path: root/drivers/rtc/rtc-mrst.c
2015-04-15rtc: remove use of seq_printf return valueJoe Perches
The seq_printf return value, because it's frequently misused, will eventually be converted to void. See: commit 1f33c41c03da ("seq_file: Rename seq_overflow() to seq_has_overflowed() and make public") Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-03-25drivers/rtc/rtc-mrst: fix suspend/resumeLars-Peter Clausen
The Moorestown RTC driver implements suspend and resume callbacks and assigns them to the suspend and resume fields of the device_driver struct. These callbacks are never actually called by anything though. Modify the driver to properly use dev_pm_ops so that the suspend and resume functions are actually executed upon suspend/resume. [akpm@linux-foundation.org: device_driver.name is const char *] Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Feng Tang <feng.tang@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13drivers/rtc/rtc-mrst.c: remove redundant dev_set_drvdataSachin Kamat
Driver core sets the driver data to NULL upon device_release or on probe failure. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-17intel_mid: Renamed *mrst* to *intel_mid*Kuppuswamy Sathyanarayanan
Following files contains code that is common to all intel mid soc's. So renamed them as below. mrst/mrst.c -> intel-mid/intel-mid.c mrst/vrtc.c -> intel-mid/intel_mid_vrtc.c mrst/early_printk_mrst.c -> intel-mid/intel_mid_vrtc.c pci/mrst.c -> pci/intel_mid_pci.c Also, renamed the corresponding header files and made changes to the driver files that included these header files. To ensure that there are no functional changes, I have compared the objdump of renamed files before and after rename and found that the only difference is file name change. Signed-off-by: Kuppuswamy Sathyanarayanan <sathyanarayanan.kuppuswamy@linux.intel.com> Link: http://lkml.kernel.org/r/1382049336-21316-4-git-send-email-david.a.cohen@linux.intel.com Signed-off-by: David Cohen <david.a.cohen@linux.intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-03-23drivers/rtc: remove IRQF_DISABLEDYong Zhang
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts disabled") we run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled - see commit b738a50a2026 ("genirq: warn when handler enables interrupts"). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-10rtc: convert drivers/rtc/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/rtc/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Ben Dooks <ben@simtec.co.uk> Cc: John Stultz <john.stultz@linaro.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-11-11vrtc: change its year offset from 1960 to 1972Feng Tang
Real world year equals the value in vrtc YEAR register plus an offset. We used 1960 as the offset to make leap year consistent, but for a device's first use, its YEAR register is 0 and the system year will be parsed as 1960 which is not a valid UNIX time and will cause many applications to fail mysteriously. So we use 1972 instead to fix this issue. Updated patch which adds a sanity check suggested by Mathias This isn't a change in behaviour for systems, because 1972 is the one we actually use. It's the old version in upstream which is out of sync with all devices. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-26drivers/rtc/rtc-mrst.c: use release_mem_region after request_mem_regionJulia Lawall
The memory allocated using request_mem_region should be released using release_mem_region, not release_region. The semantic patch that fixes part of this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1,E2,E3; @@ request_mem_region(E1,E2,E3) ... ?- release_region(E1,E2) + release_mem_region(E1,E2) // </smpl> [akpm@linux-foundation.org: use resource_size()] Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-07rtc, x86/mrst/vrtc: Fix boot crash in rtc_read_alarm()Feng Tang
Commit f44f7f96a20 ("RTC: Initialize kernel state from RTC") caused a boot regression on the MRST platform. The reason is that rtc_device_register() calls rtc_read_alarm() after that change, which function does not have all driver data set up yet. The rtc-mrst driver needs to call dev_set_drvdata() before rtc_device_register() gets called. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Acked-by: John Stultz <john.stultz@linaro.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1302140384-27571-1-git-send-email-feng.tang@intel.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-04rtc-mrst: Fix section typesMajor Lee
Fix the following section mismatch warning. WARNING: drivers/rtc/built-in.o(.data+0xa0): Section mismatch in reference from the variable vrtc_mrst_platform_driver to the function .init.text:vrtc_mrst_platform_probe() The variable vrtc_mrst_platform_driver references the function __init vrtc_mrst_platform_probe() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console, Signed-off-by: Major Lee <major_lee@wistron.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-23Merge branch 'linus' into x86/platformThomas Gleixner
Reason: Import mainline device tree changes on which further patches depend on or conflict. Trivial conflict in: drivers/spi/pxa2xx_spi_pci.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-14mrst/vrtc: Avoid using cmos rtc opsFeng Tang
If we don't assign Moorestown specific wallclock init and ops function the rtc/persisent clock code will use cmos rtc for access, this will crash Moorestown in that the ioports are not present. Also in vrtc driver, should avoid using cmos access to check UIP status. [feng.tang@intel.com: use set_fixmap_offset_nocache() to simplify code] Signed-off-by: Jacob Pan <jacob.jun.pan@linux.intel.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-03RTC: Convert rtc drivers to use the alarm_irq_enable methodJohn Stultz
Some rtc drivers use the ioctl method instead of the alarm_irq_enable method for enabling alarm interupts. With the new virtualized RTC rework, its important for drivers to use the alarm_irq_enable instead. This patch converts the drivers that use the AIE ioctl method to use the alarm_irq_enable method. Other ioctl cmds are left untouched. I have not been able to test or even compile most of these drivers. Any help to make sure this change is correct would be appreciated! CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Reported-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Tested-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-11-17x86, mrst: Add explanation for using 1960 as the year offset for vrtcFeng Tang
Explain the reason for the apparently odd choice of year offset so we don't get more questions about it. Signed-off-by: Feng Tang <feng.tang@intel.com> Signed-off-by: Alan Cox <alan@linux.intel.com> LKML-Reference: <20101117121050.9998.89348.stgit@localhost.localdomain> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-11-11rtc: Add drivers/rtc/rtc-mrst.cFeng Tang
Provide the standard kernel rtc driver interface on top of the vrtc layer added in the previous patch. Signed-off-by: Feng Tang <feng.tang@intel.com> LKML-Reference: <20101110172911.3311.20593.stgit@localhost.localdomain> [Fixed swapped arguments on IPC] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> [Cleaned up and the device creation moved to arch/x86/platform] Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
