path: root/drivers/rtc/rtc-ds1685.c
2016-07-09rtc: simplify implementations of read_alarmUwe Kleine-König
Since commit d68778b80dd7 ("rtc: initialize output parameter for read alarm to "uninitialized"") there is no need to explicitly set unsupported members to -1. So drop the respective assignments from drivers. Signed-off-by: Uwe Kleine-König <uwe@kleine-koenig.org> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-06-04rtc: ds1685: correct day of month checkingHeinrich Schuchardt
The day of month is checked in ds1685_rtc_read_alarm and ds1685_rtc_set_alarm. Multiple errors exist in the day of month check. Operator ! has a higher priority than &&. (!(mday >= 1) && (mday <= 31)) is false for mday == 32. When verifying the day of month the binary and the BCD mode have to be considered. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-05-20rtc: ds1685: actually spin forever in poweroff pathJosh Poimboeuf
objtool reports the following warning: drivers/rtc/rtc-ds1685.o: warning: objtool: ds1685_rtc_poweroff() falls through to next function ds1685_rtc_work_queue() Similar to commit 361c6ed6b153 ("rtc: ds1685: actually spin forever in poweroff error path"), there's another unreachable() annotation which is actually reachable, which we missed the first time. Actually spin forever to be consistent with the comment and to make the unreachable() annotation guaranteed to be unreachable. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-05-20rtc: remove useless DRV_VERSIONAlexandre Belloni
Many drivers are defining a DRV_VERSION. This is often only used for MODULE_VERSION and sometimes to print an info message at probe time. This is kind of pointless as they are all versionned with the kernel anyway. Also the core will print a message when a new rtc is found. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-03-14rtc: ds1685: actually spin forever in poweroff error pathJosh Poimboeuf
objtool reports the following warnings: drivers/rtc/rtc-ds1685.o: warning: objtool: ds1685_rtc_work_queue()+0x0: duplicate frame pointer save drivers/rtc/rtc-ds1685.o: warning: objtool: ds1685_rtc_work_queue()+0x3: duplicate frame pointer setup drivers/rtc/rtc-ds1685.o: warning: objtool: ds1685_rtc_work_queue()+0x0: frame pointer state mismatch The warning message needs to be improved, but what it really means in this case is that ds1685_rtc_poweroff() has a possible code path where it can actually fall through to the next function in the object code, ds1685_rtc_work_queue(). The bug is caused by the use of the unreachable() macro in a place which is actually reachable. That causes gcc to assume that the printk() immediately before the unreachable() macro never returns, when in fact it does. So gcc places the printk() at the very end of the function's object code. When the printk() returns, the next function starts executing. The surrounding comment and printk message state that the code should spin forever, which explains the unreachable() statement. However the actual spin code is missing. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-03-14rtc: ds1685: passing bogus values to irq_restoreDan Carpenter
We call spin_lock_irqrestore with "flags" set to zero instead of to the value from spin_lock_irqsave(). Fixes: aaaf5fbf56f1 ('rtc: add driver for DS1685 family of real time clocks') Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-01-11rtc: ds1685: don't try to micromanage sysfs output sizeRasmus Villemoes
...and don't do it wrong. "not ok or N/A" has length 13. Add the trailing newline, and the snprintf return value will be 14. However, we lied to snprintf and told it that only 13 bytes were available. Hence snprintf has only written "not ok or N/" and a trailing '\0' to the buffer. Next we continue lying, this time to the upper sysfs layer, claiming that we wrote 14 meaningful bytes to the buffer. That'll make the upper layer copy "not ok or N/" plus two nul bytes to user space (one nul byte from snprintf, the other since sysfs takes care to clear the buffer before giving it to the ->show method). In the other cases, the claimed buffer size is closer to sufficient, but we'll still get a nul byte instead of a newline written to user space. There's absolutely no reason to try to predict the output size, and there's plenty of room in the buffer, so just use sprintf. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-01-11rtc: use %ph for short hex dumpsRasmus Villemoes
This makes the generated code slightly smaller. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05rtc: ds1685: Use module_platform_driverVaishali Thakkar
Use module_platform_driver for drivers whose init and exit functions only register and unregister, respectively. A simplified version of the Coccinelle semantic patch that performs this transformation is as follows: @a@ identifier f, x; @@ -static f(...) { return platform_driver_register(&x); } @b depends on a@ identifier e, a.x; @@ -static e(...) { platform_driver_unregister(&x); } @c depends on a && b@ identifier a.f; declarer name module_init; @@ -module_init(f); @d depends on a && b && c@ identifier b.e, a.x; declarer name module_exit; declarer name module_platform_driver; @@ -module_exit(e); +module_platform_driver(x); Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-04-17rtc: use more standard kernel logging stylesJoe Perches
