commit 2dbcd05f1e9e0932833d16dab1696176fc164b07 upstream.
If an error occurs after the clock is enabled, the enable/disable state
can become unbalanced.
Signed-off-by: Jonghwan Choi <jhbird.choi@samsung.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
The driver does not generate an alarm interrupt even though a time for
an alarm is set.
This results from disabling rtc_clk after setting the alarm time.
To generate an alarm interrupt the driver should maintain its enabled
state for rtc_clk the until alarm interrupt occurs. This patch permits
generation of an alarm interrupt.
[akpm@linux-foundation.org: make s3c_rtc_alarm_clk_lock local to s3c_rtc_alarm_clk_enable()]
Signed-off-by: Donggeun Kim <dg77.kim@samsung.com>
Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com>
have irq.
The previous rtc-s3c had two issues related with its IRQ.
1. Users cannot open rtc multiple times because an open operation
calls request_irq on the same IRQ. (e.g., two user processes wants to
open and read RTC time from rtc-s3c at the same time)
2. If alarm is set and no one has the rtc opened with filesystem
(either the alarm is set by kernel/boot-loader or user set an alarm and
closed rtc dev file), the pending bit is not cleared and no further
interrupt is invoked. When the alarm is used by the system itself such
as a resume from suspend-to-RAM or other Low-power modes/idle, this is
a critical issue.
This patch mitigates these issues by calling request_irq at probe and
free_irq at remove.
Cc: Changhwan Youn <chaos.youn@samsung.com>
RTC-S3C used to print out debug messages incorrectly. This patch
corrects incorrect outputs. (undecoded bcd numbers, incorrectly decoded
register values)
This patch affects the pr-debug messages only.
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
Add support for clock gating. Power consumption can be reduced by setting
rtc_clk disabled state except for when RTC related registers are accessed.
Signed-off-by: KyungMin Park <kyungmin.park@samsung.com>
Cc: Ben Dooks <ben@fluff.org>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
The driver is not balancing set_irq and disable_irq_wake() calls, so
ensure that it keeps track of whether the wake is enabled.
The fixes the following error on S3C6410 devices:
WARNING: at kernel/irq/manage.c:382 set_irq_wake+0x84/0xec()
Unbalanced IRQ 92 wake disable
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Cc: <stable@kernel.org>
s3c_rtc_setpie was removed, and it resulted in compiler error:
drivers/rtc/rtc-s3c.c: In function s3c_rtc_release
drivers/rtc/rtc-s3c.c:339:2: error: implicit declaration of function
s3c_rtc_setpie
Fix it by removing s3c_rtc_release calls.
[jstultz: An identical fix was also sent in by Jiri Pinkava
<jiri.pinkava@vscht.cz>]
CC: Thomas Gleixner <tglx@linutronix.de>
CC: Alessandro Zummo <a.zummo@towertech.it>
Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com>
Signed-off-by: John Stultz <john.stultz@linaro.org>
With the generic rtc code now emulating PIE mode irqs via an
hrtimer, no one calls the rtc_class_ops->irq_set_freq call.
This patch removes the hook and deletes the driver functions
if no one else calls them.
CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br>
CC: rtc-linux@googlegroups.com
With PIE mode interrupts now emulated in generic code via an hrtimer,
no one calls rtc_class_ops->irq_set_state(), so this patch removes it
along with driver implementations.
Fix s3c_rtc_setaie() prototype to eliminate the following compile
warning:
drivers/rtc/rtc-s3c.c:383: warning: initialization from incompatible pointer type
(akpm: the rtc_class_ops.alarm_irq_enable() handler is being passed two
arguments where it expects just one, presumably with undesired effects)
Cc: Ben Dooks <ben-linux@fluff.org>
Add "rtc_valid_tm" in s3c_rtc_gettime() as per Wan ZongShun's suggestion.
Suggested-by: Wan ZongShun <mcuos.com@gmail.com>
Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
Change RTC initialization method in probe(). The 'rtc_valid_tm(tm)' can
check whether RTC BCD is valid or not. And change the method of checking
because the previous method cannot validate RTC BCD registers properly.
