path: root/drivers/rtc/rtc-cmos.c
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-09RTC: Cleanup rtc_class_ops->update_irq_enable()John Stultz
Now that the generic code handles UIE mode irqs via periodic alarm interrupts, no one calls the rtc_class_ops->update_irq_enable() method anymore. This patch removes the driver hooks and implementations of update_irq_enable if no one else is calling it. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_freq()John Stultz
With the generic rtc code now emulating PIE mode irqs via an hrtimer, no one calls the rtc_class_ops->irq_set_freq call. This patch removes the hook and deletes the driver functions if no one else calls them. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-23rtc: cmos: Add OF bindingsSebastian Andrzej Siewior
This allows to load the OF driver based informations from the device tree. Systems without BIOS may need to perform some initialization. PowerPC creates a PNP device from the OF information and performs this kind of initialization in their private PCI quirk. This looks more generic. This patch also avoids registering the platform RTC driver on X86 if we have a device tree blob. Otherwise we would setup the device based on the hardcoded information in arch/x86 rather than the device tree based one. [ tglx: Changed "int of_have_populated_dt()" to bool as recommended by Grant ] Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: sodaville@linutronix.de Cc: devicetree-discuss@lists.ozlabs.org Cc: rtc-linux@googlegroups.com Cc: Alessandro Zummo <a.zummo@towertech.it> LKML-Reference: <1298405266-1624-12-git-send-email-bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-13rtc-cmos: fix suspend/resumePaul Fox
rtc-cmos was setting suspend/resume hooks at the device_driver level. However, the platform bus code (drivers/base/platform.c) only looks for resume hooks at the dev_pm_ops level, or within the platform_driver. Switch rtc_cmos to use dev_pm_ops so that suspend/resume code is executed again. Paul said: : The user visible symptom in our (XO laptop) case was that rtcwake would : fail to wake the laptop. The RTC alarm would expire, but the wakeup : wasn't unmasked. : : As for severity, the impact may have been reduced because if I recall : correctly, the bug only affected platforms with CONFIG_PNP disabled. Signed-off-by: Paul Fox <pgf@laptop.org> Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: <stable@kernel.org> [2.6.37.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-29rtc-cmos.c : Fix warning on PowerPCSrikanth Krishnakar
The following warning is seen while compilation of PowerPC kernel: CC drivers/rtc/rtc-cmos.o drivers/rtc/rtc-cmos.c:697:2: warning: #warning Assuming 128 bytes of RTC+NVRAM address space, not 64 bytes. Fix it by adding defined(__powerpc__). Signed-off-by: Srikanth Krishnakar <skrishna@mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-11drivers/rtc: remove unneeded ifdef CONFIG_PMChristian Dietrich
Because CONFIG_PM is a precondition to CONFIG_ACPI, the ifdef CONFIG_PM within ifdef CONFIG_ACPI is redundant. Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25rtc-cmos: do dev_set_drvdata() earlier in the initializationDan Carpenter
The bug is an oops when dev_get_drvdata() returned null in cmos_update_irq_enable(). The call tree looks like this: rtc_dev_ioctl() => rtc_update_irq_enable() => cmos_update_irq_enable() It's caused by a race condition in the module initialization. It is rtc_device_register() which makes the ioctl operations live so I moved the call to dev_set_drvdata() before the call to rtc_device_register(). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15963 Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Dan Carpenter <error27@gmail.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Malte Schroder <maltesch@gmx.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21RTC: rtc-cmos: Fix binary mode supportArnaud Patard
