path: root/drivers/rtc/rtc-cmos.c
2014-02-13rtc-cmos: Add an alarm disable quirkBorislav Petkov
commit d5a1c7e3fc38d9c7d629e1e47f32f863acbdec3d upstream. 41c7f7424259f ("rtc: Disable the alarm in the hardware (v2)") added the functionality to disable the RTC wake alarm when shutting down the box. However, there are at least two b0rked BIOSes we know about: https://bugzilla.novell.com/show_bug.cgi?id=812592 https://bugzilla.novell.com/show_bug.cgi?id=805740 where, when wakeup alarm is enabled in the BIOS, the machine reboots automatically right after shutdown, regardless of what wakeup time is programmed. Bisecting the issue lead to this patch so disable its functionality with a DMI quirk only for those boxes. Cc: Brecht Machiels <brecht@mos6581.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Borislav Petkov <bp@suse.de> [jstultz: Changed variable name for clarity, added extra dmi entry] Tested-by: Brecht Machiels <brecht@mos6581.org> Tested-by: Borislav Petkov <bp@suse.de> Signed-off-by: John Stultz <john.stultz@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-12drivers/rtc/rtc-cmos.c: fix accidentally enabling rtc channelDerek Basehore
During resume, we call hpet_rtc_timer_init after masking an irq bit in hpet. This will cause the call to hpet_disable_rtc_channel to be undone if RTC_AIE is the only bit not masked. Allowing the cmos interrupt handler to run before resuming caused some issues where the timer for the alarm was not removed. This would cause other, later timers to not be cleared, so utilities such as hwclock would time out when waiting for the update interrupt. [akpm@linux-foundation.org: coding-style tweak] Signed-off-by: Derek Basehore <dbasehore@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/rtc/rtc-cmos.c: don't disable hpet emulation on suspendDerek Basehore
There's a bug where rtc alarms are ignored after the rtc cmos suspends but before the system finishes suspend. Since hpet emulation is disabled and it still handles the interrupts, a wake event is never registered which is done from the rtc layer. This patch reverts commit d1b2efa83fbf ("rtc: disable hpet emulation on suspend") which disabled hpet emulation. To fix the problem mentioned in that commit, hpet_rtc_timer_init() is called directly on resume. Signed-off-by: Derek Basehore <dbasehore@chromium.org> Cc: Maxim Levitsky <maximlevitsky@gmail.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21rtc: rtc-cmos: use dev_warn()/dev_dbg() instead of printk()/pr_debug()Jingoo Han
Fix the checkpatch warning as below: WARNING: Prefer netdev_err(netdev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ... Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc: use of_match_ptr() macroSachin Kamat
This eliminates having an #ifdef returning NULL for the case when OF is disabled. Maintains consistency in cases where OF is always selected. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-08RTC: Avoid races between RTC alarm wakeup and suspend.NeilBrown
If an RTC alarm fires just as suspend is happening, it is possible for suspend to complete and the alarm to be missed. To avoid the race, we must register the event with the PM core. As the event is made visible to userspace through a thread which is only scheduled by the interrupt, we need a pm_stay_awake/pm_relax pair preventing suspend from the interrupt until the thread completes its work. This makes the pm_wakeup_event() call in cmos_interrupt unnecessary as it provides suspend protection for all RTCs that use rtc_update_irq. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-07-17rtc-cmos: report wakeups from interrupt handlerPaul Fox
When suspending the system with an important RTC wake alarm active, it is possible that the RTC alarm will expire before the system has gone to sleep (e.g. short alarm timer, or an unusually long suspend routine). If this happens, the RTC alarm should trigger a wakeup event, possibly aborting system suspend. This condition can be detected in the form of an RTC alarm interrupt. Signed-off-by: Paul Fox <pgf@laptop.org> Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-05-29rtc-cmos / PM: report wakeup event on ACPI RTC alarmDaniel Drake
When the ACPI-driven RTC alarm wakes the system, report it as a wakeup event. This allows userspace to determine that the reason for system wakeup was RTC alarm. Signed-off-by: Daniel Drake <dsd@laptop.org> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-03-23drivers/rtc: remove IRQF_DISABLEDYong Zhang
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts disabled") we run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled - see commit b738a50a2026 ("genirq: warn when handler enables interrupts"). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10drivers/rtc/rtc-cmos.c: fix broken NVRAM bank 2 writingOndrej Zary
