Add support for maxim dallas rtc ds1347
Signed-off-by: Raghavendra Chandra Ganiga <ravi23ganiga@gmail.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Merge second patch-bomb from Andrew Morton:
- various misc bits
- the rest of MM
- add generic fixmap.h, use it
- backlight updates
- dynamic_debug updates
- printk() updates
- checkpatch updates
- binfmt_elf
- ramfs
- init/
- autofs4
- drivers/rtc
- nilfs
- hfsplus
- Documentation/
- coredump
- procfs
- fork
- exec
- kexec
- kdump
- partitions
- rapidio
- rbtree
- userns
- memstick
- w1
- decompressors
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (197 commits)
lib/decompress_unlz4.c: always set an error return code on failures
romfs: fix returm err while getting inode in fill_super
drivers/w1/masters/w1-gpio.c: add strong pullup emulation
drivers/memstick/host/rtsx_pci_ms.c: fix ms card data transfer bug
userns: relax the posix_acl_valid() checks
arch/sh/kernel/dwarf.c: use rbtree postorder iteration helper instead of solution using repeated rb_erase()
fs-ext3-use-rbtree-postorder-iteration-helper-instead-of-opencoding-fix
fs/ext3: use rbtree postorder iteration helper instead of opencoding
fs/jffs2: use rbtree postorder iteration helper instead of opencoding
fs/ext4: use rbtree postorder iteration helper instead of opencoding
fs/ubifs: use rbtree postorder iteration helper instead of opencoding
net/netfilter/ipset/ip_set_hash_netiface.c: use rbtree postorder iteration instead of opencoding
rbtree/test: test rbtree_postorder_for_each_entry_safe()
rbtree/test: move rb_node to the middle of the test struct
rapidio: add modular rapidio core build into powerpc and mips branches
partitions/efi: complete documentation of gpt kernel param purpose
kdump: add /sys/kernel/vmcoreinfo ABI documentation
kdump: fix exported size of vmcoreinfo note
kexec: add sysctl to disable kexec_load
fs/exec.c: call arch_pick_mmap_layout() only once
The Haoyu Microelectronics HYM8563 provides rtc and alarm functions as
well as a clock output of up to 32kHz.
Signed-off-by: Heiko Stuebner <heiko@sntech.de>
Cc: Rob Herring <rob.herring@calxeda.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Grant Likely <grant.likely@linaro.org>
Cc: Mike Turquette <mturquette@linaro.org>
Cc: Richard Weinberger <richard.weinberger@gmail.com>
Cc: Mark Brown <broonie@kernel.org>
next/drivers
From Jason Cooper:
mvebu driver changes for v3.14 (incremental #2)
- rtc
- add driver for Intersil ISL12057 chip
* tag 'mvebu-drivers-3.14-2' of git://git.infradead.org/linux-mvebu:
rtc: Add support for Intersil ISL12057 I2C RTC chip
b the commit.
Intersil ISL12057 is an I2C RTC chip also supporting two alarms. This
patch only adds support for basic RTC functionalities (i.e. getting
and setting time). Tests have been performed on NETGEAR ReadyNAS 102
w/ startup/shutdown scripts, hwclock, ntpdate and openntpd.
Reviewed-by: Mark Brown <broonie@linaro.org>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Arnaud Ebalard <arno@natisbad.org>
Signed-off-by: Jason Cooper <jason@lakedaemon.net>
This patch introduces the driver for the RTC in the Allwinner A10 and
A20 SoCs.
Signed-off-by: Carlo Caione <carlo.caione@gmail.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The ams AS3722 is a compact system PMU suitable for mobile phones, tablets
etc.
Add a driver to support accessing the RTC found on the ams AS3722 PMIC
using RTC framework.
Signed-off-by: Florian Lobmaier <florian.lobmaier@ams.com>
Cc: Linus Walleij <linus.walleij@linaro.org>
Add real-time clock driver for s5m8767.
