path: root/drivers/rtc/rtc-mpc5121.c
2012-04-26rtc: Fix possible null pointer dereference in rtc-mpc5121.cJohn Stultz
Mark Loard pointed out: "For example, this beauty from rtc-mpc5121.c in the same update: ... rtc->rtc = rtc_device_register("mpc5200-rtc", &op->dev, &mpc5200_rtc_ops, THIS_MODULE); ... rtc->rtc->uie_unsupported = 1; // <<<< Ooops NULL pointer >>>> if (IS_ERR(rtc->rtc)) { // <<<< this needs to be earlier >>>> err = PTR_ERR(rtc->rtc); goto out_free_irq; } ..." This patch moves setting the uie_unsupported flag to after we validate the rtc->rtc pointer to resolve this. Reported by: Mark Lord <kernel@teksavvy.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Link: http://lkml.kernel.org/r/1335300215-21427-1-git-send-email-john.stultz@linaro.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-03-29Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer core updates from Thomas Gleixner. * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ia64: vsyscall: Add missing paranthesis alarmtimer: Don't call rtc_timer_init() when CONFIG_RTC_CLASS=n x86: vdso: Put declaration before code x86-64: Inline vdso clock_gettime helpers x86-64: Simplify and optimize vdso clock_gettime monotonic variants kernel-time: fix s/then/than/ spelling errors time: remove no_sync_cmos_clock time: Avoid scary backtraces when warning of > 11% adj alarmtimer: Make sure we initialize the rtctimer ntp: Fix leap-second hrtimer livelock x86, tsc: Skip refined tsc calibration on systems with reliable TSC rtc: Provide flag for rtc devices that don't support UIE ia64: vsyscall: Use seqcount instead of seqlock x86: vdso: Use seqcount instead of seqlock x86: vdso: Remove bogus locking in update_vsyscall_tz() time: Remove bogus comments time: Fix change_clocksource locking time: x86: Fix race switching from vsyscall to non-vsyscall clock
2012-03-23drivers/rtc: remove IRQF_DISABLEDYong Zhang
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts disabled") we run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled - see commit b738a50a2026 ("genirq: warn when handler enables interrupts"). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-15rtc: Provide flag for rtc devices that don't support UIEJohn Stultz
Richard Weinberger noticed that on some RTC hardware that doesn't support UIE mode, due to coarse granular alarms (like 1minute resolution), the current virtualized RTC support doesn't properly error out when UIE is enabled. Instead the current code queues an alarm for the next second, but it won't fire until up to a miniute later. This patch provides a generic way to flag this sort of hardware and fixes the issue on the mpc5121 where Richard noticed the problem. CC: stable@vger.kernel.org Reported-by: Richard Weinberger <richard@nod.at> Tested-by: Richard Weinberger <richard@nod.at> Signed-off-by: John Stultz <john.stultz@linaro.org>
2012-01-10rtc: convert drivers/rtc/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/rtc/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Ben Dooks <ben@simtec.co.uk> Cc: John Stultz <john.stultz@linaro.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200Dmitry Eremin-Solenikov
MPC5200B contains a limited version of RTC from MPC5121. Add support for the RTC on that CPU. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Anatolij Gustschin <agust@denx.de> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-09RTC: Cleanup rtc_class_ops->update_irq_enable()John Stultz
Now that the generic code handles UIE mode irqs via periodic alarm interrupts, no one calls the rtc_class_ops->update_irq_enable() method anymore. This patch removes the driver hooks and implementations of update_irq_enable if no one else is calling it. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-28dt: Eliminate of_platform_{,un}register_driverGrant Likely
Final step to eliminate of_platform_bus_type. They're all just platform drivers now. v2: fix type in pasemi_nand.c (thanks to Stephen Rothwell) Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-06-02of/rtc: rtc-mpc5121.c: Fix build failuresGrant Likely
Fixes build errors caused by the: - OF device_node pointer being moved into struct device - removal of the match_table field from struct of_platform_driver Signed-off-by: Grant Likely <grant.likely@secretlab.ca> CC: Paul Gortmaker <p_gortmaker@yahoo.com> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Wolfgang Denk <wd@denx.de> CC: Tejun Heo <tj@kernel.org> CC: Anatolij Gustschin <agust@denx.de> CC: rtc-linux@googlegroups.com CC: devicetree-discuss@lists.ozlabs.org
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-16rtc: Add MPC5121 Real time clock driverAnatolij Gustschin
Add support for MPC5121 real time clock module. Signed-off-by: John Rigby <jcrigby@gmail.com> Signed-off-by: Piotr Ziecik <kosmo@semihalf.com> Signed-off-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