Fix writing to NVRAM bank 2 in rtc-cmos driver. It never worked since its introduction in 2.6.28 because of a typo. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-09RTC: Cleanup rtc_class_ops->update_irq_enable()John Stultz
Now that the generic code handles UIE mode irqs via periodic alarm interrupts, no one calls the rtc_class_ops->update_irq_enable() method anymore. This patch removes the driver hooks and implementations of update_irq_enable if no one else is calling it. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_freq()John Stultz
With the generic rtc code now emulating PIE mode irqs via an hrtimer, no one calls the rtc_class_ops->irq_set_freq call. This patch removes the hook and deletes the driver functions if no one else calls them. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-23rtc: cmos: Add OF bindingsSebastian Andrzej Siewior
This allows to load the OF driver based informations from the device tree. Systems without BIOS may need to perform some initialization. PowerPC creates a PNP device from the OF information and performs this kind of initialization in their private PCI quirk. This looks more generic. This patch also avoids registering the platform RTC driver on X86 if we have a device tree blob. Otherwise we would setup the device based on the hardcoded information in arch/x86 rather than the device tree based one. [ tglx: Changed "int of_have_populated_dt()" to bool as recommended by Grant ] Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: sodaville@linutronix.de Cc: devicetree-discuss@lists.ozlabs.org Cc: rtc-linux@googlegroups.com Cc: Alessandro Zummo <a.zummo@towertech.it> LKML-Reference: <1298405266-1624-12-git-send-email-bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-01-13rtc-cmos: fix suspend/resumePaul Fox
rtc-cmos was setting suspend/resume hooks at the device_driver level. However, the platform bus code (drivers/base/platform.c) only looks for resume hooks at the dev_pm_ops level, or within the platform_driver. Switch rtc_cmos to use dev_pm_ops so that suspend/resume code is executed again. Paul said: : The user visible symptom in our (XO laptop) case was that rtcwake would : fail to wake the laptop. The RTC alarm would expire, but the wakeup : wasn't unmasked. : : As for severity, the impact may have been reduced because if I recall : correctly, the bug only affected platforms with CONFIG_PNP disabled. Signed-off-by: Paul Fox <pgf@laptop.org> Signed-off-by: Daniel Drake <dsd@laptop.org> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: <stable@kernel.org> [2.6.37.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-29rtc-cmos.c : Fix warning on PowerPCSrikanth Krishnakar
The following warning is seen while compilation of PowerPC kernel: CC drivers/rtc/rtc-cmos.o drivers/rtc/rtc-cmos.c:697:2: warning: #warning Assuming 128 bytes of RTC+NVRAM address space, not 64 bytes. Fix it by adding defined(__powerpc__). Signed-off-by: Srikanth Krishnakar <skrishna@mvista.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-11drivers/rtc: remove unneeded ifdef CONFIG_PMChristian Dietrich
Because CONFIG_PM is a precondition to CONFIG_ACPI, the ifdef CONFIG_PM within ifdef CONFIG_ACPI is redundant. Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-25rtc-cmos: do dev_set_drvdata() earlier in the initializationDan Carpenter
The bug is an oops when dev_get_drvdata() returned null in cmos_update_irq_enable(). The call tree looks like this: rtc_dev_ioctl() => rtc_update_irq_enable() => cmos_update_irq_enable() It's caused by a race condition in the module initialization. It is rtc_device_register() which makes the ioctl operations live so I moved the call to dev_set_drvdata() before the call to rtc_device_register(). Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15963 Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Dan Carpenter <error27@gmail.com> Tested-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Malte Schroder <maltesch@gmx.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21RTC: rtc-cmos: Fix binary mode supportArnaud Patard
As a follow-up to the thread about RTC support for some Loongson 2E/2F boards, this patch tries to address the "REVISIT"/"FIXME" comments about rtc binary mode handling and allow rtc to work with rtc in binary mode. I've also raised the message about 24-h mode not supported to warning otherwise, one may end up with no rtc without any message in the kernel log. Signed-off-by: Arnaud Patard <apatard@mandriva.com> To: linux-mips@linux-mips.org To: rtc-linux@googlegroups.com Cc: david-b@pacbell.net Cc: a.zummo@towertech.it Cc: akpm@linux-foundation.org Patchwork: http://patchwork.linux-mips.org/patch/1158/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-05-21sysfs: add struct file* to bin_attr callbacksChris Wright