Signed-off-by: Changhwan Youn <chaos.youn@samsung.com>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Fix debug message format.
Acked-by: Ben Dooks <ben-linux@fluff.org>
The alarm_irq_enable function should be implemented to support RTC alarm.
And fix tabs instead of white space around the proc field.
Current s3c_rtc_getalarm() sets missing field of alarm time with 0xff.
But this value should be -1 according to drivers/rtc/interface.c.
S3C2410_RTCCON of TYPE_S3C64XX RTC should be read/written by readw and
writew, because TYPE_S3C64XX RTC uses bit 8 and 9. And TYPE_S3C2410 RTC
also can access it by readw and writew.
[atul.dahiya@samsung.com: tested on smdk2416]
Tested-by: Atul Dahiya <atul.dahiya@samsung.com>
This change resolves a problem about unbalanced calls of
enable_irq_wakeup() and disable_irq_wakeup() for alarm interrupt.
Bug reproduction:
root@eb600:~# echo 0 > /sys/class/rtc/rtc0/wakealarm
WARNING: at kernel/irq/manage.c:361 set_irq_wake+0x7c/0xe4()
Unbalanced IRQ 46 wake disable
Modules linked in:
[<c0025708>] (unwind_backtrace+0x0/0xd8) from [<c003358c>] (warn_slowpath_common+0x44/0x5c)
[<c003358c>] (warn_slowpath_common+0x44/0x5c) from [<c00335dc>] (warn_slowpath_fmt+0x24/0x30)
[<c00335dc>] (warn_slowpath_fmt+0x24/0x30) from [<c0058c20>] (set_irq_wake+0x7c/0xe4)
[<c0058c20>] (set_irq_wake+0x7c/0xe4) from [<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8)
[<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8) from [<c01b47a0>] (rtc_set_alarm+0x60/0x74)
[<c01b47a0>] (rtc_set_alarm+0x60/0x74) from [<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8)
[<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8) from [<c01891ec>] (dev_attr_store+0x20/0x24)
[<c01891ec>] (dev_attr_store+0x20/0x24) from [<c00be934>] (sysfs_write_file+0x104/0x13c)
[<c00be934>] (sysfs_write_file+0x104/0x13c) from [<c0080e7c>] (vfs_write+0xb0/0x158)
[<c0080e7c>] (vfs_write+0xb0/0x158) from [<c0080fcc>] (sys_write+0x3c/0x68)
[<c0080fcc>] (sys_write+0x3c/0x68) from [<c0020ec0>] (ret_fast_syscall+0x0/0x28)
Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Cc: Ben Dooks <ben@fluff.org.uk>
Cc: Atul Dahiya <atul.dahiya@samsung.com>
Cc: Taekgyun Ko <taeggyun.ko@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
RTC needs to be initialized when BCD registers have invalid value.
Signed-off-by: Taekgyun Ko <taeggyun.ko@samsung.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
This Patch does followings.
1) Enables support for alarm and time tick pending register
for periodic interrupt generation.
2) Changes writeb to writew beacuse the macro S3C64XX_RTCCON_TICEN
(Tick Timer Enable) is 9th bit of register.
3) Changes writeb to writel as max_user_freq used in s3c64xx is 32768 and
requires 15 bits to update the Tick Count Register.
Signed-off-by: Atul Dahiya <atul.dahiya@samsung.com>
This Patch updates existing Samsung RTC driver for clock enabling support.
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Make sure s3c_rtc_cpu_type is initialised _before_ it's used in an if()
check.
Reported-by: Jiri Pinkava <jiri.pinkava@vscht.cz>
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Cc: Maurus Cuelenaere <mcuelenaere@gmail.com>
s3c_rtc_setfreq() uses the platform driver data to derive struct rtc_device,
so make sure drvdata is set _before_ s3c_rtc_setfreq() is called.
Add support for the S3C64xx SoC to the generic S3C RTC driver.
Cc: Frans Pop <elendil@planet.nl>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Move the power of 2 check on frequencies down into individual rtc drivers
This is to allow for non power of 2 real time clock periodic interrupts
such as those on the pxa27x to be found in the new pxa27x-rtc driver
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into s3c-moves2
tAdd adds device_init_wakeup() ivokation to probe function of
s3c2410_rtc_driver. Without of this wakealarm sysfs attribute does not
initialise.