As a follow-up to the thread about RTC support for some Loongson 2E/2F boards, this patch tries to address the "REVISIT"/"FIXME" comments about rtc binary mode handling and allow rtc to work with rtc in binary mode. I've also raised the message about 24-h mode not supported to warning otherwise, one may end up with no rtc without any message in the kernel log. Signed-off-by: Arnaud Patard <apatard@mandriva.com> To: linux-mips@linux-mips.org To: rtc-linux@googlegroups.com Cc: david-b@pacbell.net Cc: a.zummo@towertech.it Cc: akpm@linux-foundation.org Patchwork: http://patchwork.linux-mips.org/patch/1158/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-11rtc_cmos: convert shutdown to new pnp_driver->shutdownOGAWA Hirofumi
commit abd6633c67925f90775bb74755f9c547e30f1f20 ("pnp: add a shutdown method to pnp drivers") adds shutdown method to bus driver blindly. With it, driver->shutdown is no longer valid. Use pnp_driver->shutdown instead. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14889 Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Reported-by: Malte Schröder <maltesch@gmx.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: David Hardeman <david@hardeman.nu> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: <stable@kernel.org> [2.6.32.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17RTC: rtc-cmos.c: Fix warning on MIPSWu Zhangjin
This patch fixes the following warning with RTC_LIB on MIPS: drivers/rtc/rtc-cmos.c:697:2: warning: #warning Assuming 128 bytes of RTC+NVRAM address space, not 64 bytes. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Arnaud Patard <apatard@mandriva.com> Cc: linux-mips@linux-mips.org Cc: rtc-linux@googlegroups.com Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Patchwork: http://patchwork.linux-mips.org/patch/570/ Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-16rtc-cmos: convert RTC_AIE/RTC_UIE to rtc irq APIHerton Ronaldo Krzesinski
Drop ioctl function that handles RTC_AIE/RTC_UIE, and use instead the rtc subsystem API (alarm_irq_enable/update_irq_enable callbacks). Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16rtc: disable hpet emulation on suspendMaxim Levitsky
I noticed that rtc wont generate interrupts after a resume from disk. Here hpet rtc emulation is used. Problem is that rtc hpet comparator, isn't reinitialized after resume. Easiest way to solve this, is always mask all hpet interrupts on suspend This is triggered, when suspending with alarm set. Otherwise, hpet driver will think it doesn't need to reinitialize the rtc comparator, thus rtc interrupts won't work. This emulation isn't need for wakealarm. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29rtc: mark if rtc-cmos drivers were successfully registeredThadeu Lima de Souza Cascardo
rtc-cmos has two drivers, one PNP and one platform. When PNP has not succeeded probing, platform is registered. However, it tries to unregister both drivers unconditionally, instead of only unregistering those that were successfully registered. This causes runtime warnings to be emitted from the driver core code. Fix this with a boolean variable for each driver indicating whether registering was successful. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: David Brownell <david-b@pacbell.net> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Brownell <david-b@pacbell.net> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg KH <greg@kroah.com> Cc: Ozan Caglayan <ozan@pardus.org.tr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21rtc-cmos: fix printk outputKrzysztof Halasa
With no IRQ available/defined, RTC-CMOS driver prints something like: rtc0: alarms up to one no, y3k, 114 bytes nvram ^^^^ I guess the following is a bit easier to understand: rtc0: no alarms, y3k, 114 bytes nvram Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: move power of 2 periodic frequency check down into driversJonathan Cameron
Move the power of 2 check on frequencies down into individual rtc drivers This is to allow for non power of 2 real time clock periodic interrupts such as those on the pxa27x to be found in the new pxa27x-rtc driver Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: bunch of drivers: fix 'no irq' case handingAnton Vorontsov
