path: root/drivers/rtc/rtc-tps80031.c
2016-03-14rtc: tps80031: Drop IRQF_EARLY_RESUME flagGrygorii Strashko
tps80031 RTC IRQ is nested threaded and wired to the tps80031 inerrupt controller. So, this flag is not required for nested irqs anymore, since commit 3c646f2c6aa9 ("genirq: Don't suspend nested_thread irqs over system suspend") was merged. Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com> Cc: Lee Jones <lee.jones@linaro.org> Cc: Nishanth Menon <nm@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2014-10-20rtc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-07-03drivers/rtc/rtc-tps80031.c: remove empty functionSachin Kamat
After the switch to devm_* functions and the removal of rtc_device_unregister(), the 'remove' function does not do anything. Delete it. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-tps80031: switch to using SIMPLE_DEV_PM_OPSJingoo Han
Switch to using the SIMPLE_DEV_PM_OPS macro to declare the driver's pm_ops. It reduces code size. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-tps80031: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21rtc: rtc-tps80031: use devm_request_threaded_irq()Jingoo Han
Use devm_request_threaded_irq() to make cleanup paths more simple. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21rtc: add RTC driver for TPS80031/TPS80032Laxman Dewangan
Add an RTC driver for TPS80031/TPS80032 chips by TI. This driver supports: - Setting and getting time and date. - Setting and reading alarm time. - Alarm and interrupt functionlity. [akpm@linux-foundation.org: remove obsolete __devinit/__devexit] Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Devendra Naga <devendra.aaru@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