This allows bin_attr->read,write,mmap callbacks to check file specific data (such as inode owner) as part of any privilege validation. Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-11rtc_cmos: convert shutdown to new pnp_driver->shutdownOGAWA Hirofumi
commit abd6633c67925f90775bb74755f9c547e30f1f20 ("pnp: add a shutdown method to pnp drivers") adds shutdown method to bus driver blindly. With it, driver->shutdown is no longer valid. Use pnp_driver->shutdown instead. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=14889 Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Reported-by: Malte Schröder <maltesch@gmx.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: David Hardeman <david@hardeman.nu> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: <stable@kernel.org> [2.6.32.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17RTC: rtc-cmos.c: Fix warning on MIPSWu Zhangjin
This patch fixes the following warning with RTC_LIB on MIPS: drivers/rtc/rtc-cmos.c:697:2: warning: #warning Assuming 128 bytes of RTC+NVRAM address space, not 64 bytes. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Arnaud Patard <apatard@mandriva.com> Cc: linux-mips@linux-mips.org Cc: rtc-linux@googlegroups.com Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Patchwork: http://patchwork.linux-mips.org/patch/570/ Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-16rtc-cmos: convert RTC_AIE/RTC_UIE to rtc irq APIHerton Ronaldo Krzesinski
Drop ioctl function that handles RTC_AIE/RTC_UIE, and use instead the rtc subsystem API (alarm_irq_enable/update_irq_enable callbacks). Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16rtc: disable hpet emulation on suspendMaxim Levitsky
I noticed that rtc wont generate interrupts after a resume from disk. Here hpet rtc emulation is used. Problem is that rtc hpet comparator, isn't reinitialized after resume. Easiest way to solve this, is always mask all hpet interrupts on suspend This is triggered, when suspending with alarm set. Otherwise, hpet driver will think it doesn't need to reinitialize the rtc comparator, thus rtc interrupts won't work. This emulation isn't need for wakealarm. Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: David Brownell <david-b@pacbell.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-29rtc: mark if rtc-cmos drivers were successfully registeredThadeu Lima de Souza Cascardo
rtc-cmos has two drivers, one PNP and one platform. When PNP has not succeeded probing, platform is registered. However, it tries to unregister both drivers unconditionally, instead of only unregistering those that were successfully registered. This causes runtime warnings to be emitted from the driver core code. Fix this with a boolean variable for each driver indicating whether registering was successful. Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Cc: David Brownell <david-b@pacbell.net> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Brownell <david-b@pacbell.net> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Greg KH <greg@kroah.com> Cc: Ozan Caglayan <ozan@pardus.org.tr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21rtc-cmos: fix printk outputKrzysztof Halasa
With no IRQ available/defined, RTC-CMOS driver prints something like: rtc0: alarms up to one no, y3k, 114 bytes nvram ^^^^ I guess the following is a bit easier to understand: rtc0: no alarms, y3k, 114 bytes nvram Signed-off-by: Krzysztof Halasa <khc@pm.waw.pl> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: move power of 2 periodic frequency check down into driversJonathan Cameron
Move the power of 2 check on frequencies down into individual rtc drivers This is to allow for non power of 2 real time clock periodic interrupts such as those on the pxa27x to be found in the new pxa27x-rtc driver Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: bunch of drivers: fix 'no irq' case handingAnton Vorontsov
This patch fixes a bunch of irq checking misuses. Most drivers were getting irq via platform_get_irq(), which returns -ENXIO or r->start. rtc-cmos.c is special. It is using PNP and platform bindings. Hopefully nobody is using PNP IRQ 0 for RTC. So the changes should be safe. rtc-sh.c is using platform_get_irq, but was storing a result into an unsigned type, then was checking for < 0. This is fixed now. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: struct device: replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Alessandro Zummo <a.zummo@towertech.it> Acked-By: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-06rtc-cmos: fix boot log messageFrans Pop
-rtc0: alarms up to one month, y3k, 114 bytes nvram, , hpet irqs irqs +rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs Signed-off-by: Frans Pop <elendil@planet.nl> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20x86: sysfs: kill owner field from attributeParag Warudkar