This patch fixes a bunch of irq checking misuses. Most drivers were getting irq via platform_get_irq(), which returns -ENXIO or r->start. rtc-cmos.c is special. It is using PNP and platform bindings. Hopefully nobody is using PNP IRQ 0 for RTC. So the changes should be safe. rtc-sh.c is using platform_get_irq, but was storing a result into an unsigned type, then was checking for < 0. This is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: struct device: replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-By: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06rtc-cmos: fix boot log messageFrans Pop
-rtc0: alarms up to one month, y3k, 114 bytes nvram, , hpet irqs irqs +rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs Signed-off-by: Frans Pop <elendil@planet.nl> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20x86: sysfs: kill owner field from attributeParag Warudkar
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs attribute->owner unnecessary. But the field was left in the structure to ease the merge. It's been over a year since that change and it is now time to start killing attribute->owner along with its users - one arch at a time! This patch is attempt #1 to get rid of attribute->owner only for CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on as and when possible - avr32 will be the next since that is something I can test. Compile (make allyesconfig / make allmodconfig / custom config) and boot tested. akpm: the idea is that we put the declaration of sttribute.owner inside `#ifndef CONFIG_X86'. But that proved to be too ambitious for now because new usages kept on turning up in subsystem trees. [akpm: remove the ifdef for now] Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <htejun@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20rtc-cmos: export second NVRAM bankDavid Brownell
Teach rtc-cmos about the second bank of registers found on most modern x86 systems, giving access to 128 bytes more NVRAM. This version only sees that extra NVRAM when both register banks are provided as part of *one* PNP resource. Since BIOS on some systems presents them using two IO resources, and nothing merges them, this can't always show all the NVRAM. (We're supposed to be able to use PNP id PNP0b01 too, but BIOS tables doesn't often seem to use that particular option.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14rtc-cmos: look for PNP RTC first, then for platform RTCBjorn Helgaas
We shouldn't rely on "pnp_platform_devices" to tell us whether there is a PNP RTC device. I introduced "pnp_platform_devices", but I think it was a mistake. All it tells us is whether we found any PNPBIOS or PNPACPI devices. Many machines have some PNP devices, but do not describe the RTC via PNP. On those machines, we need to do the platform driver probe to find the RTC. We should just register the PNP driver and see whether it claims anything. If we don't find a PNP RTC, fall back to the platform driver probe. This (in conjunction with the arch/x86/kernel/rtc.c patch to add a platform RTC device when PNP doesn't have one) should resolve these issues: http://bugzilla.kernel.org/show_bug.cgi?id=11580 https://bugzilla.redhat.com/show_bug.cgi?id=451188 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Reported-by: Rik Theys <rik.theys@esat.kuleuven.be> Reported-by: shr_msn@yahoo.com.tw Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14rtc-cmos: move wake setup from ACPI glue into RTC driverBjorn Helgaas
Move rtc_wake_setup() from drivers/acpi/glue.c into the RTC driver in drivers/rtc/rtc-cmos.c. This removes the ordering constraint between the module_init(acpi_rtc_init) and the cmos_do_probe() code that depends on it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 Conflicts: arch/sparc64/kernel/pci_psycho.c
2008-09-02rtc-cmos: wake again from S5Rafael J. Wysocki
