There are no driver left using .open and .release. There is no good use
case for them as there is nothing the character device interface does that
should not be done in the sysfs interface or in-kernel interface.
Remove those callbacks now to avoid future confusion.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
rtc->name is superfluous here because the rtc is already registered at that
point and its name has already been printed.
Mostly straightforward, but we had to remove the rtc_dev_add/del_device
functions as they split up the cdev_add and the device_add.
Doing this also revealed that there was likely another subtle bug:
seeing cdev_add was done after device_register, the cdev probably
was not ready before device_add when the uevent occurs. This would
race with userspace, if it tried to use the device directly after
the uevent. This is fixed just by using the new helper function.
Another weird thing is this driver would, in some error cases, call
cdev_add() without calling cdev_init. This patchset corrects this
by avoiding calling cdev_add if the devt is not set.
Signed-off-by: Logan Gunthorpe <logang@deltatee.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
struct rtc embeds both struct dev and struct cdev. Unfortunately character
device structure may outlive the parent rtc structure unless we set it up
as parent of character device so that it will stay pinned until character
device is freed.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Currently, rtc-dev.c uses y2038 problematic rtc_tm_to_time()
and rtc_time_to_tm(). So replace them with their corresponding
y2038-safe versions: rtc_tm_to_time64() and rtc_time64_to_tm().
Cc: pang.xunlei <pang.xunlei@linaro.org>
Cc: Arnd Bergmann <arnd.bergmann@linaro.org>
Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
Fix the checkpatch warning as below:
WARNING: Prefer netdev_err(netdev, ... then dev_err(dev, ... then pr_err(... to printk(KERN_ERR ...
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
This code is under #if 0 and not used.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Bryan Henderson noticed that the "RTC: Fix rtc driver ioctl specific
shortcutting" commit has a small bug: When an ioctl is called with an
invalid command code and the clock driver does not have an "ioctl"
method, the ioctl returns rc 0 instead of -ENOTTY.
This patch fixes the issue.
CC: Bryan Henderson <bryanh@giraffe-data.com>
CC: Gabor Z. Papp <gzp@papp.hu>
Reported-by: Bryan Henderson <bryanh@giraffe-data.com>
This patch re-enables UIE timer/polling emulation for rtc devices
that do not support alarm irqs.
CC: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
CC: Thomas Gleixner <tglx@linutronix.de>
Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Tested-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
Uwe pointed out that my alarm based UIE emulation is not sufficient
to replace the older timer/polling based UIE emulation on devices
where there is no alarm irq. This causes rtc devices without alarms
to return -EINVAL to UIE ioctls. The fix is to re-instate the old
timer/polling method for devices without alarm irqs.
This patch reverts the following commits:
042620a018afcfba1d678062b62e46 - Remove UIE emulation
1daeddd5962acad1bea55e524fc0fa - Cleanup removed UIE emulation declaration
b5cc8ca1c9c3a37eaddf709b2fd3e1 - Remove Kconfig symbol for UIE emulation
The emulation mode will still need to be wired-in with a following
patch before it will work.
Some RTC drivers enable functionality directly via their ioctl method
instead of using the generic ioctl handling code. With the recent
virtualization of the RTC layer, its now important that the generic
layer always be used.
This patch moved the rtc driver ioctl method call to after the generic
ioctl processing is done. This allows hardware specific features or
ioctls to still function, while relying on the generic code for handling
everything else.
This patch on its own may more obviously break rtc drivers that
implement the alarm irq enablement via their ioctl method instead of
implementing the alarm_irq_eanble method. Those drivers will be fixed
in a following patch. Additionaly, those drivers are already likely to
not be functioning reliably without this patch.
CC: Alessandro Zummo <a.zummo@towertech.it>
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Reported-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Tested-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
Since we provide UIE interrupts via a rtc_timer, the old
emulation code can be removed.
