path: root/drivers/rtc/rtc-rx6110.c
2016-09-02rtc: constify rtc_class_ops structuresJulia Lawall
Check for rtc_class_ops structures that are only passed to devm_rtc_device_register, rtc_device_register, platform_device_register_data, all of which declare the corresponding parameter as const. Declare rtc_class_ops structures that have these properties as const. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct rtc_class_ops i@p = { ... }; @ok@ identifier r.i; expression e1,e2,e3,e4; position p; @@ ( devm_rtc_device_register(e1,e2,&i@p,e3) | rtc_device_register(e1,e2,&i@p,e3) | platform_device_register_data(e1,e2,e3,&i@p,e4) ) @bad@ position p != {r.p,ok.p}; identifier r.i; @@ i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct rtc_class_ops i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Hans Ulli Kroll <ulli.kroll@googlemail.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-08-31rtc: rx6110: remove owner assignmentAlexandre Belloni
.owner is already set by the spi core. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2016-03-14rtc: add driver for RX6110SA real time clockSteffen Trumtrar
The RX6110 comes in two different variants: SPI and I2C. This driver only supports the SPI variant. If the need ever arises to also support the I2C variant, this driver could easily be refactored to support both cases. Reviewed-by: Philipp Zabel <p.zabel@pengutronix.de> Signed-off-by: Steffen Trumtrar <s.trumtrar@pengutronix.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
