path: root/drivers/rtc/rtc-vt8500.c
2014-10-20rtc: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-04-03rtc: rtc-vt8500: use devm_ioremap_resource()Jingoo Han
Use devm_ioremap_resource() in order to make the code simpler, and move 'struct resource *res' from 'struct vt8500_rtc' to vt8500_rtc_probe() because the 'res' variable is used only in vt8500_rtc_probe(). Signed-off-by: Jingoo Han <jg1.han@samsung.com> Cc: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13drivers/rtc/rtc-vt8500.c: remove redundant of_match_ptrSachin Kamat
The data structure of_match_ptr() protects is always compiled in. Hence of_match_ptr() is not needed. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-13drivers/rtc/rtc-vt8500.c: fix return valueSachin Kamat
Propagate the return value from platform_get_irq() instead of hardcoding. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03rtc: rtc-vt8500: remove unnecessary platform_set_drvdata()Jingoo Han
The driver core clears the driver data to NULL after device_release or on probe failure, since commit 0998d063100 ("device-core: Ensure drvdata = NULL when no driver is bound"). Thus, it is not needed to manually clear the device driver data to NULL. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29rtc: rtc-vt8500: use devm_rtc_device_register()Jingoo Han
devm_rtc_device_register() is device managed and makes cleanup paths simpler. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21rtc: rtc-vt8500: use devm_*() functionsJingoo Han
Use devm_*() functions to make cleanup paths more simple. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-05drivers/rtc/rtc-vt8500.c: fix year field in vt8500_rtc_set_time()Tony Prisk
The year field is incorrectly masked when setting the date. If the year is beyond 2099, the year field will be incorrectly updated in hardware. This patch masks the year field correctly. Signed-off-by: Edgar Toernig <froese@gmx.de> Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04drivers/rtc/rtc-vt8500.c: fix handling of data passed in struct rtc_timeTony Prisk
tm_mon is 0..11, whereas vt8500 expects 1..12 for the month field, causing invalid date errors for January, and causing the day field to roll over incorrectly. The century flag is only handled in vt8500_rtc_read_time, but not set in vt8500_rtc_set_time. This patch corrects the behaviour of the century flag. Signed-off-by: Edgar Toernig <froese@gmx.de> Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-04drivers/rtc/rtc-vt8500.c: correct handling of CR_24H bitfieldTony Prisk
Control register bitfield for 12H/24H mode is handled incorrectly. Setting CR_24H actually enables 12H mode. This patch renames the define and changes the initialization code to correctly set 24H mode. Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Cc: Edgar Toernig <froese@gmx.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-01-03Drivers: rtc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Cc: Wan ZongShun <mcuos.com@gmail.com> Cc: Guan Xuetao <gxt@mprc.pku.edu.cn> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-17drivers/rtc/rtc-vt8500.c: convert to use devm_kzallocDevendra Naga
Replace the kzalloc() and kfree() calls with devm_kzalloc(). Signed-off-by: Devendra Naga <devendra.aaru@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Alexey Charkov <alchark@gmail.com> Acked-by: Tony Prisk <linux@prisktech.co.nz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-21rtc: vt8500: Add devicetree support for vt8500-rtcTony Prisk
Signed-off-by: Tony Prisk <linux@prisktech.co.nz> Reviewed-by: Linus Walleij <linus.walleij@linaro.org>
2012-01-10rtc: convert drivers/rtc/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/rtc/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Guan Xuetao <gxt@mprc.pku.edu.cn> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Haojian Zhuang <haojian.zhuang@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Ben Dooks <ben@simtec.co.uk> Cc: John Stultz <john.stultz@linaro.org> Acked-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-01rtc: vt8500: Use define instead of hardcoded value for status bitWolfram Sang
Fixes the vt8500 driver to use a define value for the isr is-alarm bit. Cc: Alexey Charkov <alchark@gmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-06-23rtc: vt8500: Fix build error & cleanup rtc_class_ops->update_irq_enable()Alexey Charkov
Now that the generic code handles UIE mode irqs via periodic alarm interrupts, no one calls the rtc_class_ops->update_irq_enable() method anymore. Further the rtc_class_ops doesn't have a update_irq_enable element anymore, so this causes a build error. This patch removes the driver hooks and implementations of update_irq_enable and the associated setup. [wsa: updated commit-message and removed update_irq_enable-function, too] [jstultz: improve commit message, clarifying build issue] Signed-off-by: Alexey Charkov <alchark@gmail.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: John Stultz <john.stultz@linaro.org>
2011-05-26rtc: add support for the RTC in VIA VT8500 and compatiblesAlexey Charkov
This adds a driver for the RTC devices in VIA and WonderMedia Systems-on-Chip. Alarm, 1Hz interrupts, reading and setting time are supported. Signed-off-by: Alexey Charkov <alchark@gmail.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Cc: Alexey Charkov <alchark@gmail.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