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs attribute->owner unnecessary. But the field was left in the structure to ease the merge. It's been over a year since that change and it is now time to start killing attribute->owner along with its users - one arch at a time! This patch is attempt #1 to get rid of attribute->owner only for CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on as and when possible - avr32 will be the next since that is something I can test. Compile (make allyesconfig / make allmodconfig / custom config) and boot tested. akpm: the idea is that we put the declaration of sttribute.owner inside `#ifndef CONFIG_X86'. But that proved to be too ambitious for now because new usages kept on turning up in subsystem trees. [akpm: remove the ifdef for now] Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <htejun@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20rtc-cmos: export second NVRAM bankDavid Brownell
Teach rtc-cmos about the second bank of registers found on most modern x86 systems, giving access to 128 bytes more NVRAM. This version only sees that extra NVRAM when both register banks are provided as part of *one* PNP resource. Since BIOS on some systems presents them using two IO resources, and nothing merges them, this can't always show all the NVRAM. (We're supposed to be able to use PNP id PNP0b01 too, but BIOS tables doesn't often seem to use that particular option.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14rtc-cmos: look for PNP RTC first, then for platform RTCBjorn Helgaas
We shouldn't rely on "pnp_platform_devices" to tell us whether there is a PNP RTC device. I introduced "pnp_platform_devices", but I think it was a mistake. All it tells us is whether we found any PNPBIOS or PNPACPI devices. Many machines have some PNP devices, but do not describe the RTC via PNP. On those machines, we need to do the platform driver probe to find the RTC. We should just register the PNP driver and see whether it claims anything. If we don't find a PNP RTC, fall back to the platform driver probe. This (in conjunction with the arch/x86/kernel/rtc.c patch to add a platform RTC device when PNP doesn't have one) should resolve these issues: http://bugzilla.kernel.org/show_bug.cgi?id=11580 https://bugzilla.redhat.com/show_bug.cgi?id=451188 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Reported-by: Rik Theys <rik.theys@esat.kuleuven.be> Reported-by: shr_msn@yahoo.com.tw Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-14rtc-cmos: move wake setup from ACPI glue into RTC driverBjorn Helgaas
Move rtc_wake_setup() from drivers/acpi/glue.c into the RTC driver in drivers/rtc/rtc-cmos.c. This removes the ordering constraint between the module_init(acpi_rtc_init) and the cmos_do_probe() code that depends on it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-16Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 Conflicts: arch/sparc64/kernel/pci_psycho.c
2008-09-02rtc-cmos: wake again from S5Rafael J. Wysocki
Update rtc-cmos shutdown handling to leave RTC alarms active, resolving http://bugzilla.kernel.org/show_bug.cgi?id=11411 on several boards. There are still some systems where the ACPI event handling doesn't cooperate. (Possibly related to bugid 11312, reporting the spontaneous disabling of RTC events.) Bug 11411 reported that changes to work around some ACPI event issues broke wake-from-S5 handling, as used for DVR applications. (They like to power off, then wake later to record programs.) [yakui.zhao@intel.com: add shutdown for PNP devices] [dbrownell@users.sourceforge.net: update comments] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Stefan Bauer <stefan.bauer@cs.tu-chemnitz.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-29rtc: Allow RTC_DRV_CMOS to be used on SPARC.David S. Miller
Add Sparc to the Kconfig depends list. Add __sparc___ to address_sparc = 128 ifdef. Finally, don't be concerned about 24-hour BCD mode support if the RTC doesn't have a valid IRQ. We won't even use the alarm code in this case and the Sparc RTCs have this limitation. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-24rtc-cmos: avoid spurious irqsDavid Brownell
This fixes kernel http://bugzilla.kernel.org/show_bug.cgi?id=11112 (bogus RTC update IRQs reported) for rtc-cmos, in two ways: - When HPET is stealing the IRQs, use the first IRQ to grab the seconds counter which will be monitored (instead of using whatever was previously in that memory); - In sane IRQ handling modes, scrub out old IRQ status before enabling IRQs. That latter is done by tightening up IRQ handling for rtc-cmos everywhere, also ensuring that when HPET is used it's the only thing triggering IRQ reports to userspace; net object shrink. Also fix a bogus HPET message related to its RTC emulation. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Report-by: W Unruh <unruh@physics.ubc.ca> Cc: Andrew Victor <avictor.za@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc-cmos: improve HPET IRQ glueDavid Brownell
