Correct PRE_BYPASS (clock scaler 32kHz/1kHz select) bitfield.
Add platform data to tune RTC XTAL capacitance in board file.
Bug 798832, Tested on Ventana/wake via Alarm Clock
Change-Id: I82d67610a815866707fc1db934d7d4d7cf93d883
Reviewed-on: http://git-master/r/22402
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
Reviewed-by: David Schalig <dschalig@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
This change allows rtc alarms to wake the system.
Change-Id: I2a7212fe7cc02b08893fe3a37824b0d39a9f5386
Reviewed-on: http://git-master/r/20101
Tested-by: Thomas Cherry <tcherry@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
alarm_irq_enable can enable/disable irqs and the same irq will
be enabled/disabled in set_alarm.
Bug 770380
Change-Id: Ibd006e83028cea5cd251d789d258a5549bfa34ce
Reviewed-on: http://git-master/r/18661
Bug 770380
Change-Id: I8950a3ef2259b233b1711b266fa7d29270d95bfd
Reviewed-on: http://git-master/r/18565
Initial checkin for Maxim max8907c RTC driver
Change-Id: I764440cc1b0410e54f480a6e0ce424103052df14
Reviewed-on: http://git-master/r/16615
instead of clearing the irq for alarm enable/disable,
the proper bit in RTC_CONFIG has to be set/cleared.
tps6586 does not support 1/sec update counter so
remove support for update_irq_enable. replace it with
alarm_irq_enable.
Change-Id: Iee66a6625e810169253a750faf3f12d20d65d7d9
Reviewed-on: http://git-master/r/17990
This reverts commit 0f04e9f691396f4d1e4288fff91ae8f5862dbba3.
Enable rtc alarm suspend/resume handlers which were disabled
as WAR.
BUG 773133
Change-Id: I666fdf92cb716b247eea1933d837f4c2439cd6fd
Reviewed-on: http://git-master/r/17179
Tested-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Reviewed-by: Mayuresh Kulkarni <mkulkarni@nvidia.com>
drivers/net/wireless/bcm4329/Makefile
Change-Id: I31ce81e09c6f18d6966a5cffebc533453bce02d8
This is a temporary WAR to avoid the undesired "RTC wakeup"
issue. The original source of the problem seems to be in
userspace. But use this WAR till we find a proper fix.
Bug 773133
Change-Id: I20930056f9a33f539699e777ec9ae45bb4bac34f
Reviewed-on: http://git-master/r/15487
Reviewed-by: Deepesh Subhash Gujarathi (Engrg-Mobile) <dgujarathi@nvidia.com>
Tested-by: Deepesh Subhash Gujarathi (Engrg-Mobile) <dgujarathi@nvidia.com>
If an alarm was restarted with a value that moved it away from the head
of a queue, the hrtimer would not be updated. This would cause unnecessary
wakeups.
Change-Id: If379f8dd92b0bdb3173bd8d057adfe0dc1d15259
Signed-off-by: Arve Hjønnevåg <arve@android.com>
arch/arm/mach-tegra/fuse.c
drivers/misc/Makefile
Change-Id: I300b925d78b31efe00c342190d8dbd50e2e81230
In the TPS6586x PMU/PMIC RTC support code, when
converting from seconds to ticks using a shift
operator, the most significant bits were being lost
due to seconds being a 32-bit value and ticks being
a 64-bit value. A hard cast was added to avoid this
loss.
Reviewed-by: Lowell Dennis <ldennis@nvidia.com>
Tested-by: Lowell Dennis <ldennis@nvidia.com>
Reviewed-by: Peter Zu <pzu@nvidia.com>
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Signed-off-by: Colin Cross <ccross@android.com>
arch/arm/mm/cache-v6.S
Change-Id: I1a2063218dd705a762a40f4a9dfe504ce1a1d491
commit 118364948fad7b6c0469ef2d3ddaee447d7a0b5f upstream.
Match the buffer size to the amount of initialized values. Before, it was
one too big and thus destroyed the neighbouring register causing the clock
to run at false speeds.
Reported-by: Andre van Rooyen <a.v.rooyen@sercom.nl>
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cleanup comment.
Change config.
Change-Id: I33ec8d70230672993129e89675aada016286b065
Reviewed-on: http://git-master/r/14080
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Implementation using internal RTC(real time clock).
Alarm wake up from lp0/lp1 is supported.
Use option CONFIG_RTC_DRV_TEGRA to enable.