Signed-off-by: Sangbeom Kim <sbkim73@samsung.com>
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Todd Broch <tbroch@chromium.org>
Acked-by: Lee Jones <lee.jones@linaro.org> [mfd parts]
Add RTC driver for MOXA ART SoCs.
Signed-off-by: Jonas Jensen <jonas.jensen@gmail.com>
On CSR SiRFprimaII/atlasVI, there is a programmable 16-bit divider
(RTC_DIV) that divides the input 32.768KHz clock to the frequency that
users need (E.g. 1 Hz). The divided real-time clock will be used to
drive a 32-bit counter (RTC_COUNTER) that provides users with the actual
time.
In each cycle of the divided real-time clock, there is a Hertz interrupt
generated to the RISC. Users can also configure an alarm (RTC_ALARM).
When RTC_COUNTER matches the alarm, there will be an alarm interrupt
The system RTC can generate an alarm wake-up signal to notify the power
controller to wake up from power saving mode.
Signed-off-by: Xianglong Du <Xianglong.Du@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Added support for NXP PCF2127 RTC (i2c).
[akpm@linux-foundation.org: fix typo, fix warnings]
Signed-off-by: Renaud Cerrato <r.cerrato@til-technologies.fr>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFS updates from Samuel Ortiz:
"This is the MFD pull request for the 3.9 merge window.
No new drivers this time, but a bunch of fairly big cleanups:
- Roger Quadros worked on a OMAP USBHS and TLL platform data
consolidation, OMAP5 support and clock management code cleanup.
- The first step of a major sync for the ab8500 driver from Lee
Jones. In particular, the debugfs and the sysct interfaces got
extended and improved.
- Peter Ujfalusi sent a nice patchset for cleaning and fixing the
twl-core driver, with a much needed module id lookup code
improvement.
- The regular wm5102 and arizona cleanups and fixes from Mark Brown.
- Laxman Dewangan extended the palmas APIs in order to implement the
palmas GPIO and rt drivers.
- Laxman also added DT support for the tps65090 driver.
- The Intel SCH and ICH drivers got a couple fixes from Aaron Sierra
and Darren Hart.
- Linus Walleij patchset for the ab8500 driver allowed ab8500 and
ab9540 based devices to switch to the new abx500 pin-ctrl driver.
- The max8925 now has device tree and irqdomain support thanks to
Qing Xu.
- The recently added rtsx driver got a few cleanups and fixes for a
better card detection code path and now also supports the RTS5227
chipset, thanks to Wei Wang and Roger Tseng."
* tag 'mfd-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (109 commits)
mfd: lpc_ich: Use devres API to allocate private data
mfd: lpc_ich: Add Device IDs for Intel Wellsburg PCH
mfd: lpc_sch: Accomodate partial population of the MFD devices
mfd: da9052-i2c: Staticize da9052_i2c_fix()
mfd: syscon: Fix sparse warning
mfd: twl-core: Fix kernel panic on boot
mfd: rtsx: Fix issue that booting OS with SD card inserted
mfd: ab8500: Fix compile error
mfd: Add missing GENERIC_HARDIRQS dependecies
Documentation: Add docs for max8925 dt
mfd: max8925: Add dts
mfd: max8925: Support dt for backlight
mfd: max8925: Fix onkey driver irq base
mfd: max8925: Fix mfd device register failure
mfd: max8925: Add irqdomain for dt
mfd: vexpress: Allow vexpress-sysreg to self-initialise
mfd: rtsx: Support RTS5227
mfd: rtsx: Implement driving adjustment to device-dependent callbacks
mfd: vexpress: Add pseudo-GPIO based LEDs
mfd: ab8500: Rename ab8500 to abx500 for hwmon driver
Merge misc patches from Andrew Morton:
- Florian has vanished so I appear to have become fbdev maintainer
again :(
- Joel and Mark are distracted to welcome to the new OCFS2 maintainer
- The backlight queue
- Small core kernel changes
- lib/ updates
- The rtc queue
- Various random bits
* akpm: (164 commits)
rtc: rtc-davinci: use devm_*() functions
rtc: rtc-max8997: use devm_request_threaded_irq()
rtc: rtc-max8907: use devm_request_threaded_irq()
rtc: rtc-da9052: use devm_request_threaded_irq()
rtc: rtc-wm831x: use devm_request_threaded_irq()
rtc: rtc-tps80031: use devm_request_threaded_irq()