LKML Reference: <1290136329-18291-5-git-send-email-john.stultz@linaro.org>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
CC: Richard Cochran <richardcochran@gmail.com>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
The rtc_update_irq() might be called with irqs enabled, if a interrupt
handler was registered without IRQF_DISABLED. Use
spin_lock_irqsave/spin_unlock_irqrestore instead of spin_lock/spin_unlock.
Also update kerneldoc and drivers which do extra work to follow the
current interface spec, as suggestted by David Brownell.
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Cc: David Brownell <david-b@pacbell.net>
Add standard interfaces for alarm/update irqs enabling. Drivers are no
more required to implement equivalent ioctl code as rtc-dev will provide
it.
UIE emulation should now be handled correctly and will work even for those
RTC drivers who cannot be configured to do both UIE and AIE.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
As it is, all instances of ->release() for files that have ->fasync()
need to remember to evict file from fasync lists; forgetting that
creates a hole and we actually have a bunch that *does* forget.
So let's keep our lives simple - let __fput() check FASYNC in
file->f_flags and call ->fasync() there if it's been set. And lose that
crap in ->release() instances - leaving it there is still valid, but we
don't have to bother anymore.
Make the rtc framework consistent about disabling 1/second update IRQs
that may have been activated through the /dev interface, when that /dev
file is closed. (It may have closed because of coredump, etc.) This was
previously done only for emulated update IRQs ... now, do it always.
Also comment the current policy: repeating IRQs (periodic, update) that
userspace enabled will be cleanly disabled, but alarms are left alone.
Such repeating IRQs are a constant and pointless system load.
Update some RTC drivers to remove now-needless release() methods. Most
such methods just enforce that policy. The others all seem to be buggy,
and mistreat in-kernel clients of periodic or alarm IRQs.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Acked-by: Andrew Sharp <andy.sharp@onstor.com>
Cc: Angelo Castello <angelo.castello@st.com>
Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: Paul Mundt <lethal@linux-sh.org>
Cc: Thomas Hommel <thomas.hommel@gefanuc.com>
When userspace uses SIGIO notification and forgets to disable it before
closing file descriptor, rtc->async_queue contains stale pointer to struct
file. When user space enables again SIGIO notification in different
process, kernel dereferences this (poisoned) pointer and crashes.
So disable SIGIO notification on close.
Kernel panic:
(second run of qemu (requires echo 1024 > /sys/class/rtc/rtc0/max_user_freq))
general protection fault: 0000 [1] PREEMPT
CPU 0
Modules linked in: af_packet snd_pcm_oss snd_mixer_oss snd_seq_oss snd_seq_midi_event snd_seq usbhid tuner tea5767 tda8290 tuner_xc2028 xc5000 tda9887 tuner_simple tuner_types mt20xx tea5761 tda9875 uhci_hcd ehci_hcd usbcore bttv snd_via82xx snd_ac97_codec ac97_bus snd_pcm snd_timer ir_common compat_ioctl32 snd_page_alloc videodev v4l1_compat snd_mpu401_uart snd_rawmidi v4l2_common videobuf_dma_sg videobuf_core snd_seq_device snd btcx_risc soundcore tveeprom i2c_viapro
Pid: 5781, comm: qemu-system-x86 Not tainted 2.6.27-rc6 #363
RIP: 0010:[<ffffffff8024f891>] [<ffffffff8024f891>] __lock_acquire+0x3db/0x73f
RSP: 0000:ffffffff80674cb8 EFLAGS: 00010002
RAX: ffff8800224c62f0 RBX: 0000000000000046 RCX: 0000000000000002
RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff8800224c62f0
RBP: ffffffff80674d08 R08: 0000000000000002 R09: 0000000000000001
R10: ffffffff80238941 R11: 0000000000000001 R12: 0000000000000000
R13: 6b6b6b6b6b6b6b6b R14: ffff88003a450080 R15: 0000000000000000
FS: 00007f98b69516f0(0000) GS:ffffffff80623200(0000) knlGS:00000000f7cc86d0
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000a87000 CR3: 0000000022598000 CR4: 00000000000006e0
Process qemu-system-x86 (pid: 5781, threadinfo ffff880028812000, task ffff88003a450080)
Stack: ffffffff80674cf8 0000000180238440 0000000200000002 0000000000000000
ffff8800224c62f0 0000000000000046 0000000000000000 0000000000000002
0000000000000002 0000000000000000 ffffffff80674d68 ffffffff8024fc7a
Call Trace:
<IRQ> [<ffffffff8024fc7a>] lock_acquire+0x85/0xa9
[<ffffffff8029cb62>] ? send_sigio+0x2a/0x184
[<ffffffff80491d1f>] _read_lock+0x3e/0x4a
[<ffffffff8029cb62>] send_sigio+0x2a/0x184
[<ffffffff8024fb97>] ? __lock_acquire+0x6e1/0x73f
[<ffffffff8029cd4d>] ? kill_fasync+0x2c/0x4e
[<ffffffff8029cd10>] __kill_fasync+0x54/0x65
[<ffffffff8029cd5b>] kill_fasync+0x3a/0x4e
[<ffffffff80402896>] rtc_update_irq+0x9c/0xa5
[<ffffffff80404640>] cmos_interrupt+0xae/0xc0
[<ffffffff8025d1c1>] handle_IRQ_event+0x25/0x5a
[<ffffffff8025e5e4>] handle_edge_irq+0xdd/0x123
[<ffffffff8020da34>] do_IRQ+0xe4/0x144
[<ffffffff8020bad6>] ret_from_intr+0x0/0xf
<EOI> [<ffffffff8026fdc2>] ? __alloc_pages_internal+0xe7/0x3ad
[<ffffffff8033fe67>] ? clear_page_c+0x7/0x10
[<ffffffff8026fc10>] ? get_page_from_freelist+0x385/0x450
[<ffffffff80280aac>] ? anon_vma_prepare+0x2e/0xf6
[<ffffffff80279400>] ? handle_mm_fault+0x227/0x6a5
[<ffffffff80494716>] ? do_page_fault+0x494/0x83f
[<ffffffff8049251d>] ? error_exit+0x0/0xa9
Code: cc 41 39 45 28 74 24 e8 5e 1d 0f 00 85 c0 0f 84 6a 03 00 00 83 3d 8f a9 aa 00 00 be 47 03 00 00 0f 84 6a 02 00 00 e9 53 03 00 00 <41> ff 85 38 01 00 00 45 8b be 90 06 00 00 41 83 ff 2f 76 24 e8
RIP [<ffffffff8024f891>] __lock_acquire+0x3db/0x73f
RSP <ffffffff80674cb8>
---[ end trace 431877d860448760 ]---
Kernel panic - not syncing: Aiee, killing interrupt handler!
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: <stable@kernel.org>
With commit 5ad31a575157147b43fa84ef1e21471661653878 ("rtc: remove BKL
for ioctl()"), RTC_UIE_ON ioctl cause double lock on rtc->ops_lock.
The ops_lock must not be held while set_uie() calls rtc_read_time()
which takes the lock. Also clear_uie() does not need ops_lock. This
patch fixes return value of RTC_UIE_OFF ioctl too.
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Revert commit 51a776fa7a7997e726d4a478eda0854c6f9143bd ("rtc: cdev
lock_kernel() pushdown"). The RTC framework does not need BKL
protection.
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
Solves http://bugzilla.kernel.org/show_bug.cgi?id=11127
The old rtc.c driver did it and some drivers (like rtc-sh) do it in their
release function, though they should not -- because they should provide
the irq_set_state op and the rtc framework itself should care about it.
This patch makes it do so.
I am aware that some drivers, like rtc-sh, handle userspace PIE sets in
their ioctl op (instead of having the framework call the op), exporting
the irq_set_state op at the same time. The logic in rtc_irq_set_state
should make sure it doesn't matter and the driver should not need to care
stopping periodic interrupts in its release routine any more.
The correct way, in my opinion, should be this:
1) The driver provides the irq_set_state op and does not care closing the
interrupts in its release op.
