Instead of creating wakealarm attribute manually, after the device has been
registered, let's rely on facilities provided by the attribute groups to
control which attributes are visible and which are not. This allows to
create all needed attributes at once, at the same time that we register RTC
class device.
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Instead of using older style DEVICE_ATTR for wakealarm attribute let's
switch to using DEVICE_ATTR_RW that ensures consistent across the kernel
permissions on the attribute.
Users of rtc_does_wakealarm() return value treat it as boolean so let's
change the signature accordingly.
The dev_attrs field of struct class is going away soon, dev_groups
should be used instead. This converts the rtc class code to use the
correct field.
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
This adds the ability for the rtc sysfs code to handle += characters at
the beginning of a wakealarm setting string. This will allow the user
to attempt to push out an existing wakealarm by a provided amount.
In the case that the += characters are provided but the alarm is not
active -EINVAL is returned.
his is useful, at least for my purposes in suspend/resume testing. The
basic test goes something like:
1. Set a wake alarm from userspace 5 seconds in the future
2. Start the suspend process (echo mem > /sys/power/state)
3. After ~2.5 seconds if userspace is still running (using another
thread to check this), move the wake alarm 5 more seconds
If the "move" involves an unset of the wakealarm then there's a period
of time where the system is midway through suspending but has no wake
alarm. It will get stuck.
We'd rather not remove the "move" since the idea is to avoid a cancelled
suspend when the alarm fires _during_ suspend. It is difficult for the
test to tell the difference between a suspend that was cancelled because
the alarm fired too early and a suspend that was
Signed-off-by: Bernie Thompson <bhthompson@chromium.org>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Doug Anderson <dianders@chromium.org>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Without this patch /sys/class/rtc/$CONFIG_RTC_HCTOSYS_DEVICE/hctosys
contains a 1 (meaning "This rtc was used to initialize the system
clock") even if setting the time by do_settimeofday() at bootup failed.
The RTC can also be used to set the clock on resume, if it did 1,
otherwise 0. Previously there was no indication if the RTC was used
to set the clock in resume.
This uses only CONFIG_RTC_HCTOSYS_DEVICE for conditional compilation
instead of it and CONFIG_RTC_HCTOSYS to be more consistent.
rtc_hctosys_ret was moved to class.c so class.c no longer depends on
hctosys.c.
[sfr@canb.auug.org.au: fix build]
Signed-off-by: David Fries <David@Fries.net>
Cc: Matthew Garrett <mjg@redhat.com>
Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de>
contains a 1 (meaning "This rtc was used to initialize the system clock")
even if reading the time at bootup failed.
Moreover change error handling in rtc_hctosys() to use goto and so reduce
the indention level.
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
CONFIG_RTC_HCTOSYS allows the kernel to read the system time from the RTC
at boot and resume, avoiding the need for userspace to do so.
Unfortunately userspace currently has no way to know whether this
configuration option is enabled and thus cannot sensibly choose whether to
run hwclock itself or not. Add a hctosys sysfs attribute which indicates
whether a given RTC set the system clock.
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: David Brownell <david-b@pacbell.net>
In current kernel if we want to set the alarm time, the absolute time the
seconds relative to 1970-01-01 00:00:00) should be written into
/sys/class/rtc/rtc0/wakealarm. It is not convenient.
It is more reasonable to add the support for the alarm time relative to
current RTC time.(the unit is second)
For example:
If the RTC is required to generate alarm after 2 minutes, the following
will be OK.
echo +120 > /sys/class/rtc/rtc0/wakealarm
or echo +0x78 > /sys/class/rtc/rtc0/wakealarm
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Start making the rtc-cmos alarm act more like a oneshot alarm by disabling
that alarm after its IRQ fires. (ACPI hooks are also needed.)
The Linux RTC framework has previously been a bit vague in this area, but
any other behavior is problematic and not very portable. RTCs with full
YYYY-MM-DD HH:MM[:SS] alarms won't have a problem here. Only ones with
partial match criteria, with the most visible example being the PC RTC, get
confused. (Because the criteria will match repeatedly.)