rtc: rtc-lp8788: use devm_request_threaded_irq()
rtc: rtc-coh901331: use devm_clk_get()
rtc: rtc-vt8500: use devm_*() functions
rtc: rtc-tps6586x: use devm_request_threaded_irq()
rtc: rtc-imxdi: use devm_clk_get()
rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug()
rtc: rtc-pcf8583: use dev_warn() instead of printk()
rtc: rtc-sun4v: use pr_warn() instead of printk()
rtc: rtc-vr41xx: use dev_info() instead of printk()
rtc: rtc-rs5c313: use pr_err() instead of printk()
rtc: rtc-at91rm9200: use dev_dbg()/dev_err() instead of printk()/pr_debug()
rtc: rtc-rs5c372: use dev_dbg()/dev_warn() instead of printk()/pr_debug()
rtc: rtc-ds2404: use dev_err() instead of printk()
rtc: rtc-efi: use dev_err()/dev_warn()/pr_err() instead of printk()
Add an rtc driver for Maxim 8997 multifunction chip. Max8997 has rtc
module in it. and it can be used for timekeeping clock and system alarm.
It provide various operational mode those are BCD/binary, 24/12hour,
am/pm. Driver sets binary/24/ for default. Maxim 8997 also supports
SMPL(Sudden Momentary Power Loss), WTSR (Watchdog Timeout and Software
Reset).
Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com>
Cc: Devendra Naga <devendra.aaru@gmail.com>
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Torben Hohn <torbenh@linutronix.de>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Add an RTC driver for TPS80031/TPS80032 chips by TI. This driver
supports:
- Setting and getting time and date.
- Setting and reading alarm time.
- Alarm and interrupt functionlity.
[akpm@linux-foundation.org: remove obsolete __devinit/__devexit]
Reviewed-by: Devendra Naga <devendra.aaru@gmail.com>
TI LP8788 PMU supports regulators, battery charger, RTC, ADC, backlight
driver and current sinks. This patch enables LP8788 rtc module.
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
Cc: "devendra.aaru" <devendra.aaru@gmail.com>
Add a driver to support max77686 rtc. MAX77686 rtc support smpl and wtsr
mode. It has two alarm register which can be used for alarming to wake
system up. This drvier uses regmap to access its register.
[akpm@linux-foundation.org: remove inline, __devinit annotations]
[jg1.han@samsung.com: fix build warnings]
[akpm@linux-foundation.org: simplify code]
Signed-off-by: Chiwoong Byun <woong.byun@samsung.com>
Signed-off-by: Myugnjoo Ham <myungjoo.ham@samsung.com>
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging
Pull staging tree update from Greg Kroah-Hartman:
"Here's the big staging tree merge for 3.9-rc1
Lots of cleanups and updates for drivers all through the staging tree.
We are pretty much "code neutral" here, adding just about as many
lines as we removed.
All of these have been in linux-next for a while."
* tag 'staging-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (804 commits)
staging: comedi: vmk80xx: wait for URBs to complete
staging: comedi: drivers: addi-data: hwdrv_apci3200.c: Add a missing semicolon
staging: et131x: Update TODO list
staging: et131x: Remove assignment of skb->dev
staging: wlan-ng: hfa384x.h: fix for error reported by smatch
staging/zache checkpatch ERROR: spaces prohibited around that
staging/ozwpan: Mark read only parameters and structs as const
staging/ozwpan: Remove empty and unused function oz_cdev_heartbeat
staging/ozwpan: Mark local functions as static (fix sparse warnings)
staging/ozwpan: Add missing header includes
staging/usbip: Mark local functions as static (fix sparse warnings)
staging/xgifb: Remove duplicated code in loops.
staging/xgifb: Consolidate return paths
staging/xgifb: Remove code without effect
staging/xgifb: Remove unnecessary casts
staging/xgifb: Consolidate if/else if with identical code branches
staging: vt6656: replaced custom TRUE definition with true
staging: vt6656: replaced custom FALSE definition with false
staging: vt6656: replace custom BOOL definition with bool
staging/rtl8187se: Mark functions as static to silence sparse
TI Palmas series PMIC support the RTC and alarm functionality.