Update rtc-cmos shutdown handling to leave RTC alarms active, resolving http://bugzilla.kernel.org/show_bug.cgi?id=11411 on several boards. There are still some systems where the ACPI event handling doesn't cooperate. (Possibly related to bugid 11312, reporting the spontaneous disabling of RTC events.) Bug 11411 reported that changes to work around some ACPI event issues broke wake-from-S5 handling, as used for DVR applications. (They like to power off, then wake later to record programs.) [yakui.zhao@intel.com: add shutdown for PNP devices] [dbrownell@users.sourceforge.net: update comments] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Stefan Bauer <stefan.bauer@cs.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-29rtc: Allow RTC_DRV_CMOS to be used on SPARC.David S. Miller
Add Sparc to the Kconfig depends list. Add __sparc___ to address_sparc = 128 ifdef. Finally, don't be concerned about 24-hour BCD mode support if the RTC doesn't have a valid IRQ. We won't even use the alarm code in this case and the Sparc RTCs have this limitation. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-24rtc-cmos: avoid spurious irqsDavid Brownell
This fixes kernel http://bugzilla.kernel.org/show_bug.cgi?id=11112 (bogus RTC update IRQs reported) for rtc-cmos, in two ways: - When HPET is stealing the IRQs, use the first IRQ to grab the seconds counter which will be monitored (instead of using whatever was previously in that memory); - In sane IRQ handling modes, scrub out old IRQ status before enabling IRQs. That latter is done by tightening up IRQ handling for rtc-cmos everywhere, also ensuring that when HPET is used it's the only thing triggering IRQ reports to userspace; net object shrink. Also fix a bogus HPET message related to its RTC emulation. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Report-by: W Unruh <unruh@physics.ubc.ca> Cc: Andrew Victor <avictor.za@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc-cmos: improve HPET IRQ glueDavid Brownell
Resolve http://bugzilla.kernel.org/show_bug.cgi?id=11051 and other bugs related to the way the HPET glue code in rtc-cmos was incomplete and inconsistent: * Switch the approach so that the basic driver code flow isn't changed by having HPET ... instead, just have HPET shadow the RTC_CONTROL irq enables and RTC_FREQ_SELECT data. It's only coping with IRQ thievery, after all. * Do that consistently (!!) to avoid problems when the HPET code is out of sync with the real RTC intent. Examples include: - cmos_procfs(), which now reports correct data - cmos_irq_set_state() ... also removing the previous PIE_{ON,OFF} ioctl support so only one code path manages "periodic" IRQs - cmos_do_shutdown() ... currently a "just in case" change. - cmos_suspend() and cmos_resume() ... also handling a bug that was specific to HPET's IRQ thievery, where the alarm wasn't disabled after waking the system * Always call that HPET code under the RTC spinlock (it doesn't do its own locking) Also clean up the HPET glue: * Add some comments explaining what's going on. * Switch to having just one #ifdef for the HPET glue, and inline functions (not #defines) to avoid some compiler warnings. * Have the probe message also report when HPET IRQs are involved This still leaves various holes in the HPET glue, like the emulated update IRQs being out of sync with the RTC, alarms never using day or month matches, and many extra IRQs (at 64 Hz). [akpm@linux-foundation.org: fix build] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Tomas Janousek <tomi@nomi.cz> Cc: Bernhard Walle <bwalle@suse.de> Cc: Carlos R. Mafra <crmafra@ift.unesp.br> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: remove and clarify unneeded externsCarlos R. Mafra
When CONFIG_HPET_EMULATE_RTC is defined the external declaration of hpet_rtc_interrupt is redundant due to the inclusion of hpet.h. When !CONFIG_HPET_EMULATE_RTC we make it clear that hpet_rtc_interrupt is not used by defining it to return zero. Signed-off-by: Carlos R. Mafra <crmafra@ift.unesp.br> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12provide rtc_cmos platform deviceStas Sergeev
