Added schedule() call after complete is called
to ensure that signalled processes get a chance
to handle the current time change value before
any new time changes occur.
Signed-off-by: Anish Trivedi <anish@freescale.com>
Upgrade of SRTC driver to kernel version 2.6.35 required
that device pointer be provided when calling clk_get_rate
There are not MX28/MX23 power/wakeup node at sys directory.
Signed-off-by: Frank Li <Frank.Li@freescale.com>
This patch contains changes to /drivers files
Contains all checkpatch and copyright fixes.
Acked-by: Rob Herring <r.herring@freescale.com>
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
Fix the logic while writing new date/time to the chip. The driver
incorrectly wrote back register values to different registers and even
with wrong mask. The patch adds clearing of the VLF register, which
should be cleared if all date/time values are set.
Signed-off-by: Rudolf Marek <rudolf.marek@sysgo.com>
Acked-by: Wan ZongShun <mcuos.com@gmail.com>
Cc: Martyn Welch <martyn.welch@gefanuc.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
The ds1307 driver misreads the ds1388 registers when checking for 12 or 24
hour mode. Instead of checking the hour register it reads the minute
register. Therefore the driver thinks minutes >= 40 has the 12HR bit set
and resets the minute register by zeroing the high bits. This results in
minutes are reset to 0-9, jumping back in time 40 or 50 minutes. The time
jump is also written back to the RTC.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Cc: Wan ZongShun <mcuos.com@gmail.com>
Cc: Paul Gortmaker <p_gortmaker@yahoo.com>
Cc: <stable@kernel.org>
Implicit slab.h inclusion via percpu.h is about to go away. Make sure
gfp.h or slab.h is included as necessary.
Cc: Kevin Hilman <khilman@deeprootsystems.com>
Make sure s3c_rtc_cpu_type is initialised _before_ it's used in an if()
check.
Reported-by: Jiri Pinkava <jiri.pinkava@vscht.cz>
Signed-off-by: Maurus Cuelenaere <mcuelenaere@gmail.com>
Cc: Maurus Cuelenaere <mcuelenaere@gmail.com>
s3c_rtc_setfreq() uses the platform driver data to derive struct rtc_device,
so make sure drvdata is set _before_ s3c_rtc_setfreq() is called.
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging
* 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging:
i2c: Remove all i2c_set_clientdata(client, NULL) in drivers
i2c/busses: Move two drivers to embedded section
i2c: Rename i2c_check_addr to i2c_check_addr_busy
i2c: Document reserved I2C addresses
i2c: Check for address validity on client registration
i2c: Share the I2C device presence detection code
Documentation/i2c: Checkpatch cleanup
I2C drivers can use the clientdata-pointer to point to private data. As I2C
devices are not really unregistered, but merely detached from their driver, it
used to be the drivers obligation to clear this pointer during remove() or a
failed probe(). As a couple of drivers forgot to do this, it was agreed that it
was cleaner if the i2c-core does this clearance when appropriate, as there is
no guarantee for the lifetime of the clientdata-pointer after remove() anyhow.
This feature was added to the core with commit
e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers.
As there is no need anymore to clear the clientdata-pointer, remove all current
occurrences in the drivers to simplify the code and prevent confusion.
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Richard Purdie <rpurdie@linux.intel.com>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Fixes build errors caused by the:
- OF device_node pointer being moved into struct device
- removal of the match_table field from struct of_platform_driver
CC: Paul Gortmaker <p_gortmaker@yahoo.com>
CC: Alessandro Zummo <a.zummo@towertech.it>
CC: Wolfgang Denk <wd@denx.de>
CC: Tejun Heo <tj@kernel.org>
CC: Anatolij Gustschin <agust@denx.de>
CC: rtc-linux@googlegroups.com
CC: devicetree-discuss@lists.ozlabs.org
The interface for the AB3100 is changed to make way for the
ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson
Analog Baseband chips. The register access functions are moved
out to a separate struct abx500_ops. In this way the interface
is moved from the implementation and the sub functionality drivers
can keep their interface intact when chip infrastructure and
communication mechanisms changes. We also define the AB3550
device IDs and the AB3550 platform data struct and convert
the catenated 32bit event to an array of 3 x 8bits.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
The goal here is to make way for a more general interface for the
analog baseband chips ab3100 ab3550 ab550 and future chips.
This patch have been divided into two parts since both changing name
and content of a file is not recommended in git.
Use nonseekable_open() for this since seeking is not supported anyway.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Add a driver for the RTC on the AB8500 power management chip. This is a
client of the AB8500 MFD driver.
Signed-off-by: Virupax Sadashivpetimath <virupax.sadashivpetimath@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Now that the WM831x core uses genirq for the IRQ controller there is no
need to use the WM831x-specific wrappers to request interrupts so convert
to use genirq directly.
Also use more meaningful strings to make /proc/interrupts more readily
legible.
The bug is an oops when dev_get_drvdata() returned null in
cmos_update_irq_enable(). The call tree looks like this:
rtc_dev_ioctl()
=> rtc_update_irq_enable()
=> cmos_update_irq_enable()
It's caused by a race condition in the module initialization. It is
rtc_device_register() which makes the ioctl operations live so I moved
the call to dev_set_drvdata() before the call to rtc_device_register().