Update comments relating to that oneshot behavior and timezone handling.
(Timezones are another issue that's mostly visible with rtc-cmos. That's
because PCs often dual-boot MS-Windows, which likes its RTC to match local
wall-clock time instead of UTC.)
Found these while looking at printk uses.
Add missing newlines to dev_<level> uses
Add missing KERN_<level> prefixes to multiline dev_<level>s
Fixed a wierd->weird spelling typo
Added a newline to a printk
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Mark M. Hoffman <mhoffman@lightlink.com>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Tilman Schmidt <tilman@imap.cc>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: Greg KH <greg@kroah.com>
Cc: James Smart <James.Smart@Emulex.Com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
drivers/char/rtc.c exposed a sysctl to change the maximum frequency at
which a non-root user could ask the RTC to generate interrupts (via the
RTC_IRQP_SET ioctl). This value is no longer available under the new RTC
subsystem, so add it to sysfs for each RTC device.
Works for me on x86_64 (both reads and writes), using rtc-cmos.
Signed-off-by: Bryan Kadzban <bryan@kdzbn.homelinux.net>
Finish converting the RTC framework so it no longer uses class_device.
Acked-By: Alessandro Zummo <a.zummo@towertech.it>
This simplifies the RTC sysfs support by removing the class_interface that
hooks it into the rtc core. If it's configured, then sysfs support is now
part of the RTC core, and is never a separate module.
It's another step towards being able to remove "struct class_device".
This patch removes class_device from the programming interface that the RTC
framework exposes to the rest of the kernel. Now an rtc_device is passed,
which is more type-safe and streamlines all the relevant code.
This adds a new "wakealarm" sysfs attribute to RTC class devices which support
alarm operations and are wakeup-capable:
- It reads as either empty, or the scheduled alarm time as seconds
since the POSIX epoch. (That time may already have passed, since
nothing currently enforces one-shot alarm semantics.)
- It can be written with an alarm time in the future, again seconds
since the POSIX epoch, which enables the alarm.
- It can be written with an alarm time not in the future (such as 0,
the start of the POSIX epoch) to disable the alarm.
Usage examples (some need GNU date) after "cd /sys/class/rtc/rtcN":
alarm after 10 minutes:
# echo $(( $(cat since_epoch) + 10 * 60 )) > wakealarm
alarm tuesday evening 10pm:
# date -d '10pm tuesday' "+%s" > wakealarm
disable alarm:
# echo 0 > wakealarm
This resembles the /proc/acpi/alarm file in that nothing happens when the
alarm triggers ... except possibly waking the system from sleep. It's also
like that in a nasty way: not much can be done to prevent one task from
clobbering another task's alarm settings.
It differs from that file in that there's no in-kernel date parser.
Note that a few RTCs ignore rtc_wkalrm.enabled when setting alarms, or aren't
set up correctly, so they won't yet behave with this attribute.
Acked-by: Pavel Machek <pavel@ucw.cz>
rtc_sysfs_add_device is needed even after dev initialization, so drop __devinit.
Cc: <stable@kernel.org>
This removes some syslog spam as RTC drivers register; debug messages
shouldn't come out at "info" level.
It's not clear how this thinko got through..
Cc: Olaf Hering <olaf@aepfle.de>
Cc: Alessandro Zummo <alessandro.zummo@towertech.it>
This makes RTC core components use "subsys_init" instead of "module_init", as
appropriate for subsystem infrastructure. This is mostly useful for
statically linking drivers in other parts of the tree that may provide an RTC
interface as a secondary functionality (e.g. part of a multifunction chip);
they won't need to worry so much about drivers/Makefile link order.
Acked-by: Oleg Verych <olecom@flower.upol.cz>
This patch adds the sysfs interface to the RTC subsystem.
Each RTC client will have his own entry under /sys/classs/rtc/rtcN .
Within this entry some attributes are exported by the subsystem, like date and
time.
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