Add RTC driver with alarm support for this device.
into timers/core
Trivial conflict in arch/x86/Kconfig
This resolves a merge issue with a iio driver, and the zram code.
The purpose of this option is to allow ARM/etc systems that rely on the
class RTC subsystem to have the same kind of automatic NTP based
synchronization that we have on PC platforms. Today ARM does not
implement update_persistent_clock and makes extensive use of the class
RTC system.
When enabled CONFIG_RTC_SYSTOHC will provide a generic
rtc_update_persistent_clock that stores the current time in the RTC and
is intended complement the existing CONFIG_RTC_HCTOSYS option that loads
the RTC at boot.
Like with RTC_HCTOSYS the platform's update_persistent_clock is used
first, if it works. Platforms with mixed class RTC and non-RTC drivers
need to return ENODEV when class RTC should be used. Such an update for
PPC is included in this patch.
Long term, implementations of update_persistent_clock should migrate to
proper class RTC drivers and use CONFIG_RTC_SYSTOHC instead.
Tested on ARM kirkwood and PPC405
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
This driver makes the time from HID sensors (hubs) which are offering
such available like any other RTC does.
It is necessary that all values like year, month etc, are send as
8bit values (1 byte each) and all of them in 1 report. Also the
spec HUTRR39b doesn't define the range of the year field, we
tread it as 0 - 99 because that's what most RTCs I know about are
offering.
Currently the time can only be read. Setting the time must be done
through sending a report (or a feature). The spec currently doesn't
define how and I'm not sure if I just should define something by myself.
Signed-off-by: Alexander Holler <holler@ahsoftware.de>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
Add an RTC driver for TPS6586X chips by TI. This driver supports:
[akpm@linux-foundation.org: remove stray semicolons]
[akpm@linux-foundation.org: start epoch in 2009]
Tested-by: Marc Dietrich <marvin24@gmx.de>
A driver for the DA9055 PMIC. This has a dependency upon the DA9055 MFD
core.
Functionally tested on Samsung SMDKV6410.
Signed-off-by: David Dajun Chen <dchen@diasemi.com>
Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Add an RTC driver for PCF8523 chips by NXP Semiconductors. No support is
currently provided for the alarm and interrupt functions. Only the time
and date functionality is implemented.
Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Add an RTC driver for the RTC device on Ricoh MFD Rc5t583. Ricoh RTC has
3 types of alarms. The current patch adds support for the Y-Alarm of
RC5t583 RTC.
Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
The MAX8907 is an I2C-based power-management IC containing voltage
regulators, a reset controller, a real-time clock, and a touch-screen
controller.
The driver is based on an original by or fixed by:
* Tom Cherry
* Prashant Gaikwad
* Joseph Yoon
During upstreaming, I (swarren):
* Converted to regmap.
* Fixed handling of RTC_HOUR register containing 12.
* Fixed handling of RTC_WEEKDAY register.
* General cleanup.
Cc: Tom Cherry <tcherry@nvidia.com>
Cc: Prashant Gaikwad <pgaikwad@nvidia.com>
Cc: Joseph Yoon <tyoon@nvidia.com>
TPS65910 PMIC is a MFD with RTC as one of the device. Adding RTC driver
for supporting RTC device present inside TPS65910 PMIC.
Only support for RTC alarm is implemented as part of this patch.
Add an RTC driver for Freescale Secure Non-Volatile Storage (SNVS)
Low Power (LP) RTC.
