path: root/drivers/rtc/rtc-ab3100.c
2010-09-22drivers/rtc/rtc-ab3100.c: add missing platform_set_drvdata() in ↵Axel Lin
ab3100_rtc_probe() Otherwise, calling platform_get_drvdata() in ab3100_rtc_remove() returns NULL. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by:Wan ZongShun <mcuos.com@gmail.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-28mfd: AB3100 register access change to abx500 APIMattias Wallin
The interface for the AB3100 is changed to make way for the ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson Analog Baseband chips. The register access functions are moved out to a separate struct abx500_ops. In this way the interface is moved from the implementation and the sub functionality drivers can keep their interface intact when chip infrastructure and communication mechanisms changes. We also define the AB3550 device IDs and the AB3550 platform data struct and convert the catenated 32bit event to an array of 3 x 8bits. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Renamed ab3100.h to abx500.hLinus Walleij
The goal here is to make way for a more general interface for the analog baseband chips ab3100 ab3550 ab550 and future chips. This patch have been divided into two parts since both changing name and content of a file is not recommended in git. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17rtc: AB3100 RTC supportLinus Walleij
This adds support for the RTC found inside the AB3100 Mixed Signal chip. The symbols used for communicating with the chip is found in the mfd/ab3100-core.c driver that also provides the platform device. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
