[ Upstream commit 347876ad47b9923ce26e686173bbf46581802ffa ]
The shifting of buf[5] by 24 bits to the left will be promoted to
a 32 bit signed int and then sign-extended to an unsigned long. If
the top bit of buf[5] is set then all then all the upper bits sec
end up as also being set because of the sign-extension. Fix this by
casting buf[5] to an unsigned long before the shift.
Detected by CoverityScan, CID#1465292 ("Unintended sign extension")
Fixes: 0e1492330cd2 ("rtc: add rtc-tx4939 driver")
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
The change removes redundant sysfs binary file boundary checks, since
this task is already done on caller side in fs/sysfs/file.c
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The patch "rtc: verify a critical argument to rtc_update_irq() before
using it" introduces validation for rtc_device in the RTC core, so there
are no need to check this argument for rtc_update_irq() from the
drivers.
This patch removes such check for the existing rtc_update_irq() users.
Signed-off-by: Alexander Shiyan <shc_work@mail.ru>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Convert the composition of devm_request_mem_region and devm_ioremap to a
single call to devm_ioremap_resource. The associated call to
platform_get_resource is also simplified and moved next to the new call
This was done using a combination of the semantic patches
devm_ioremap_resource.cocci and devm_request_and_ioremap.cocci, found in
the scripts/coccinelle/api directory.
In rtc-lpc32xx.c and rtc-mv.c, the local variable size is no longer needed.
In rtc-ds1511.c the size field of the local structure is not useful any
more, and is deleted.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
devm_rtc_device_register() is device managed and makes cleanup
paths simpler.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Use module_platform_driver_probe() macro which makes the code smaller and
simpler.
Since commit e58aa3d2d0cc ("genirq: run irq handlers with interrupts
disabled") we run all interrupt handlers with interrupts disabled and we
even check and yell when an interrupt handler returns with interrupts
enabled - see commit b738a50a2026 ("genirq: warn when handler enables
interrupts").
So now this flag is a NOOP and can be removed.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
The module.h was implicitly everywhere, but when we clean
that up, the implicit users will compile fail; fix them up
in advance.
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* Use its own spinlock instead of rtc->irq_lock
* Check pdata->rtc before calling rtc_update_irq
* Disable interrupt after rtc_device_unregister
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
IRQF_SHARED should not be used with IRQF_DISABLED. This RTC have a
dedicated irq line to SoC's internal interrupt controller so there is
no reason to use IRQF_SHARED.
Add support for RTC in TX4939 SoC.
