path: root/drivers/rtc/rtc-lib.c
2008-05-13rtc: rtc_time_to_tm: use unsigned arithmeticMaciej W. Rozycki
The input argument to rtc_time_to_tm() is unsigned as well as are members of the output structure. However signed arithmetic is used within for calculations leading to incorrect results for input values outside the signed positive range. If this happens the time of day returned is out of range. Found the problem when fiddling with the RTC and the driver where year was set to an unexpectedly large value like 2070, e.g.: rtc0: setting system clock to 2070-01-01 1193046:71582832:26 UTC (3155760954) while it should be: rtc0: setting system clock to 2070-01-01 00:15:54 UTC (3155760954) Changing types to unsigned fixes the problem. [akpm@linux-foundation.org: remove old-fashioned `register' keyword] Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08revert "rtc: Add rtc_merge_alarm()"Andrew Morton
David says "884b4aaaa242a2db8c8252796f0118164a680ab5 should be reverted. It added an rtc_merge_alarm() call to the 2.6.20 kernel, which hasn't yet been used by any in-tree driver; this patch obviates the need for that call, and uses a more robust approach." Cc: Scott Wood <scottwood@freescale.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] rtc: Add rtc_merge_alarm()Scott Wood
Add rtc_merge_alarm(), which can be used by rtc drivers to turn a partially specified alarm expiry (i.e. most significant fields set to -1, as with the RTC_ALM_SET ioctl()) into a fully specified expiry. If the most significant specified field is earlier than the current time, the least significant unspecified field is incremented. Signed-off-by: Scott Wood <scottwood@freescale.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class: error checksDavid Brownell
The rtc_is_valid_tm() routine needs to treat some of the fields it checks as unsigned, to prevent wrongly accepting invalid rtc_time structs; this is the same approach used elsewhere in the RTC code for such tests. Conversely, rtc_proc_show() is missing one invalid-day-of-month test that rtc_is_valid_tm() makes: there is no day zero. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] RTC: Add rtc_year_days() to calculate tm_ydayAndrew Victor
RTC: Add exported function rtc_year_days() to calculate the tm_yday value. Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC Subsystem: library functionsAlessandro Zummo
RTC and date/time related functions. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