Recently (around 2.6.25) I've noticed that RTC no longer works for me. It turned out this is because I use pnpacpi=off kernel option to work around the parport_pc bugs. I always did so, but RTC used to work fine in the past, and now it have regressed. The patch fixes the problem by creating the platform device for the RTC when PNP is disabled. This may also help running the PNP-enabled kernel on an older PCs. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29rtc: dont reference pnp_resource_table directlyBjorn Helgaas
pnp_resource_table is going away soon, so use the more generic public interfaces instead. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-15rtc: fix the error in the function of cmos_set_alarmZhao Yakui
There is a bug in the function of cmos_set_alarm. RTC alarm time for October can't be set correctly. For October: 0x0A will be written into the RTC region (MONTH_ALARM) in current kernel. But in fact 0x10 should be written. Wildcards are also not handled correctly. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23rtc-cmos: display HPET emulation modeDavid Brownell
For the "cmos" RTC, have /proc/driver/rtc say whether HPET based IRQ emulation is in effect. Given the problems we've had with this particular hardware maldesign (and the fact that most BIOS code seems not to provide the IRQ routing needed to use the saner HPET modes), this should help troubleshooting. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: add HPET RTC emulation to RTC_DRV_CMOSBernhard Walle
That patch adds the RTC emulation of the HPET timer to the new RTC_DRV_CMOS. The old drivers/char/rtc.ko driver had that functionality and it's important on new systems. [akpm@linux-foundation.org: unbreak alpha build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Robert Picco <Robert.Picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-cmos alarm acts as oneshotDavid Brownell
Start making the rtc-cmos alarm act more like a oneshot alarm by disabling that alarm after its IRQ fires. (ACPI hooks are also needed.) The Linux RTC framework has previously been a bit vague in this area, but any other behavior is problematic and not very portable. RTCs with full YYYY-MM-DD HH:MM[:SS] alarms won't have a problem here. Only ones with partial match criteria, with the most visible example being the PC RTC, get confused. (Because the criteria will match repeatedly.) Update comments relating to that oneshot behavior and timezone handling. (Timezones are another issue that's mostly visible with rtc-cmos. That's because PCs often dual-boot MS-Windows, which likes its RTC to match local wall-clock time instead of UTC.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-cmos: export nvram in sysfsDavid Brownell
This makes rtc-cmos export its NVRAM, like several other RTC drivers. It still works within the limits of the current CMOS_READ/CMOS_WRITE calls, which don't understand how to access multiple register banks. The primary impact of that limitation is that Linux can't access the uppermost 128 bytes of NVRAM on many systems. Note that this isn't aiming to be a drop-in replacement for the legacy /dev/nvram support. (Presumably that has real users, and isn't just getting carried forward automatically?) Userspace handles more work: - When userspace code updates NVRAM, that will need to include updating any platform-specific checksums that may apply. - No /proc/driver/nvram file will parse and display NVRAM data according to whichever boot firmware your board expects. Also minor pnp-related updates: update a comment, remove dead code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-04rtc: ignore msb when reading back mday from alarmMark Lord
I have a system here that actively relies upon RTC wake alarms, and it has been failing (again) for a few days when attempting to use the /sys/class/rtc/rtc?/wakealarm interface. The old (fixed by Linus) /proc/ interface still works, but I'd like to get it using the new one. This patch fixes rtc-cmos to ignore the two upper bits when reading the BCD mday (day of month) register from CMOS. Some systems (eg. mine) seem to have the top bit set to "1" for some reason. The older /proc/ interface ignores the upper bits, and so we should too. Signed-off-by: Mark Lord <mlord@pobox.com> Acked-by: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16rtc-cmos probe() cleanupDavid Brownell