2) If the driver does not provide the op and handles PIE in the ioctl op, it's
reponsible for closing them in its release op.
3) Something similar for other IRQs, like UIE -- if there's no in-kernel API
like irq_set_state, handle it in ioctl and release ops. The framework will
be responsible either for everything or for nothing. (This will probably
change later.)
Signed-off-by: Tomas Janousek <tomi@nomi.cz>
It was pointed out that the RTC framework handles its mutex locks oddly
... returning -EBUSY when interrupted. This fixes that by returning the
value of mutex_lock_interruptible() (i.e. -EINTR).
Remove implicit use of BKL in ioctl() from the RTC framework.
Instead, the rtc->ops_lock is used. That's the same lock that already
protects the RTC operations when they're issued through the exported
rtc_*() calls in drivers/rtc/interface.c ... making this a bugfix, not
just a cleanup, since both ioctl calls and set_alarm() need to update IRQ
enable flags and that implies a common lock (which RTC drivers as a rule
do not provide on their own).
A new comment at the declaration of "struct rtc_class_ops" summarizes
current locking rules. It's not clear to me that the exceptions listed
there should exist ... if not, those are pre-existing problems which can
be fixed in a patch that doesn't relate to BKL removal.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Start making the rtc-cmos alarm act more like a oneshot alarm by disabling
that alarm after its IRQ fires. (ACPI hooks are also needed.)
The Linux RTC framework has previously been a bit vague in this area, but
any other behavior is problematic and not very portable. RTCs with full
YYYY-MM-DD HH:MM[:SS] alarms won't have a problem here. Only ones with
partial match criteria, with the most visible example being the PC RTC, get
confused. (Because the criteria will match repeatedly.)
Update comments relating to that oneshot behavior and timezone handling.
(Timezones are another issue that's mostly visible with rtc-cmos. That's
because PCs often dual-boot MS-Windows, which likes its RTC to match local
wall-clock time instead of UTC.)
We must make sure that the RTC_DEV_BUSY flag has proper lock semantics,
i.e. that the RTC_DEV_BUSY stores clearing the flag don't get reordered
before the preceeding stores and loads and vice versa.
Spotted by Nick Piggin.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
RTC code is using mutex to assure exclusive access to /dev/rtc. This is
however wrong usage, as it leaves the mutex locked when returning into
userspace, which is unacceptable.
Convert rtc->char_lock into bit operation.
drivers/char/rtc.c allowed RTC_PIE_ON ioctls for non-root users, as long as
the current interval (set via RTC_IRQP_SET) is <= max_user_freq. Allow
RTC_PIE_ON under the same conditions when /dev/rtc* is handled by the rtc
subsystem.
Signed-off-by: Bryan Kadzban <bryan@kdzbn.homelinux.net>
In rtc-dev.c, when a rtc device is opened, file->private_data is already
attached with the rtc device pointer, so there is no need to call
to_rtc_device() to convert file->private_data to a rtc device pointer.
Signed-off-by: Mark Zhan <rongkai.zhan@windriver.com>
Add kernel/kernel and kernel/user locking for the periodic irq feature of
the rtc class.
PIE ioctls are also supported.
Prevent the RTC driver from returning ENOIOCTLCMD to userspace.
Signed-off-by: Thomas Hommel <thomas.hommel@gefanuc.com>
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com>
Cc: Haavard Skinnemoen <hskinnemoen@atmel.com>
This fixes a common glitch in how RTC drivers handle two "set alarm" modes,
by getting rid of the surprising/hidden one that was rarely implemented
correctly (and which could expose nonportable hardware-specific behavior).
The glitch comes from the /dev/rtcX logic implementing the legacy
RTC_ALM_SET (limited to 24 hours, needing RTC_AIE_ON) ioctl on top of the
RTC driver call providing access to the newer RTC_WKALM_SET (without those
limitations) by initializing the day/month/year fields to be invalid ...
that second mode.
