path: root/drivers/rtc/rtc-da9055.c
2014-10-20rtc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-04-03drivers/rtc/rtc-da9055.c: remove use of regmap_irq_get_virq()Adam Thomson
Using platform_get_irq_byname() to retrieve the IRQ number returns the VIRQ number rather than the local IRQ number for the device. Passing that value then into regmap_irq_get_virq() causes a failure because the function is expecting the local IRQ number (e.g. 0, 1, 2, 3, etc). This patch removes use of regmap_irq_get_virq() to prevent this failure from happening Signed-off-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13drivers/rtc/rtc-da9055.c: use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. This is a cosmetic change to make the code simpler and enhance the readability. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03drivers/rtc/rtc-da9055.c: remove empty functionSachin Kamat
After the switch to devm_ functions and the removal of rtc_device_unregister(), the 'remove' function does not do anything. Delete it. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: David Dajun Chen <dchen@diasemi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rtc: rtc-da9055: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d063100 ("device-core: Ensure drvdata = NULL when no driver is bound"). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-da9055: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-11drivers/rtc/rtc-da9055.c: fix cross-section referenceAndrew Morton
Fix the warning WARNING: drivers/rtc/rtc-da9055.o(.text+0xa71): Section mismatch in reference from the function da9055_rtc_probe() to the function .init.text:da9055_rtc_device_init() Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17rtc: DA9055 RTC driverAshish Jangam
A driver for the DA9055 PMIC. This has a dependency upon the DA9055 MFD core. Functionally tested on Samsung SMDKV6410. Signed-off-by: David Dajun Chen <dchen@diasemi.com> Signed-off-by: Ashish Jangam <ashish.jangam@kpitcummins.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