Some cleanups for the rtc-cmos probe logic: - Claim i/o ports with request_region() not request_resource(), for better coexistence betwen platform and pnp bus glues. - Claim those ports earlier, to help work around procfs bugs (it allows duplicate names, like /proc/driver/rtc). - Fix some glitches in cleanup code, notably a cut'n'paste-o where the i/o port region might not get released during cleanup after a probe fault. And some comment clarifications, including noting that this code must work with PNPBIOS not just PNPACPI.. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16rtc_irq_set_freq() requires power-of-two and associated kerneldocDavid Brownell
RTC periodic IRQs are only defined to work for 2^N Hz values. This patch moves that validity check into the infrastructure, so drivers don't need to check it; and adds kerneldoc for the two interface functions related to periodic IRQs. (One of which was quite mysterious until its first use was recently checked in!) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19RTC: add periodic irq support to rtc-cmosAlessandro Zummo
Adds support for periodic irq enabling in rtc-cmos. This could be used by the ALSA driver and is already being tested with the zaptel ztdummy module. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-01RTC: use fallback IRQ if PNP tables don't provide oneMatthew Garrett
Intel Macs (and possibly other machines) provide a PNP entry for the RTC, but provide no IRQ. As a result the rtc-cmos driver doesn't allow wakeup alarms. If the RTC is located at the legacy ioport range, assume that it's on IRQ 8 unless the tables say otherwise. Signed-off-by: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc-cmos: make it load on PNPBIOS systemsMarko Vrh
Replace CONFIG_PNPACPI with CONFIG_PNP, so it loads on ACPI-less PNPBIOS systems. Signed-off-by: Marko Vrh <mvrh@freeshells.ch> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc-cmos wakeup interfaceDavid Brownell
I finally got around to testing the updated wakeup event hooks for rtc-cmos, and they follow in two patches: - Interface update ... when a simple enable_irq_wake() doesn't suffice, the platform data can hold suspend/resume callback hooks. - ACPI implementation ... provides callback hooks to do ACPI magic, and eliminate the legacy /proc/acpi/alarm file. The interface update could go into 2.6.21, but that's not essential; they will be NOPs on most PCs, without the ACPI stuff. I suspect the ACPI folk may have opinions about how to merge that second patch, and how to obsolete that legacy procfs file. I'd like to see that merge into 2.6.22 if possible... As for how to kick it in ... two ways: - The appended "rtcwake" program; updated since the last time it was posted, it deals much better with timezones and DST. - Write the /sys/class/rtc/.../wakealarm file, then go to sleep. For some reason RTC wake from "swsusp" stopped working on a system where it previously worked; the alarm setting appears to get clobbered. But on the bright side, RTC wake from "standby" worked on a system that had never been able to resume from that state before ... IDEACPI is my guess as to why it finally started to work. It's the old "two steps forward, one step back" dance, I guess. - Dave /* gcc -Wall -Os -o rtcwake rtcwake.c */ #include <stdio.h> #include <getopt.h> #include <fcntl.h> #include <stdlib.h> #include <string.h> #include <unistd.h> #include <errno.h> #include <time.h> #include <sys/ioctl.h> #include <sys/time.h> #include <sys/types.h> #include <linux/rtc.h> /* constants from legacy PC/AT hardware */ #define RTC_PF 0x40 #define RTC_AF 0x20 #define RTC_UF 0x10 /* * rtcwake -- enter a system sleep state until specified wakeup time. * * This uses cross-platform Linux interfaces to enter a system sleep state, * and leave it no later than a specified time. It uses any RTC framework * driver that supports standard driver model wakeup flags. * * This is normally used like the old "apmsleep" utility, to wake from a * suspend state like ACPI S1 (standby) or S3 (suspend-to-RAM). Most * platforms can implement those without analogues of BIOS, APM, or ACPI. * * On some systems, this can also be used like "nvram-wakeup", waking * from states like ACPI S4 (suspend to disk). Not all systems have * persistent media that are appropriate for such suspend modes. * * The best way to set the system's RTC is so that it holds the current * time in UTC. Use the "-l" flag to tell this program that the system * RTC uses a local timezone instead (maybe you dual-boot MS-Windows). */ static char *progname; #ifdef DEBUG #define VERSION "1.0 dev (" __DATE__ " " __TIME__ ")" #else #define VERSION "0.9" #endif static unsigned verbose; static int rtc_is_utc = -1; static int may_wakeup(const char *devname) { char buf[128], *s; FILE *f; snprintf(buf, sizeof buf, "/sys/class/rtc/%s/device/power/wakeup", devname); f = fopen(buf, "r"); if (!f) { perror(buf); return 0; } fgets(buf, sizeof buf, f); fclose(f); s = strchr(buf, '\n'); if (!s) return 0; *s = 0; /* wakeup events could be disabled or not supported */ return strcmp(buf, "enabled") == 0; } /* all times should be in UTC */ static time_t sys_time; static time_t rtc_time; static int get_basetimes(int fd) { struct tm tm; struct rtc_time rtc; /* this process works in RTC time, except when working * with the system clock (which always uses UTC). */ if (rtc_is_utc) setenv("TZ", "UTC", 1); tzset(); /* read rtc and system clocks "at the same time", or as * precisely (+/- a second) as we can read them. */ if (ioctl(fd, RTC_RD_TIME, &rtc) < 0) { perror("read rtc time"); return 0; } sys_time = time(0); if (sys_time == (time_t)-1) { perror("read system time"); return 0; } /* convert rtc_time to normal arithmetic-friendly form, * updating tm.tm_wday as used by asctime(). */ memset(&tm, 0, sizeof tm); tm.tm_sec = rtc.tm_sec; tm.tm_min = rtc.tm_min; tm.tm_hour = rtc.tm_hour; tm.tm_mday = rtc.tm_mday; tm.tm_mon = rtc.tm_mon; tm.tm_year = rtc.tm_year; tm.tm_isdst = rtc.tm_isdst; /* stays unspecified? */ rtc_time = mktime(&tm); if (rtc_time == (time_t)-1) { perror("convert rtc time"); return 0; } if (verbose) { if (!rtc_is_utc) { printf("\ttzone = %ld\n", timezone); printf("\ttzname = %s\n", tzname[daylight]); gmtime_r(&rtc_time, &tm); } printf("\tsystime = %ld, (UTC) %s", (long) sys_time, asctime(gmtime(&sys_time))); printf("\trtctime = %ld, (UTC) %s", (long) rtc_time, asctime(&tm)); } return 1; } static int setup_alarm(int fd, time_t *wakeup) { struct tm *tm; struct rtc_wkalrm wake; tm = gmtime(wakeup); wake.time.tm_sec = tm->tm_sec; wake.time.tm_min = tm->tm_min; wake.time.tm_hour = tm->tm_hour; wake.time.tm_mday = tm->tm_mday; wake.time.tm_mon = tm->tm_mon; wake.time.tm_year = tm->tm_year; wake.time.tm_wday = tm->tm_wday; wake.time.tm_yday = tm->tm_yday; wake.time.tm_isdst = tm->tm_isdst; /* many rtc alarms only support up to 24 hours from 'now' ... */ if ((rtc_time + (24 * 60 * 60)) > *wakeup) { if (ioctl(fd, RTC_ALM_SET, &wake.time) < 0) { perror("set rtc alarm"); return 0; } if (ioctl(fd, RTC_AIE_ON, 0) < 0) { perror("enable rtc alarm"); return 0; } /* ... so use the "more than 24 hours" request only if we must */ } else { /* avoid an extra AIE_ON call */ wake.enabled = 1; if (ioctl(fd, RTC_WKALM_SET, &wake) < 0) { perror("set rtc wake alarm"); return 0; } } return 1; } static void suspend_system(const char *suspend) { FILE *f = fopen("/sys/power/state", "w"); if (!f) { perror("/sys/power/state"); return; } fprintf(f, "%s\n", suspend); fflush(f); /* this executes after wake from suspend */ fclose(f); } int main(int argc, char **argv) { static char *devname = "rtc0"; static unsigned seconds = 0; static char *suspend = "standby"; int t; int fd; time_t alarm = 0; progname = strrchr(argv[0], '/'); if (progname) progname++; else progname = argv[0]; if (chdir("/dev/") < 0) { perror("chdir /dev"); return 1; } while ((t = getopt(argc, argv, "d:lm:s:t:uVv")) != EOF) { switch (t) { case 'd': devname = optarg; break; case 'l': rtc_is_utc = 0; break; /* what system power mode to use? for now handle only * standardized mode names; eventually when systems define * their own state names, parse /sys/power/state. * * "on" is used just to test the RTC alarm mechanism, * bypassing all the wakeup-from-sleep infrastructure. */ case 'm': if (strcmp(optarg, "standby") == 0 || strcmp(optarg, "mem") == 0 || strcmp(optarg, "disk") == 0 || strcmp(optarg, "on") == 0 ) { suspend = optarg; break; } printf("%s: unrecognized suspend state '%s'\n", progname, optarg); goto usage; /* alarm time, seconds-to-sleep (relative) */ case 's': t = atoi(optarg); if (t < 0) { printf("%s: illegal interval %s seconds\n", progname, optarg); goto usage; } seconds = t; break; /* alarm time, time_t (absolute, seconds since 1/1 1970 UTC) */ case 't': t = atoi(optarg); if (t < 0) { printf("%s: illegal time_t value %s\n", progname, optarg); goto usage; } alarm = t; break; case 'u': rtc_is_utc = 1; break; case 'v': verbose++; break; case 'V': printf("%s: version %s\n", progname, VERSION); break; default: usage: printf("usage: %s [options]" "\n\t" "-d rtc0|rtc1|...\t(select rtc)" "\n\t" "-l\t\t\t(RTC uses local timezone)" "\n\t" "-m standby|mem|...\t(sleep mode)" "\n\t" "-s seconds\t\t(seconds to sleep)" "\n\t" "-t time_t\t\t(time to wake)" "\n\t" "-u\t\t\t(RTC uses UTC)" "\n\t" "-v\t\t\t(verbose messages)" "\n\t" "-V\t\t\t(show version)" "\n", progname); return 1; } } if (!alarm && !seconds) { printf("%s: must provide wake time\n", progname); goto usage; } /* REVISIT: if /etc/adjtime exists, read it to see what * the util-linux version of hwclock assumes. */ if (rtc_is_utc == -1) { printf("%s: assuming RTC uses UTC ...\n", progname); rtc_is_utc = 1; } /* this RTC must exist and (if we'll sleep) be wakeup-enabled */ fd = open(devname, O_RDONLY); if (fd < 0) { perror(devname); return 1; } if (strcmp(suspend, "on") != 0 && !may_wakeup(devname)) { printf("%s: %s not enabled for wakeup events\n", progname, devname); return 1; } /* relative or absolute alarm time, normalized to time_t */ if (!get_basetimes(fd)) return 1; if (verbose) printf("alarm %ld, sys_time %ld, rtc_time %ld, seconds %u\n", alarm, sys_time, rtc_time, seconds); if (alarm) { if (alarm < sys_time) { printf("%s: time doesn't go backward to %s", progname, ctime(&alarm)); return 1; } alarm += sys_time - rtc_time; } else alarm = rtc_time + seconds + 1; if (setup_alarm(fd, &alarm) < 0) return 1; sync(); printf("%s: wakeup from \"%s\" using %s at %s", progname, suspend, devname, ctime(&alarm)); fflush(stdout); usleep(10 * 1000); if (strcmp(suspend, "on") != 0) suspend_system(suspend); else { unsigned long data; do { t = read(fd, &data, sizeof data); if (t < 0) { perror("rtc read"); break; } if (verbose) printf("... %s: %03lx\n", devname, data); } while (!(data & RTC_AF)); } if (ioctl(fd, RTC_AIE_OFF, 0) < 0) perror("disable rtc alarm interrupt"); close(fd); return 0; } This patch: Make rtc-cmos do the relevant magic so this RTC can wake the system from a sleep state. That magic comes in two basic flavors: - Straightforward: enable_irq_wake(), the way it'd work on most SOC chips; or generally with system sleep states which don't disable core IRQ logic. - Roundabout, using non-IRQ platform hooks. This is needed with ACPI and one almost-clone chip which uses a special wakeup-only alarm. (That's the RTC used on Footbridge boards, FWIW, which don't do PM in Linux.) A separate patch implements those hooks for ACPI platforms, so that rtc_cmos can issue system wakeup events (and its sysfs "wakealarm" attribute works on at least some systems). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove rest of class_deviceDavid Brownell
Finish converting the RTC framework so it no longer uses class_device. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-02[PATCH] rtc-cmos lockdep fix, irq updatesDavid Brownell
Lockdep reported cmos_suspend() and cmos_resume() calling rtc_update_irq() with IRQs enabled; not allowed. Also fix problems seen on some hardware, whereby false alarm IRQs could be reported (primarily to userspace); and update two comments to match changes in ACPI. Those make up most of this patch, by volume. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
