path: root/drivers/rtc/rtc-proc.c
2016-01-11rtc: fix module reference count in rtc-procGeliang Tang
rtc-proc.c is not built as a module. Thus, rather than dealing with THIS_MODULE's reference count, we should deal with rtc->owner's reference count. Signed-off-by: Geliang Tang <geliangtang@163.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-06rtc-proc: permit the /proc/driver/rtc device to use other devicesKim, Milo
To get time information via /proc/driver/rtc, only the first device (rtc0) is used. If the rtcN (eg. rtc1 or rtc2) is used for the system clock, there is no way to get information of rtcN via /proc/driver/rtc. With this patch, the time data can be retrieved from the system clock RTC. If the RTC_HCTOSYS_DEVICE is not defined, then rtc0 is used by default. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-09RTC: Include information about UIE and PIE in RTC driver proc.Marcelo Roberto Jimenez
Generic RTC code is always able to provide the necessary information about update and periodic interrupts. This patch add such information to the proc interface. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-02-11drivers/rtc/rtc-proc.c: add module_put on error path in rtc_proc_open()Alexander Strakh
In file drivers/rtc/rtc-proc.c seq_open() can return -ENOMEM. 86 if (!try_module_get(THIS_MODULE)) 87 return -ENODEV; 88 89 return single_open(file, rtc_proc_show, rtc); In this case before exiting (line 89) from rtc_proc_open the module_put(THIS_MODULE) must be called. Found by Linux Device Drivers Verification Project Signed-off-by: Alexander Strakh <strakh@ispras.ru> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31proc 2/2: remove struct proc_dir_entry::ownerAlexey Dobriyan
Setting ->owner as done currently (pde->owner = THIS_MODULE) is racy as correctly noted at bug #12454. Someone can lookup entry with NULL ->owner, thus not pinning enything, and release it later resulting in module refcount underflow. We can keep ->owner and supply it at registration time like ->proc_fops and ->data. But this leaves ->owner as easy-manipulative field (just one C assignment) and somebody will forget to unpin previous/pin current module when switching ->owner. ->proc_fops is declared as "const" which should give some thoughts. ->read_proc/->write_proc were just fixed to not require ->owner for protection. rmmod'ed directories will be empty and return "." and ".." -- no harm. And directories with tricky enough readdir and lookup shouldn't be modular. We definitely don't want such modular code. Removing ->owner will also make PDE smaller. So, let's nuke it. Kudos to Jeff Layton for reminding about this, let's say, oversight. http://bugzilla.kernel.org/show_bug.cgi?id=12454 Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2008-04-29drivers: use non-racy method for proc entries creation (2)Denis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Dmitry Torokhov <dtor@mail.ru> Cc: Neil Brown <neilb@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove rest of class_deviceDavid Brownell
Finish converting the RTC framework so it no longer uses class_device. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: simplified /proc/driver/rtc handlingDavid Brownell
This simplifies the RTC procfs support by removing the class_interface that hooks it into the rtc core. If it's configured, then sysfs support is now part of the RTC core, and is never a separate module. It also removes the class_interface hook, now that its last remaining user is gone. (That API is usable only with a "struct class_device".) It's another step towards being able to remove "struct class_device". Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 5Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] rtc framewok: rtc_wkalrm.enabled reporting updatesDavid Brownell
Fix a glitch in the procfs dumping of whether the alarm IRQ is enabled: use the traditional name (from drivers/char/rtc.c and many other places) of "alarm_IRQ", not "alrm_wakeup" (which didn't even match the efirtc code, which originated that reporting API). Also, update a few of the RTC drivers to stop providing that duplicate status, and/or to expose it properly when reporting the alarm state. We really don't want every RTC driver doing their own thing here... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] rtc: remove syslog spam on registrationDavid Brownell
This removes some syslog spam as RTC drivers register; debug messages shouldn't come out at "info" level. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] constify rtc_class_ops: update driversDavid Brownell
Update RTC framework so that drivers can constify their method tables, moving them from ".data" to ".rodata". Then update the drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class: error checksDavid Brownell
The rtc_is_valid_tm() routine needs to treat some of the fields it checks as unsigned, to prevent wrongly accepting invalid rtc_time structs; this is the same approach used elsewhere in the RTC code for such tests. Conversely, rtc_proc_show() is missing one invalid-day-of-month test that rtc_is_valid_tm() makes: there is no day zero. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class uses subsys_initDavid Brownell
This makes RTC core components use "subsys_init" instead of "module_init", as appropriate for subsystem infrastructure. This is mostly useful for statically linking drivers in other parts of the tree that may provide an RTC interface as a secondary functionality (e.g. part of a multifunction chip); they won't need to worry so much about drivers/Makefile link order. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] RTC subsystem: fix proc outputAlessandro Zummo
Move the "24hr: yes" proc output from drivers to rtc proc code. This is required because the time value in the proc output is always in 24hr mode regardless of the driver. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: proc interfaceAlessandro Zummo
Add the proc interface to the RTC subsystem. The first RTC driver which registers with the class will be accessible by /proc/driver/rtc . This is required for compatibility with the standard RTC driver and to avoid breaking any user space application which may erroneusly rely on this. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