Change-Id: Iadb767b35423463186eca32b8f47694a59aee7f4
Reviewed-on: http://git-master/r/13780
loss.
Fixes: NVBug 754198 and 751811
Change-Id: I91c3dbd8474c11b3a11f1d3a13eacd213e80cd1a
Reviewed-on: http://git-master/r/11845
drivers/input/touchscreen/Kconfig
Change-Id: Ifc75266e258f9513d78c47c12e2f1de1d2344f02
Signed-off-by: Gary King <gking@nvidia.com>
Change-Id: Ie22a19b662fda6365b1c514aaf83c9de12fabbd4
A few new i2c-drivers came into the kernel which clear the clientdata-pointer
on exit. This is obsolete meanwhile, so fix it and hope the word will spread.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Change-Id: Iaefeca497de02fe36b7f5d79075912f6e349ec53
When we resume we only know how many whole seconds has elapsed.
These errors would accumulate in delta. We now only set the delta
if it would change by more than two seconds. If we drift back by
by more than a second add one in resume.
Drivers can now create alarms that will use an hrtimer while the
system is running and the rtc to wake up from suspend.
This change resolves a problem about unbalanced calls of
enable_irq_wakeup() and disable_irq_wakeup() for alarm interrupt.
Bug reproduction:
root@eb600:~# echo 0 > /sys/class/rtc/rtc0/wakealarm
WARNING: at kernel/irq/manage.c:361 set_irq_wake+0x7c/0xe4()
Unbalanced IRQ 46 wake disable
Modules linked in:
[<c0025708>] (unwind_backtrace+0x0/0xd8) from [<c003358c>] (warn_slowpath_common+0x44/0x5c)
[<c003358c>] (warn_slowpath_common+0x44/0x5c) from [<c00335dc>] (warn_slowpath_fmt+0x24/0x30)
[<c00335dc>] (warn_slowpath_fmt+0x24/0x30) from [<c0058c20>] (set_irq_wake+0x7c/0xe4)
[<c0058c20>] (set_irq_wake+0x7c/0xe4) from [<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8)
[<c01b5e80>] (s3c_rtc_setalarm+0xa8/0xb8) from [<c01b47a0>] (rtc_set_alarm+0x60/0x74)
[<c01b47a0>] (rtc_set_alarm+0x60/0x74) from [<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8)
[<c01b5a98>] (rtc_sysfs_set_wakealarm+0xc8/0xd8) from [<c01891ec>] (dev_attr_store+0x20/0x24)
[<c01891ec>] (dev_attr_store+0x20/0x24) from [<c00be934>] (sysfs_write_file+0x104/0x13c)
[<c00be934>] (sysfs_write_file+0x104/0x13c) from [<c0080e7c>] (vfs_write+0xb0/0x158)
[<c0080e7c>] (vfs_write+0xb0/0x158) from [<c0080fcc>] (sys_write+0x3c/0x68)
[<c0080fcc>] (sys_write+0x3c/0x68) from [<c0020ec0>] (ret_fast_syscall+0x0/0x28)
Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Cc: Ben Dooks <ben@fluff.org.uk>
Cc: Atul Dahiya <atul.dahiya@samsung.com>
Cc: Taekgyun Ko <taeggyun.ko@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: <stable@kernel.org>
ab3100_rtc_probe()
Otherwise, calling platform_get_drvdata() in ab3100_rtc_remove() returns
NULL.
Acked-by:Wan ZongShun <mcuos.com@gmail.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
It was a mistake to mark the PL031 IRQ as shared (for the U8500),
we misread the datasheet. Get rid of this.
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
Cc: Jonas Aberg <jonas.aberg@stericsson.com>
Cc: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Commit b485fe5ea ("rtc/m41t80: use rtc_valid_tm() to check returned tm")
added rtc_valid_tm to m41t80_rtc_read_alarm() but it was wrong while the
t->time does not contain complete date/time.
This patch also fixes a warning:
warning: passing argument 1 of 'rtc_valid_tm' from incompatible pointer type
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Much (but not all) of the RTC state is kept in the RTC peripheral which
has its own power domain. Periodically (1 HZ), that state is synced from
one power domain to the other (peripheral->core). When we are resuming,
we need to wait for the sync to occur so that we don't get a mismatch of
reading undefined state in the rest of the driver.
Further, once the externally maintained bits have been synced back into
the core, we then need to restore the bits maintained in the core. In our
particular case, that is just the write completion interrupt bit.
