path: root/drivers/reset/Kconfig
2014-03-11drivers: reset: STi SoC system configuration reset controller supportStephen Gallimore
This patch adds a reset controller implementation for STMicroelectronics STi family SoCs; it allows a group of related reset like controls found in multiple system configuration registers to be represented by a single controller device. System configuration registers are accessed through the regmap framework and the mfd/syscon driver. The implementation optionally supports waiting for the reset action to be acknowledged in a separate status register and supports both active high and active low reset lines. These properties are common across all the reset channels in a specific reset controller instance, hence all channels in a paritcular controller are expected to behave in the same way. Signed-off-by: Stephen Gallimore <stephen.gallimore@st.com> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
2013-04-12reset: Add reset controller APIPhilipp Zabel
This adds a simple API for devices to request being reset by separate reset controller hardware and implements the reset signal device tree binding. Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de> Reviewed-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Shawn Guo <shawn.guo@linaro.org> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Pavel Machek <pavel@ucw.cz>