Now, since few RTC drivers check those fields, and most hardware misbehaves
when faced with invalid date fields, many RTC drivers will set bogus alarm
times on those RTC_ALM_SET code paths. (Several in-tree drivers have that
issue, and I also noticed it with code reviews on several new RTC drivers.)
This patch ensures that RTC drivers never see such invalid alarm fields, by
moving some logic out of rtc-omap into the RTC_ALM_SET code and adding an
explicit check (which will prevent the issue on other code paths).
Cc: Scott Wood <scottwood@freescale.com>
Fix a goof in the revised classdev support for RTCs: make sure the /dev
node info is ready before the device is registered, not after. Otherwise
the /sys/class/rtc/rtcN/dev attribute won't be created and then udev won't
have the information it needs to create the /dev/rtcN node.
Finish converting the RTC framework so it no longer uses class_device.
Acked-By: Alessandro Zummo <a.zummo@towertech.it>
This patch removes class_device from the programming interface that the RTC
framework exposes to the rest of the kernel. Now an rtc_device is passed,
which is more type-safe and streamlines all the relevant code.
This simplifies the /dev support by removing a superfluous class_device (the
/sys/class/rtc-dev stuff) and the class_interface that hooks it into the rtc
core. Accordingly, if it's configured then /dev support is now part of the
RTC core, and is never a separate module.
It's another step towards being able to remove "struct class_device".
[bunk@stusta.de: drivers/rtc/rtc-dev.c should #include "rtc-core.h"]
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
This removes some syslog spam as RTC drivers register; debug messages
shouldn't come out at "info" level.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/infiniband/core/iwcm.c
drivers/net/chelsio/cxgb2.c
drivers/net/wireless/bcm43xx/bcm43xx_main.c
drivers/net/wireless/prism54/islpci_eth.c
drivers/usb/core/hub.h
drivers/usb/input/hid-core.c
net/core/netpoll.c
Fix up merge failures with Linus's head and fix new compilation failures.
Signed-Off-By: David Howells <dhowells@redhat.com>
I got a lockdep warning when running "rtctest" so I though it'd be good
to see what was up.
- The warning was for rtc->irq_task_lock, gotten from rtc_update_irq()
by irq handlerss ... but in a handful of other cases, grabbed without
blocking IRQs.
- Some callers to rtc_update_irq() were not ensuring IRQs were blocked,
yet the routine expects that; make sure all callers block IRQs.
It would appear that RTC API tests haven't been part of anyone's kernel
regression test suite recently, at least not with lockdep running.
The RTC framework has an irq_set_freq() method that should be used to manage
the periodic IRQ frequency, but the current ioctl logic doesn't know how to do
that. This patch teaches it how.
This means that drivers implementing irq_set_freq() will automatically support
RTC_IRQP_{READ,SET} ioctls; that logic doesn't need duplication within the
driver.
[akpm@osdl.org: export rtc_irq_set_freq]
Fix up for make allyesconfig.
Update RTC framework so that drivers can constify their method tables, moving
them from ".data" to ".rodata". Then update the drivers.
This makes RTC core components use "subsys_init" instead of "module_init", as
appropriate for subsystem infrastructure. This is mostly useful for
statically linking drivers in other parts of the tree that may provide an RTC
interface as a secondary functionality (e.g. part of a multifunction chip);
they won't need to worry so much about drivers/Makefile link order.
Acked-by: Oleg Verych <olecom@flower.upol.cz>
If cdev_add() fails there is no good reason to call cdev_del().
Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de>
Cc: Dmitry Torokhov <dtor@mail.ru>
Centralize CAP_SYS_XXX checks to avoid duplicate code and missing checks in
the drivers.
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp>
Import genrtc's RTC UIE emulation (CONFIG_GEN_RTC_X) to rtc-dev driver with
slight adjustments/refinements. This makes UIE-less rtc drivers work
better with programs doing read/poll on /dev/rtc, such as hwclock. This
emulation should not harm rtc drivers with UIE support, since
rtc_dev_ioctl() calls underlaying rtc driver's ioctl() first.