Signed-off-by: Yauhen Kharuzhy <jekhor@gmail.com>
Warnings was appeared when compile rtc-s3c.c because
platform_driver structure s3c2410_rtcdrv has wrong name.
Move regs-rtc.h to arch/arm/plat-s3c/include/plat ready
to clean out old include directories.
Change drivers/rtc/ to use the new bcd2bin/bin2bcd functions instead of
the obsolete BCD_TO_BIN/BIN_TO_BCD/BCD2BIN/BIN2BCD macros.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This just leaves include/asm-arm/plat-* to deal with.
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h.
Then, since asm/hardware.h only exists to include asm/arch/hardware.h,
update everything to directly include asm/arch/hardware.h and remove
asm/hardware.h.
The rtc-s3c.c driver has been using its own ioctl() handling to deal with
alarm and periodic interrupts to handle what should now be done with the
rtc core code.
Change to using the .irq_set_freq and .irq_set_state driver entries and
remove the .ioctl handling.
Add the relevant __devinit and __devexit attributes to the rtc-s3c driver.
On ARM, asm/rtc.h only contains definitions for the predecessor to
the RTC class support. RTC class drivers should not be including
this include.
Build tested on at91sam9rl and s3c2410 configurations.
asm/mach/time.h is the ARM header file for setting up kernel ticker
timekeeping (be that the old jiffy interrupt or the new clocksource.)
RTC drivers have no business using this header file, and in fact do
not require it.
Build tested on at91sam9rl, omap and s3c2410 configurations.
Acked-by: Andrew Victor <linux@maxim.org.za>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC
platform drivers, to re-enable module auto loading.
[dbrownell@users.sourceforge.net: more drivers, minor fix]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Greg KH <greg@kroah.com>
Use is_power_of_2() macro for simplicity.
Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl>
Fixup the changes from moving around the arch support for s3c24xx based
systems.
RTC class suspend/resume support, re-initializing the system clock on resume
from the clock used to initialize it at boot time.
- The reinit-on-resume is hooked to the existing RTC_HCTOSYS config
option, on the grounds that a clock good enough for init must also
be good enough for re-init.
- Inlining a version of the code used by ARM, to save and restore the
delta between a selected RTC and the current system wall-clock time.
- Removes calls to that ARM code from AT91, OMAP1, and S3C RTCs. This
means that systems using those RTCs across suspend/resume will likely
want to change their kernel configs to enable RTC_HCTOSYS.
If HCTOSYS isn't using a second RTC (with battery?), this changes the
system's initial date from Jan 1970 to the epoch this hardware uses:
1998 for AT91, 2000 for OMAP1 (assuming no split power mode), etc.
This goes on top of the patch series removing "struct class_device" usage
from the RTC framework. That's all needed for class suspend()/resume().
Acked-By: Alessandro Zummo <a.zummo@towertech.it>
This patch removes class_device from the programming interface that the RTC
framework exposes to the rest of the kernel. Now an rtc_device is passed,
which is more type-safe and streamlines all the relevant code.
The obsolete SA_xxx interrupt flags have been used despite the scheduled
removal. Fixup the remaining users.
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Dave Airlie <airlied@linux.ie>
Cc: James Simmons <jsimmons@infradead.org>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Fix a glitch in the procfs dumping of whether the alarm IRQ is enabled: use
the traditional name (from drivers/char/rtc.c and many other places) of
"alarm_IRQ", not "alrm_wakeup" (which didn't even match the efirtc code, which
originated that reporting API).
Also, update a few of the RTC drivers to stop providing that duplicate status,
and/or to expose it properly when reporting the alarm state. We really don't
want every RTC driver doing their own thing here...
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
Update RTC framework so that drivers can constify their method tables, moving
them from ".data" to ".rodata". Then update the drivers.
Fix the year check on setting the time with the S3C24XX RTC driver. Also
move the debug to before the set to see what is going on if it does fail.
