The Linux i2c layer has functions to execute common SMBUS/I2C
transactions. The register access code here is identical to the I2C
read/write block data routines.
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Alexandre Belloni <alexandre.belloni@bootlin.com>
Signed-off-by: Trent Piepho <tpiepho@impinj.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
The core header file is reserved for the core, stop including it.
Also reorder includes alphabetically.
Use rtc_add_group to add the common sysfs group to avoid a possible race
condition.
[Denis.Osterland@diehl.com: use to_i2c_client(dev->parent)]
Signed-off-by: Denis Osterland <Denis.Osterland@diehl.com>
The move of atrim, dtrim usr sysfs properties from i2c device
to rtc device require to access them via dev->parent.
This patch also aligns timestamp0.
Add support to disable event in pull-up.
Add support for "evdet" named interrupt source.
The check if i2c client irq matches evdet irq is needed
for the case that there is only one interrupt named "evdet".
In this case i2c client code handles this like an unnamed
interrupt souce and assigns the value.
Reviewed-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
We add support for the ISL1219 chip that got an integrated tamper
detection function. This patch implements the feature by adding
an additional timestamp0 file to sysfs device path.
This file contains seconds since epoch, if an event occurred,
or is empty, if none occurred.
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
Fix possible race condition.
It is not allowed to return with an error code after RTC is registered.
Suggested-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
The interrupt handler got enabled very early. If the interrupt cause is
triggering immediately before the context is fully prepared. This can
lead to undefined behaviour. Therefor we move the interrupt enable code
to the end of the probe function.
After successful
sr = isl1208_i2c_set_regs(client, 0, regs, ISL1208_RTC_SECTION_LEN);
sr will be 0.
As a result
sr = i2c_smbus_write_byte_data(client, ISL1208_REG_SR,
sr & ~ISL1208_REG_SR_WRTC);
is equal to
sr = i2c_smbus_write_byte_data(client, ISL1208_REG_SR, 0);
which clears all flags in SR.
Add an additional read of SR, to have value of SR in sr again.
The driver doesn't have a struct of_device_id table but supported devices
are registered via Device Trees. This is working on the assumption that a
I2C device registered via OF will always match a legacy I2C device ID and
that the MODALIAS reported will always be of the form i2c:<device>.
But this could change in the future so the correct approach is to have an
OF device ID table if the devices are registered via OF.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Many drivers are defining a DRV_VERSION. This is often only used for
MODULE_VERSION and sometimes to print an info message at probe time. This
is kind of pointless as they are all versionned with the kernel anyway.
Also the core will print a message when a new rtc is found.
Since commit 1c6c69525b40eb76de8adf039409722015927dc3 ("genirq: Reject
bogus threaded irq requests") threaded IRQs without a primary handler
need to be requested with IRQF_ONESHOT, otherwise the request will fail.
So pass the IRQF_ONESHOT flag in this case.
The semantic patch that makes this change is available
in scripts/coccinelle/misc/irqf_oneshot.cocci
isl1208_i2c_set_alarm() uses deprecated rtc_tm_to_time(),
which will overflow in year 2106 on 32-bit machines.
This patch solves this by:
- Replacing rtc_tm_to_time() with rtc_tm_sub()
Cc: Herbert Valerio Riedel <hvr@gnu.org>
Signed-off-by: Xunlei Pang <pang.xunlei@linaro.org>
devm_* APIs are device managed and make code simpler.
Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org>
Cc: Jingoo Han <jg1.han@samsung.com>
i2c_smbus_read_byte_data() returns negative errno on failure. Return the
value obtained from it directly.
Previously the alarm event was not propagated into the RTC subsystem.
By adding a call to rtc_update_irq, this fixes a timeout problem with
the hwclock utility.
Signed-off-by: Jan Luebbe <jlu@pengutronix.de>
Cc: <stable@vger.kernel.org>
"Whether" is misspelled in various comments across the tree; this
fixes them. No code changes.
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Convert the struct i2c_msg initialization to C99 format. This makes
maintaining and editing the code simpler. Also helps once other fields
like transferred are added in future.
Signed-off-by: Shubhrajyoti D <shubhrajyoti@ti.com>
Reviewed-by: Felipe Balbi <balbi@ti.com>
The ISL1218 chip is identical to the ISL1208, except that it has 6
additional user-storage registers. This patch does not enable access to
those additional registers, but only adds the chip name to the list.
Signed-off-by: Ben Gardner <gardner.ben@gmail.com>
Factor out some boilerplate code for i2c driver registration into
module_i2c_driver.
Cc: Piotr Ziecik <kosmo@semihalf.com>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Cc: Mike Rapoport <mike@compulab.co.il>
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Roman Fietze <roman.fietze@telemotive.de>
Cc: Alexander Bigga <ab@mycable.de>
Cc: Dale Farnsworth <dale@farnsworth.org>
Cc: Gregory Hermant <gregory.hermant@calao-systems.com>
Cc: Wolfgang Grandegger <wg@grandegger.com>
Cc: Martyn Welch <martyn.welch@ge.com>
Cc: Byron Bradley <byron.bbradley@gmail.com>
Add alarm/wakeup support to rtc isl1208 driver
Signed-off-by: Ryan Mallon <ryan@bluewatersys.com>
Instead of individually creating and removing the sysfs device attribute
files, wrap them in an attribute_group and use
sysfs_{create/remove}_group.
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
This patch for the rtc-isl1208 driver makes it reject invalid dates.
Signed-off-by: Chris Elston <celston@katalix.com>
[a.zummo@towertech.it: added comment explaining the check]
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: Hebert Valerio Riedel <hvr@gnu.org>
Cc: David Brownell <david-b@pacbell.net>
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of
the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: Hartley Sweeten <hartleys@visionengravers.com>
Based on earlier work by Jon Smirl and Jochen Friedrich.
Update most new-style i2c drivers to use standard module aliasing
instead of the old driver_name/type driver matching scheme. I've
left the video drivers apart (except for SoC camera drivers) as
they're a bit more diffcult to deal with, they'll have their own
patch later.
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Jochen Friedrich <jochen@scram.de>
This patch allows new-style i2c chip drivers to have alias names using
the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this
point, the old i2c driver binding scheme (driver_name/type) is still
supported.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it>
Update RTC framework so that drivers can constify their method tables, moving
them from ".data" to ".rodata". Then update the drivers.
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Add support for the I2C-attached Intersil ISL1208 RTC chip.
[akpm@osdl.org: cleanups, fixlets]
Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org>
