path: root/drivers/rtc/rtc-m41t93.c
2013-07-03drivers/rtc/rtc-m41t93.c: remove empty functionSachin Kamat
After the switch to devm_* functions and the removal of rtc_device_unregister(), the 'remove' function does not do anything. Delete it. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Nikolaus Voss <n.voss@weinmann.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-m41t93: use spi_set_drvdata()Jingoo Han
Use the wrapper functions for getting and setting the driver data using spi_device instead of using dev_{get|set}_drvdata with &spi->dev, so we can directly pass a struct spi_device. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-m41t93: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-29drivers/rtc/rtc-m41t93.c: don't let get_time() reset M41T93_FLAG_OFNikolaus Voss
If the rtc reports the time might be invalid due to oscillator failure, M41T93_FLAG_OF flag must not be reset by get_time() as the read operation doesn't make the time valid. Without this patch, only the first get_time() reported an invalid time, the second get_time() reported a valid time althought the reported time is probably wrong due to oscillator failure. Instead of resetting in get_time(), with this patch M41T93_FLAG_OF is reset in set_time() when a valid time is to be written. Signed-off-by: Nikolaus Voss <n.voss@weinmann.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23rtc: convert rtc spi drivers to module_spi_driverAxel Lin
Factor out some boilerplate code for spi driver registration into module_spi_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Mark Jackson <mpfj@mimc.co.uk> Cc: Dennis Aberilla <denzzzhome@yahoo.com> Cc: Nikolaus Voss <n.voss@weinmann.de> Cc: "Kim B. Heino" <Kim.Heino@bluegiga.com> Cc: Raphael Assenat <raph@raphnet.net> Cc: Chris Verges <chrisv@cyberswitching.com> Cc: Magnus Damm <damm@opensource.se> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10drivers/rtc/: remove redundant spi driver bus initializationLars-Peter Clausen
In ancient times it was necessary to manually initialize the bus field of an spi_driver to spi_bus_type. These days this is done in spi_driver_register(), so we can drop the manual assignment. The patch was generated using the following coccinelle semantic patch: // <smpl> @@ identifier _driver; @@ struct spi_driver _driver = { .driver = { - .bus = &spi_bus_type, }, }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-08spi/rtc-m41t93: Use spi_get_drvdata() for SPI devicesGeert Uytterhoeven
One new offender detected by the recently increased type checking in platform_get_drvdata(): drivers/rtc/rtc-m41t93.c: In function ‘m41t93_remove’: drivers/rtc/rtc-m41t93.c:192: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type Use spi_get_drvdata() instead of platform_get_drvdata(), cfr. commit 42fea15d6dc410e62dac6a764142045280624a5b ("spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devices") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-05-26rtc: add basic support for ST M41T93 SPI RTCVoss, Nikolaus
Add basic support for ST m41t93 SPI RTCs. Tested with factory-new and with "run-in" species with and without backup batteries. Signed-off-by: Nikolaus Voss <n.voss@weinmann.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
