path: root/drivers/rtc/rtc-mrst.c
2011-04-07rtc, x86/mrst/vrtc: Fix boot crash in rtc_read_alarm()Feng Tang
Commit f44f7f96a20 ("RTC: Initialize kernel state from RTC") caused a boot regression on the MRST platform. The reason is that rtc_device_register() calls rtc_read_alarm() after that change, which function does not have all driver data set up yet. The rtc-mrst driver needs to call dev_set_drvdata() before rtc_device_register() gets called. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: John Stultz <john.stultz@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1302140384-27571-1-git-send-email-feng.tang@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-04rtc-mrst: Fix section typesMajor Lee
Fix the following section mismatch warning. WARNING: drivers/rtc/built-in.o(.data+0xa0): Section mismatch in reference from the variable vrtc_mrst_platform_driver to the function .init.text:vrtc_mrst_platform_probe() The variable vrtc_mrst_platform_driver references the function __init vrtc_mrst_platform_probe() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Signed-off-by: Major Lee <major_lee@wistron.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-23Merge branch 'linus' into x86/platformThomas Gleixner
Reason: Import mainline device tree changes on which further patches depend on or conflict. Trivial conflict in: drivers/spi/pxa2xx_spi_pci.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-14mrst/vrtc: Avoid using cmos rtc opsFeng Tang
If we don't assign Moorestown specific wallclock init and ops function the rtc/persisent clock code will use cmos rtc for access, this will crash Moorestown in that the ioports are not present. Also in vrtc driver, should avoid using cmos access to check UIP status. [feng.tang@intel.com: use set_fixmap_offset_nocache() to simplify code] Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-03RTC: Convert rtc drivers to use the alarm_irq_enable methodJohn Stultz
Some rtc drivers use the ioctl method instead of the alarm_irq_enable method for enabling alarm interupts. With the new virtualized RTC rework, its important for drivers to use the alarm_irq_enable instead. This patch converts the drivers that use the AIE ioctl method to use the alarm_irq_enable method. Other ioctl cmds are left untouched. I have not been able to test or even compile most of these drivers. Any help to make sure this change is correct would be appreciated! CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Reported-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Tested-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-11-17x86, mrst: Add explanation for using 1960 as the year offset for vrtcFeng Tang
Explain the reason for the apparently odd choice of year offset so we don't get more questions about it. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> LKML-Reference: <20101117121050.9998.89348.stgit@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-11-11rtc: Add drivers/rtc/rtc-mrst.cFeng Tang
Provide the standard kernel rtc driver interface on top of the vrtc layer added in the previous patch. Signed-off-by: Feng Tang <feng.tang@intel.com> LKML-Reference: <20101110172911.3311.20593.stgit@localhost.localdomain> [Fixed swapped arguments on IPC] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> [Cleaned up and the device creation moved to arch/x86/platform] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
