There are cases where a system will want to read a reset status bit before
doing any other toggling. Add a reset_control_status helper function to the
reset controller API.
Signed-off-by: Dinh Nguyen <dinguyen@opensource.altera.com>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
In some cases, you might need to deassert from reset an hardware block that
doesn't associated to a struct device (CPUs, timers, etc.).
Add a small helper to retrieve the reset controller from the device tree
without the need to pass a struct device.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Mark function of_reset_simple_xlate() as static in core.c
because it is not used outside this file.
Also, remove functions devm_reset_control_put() and
devm_reset_control_match() because they are unused.
This eliminates the following warnings in core.c:
drivers/reset/core.c:46:5: warning: no previous prototype for ‘of_reset_simple_xlate’ [-Wmissing-prototypes]
drivers/reset/core.c:262:6: warning: no previous prototype for ‘devm_reset_control_put’ [-Wmissing-prototypes]
Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
If the requested reset controller is not yet available, have reset_control_get
and device_reset return -EPROBE_DEFER so the driver can decide to request
probe deferral.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
"rstc" is NULL here and we should use "rcdev" instead of "rstc->rcdev".
This adds a simple API for devices to request being reset
by separate reset controller hardware and implements the
reset signal device tree binding.
Reviewed-by: Shawn Guo <shawn.guo@linaro.org>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
