Add reset control for SPI controller on UniPhier SoCs.
Signed-off-by: Kunihiko Hayashi <hayashi.kunihiko@socionext.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Add reset lines for MPEG2 transport stream I/O and demux system (HSC)
on UniPhier LD11/LD20 SoCs.
Signed-off-by: Katsuhiro Suzuki <suzuki.katsuhiro@socionext.com>
Add reset lines for SATA controller on UniPhier SoCs.
This adds support for Pro4 and PXs3 in addition to PXs2.
And this changes the ID of the reset line for SATA-PHY on PXs2.
Since some SoCs have two controller instances with a common PHY, this moves
the ID of SATA-PHY for consistency.
Add reset lines for PCIe controller on UniPhier SoCs. This adds support for
Pro5, LD20 and PXs3.
For LD20, the bit 5 of the offset 0x200c turned out to be a USB3
reset. The hardware document says it is the GIO reset despite LD20
has no GIO bus, confusingly.
Also, fix confusing comments for PXs3.
Add reset lines for ethernet controller on PXs3 SoC.
Add reset lines for audio subsystem (AIO) on UniPhier
Pro4/Pro5/PXs2 SoCs.
Add basic reset data for Socionext's new SoC PXs3.
Add reset lines for ethernet controller on Pro4, PXs2, LD11 and
LD20 SoCs.
Add a reset line for analog signal amplifier core (ADAMV) on
Add a reset line for video input subsystem (EXIV) on
Add reset lines for audio subsystem (AIO) and
SoC internal audio codec (EVEA) on UniPhier LD11/LD20 SoCs.
This macro turned out not so useful as I had expected.
Hardware engineers said they would change reset bit assignments for
every SoC going forward. This means we can not share the macros
among SoCs. Just use primitive macros.
This SoC is too old. It is difficult to maintain any longer.
Acked-by: Rob Herring <robh@kernel.org>
Add reset lines for the Denali NAND controller on all UniPhier SoCs,
for the Cadence eMMC controller on LD11/LD20 SoCs.
Fixes the following sparse warnings:
drivers/reset/reset-uniphier.c:68:34: warning:
symbol 'uniphier_sld3_sys_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:73:34: warning:
symbol 'uniphier_pro4_sys_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:81:34: warning:
symbol 'uniphier_pro5_sys_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:89:34: warning:
symbol 'uniphier_pxs2_sys_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:103:34: warning:
symbol 'uniphier_ld11_sys_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:108:34: warning:
symbol 'uniphier_ld20_sys_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:137:34: warning:
symbol 'uniphier_sld3_mio_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:157:34: warning:
symbol 'uniphier_pro5_sd_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:174:34: warning:
symbol 'uniphier_ld4_peri_reset_data' was not declared. Should it be static?
drivers/reset/reset-uniphier.c:187:34: warning:
symbol 'uniphier_pro4_peri_reset_data' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
The LD11 SoC is equipped with not only MIO-reset but also SD-reset
for controlling RST_n pin of the eMMC device.
Update the binding document and remove unneeded "." from each line
in itemization.
I made a mistake as for naming for this block. The MIO block is not
implemented for these 3 SoCs in the first place. The current naming
will be a trouble if an SoC with both MIO and SD-ctrl blocks appear
in the future.
This driver has just been merged in the previous merge window.
Rename it before the release.
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
This is the initial commit for UniPhier reset controller driver.
