path: root/drivers/reset/reset-lantiq.c
2017-09-04reset: Add a reset controller driver for the Lantiq XWAY based SoCsMartin Blumenstingl
The reset controllers (on xRX200 and newer SoCs have two of them) are provided by the RCU module. This was initially implemented as a simple reset controller. However, the RCU module provides more functionality (ethernet GPHYs, USB PHY, etc.), which makes it a MFD device. The old reset controller driver implementation from arch/mips/lantiq/xway/reset.c did not honor this fact. For some devices the request and the status bits are different. Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com> Acked-by: Philipp Zabel <p.zabel@pengutronix.de> Acked-by: Rob Herring <robh@kernel.org> Cc: john@phrozen.org Cc: kishon@ti.com Cc: mark.rutland@arm.com Cc: linux-mips@linux-mips.org Cc: linux-mtd@lists.infradead.org Cc: linux-watchdog@vger.kernel.org Cc: devicetree@vger.kernel.org Cc: linux-spi@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/17125/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
