic.pallardy@st.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: Modify the function namesSarangdhar Joshi
The functions rproc_add_virtio_devices() and rproc_fw_config_virtio() are reduced to trigger auto-boot only. Modify these function names and related comments to reflect their current state. This patch does not add any functional change. Signed-off-by: Sarangdhar Joshi <spjoshi@codeaurora.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: Reduce asynchronous request_firmware to auto-boot onlySarangdhar Joshi
The rproc_add_virtio_devices() requests firmware asynchronously and triggers boot if the auto_boot flag is set. However, this asynchronous call seems to be redundant for non auto-boot scenario since the rproc_boot() would call request_firmware() anyways. Move the auto_boot check to rproc_add() so that a redundant call to _request_firmware can be avoided for non auto-boot case. Signed-off-by: Sarangdhar Joshi <spjoshi@codeaurora.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: Drop qcom_scm_pas_supported() from adsp_probe()Sarangdhar Joshi
SCM call to check whether Peripheral Authentication Service (PAS) is supported returns false for ADSP on MSM8996. Drop this call from the driver so that the probe() function succeeds for ADSP PIL device. Signed-off-by: Sarangdhar Joshi <spjoshi@codeaurora.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: qcom: Use common SMD edge handlerBjorn Andersson
Call the common SMD edge handler to instantiate subdevices to bring associated SMD edges up and down as the remoteproc is started and stopped. Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: qcom: wcnss: Make SMD handling commonBjorn Andersson
Move the SMD edge handling to the Qualcomm common file to make it reusable for other Qualcomm remoteproc drivers. Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: Move qcom_mdt_loader into drivers/soc/qcomBjorn Andersson
With the remoteproc parts cleaned out of the MDT loader we can move it to drivers/soc/qcom. Acked-by: Andy Gross <andy.gross@linaro.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
2017-02-06remoteproc: qcom: mdt_loader: Refactor MDT loaderBjorn Andersson
Pushing the SCM calls into the MDT loader reduces duplication in the callers and allows for non-remoteproc clients to use the helper for parsing and loading MDT files. Cc: Andy Gross <andy.gross@linaro.com> Signed-off-by: Bjorn Andersson <bjorn.andersson@linaro.org>
