path: root/drivers/rtc/rtc-m41t94.c
2012-03-23rtc: convert rtc spi drivers to module_spi_driverAxel Lin
Factor out some boilerplate code for spi driver registration into module_spi_driver. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Mark Jackson <mpfj@mimc.co.uk> Cc: Dennis Aberilla <denzzzhome@yahoo.com> Cc: Nikolaus Voss <n.voss@weinmann.de> Cc: "Kim B. Heino" <Kim.Heino@bluegiga.com> Cc: Raphael Assenat <raph@raphnet.net> Cc: Chris Verges <chrisv@cyberswitching.com> Cc: Magnus Damm <damm@opensource.se> Cc: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10drivers/rtc/: remove redundant spi driver bus initializationLars-Peter Clausen
In ancient times it was necessary to manually initialize the bus field of an spi_driver to spi_bus_type. These days this is done in spi_driver_register(), so we can drop the manual assignment. The patch was generated using the following coccinelle semantic patch: // <smpl> @@ identifier _driver; @@ struct spi_driver _driver = { .driver = { - .bus = &spi_bus_type, }, }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17spi/rtc-{ds1390,ds3234,m41t94}: Use spi_get_drvdata() for SPI devicesGeert Uytterhoeven
The recently increased type checking in platform_get_drvdata() reveals a few offenders: drivers/rtc/rtc-ds1390.c:161: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type drivers/rtc/rtc-ds3234.c:161: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type drivers/rtc/rtc-m41t94.c:139: warning: passing argument 1 of ‘platform_get_drvdata’ from incompatible pointer type Use spi_get_drvdata() instead of platform_get_drvdata(). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-09-23spi: prefix modalias with "spi:"Anton Vorontsov
This makes it consistent with other buses (platform, i2c, vio, ...). I'm not sure why we use the prefixes, but there must be a reason. This was easy enough to do it, and I did it. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: "John W. Linville" <linville@tuxdriver.com> Acked-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20drivers/rtc/: use bcd2bin/bin2bcdAdrian Bunk
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24rtc: add support for ST M41T94 SPI RTCKim B. Heino
This patch adds kernel driver for M41T94 RTC chip connected via SPI. I've tested it on two different AT91-based hardwares. This is third revision of the patch: some comments made by Alessandro Zummo fixed. Revision two added support for century bit and fixes. Signed-off-by: Kim B. Heino <Kim.Heino@bluegiga.com> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