Reviewed-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
[akpm@linux-foundation.org: fix warning]
Signed-off-by: Sven Schnelle <svens@stackframe.org>
add rtc driver for MARVELL 88PM80X PMIC and enable rtc function.
Signed-off-by: Qiao Zhou <zhouqiao@marvell.com>
In order to keep consistency with other rtc drivers,rename CONFIG_RTC_MXC
to CONFIG_RTC_DRV_MXC.
[akpm@linux-foundation.org: fix missed arch/arm/configs/imx_v6_v7_defconfig]
RTC Driver for Dialog Semiconductor DA9052/53 PMICs.
This patch is functionally tested on Samsung SMDKV6410.
[akpm@linux-foundation.org: clean up file header layout, remove unneeded initialisation of local arrays]
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Cc: David Dajun Chen <dchen@diasemi.com>
Add RTC support(TOY counter0) for loongson1B SOC
Signed-off-by: zhao zhang <zhzhl555@gmail.com>
Add support for PMIC8xxx based RTC. PMIC8xxx is Qualcomm's power
management IC that internally houses an RTC module. This driver
communicates with the PMIC module over SSBI bus.
[akpm@linux-foundation.org: cosmetic tweaks]
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Signed-off-by: Anirudh Ghayal <aghayal@codeaurora.org>
Signed-off-by: Ashay Jaiswal <ashayj@codeaurora.org>
Cc: Wan ZongShun <mcuos.com@gmail.com>
The patch moves rtc driver for PKUnity-v3 SoC from arch/unicore32/kernel/
to drivers/rtc/, with renaming it to rtc-puv3.c.
Also, Kconfig, Makefile, and MAINTAINERS are modified correspondingly.
Signed-off-by: Guan Xuetao <gxt@mprc.pku.edu.cn>
Signed-off-by: Rajeev Kumar <rajeev-dlh.kumar@st.com>
Signed-off-by: Viresh Kumar <viresh.kumar@st.com>
Add basic support for ST m41t93 SPI RTCs. Tested with factory-new and
with "run-in" species with and without backup batteries.
Signed-off-by: Nikolaus Voss <n.voss@weinmann.de>
Cc: Grant Likely <grant.likely@secretlab.ca>
Add support for the Micro Crystal RV3029-C2 RTC chips.
Signed-off-by: Gregory Hermant <gregory.hermant@calao-systems.com>
Add support for EM Microelectronic EM3027 RTC chip.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This adds a driver for the RTC devices in VIA and WonderMedia
Systems-on-Chip. Alarm, 1Hz interrupts, reading and setting time are
supported.
Signed-off-by: Alexey Charkov <alchark@gmail.com>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Alexey Charkov <alchark@gmail.com>
Enable rtc function in 88pm860x PMIC.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
This is a simple RTC driver that lets Tilera hardware boot up and
set the clock correctly.
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
This is a platform driver that supports the built-in real-time clock on
Tegra SOCs.
Signed-off-by: Andrew Chew <achew@nvidia.com>
Acked-by: Jon Mayo <jmayo@nvidia.com>
Replace EXTRA_CFLAGS with ccflags-y.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Provide the standard kernel rtc driver interface on top of the vrtc layer
added in the previous patch.
Signed-off-by: Feng Tang <feng.tang@intel.com>
LKML-Reference: <20101110172911.3311.20593.stgit@localhost.localdomain>
[Fixed swapped arguments on IPC]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
[Cleaned up and the device creation moved to arch/x86/platform]
Signed-off-by: Alan Cox <alan@linux.intel.com>
The mfd driver for MC13783 recently got support for MC13892 and was
renamed accordingly from mc13783-core to mc13xxx-core. Do the same for
rtc-mc13783.
The only relevant change is to use platform id's to tell the platform bus
that this driver is responsible for mc13892-rtc devices, too.
This adds support for the RTC provided by the Maxim 8998 chip. This
driver was tested on a GONI board by using the rtc-test application from
the Documentation/rtc.txt.
Signed-off-by: Joonyoung Shim <jy0922.shim@samsung.com>
