path: root/drivers/rtc/rtc-tps65910.c
2014-10-20rtc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-08-08drivers/rtc/rtc-tps65910.c: fix potential NULL-pointer dereferenceThierry Reding
The interrupt handler gets the driver data associated with the RTC device and doesn't check it for validity. This can cause a NULL pointer being dereferenced when and interrupt fires before the driver data was properly set up. Fix this by setting the driver data earlier (before the interrupt is requested). Signed-off-by: Thierry Reding <treding@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13drivers/rtc/rtc-tps65910.c: remove unnecessary includeManish Badarkhe
Currently, driver includes 'pm_runtime.h' which is not used anywhere in code hence remove this unnecessory inclusion. Signed-off-by: Manish Badarkhe <badarkhe.manish@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29drivers/rtc/rtc-tps65910.c: fix incorrect return value on errorSachin Kamat
'ret' was not initialized to correct error value before returning. Since 'irq' is also being tested for 0, we cannot return irq itself as it means function is success even though we are returning before completing the probe. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Chiwoong Byun <woong.byun@samsung.com> Cc: Jonghwa Lee <jonghwa3.lee@samsung.com> Cc: Laxman dewangan <ldewangan@nvidia.com> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-tps65910: switch to using SIMPLE_DEV_PM_OPSJingoo Han
Switch to using the SIMPLE_DEV_PM_OPS macro to declare the driver's pm_ops. It reduces code size. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-tps65910: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-tps65910.c: set irq flag to IRQF_EARLY_RESUME during irq requestLaxman Dewangan
All interrupt get disabled during system suspend and enabled during system resume. The enabling/disabling of interrupt happen in sequence of interrupt registration with framework. Therefore, in resume, the parent interrupt of this device enabled before the RTC irq interrupt enabled. If RTC is enabled for alarm wake and if system wake by alarm then there is interrupt pending for RTC. In resume, the parent interrupt get enabled before the rtc interrupt and hence ISR get served. In ISR, it founds that rtc interrupt is disabled and so it does not call the rtc isr handler and hence it misses the interrupt. Setting flag for early resume so that rtc interrupt get enabled before parent interrupt and so rtc interrupt get enabled when parent interrupt handler check for interrupt of device and call the rtc handler if it is there. This way it will not miss the interrupt. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-tps65910.c: use sleep_pm_ops macro for initialising ↵Laxman Dewangan
suspend/resume callbacks Use SET_SYSTEM_SLEEP_PM_OPS for setting suspend/resume callbacks for dev_pm_ops. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-tps65910.c: remove unnecessary irq stat save and restoreLaxman Dewangan
The driver stores the interrupt enable register before going to suspend and restore in resume. Also it enables alarm before going to suspend. The driver only write the Interrupt enable register for enabling ALARM and does not enable any other bits. So it is not require to save complete register and enable ALARM interrupt before suspend and restore in resume. Also ALARM interrupt already enable if alarm is enabled before going to suspend and hence it is not require to enable explictly in suspend. Removing such above code. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21drivers/rtc/rtc-tps65910.c: enable/disable wake in suspend/resumeLaxman Dewangan
Making the rtc driver as wakeup capabale and leaving the wake enable/disable decision to user space through a sysfs attribute. In suspend, enable wake if device wakeup enabled. In resume disable wake again. This change is inline with the Documentation/power/devices.txt# /sys/devices/.../power/wakeup files Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17drivers/rtc/rtc-tps65910.c: enable RTC power domain on initializationKim, Milo
Enabling RTC HW block depends on the default value of TPS65910 register. In some mode, RTC block is disabled by default.(eg. AM3517 Craneboard) In this case, RTC_PWDN(RTC power down) bit should be cleared to enable the RTC HW block. This patch also works in case that RTC block is active by default, because there is no side effect even if the bit is updated again. Tested on AM3517 Craneboard. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Acked-by: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Sivaram Nair <sivaramn@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17drivers/rtc/rtc-tps65910.c: rename irq to match deviceSivaram Nair
A cosmetic change to rename the irq name to match the device name. Signed-off-by: Sivaram Nair <sivaramn@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-11-30drivers/rtc/rtc-tps65910.c: fix invalid pointer access on _remove()Kim, Milo
The tps65910_rtc data is registered as the platform driver data in _probe(= ). Therefore the tps65910_rtc should be used on unregistering the rtc device. And device pointer should be retrieved from the platform_device structure. This patch fixes the below oops: Unable to handle kernel NULL pointer dereference at virtual address 00000008 Modules linked in: rtc_tps65910(-) CPU: 0 Not tainted (3.7.0-rc7-next-20121128-g6b1f974-dirty #7) PC is at tps65910_rtc_alarm_irq_enable+0x20/0x2c [rtc_tps65910] (tps65910_rtc_alarm_irq_enable+0x20/0x2c [rtc_tps65910]) (tps65910_rtc_remove+0x18/0x28 [rtc_tps65910]) (platform_drv_remove+0x18/0x1c) (__device_release_driver+0x70/0xcc) (driver_detach+0xb4/0xb8) (bus_remove_driver+0x7c/0xc0) (sys_delete_module+0x148/0x21c) Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06drivers/rtc/rtc-tps65910.c: use platform_get_irq() to get RTC irq detailsVenu Byravarasu
As RTC driver needs only irq number from platform data, using platform_get_irq(), instead of generic dev_get_platdata(). Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06rtc: tps65910: add RTC driver for TPS65910 PMIC RTCVenu Byravarasu
TPS65910 PMIC is a MFD with RTC as one of the device. Adding RTC driver for supporting RTC device present inside TPS65910 PMIC. Only support for RTC alarm is implemented as part of this patch. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
