path: root/drivers/rtc/rtc-sysfs.c
2010-03-12rtc/hctosys: only claim the RTC provided the system time if it didUwe Kleine-König
Without this patch /sys/class/rtc/$CONFIG_RTC_HCTOSYS_DEVICE/hctosys contains a 1 (meaning "This rtc was used to initialize the system clock") even if reading the time at bootup failed. Moreover change error handling in rtc_hctosys() to use goto and so reduce the indention level. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Cc: Paul Gortmaker <p_gortmaker@yahoo.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23rtc: add boot_timesource sysfs attributeMatthew Garrett
CONFIG_RTC_HCTOSYS allows the kernel to read the system time from the RTC at boot and resume, avoiding the need for userspace to do so. Unfortunately userspace currently has no way to know whether this configuration option is enabled and thus cannot sensibly choose whether to run hwclock itself or not. Add a hctosys sysfs attribute which indicates whether a given RTC set the system clock. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28rtc: add the support for alarm time relative to current time in sysfsZhao Yakui
In current kernel if we want to set the alarm time, the absolute time the seconds relative to 1970-01-01 00:00:00) should be written into /sys/class/rtc/rtc0/wakealarm. It is not convenient. It is more reasonable to add the support for the alarm time relative to current RTC time.(the unit is second) For example: If the RTC is required to generate alarm after 2 minutes, the following will be OK. echo +120 > /sys/class/rtc/rtc0/wakealarm or echo +0x78 > /sys/class/rtc/rtc0/wakealarm Signed-off-by: Zhao Yakui <yakui.zhao@intel.com> Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc-cmos alarm acts as oneshotDavid Brownell
Start making the rtc-cmos alarm act more like a oneshot alarm by disabling that alarm after its IRQ fires. (ACPI hooks are also needed.) The Linux RTC framework has previously been a bit vague in this area, but any other behavior is problematic and not very portable. RTCs with full YYYY-MM-DD HH:MM[:SS] alarms won't have a problem here. Only ones with partial match criteria, with the most visible example being the PC RTC, get confused. (Because the criteria will match repeatedly.) Update comments relating to that oneshot behavior and timezone handling. (Timezones are another issue that's mostly visible with rtc-cmos. That's because PCs often dual-boot MS-Windows, which likes its RTC to match local wall-clock time instead of UTC.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add missing newlines to some uses of dev_<level> messagesJoe Perches
Found these while looking at printk uses. Add missing newlines to dev_<level> uses Add missing KERN_<level> prefixes to multiline dev_<level>s Fixed a wierd->weird spelling typo Added a newline to a printk Signed-off-by: Joe Perches <joe@perches.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mark M. Hoffman <mhoffman@lightlink.com> Cc: Roland Dreier <rolandd@cisco.com> Cc: Tilman Schmidt <tilman@imap.cc> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Greg KH <greg@kroah.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Cc: James Smart <James.Smart@Emulex.Com> Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16rtc: add max_user_freq to sysfsBryan Kadzban
drivers/char/rtc.c exposed a sysctl to change the maximum frequency at which a non-root user could ask the RTC to generate interrupts (via the RTC_IRQP_SET ioctl). This value is no longer available under the new RTC subsystem, so add it to sysfs for each RTC device. Works for me on x86_64 (both reads and writes), using rtc-cmos. Signed-off-by: Bryan Kadzban <bryan@kdzbn.homelinux.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove rest of class_deviceDavid Brownell
Finish converting the RTC framework so it no longer uses class_device. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: simplified rtc sysfs attribute handlingDavid Brownell
This simplifies the RTC sysfs support by removing the class_interface that hooks it into the rtc core. If it's configured, then sysfs support is now part of the RTC core, and is never a separate module. It's another step towards being able to remove "struct class_device". Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: rtc interfaces don't use class_deviceDavid Brownell
This patch removes class_device from the programming interface that the RTC framework exposes to the rest of the kernel. Now an rtc_device is passed, which is more type-safe and streamlines all the relevant code. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-By: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] RTC gets sysfs wakealarm attributeDavid Brownell
This adds a new "wakealarm" sysfs attribute to RTC class devices which support alarm operations and are wakeup-capable: - It reads as either empty, or the scheduled alarm time as seconds since the POSIX epoch. (That time may already have passed, since nothing currently enforces one-shot alarm semantics.) - It can be written with an alarm time in the future, again seconds since the POSIX epoch, which enables the alarm. - It can be written with an alarm time not in the future (such as 0, the start of the POSIX epoch) to disable the alarm. Usage examples (some need GNU date) after "cd /sys/class/rtc/rtcN": alarm after 10 minutes: # echo $(( $(cat since_epoch) + 10 * 60 )) > wakealarm alarm tuesday evening 10pm: # date -d '10pm tuesday' "+%s" > wakealarm disable alarm: # echo 0 > wakealarm This resembles the /proc/acpi/alarm file in that nothing happens when the alarm triggers ... except possibly waking the system from sleep. It's also like that in a nasty way: not much can be done to prevent one task from clobbering another task's alarm settings. It differs from that file in that there's no in-kernel date parser. Note that a few RTCs ignore rtc_wkalrm.enabled when setting alarms, or aren't set up correctly, so they won't yet behave with this attribute. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-26[PATCH] remove __devinit markings from rtc_sysfs_add_device()Mike Frysinger
rtc_sysfs_add_device is needed even after dev initialization, so drop __devinit. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] rtc: remove syslog spam on registrationDavid Brownell
This removes some syslog spam as RTC drivers register; debug messages shouldn't come out at "info" level. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] rtc-sysfs fixAndrew Morton
It's not clear how this thinko got through.. Cc: Olaf Hering <olaf@aepfle.de> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] RTC class uses subsys_initDavid Brownell
This makes RTC core components use "subsys_init" instead of "module_init", as appropriate for subsystem infrastructure. This is mostly useful for statically linking drivers in other parts of the tree that may provide an RTC interface as a secondary functionality (e.g. part of a multifunction chip); they won't need to worry so much about drivers/Makefile link order. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] RTC subsystem: sysfs interfaceAlessandro Zummo
This patch adds the sysfs interface to the RTC subsystem. Each RTC client will have his own entry under /sys/classs/rtc/rtcN . Within this entry some attributes are exported by the subsystem, like date and time. Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