Resolve http://bugzilla.kernel.org/show_bug.cgi?id=11051 and other bugs related to the way the HPET glue code in rtc-cmos was incomplete and inconsistent: * Switch the approach so that the basic driver code flow isn't changed by having HPET ... instead, just have HPET shadow the RTC_CONTROL irq enables and RTC_FREQ_SELECT data. It's only coping with IRQ thievery, after all. * Do that consistently (!!) to avoid problems when the HPET code is out of sync with the real RTC intent. Examples include: - cmos_procfs(), which now reports correct data - cmos_irq_set_state() ... also removing the previous PIE_{ON,OFF} ioctl support so only one code path manages "periodic" IRQs - cmos_do_shutdown() ... currently a "just in case" change. - cmos_suspend() and cmos_resume() ... also handling a bug that was specific to HPET's IRQ thievery, where the alarm wasn't disabled after waking the system * Always call that HPET code under the RTC spinlock (it doesn't do its own locking) Also clean up the HPET glue: * Add some comments explaining what's going on. * Switch to having just one #ifdef for the HPET glue, and inline functions (not #defines) to avoid some compiler warnings. * Have the probe message also report when HPET IRQs are involved This still leaves various holes in the HPET glue, like the emulated update IRQs being out of sync with the RTC, alarms never using day or month matches, and many extra IRQs (at 64 Hz). [akpm@linux-foundation.org: fix build] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Tomas Janousek <tomi@nomi.cz> Cc: Bernhard Walle <bwalle@suse.de> Cc: Carlos R. Mafra <crmafra@ift.unesp.br> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: remove and clarify unneeded externsCarlos R. Mafra
When CONFIG_HPET_EMULATE_RTC is defined the external declaration of hpet_rtc_interrupt is redundant due to the inclusion of hpet.h. When !CONFIG_HPET_EMULATE_RTC we make it clear that hpet_rtc_interrupt is not used by defining it to return zero. Signed-off-by: Carlos R. Mafra <crmafra@ift.unesp.br> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-12provide rtc_cmos platform deviceStas Sergeev
Recently (around 2.6.25) I've noticed that RTC no longer works for me. It turned out this is because I use pnpacpi=off kernel option to work around the parport_pc bugs. I always did so, but RTC used to work fine in the past, and now it have regressed. The patch fixes the problem by creating the platform device for the RTC when PNP is disabled. This may also help running the PNP-enabled kernel on an older PCs. Signed-off-by: Stas Sergeev <stsp@aknet.ru> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29rtc: dont reference pnp_resource_table directlyBjorn Helgaas
pnp_resource_table is going away soon, so use the more generic public interfaces instead. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-15rtc: fix the error in the function of cmos_set_alarmZhao Yakui
There is a bug in the function of cmos_set_alarm. RTC alarm time for October can't be set correctly. For October: 0x0A will be written into the RTC region (MONTH_ALARM) in current kernel. But in fact 0x10 should be written. Wildcards are also not handled correctly. Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11rtc: fix platform driver hotplug/coldplugKay Sievers
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC platform drivers, to re-enable module auto loading. [dbrownell@users.sourceforge.net: more drivers, minor fix] Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-23rtc-cmos: display HPET emulation modeDavid Brownell
For the "cmos" RTC, have /proc/driver/rtc say whether HPET based IRQ emulation is in effect. Given the problems we've had with this particular hardware maldesign (and the fact that most BIOS code seems not to provide the IRQ routing needed to use the saner HPET modes), this should help troubleshooting. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: add HPET RTC emulation to RTC_DRV_CMOSBernhard Walle
That patch adds the RTC emulation of the HPET timer to the new RTC_DRV_CMOS. The old drivers/char/rtc.ko driver had that functionality and it's important on new systems. [akpm@linux-foundation.org: unbreak alpha build] Signed-off-by: Bernhard Walle <bwalle@suse.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@suse.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Robert Picco <Robert.Picco@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