If we don't do any of this, working with the RTC causes ~5 second delays
from time to time after waking up due to the write completion interrupt
never firing.
Reported-by: Michael Dean <mdean@aeronix.com>
Reported-by: Michael Hennerich <michael.hennerich@analog.com>
The int_clear helper takes a bitmask of interrupts to keep, not to
disable. When suspending without wakeup enabled, we want to disable
all interrupts, so use 0 (keep none) instead of -1 (keep all).
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (226 commits)
ARM: 6323/1: cam60: don't use __init for cam60_spi_{flash_platform_data,partitions}
ARM: 6324/1: cam60: move cam60_spi_devices to .init.data
ARM: 6322/1: imx/pca100: Fix name of spi platform data
ARM: 6321/1: fix syntax error in main Kconfig file
ARM: 6297/1: move U300 timer to dynamic clock lookup
ARM: 6296/1: clock U300 intcon and timer properly
ARM: 6295/1: fix U300 apb_pclk split
ARM: 6306/1: fix inverted MMC card detect in U300
ARM: 6299/1: errata: TLBIASIDIS and TLBIMVAIS operations can broadcast a faulty ASID
ARM: 6294/1: etm: do a dummy read from OSSRR during initialization
ARM: 6292/1: coresight: add ETM management registers
ARM: 6288/1: ftrace: document mcount formats
ARM: 6287/1: ftrace: clean up mcount assembly indentation
ARM: 6286/1: fix Thumb-2 decompressor broken by "Auto calculate ZRELADDR"
ARM: 6281/1: video/imxfb.c: allow usage without BACKLIGHT_CLASS_DEVICE
ARM: 6280/1: imx: Fix build failure when including <mach/gpio.h> without <linux/spinlock.h>
ARM: S5PV210: Fix on missing s3c-sdhci card detection method for hsmmc3
ARM: S5P: Fix on missing S5P_DEV_FIMC in plat-s5p/Kconfig
ARM: S5PV210: Override FIMC driver name on Aquila board
ARM: S5PC100: enable FIMC on SMDKC100
Fix up conflicts in arch/arm/mach-{s5pc100,s5pv210}/cpu.c due to
different subsystem 'setname' calls, and trivial port types in
include/linux/serial_core.h
The Ricoh RP5C01 RTC contains 26 x 4 bits of NVRAM. Provide access to it
via a sysfs "nvram" attribute file.
Because CONFIG_PM is a precondition to CONFIG_ACPI, the ifdef CONFIG_PM
within ifdef CONFIG_ACPI is redundant.
Signed-off-by: Christian Dietrich <qy03fugy@stud.informatik.uni-erlangen.de>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Mask out PM flag when reading the hour, always set MIL bit when
writing the hour.
Signed-off-by: Roman Fietze <roman.fietze@telemotive.de>
Add a driver for the DS3232 RTC chip via the I2C bus. Alarms are not
supported in this version of the driver.
[akpm@linux-foundation.org: fix Kconfig help text]
Signed-off-by: Mingkai Hu <Mingkai.hu@freescale.com>
Signed-off-by: Jingchang Lu <b22599@freescale.com>
Signed-off-by: Srikanth Srinivasan <srikanth.srinivasan@freescale.com>
Signed-off-by: Roy Zang <tie-fei.zang@freescale.com>
Cc: Kumar Gala <kumar.gala@freescale.com>
Remove unused local variable.
Signed-off-by: Wan ZongShun <mcuos.com@gmail.com>
This patch does two modifications:
(1) Adjust enable/disable IRQs location,enable it after rtc
registration and disable it prior to unregistration.
(2) Put 'platform_set_drvdata(pdev, nuc900_rtc)' in front of rtc
registration still be safety, though there is no need to do this, when
I move enable irq after rtc registration, I think still put
'platform_set_drvdata' before rtc registration that would be a good
habit.
Make returning time checking function valid. In spite of using the
'rtc_valid_tm', nevertheless, the read time function omits its returning
value, that means the 'rtc_valid_tm' is useless here.
Use rtc_valid_tm() to check the returned struct rtc_time *tm, to avoid
returning a wrong tm value.
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Use rtc_valid_tm to check the returned struct rtc_time *tm, to avoid
Use rtc_valid_tm() to check returning tm for max6900, it can avoid
returning wrong tm value.
Acked-by: Dale Farnsworth <dale@farnsworth.org>
Use rtc_valid_tm() to check returned struct rtc_time *tm - it can avoid
