path: root/drivers/rtc/rtc-pxa.c
2018-06-07rtc: pxa: fix probe functionDan Carpenter
This patch is from static analysis and I don't have the hardware to to test it. I think the test is reversed so now the probe function will return success early and the last part of the function is dead code. Fixes: 3cdf4ad9633e ("rtc: pxa: convert to use shared sa1100 functions") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
2017-08-24rtc: pxa: fix possible race conditionAlexandre Belloni
pxa_rtc_open() registers the interrupt handler which will access the RTC registers. However, pxa_rtc_open() is called before the register range is ioremapped. Instead, call it after devm_ioremap(). Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05rtc: sa1100/pxa: convert to run-time register mappingRob Herring
SA1100 and PXA differ only in register offsets which are currently hardcoded in a machine specific header. Some arm64 platforms (PXA1928) have this RTC block as well (and not the PXA270 variant). Convert the driver to use ioremap and set the register offsets dynamically. Since we are touching all the register accesses, convert them all to readl_relaxed/writel_relaxed. Signed-off-by: Rob Herring <robh@kernel.org> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: rtc-linux@googlegroups.com Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-09-05rtc: pxa: convert to use shared sa1100 functionsRob Herring
Currently, the rtc-sa1100 and rtc-pxa drivers co-exist as rtc-pxa has a superset of functionality. Having 2 drivers sharing the same memory resource is not allowed by the driver model if resources are properly declared. This problem was avoided by not adding memory resources to the SA1100 RTC driver, but that prevents clean-up of the SA1100 driver. This commit converts the PXA RTC to use the exported SA1100 RTC functions. Now the sa1100-rtc and pxa-rtc devices are mutually exclusive, so we must remove the sa1100-rtc from pxa27x and pxa3xx. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Daniel Mack <daniel@zonque.org> Cc: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Russell King <linux@arm.linux.org.uk> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: linux-arm-kernel@lists.infradead.org Cc: rtc-linux@googlegroups.com Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2014-06-06drivers/rtc/rtc-pxa.c: make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-12-20rtc: pxa: drop unused #define TIMER_FREQUwe Kleine-König
It seems this symbol was unused since the driver was introduced in commit dc94436 (rtc: driver for pxa27x and pxa3xx SoC) back in 2009. As a by-product this patch makes the driver stop "using" the symbol CLOCK_TICK_RATE which is about to be removed very soon (for ARM). Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
2013-07-03rtc: rtc-pxa: use devm_*() functionsJingoo Han
Use devm_*() functions to make cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-pxa: switch to using SIMPLE_DEV_PM_OPSJingoo Han
Switch to using the SIMPLE_DEV_PM_OPS macro to declare the driver's pm_ops. It reduces code size. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-pxa: use module_platform_driver_probe()Jingoo Han
Use module_platform_driver_probe() macro which makes the code smaller and simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-pxa.c: avoid cpuid checkingHaojian Zhuang
pxa-rtc is widely used in pxa27x/pxa3xx/pxa93x/pxa95x. Checking cpuid in pxa-rtc driver is unnecessary since we assign on-chip device in soc files. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-pxa.c: fix alarm can't wake up system issueLeo Song
Fix alarm can't wake up system issue Signed-off-by: Leo Song <liangs@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-pxa.c: fix alarm not match issueLeo Song
Fix pxa rtc alarm issue by setting week of month and day of week in rdar/rdcr or it would not match. Signed-off-by: Leo Song <liangs@marvell.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-08-16RTC: add DT bindings to pxa-rtcDaniel Mack
This patch adds generic device tree bindings to the PXA RTC driver. Documentation for bindings were also added. Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Haojian Zhuang <haojian.zhuang@gmail.com>
2012-03-23drivers/rtc: remove IRQF_DISABLEDYong Zhang
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts disabled") we run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled - see commit b738a50a2026 ("genirq: warn when handler enables interrupts"). So now this flag is a NOOP and can be removed. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-09RTC: Cleanup rtc_class_ops->update_irq_enable()John Stultz
Now that the generic code handles UIE mode irqs via periodic alarm interrupts, no one calls the rtc_class_ops->update_irq_enable() method anymore. This patch removes the driver hooks and implementations of update_irq_enable if no one else is calling it. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_freq()John Stultz
With the generic rtc code now emulating PIE mode irqs via an hrtimer, no one calls the rtc_class_ops->irq_set_freq call. This patch removes the hook and deletes the driver functions if no one else calls them. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-03-09RTC: Cleanup rtc_class_ops->irq_set_stateJohn Stultz
With PIE mode interrupts now emulated in generic code via an hrtimer, no one calls rtc_class_ops->irq_set_state(), so this patch removes it along with driver implementations. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2010-08-11rtc/pxa: remove unnecessary private ops->ioctl()Wan ZongShun
We shouldn't implement private ops->ioctl() unless absolutely necessary. pxa series RTC driver's ioctl() is unnecessary, since RTC subsystem has implement the ioctl() very well,so we can only use the API of '.alarm_irq_enable' and '.update_irq_enable' to do enable irq action. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Acked-by: Robert Jarzmik <robert.jarzmik@free.fr> Acked-by: Eric Miao <eric.y.miao@gmail.com> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11rtc/pxa: remove unused fieldWan ZongShun
pxa_rtc.rtc_alarm is unused. Signed-off-by: Wan ZongShun <mcuos.com@gmail.com> Cc: Eric Miao <eric.y.miao@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-15const: constify remaining dev_pm_opsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-10[ARM] pxa: update rtc-pxa.c to use 'struct dev_pm_ops'Robert Jarzmik
Remove the following warning: Platform driver 'pxa-rtc' needs updating - please use dev_pm_ops Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Eric Miao <eric.y.miao@gmail.com>
2009-02-11rtc: update maintainership of pxa rtc driverRobert Jarzmik
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15rtc-pxa: fix build failureAntonio Ospite
Fix these build errors: CC drivers/rtc/rtc-pxa.o drivers/rtc/rtc-pxa.c: In function `pxa_rtc_init': drivers/rtc/rtc-pxa.c:472: error: implicit declaration of function `cpu_is_pxa27x' drivers/rtc/rtc-pxa.c:472: error: implicit declaration of function `cpu_is_pxa3xx' Signed-off-by: Antonio Ospite <ao2@openezx.org> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: pxa27x/pxa3xx driver fixes, revisedAlessandro Zummo
Small fixes for the pxa27x/pxa3xx driver - use platform_driver_probe - fixed exit paths - fixed probe sequence - added missing include - using linux/io.h instead of asm/io.h Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Tested-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Jonathan Cameron <jic23@cam.ac.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06rtc: driver for pxa27x and pxa3xx SoCRobert Jarzmik
With PXA27x and above, a new RTC hardware block was added in addition to the legacy one which is also found on the SA1100 SOC family. This second RTC block is called "wristwatch" and "periodic interrupt" and works independently from the other RTC block. The driver offers provides : - a 1Hz ticking clock - a periodic alarm, in the 1Hz to 1000Hz range - a one shot alarm Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