Neaten the logging a bit by adding #define pr_fmt Miscellanea: o Remove __FILE__/__func__ uses o Coalesce formats adding missing spaces o Align arguments o (rtc-cmos) Integrated 2 consecutive messages Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Joshua Kinard <kumba@gentoo.org> Cc: Chanwoo Choi <cw00.choi@samsung.com> Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Tested-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Aaro Koskinen <aaro.koskinen@iki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17drivers/rtc/rtc-ds1685.c: fix sparse warningsJoshua Kinard
Fix two minor sparse warnings: CHECK drivers/rtc/rtc-ds1685.c drivers/rtc/rtc-ds1685.c:2178:1: warning: function 'ds1685_rtc_poweroff' with external linkage has definition drivers/rtc/rtc-ds1685.c:802:23: warning: Using plain integer as NULL pointer Fixes: aaaf5fbf56f1 ("rtc: add driver for DS1685 family of real time clocks") Signed-off-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-17drivers/rtc/rtc-ds1685.c: remove .owner assignment from platform_driverJoshua Kinard
The rtc driver core now sets the platform_driver 'owner' property, so remove the assignment from the DS1685 driver. Fixes: aaaf5fbf56f1: "rtc: add driver for DS1685 family of real time clocks" Signed-off-by: Joshua Kinard <kumba@gentoo.org> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28drivers/rtc/rtc-ds1685.c: fix conditional in ↵Joshua Kinard
ds1685_rtc_sysfs_time_regs_{show,store} Fix a conditional statement checking for NULL in both ds1685_rtc_sysfs_time_regs_show and ds1685_rtc_sysfs_time_regs_store that was using a logical AND when it should be using a logical OR so that we fail out of the function properly if the condition ever evaluates to true. Fixes: aaaf5fbf56f1 ("rtc: add driver for DS1685 family of real time clocks") Signed-off-by: Joshua Kinard <kumba@gentoo.org> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28rtc: ds1685: remove superfluous checks for out-of-range u8 valuesGeert Uytterhoeven
drivers/rtc/rtc-ds1685.c: In function `ds1685_rtc_read_alarm': drivers/rtc/rtc-ds1685.c:402: warning: comparison is always true due to limited range of data type drivers/rtc/rtc-ds1685.c:409: warning: comparison is always true due to limited range of data type drivers/rtc/rtc-ds1685.c:416: warning: comparison is always true due to limited range of data type drivers/rtc/rtc-ds1685.c: In function `ds1685_rtc_set_alarm': drivers/rtc/rtc-ds1685.c:475: warning: comparison is always true due to limited range of data type drivers/rtc/rtc-ds1685.c:478: warning: comparison is always true due to limited range of data type drivers/rtc/rtc-ds1685.c:481: warning: comparison is always true due to limited range of data type u8 cannot contain a value larger than 0xff, hence drop the checks. Wrapping the checks in unlikely() indicated some sense of humor, though ;-) Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Joshua Kinard <kumba@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-28rtc: ds1685: fix ds1685_rtc_alarm_irq_enable build errorArnd Bergmann
The newly added ds1685 driver causes a build error when enabled without CONFIG_RTC_INTF_DEV: drivers/rtc/rtc-ds1685.c:919:22: error: 'ds1685_rtc_alarm_irq_enable' undeclared here (not in a function) .alarm_irq_enable = ds1685_rtc_alarm_irq_enable, Apparently the driver was incorrectly changed to reflect the interface change from 16380c153a69c ("RTC: Convert rtc drivers to use the alarm_irq_enable method"), which removed the respective #ifdef from all other rtc drivers. This does the same change that was merged for the other drivers before and removes the #ifdef, allowing the interrupts to be enabled through the in-kernel rtc interface independent of the existence of /dev/rtc. Fixes: aaaf5fbf56f ("rtc: add driver for DS1685 family of real time clocks") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Joshua Kinard <kumba@gentoo.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-16rtc: add driver for DS1685 family of real time clocksJoshua Kinard
This adds a driver for the Dallas/Maxim DS1685-family of RTC chips. It supports the DS1685/DS1687, DS1688/DS1691, DS1689/DS1693, DS17285/DS17287, DS17485/DS17487, and DS17885/DS17887 RTC chips. These chips are commonly found in SGI O2 and SGI Octane systems. It was originally derived from a driver patch submitted by Matthias Fuchs many years ago for use in EPPC-405-UC modules, which also used these RTCs. In addition to the time-keeping functions, this RTC also handles the shutdown mechanism of the O2 and Octane and acts as a partial NVRAM for the boot PROMS in these systems. Verified on both an SGI O2 and an SGI Octane. Signed-off-by: Joshua Kinard <kumba@gentoo.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