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=15963
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Tested-by: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Malte Schroder <maltesch@gmx.de>
Cc: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
The current ds1302 driver (or at least the one that lives in /drivers/rtc)
seems to be designed for memory mapped devices only. This make it quite
hard to add support for GPIO-based implementations (as this is the case
for the upcoming Arcom Vulcan).
This patch moves the direct register access to inline functions with
explicit names. Still not as good as a proper platform driver, but at
least neater.
Signed-off-by: Marc Zyngier <maz@misterjones.org>
Instead of individually creating and removing the sysfs device attribute
files, wrap them in an attribute_group and use
sysfs_{create/remove}_group.
On imx SoCs rtc clock parent is CKIL, but clock rate shall be determined
using rtc clock itself, that eliminates CKIL clock usage in the driver.
Signed-off-by: Vladimir Zapolskiy <vzapolskiy@gmail.com>
Cc: Daniel Mack <daniel@caiaq.de>
Add support for the S3C64xx SoC to the generic S3C RTC driver.
Acked-by: Ben Dooks <ben-linux@fluff.org>
Cc: Frans Pop <elendil@planet.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
uml: Pushdown the bkl from harddog_kern ioctl
sunrpc: Pushdown the bkl from sunrpc cache ioctl
sunrpc: Pushdown the bkl from ioctl
autofs4: Pushdown the bkl from ioctl
uml: Convert to unlocked_ioctls to remove implicit BKL
ncpfs: BKL ioctl pushdown
coda: Clean-up whitespace problems in pioctl.c
coda: BKL ioctl pushdown
drivers: Push down BKL into various drivers
isdn: Push down BKL into ioctl functions
scsi: Push down BKL into ioctl functions
dvb: Push down BKL into ioctl functions
smbfs: Push down BKL into ioctl function
coda/psdev: Remove BKL from ioctl function
um/mmapper: Remove BKL usage
sn_hwperf: Kill BKL usage
hfsplus: Push down BKL into ioctl function
As a follow-up to the thread about RTC support for some Loongson 2E/2F
boards, this patch tries to address the "REVISIT"/"FIXME" comments about
rtc binary mode handling and allow rtc to work with rtc in binary mode.
I've also raised the message about 24-h mode not supported to warning
otherwise, one may end up with no rtc without any message in the kernel
log.
Signed-off-by: Arnaud Patard <apatard@mandriva.com>
To: linux-mips@linux-mips.org
To: rtc-linux@googlegroups.com
Cc: david-b@pacbell.net
Cc: a.zummo@towertech.it
Cc: akpm@linux-foundation.org
Patchwork: http://patchwork.linux-mips.org/patch/1158/
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits)
vlynq: make whole Kconfig-menu dependant on architecture
add descriptive comment for TIF_MEMDIE task flag declaration.
EEPROM: max6875: Header file cleanup
EEPROM: 93cx6: Header file cleanup
EEPROM: Header file cleanup
agp: use NULL instead of 0 when pointer is needed
rtc-v3020: make bitfield unsigned
PCI: make bitfield unsigned
jbd2: use NULL instead of 0 when pointer is needed
cciss: fix shadows sparse warning
doc: inode uses a mutex instead of a semaphore.
uml: i386: Avoid redefinition of NR_syscalls
fix "seperate" typos in comments
cocbalt_lcdfb: correct sections
doc: Change urls for sparse
Powerpc: wii: Fix typo in comment
i2o: cleanup some exit paths
Documentation/: it's -> its where appropriate
UML: Fix compiler warning due to missing task_struct declaration
UML: add kernel.h include to signal.c
logic"
This reverts commit 9c0a342c45b2d98209ac473ea7a429ddd5c1b473 because
it was included without proper signoffs from RTC maintainers.
These are the last remaining device drivers using
the ->ioctl file operation in the drivers directory
(except from v4l drivers).
[fweisbec: drop i8k pushdown as it has been done from
procfs pushdown branch already]
The rtc-omap driver currently hardcodes the RTC wakeup capability
to be "not capable". While this seems to be true for existing OMAP1
boards which are not wired for this, the DA850/OMAP-L138 SoC, the
RTC can always be wake up source from its "deep sleep" mode.
This patch lets the wakeup capability to be set from platform data and
does not override the setting from the driver. For DA850/OMAP-L138, this
is done from arch/arm/mach-davinci/devices-da8xx.c:da8xx_register_rtc()
Note that this patch does not change the behavior on any existing OMAP1
board since the platform device registration sets the wakeup capability
to 0 by default.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com>
This driver features:
* Alarm support.
* Periodic interrupt by using a timer include into the RTC module.
* The update interrupt is not supported by this RTC module.
This driver was tested on a DM365 EVM by using the rtc-test application
from the Documentation/rtc.txt.
Signed-off-by: Miguel Aguilar <miguel.aguilar@ridgerun.com>
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
This patch corrects author and copyright notices in the stk17ta8 driver
following the split-up of the GE Fanuc joint venture.
Signed-off-by: Martyn Welch <martyn.welch@ge.com>
Acked-by: Thomas Hommel <thomas.hommel@ge.com>
This patch corrects author and copyright notices following the split-up of
On exit paths in mxc_rtc_probe() method some resources are not freed
correctly.
This patch fixes:
* unrequested memory region containing imx RTC registers
* iounmap() isn't called on exit_free_pdata branch
* clock get rate is called for freed clock source
* clock isn't disabled on exit_put_clk branch
To simplify the fix managed device resources are used.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
This was introduced by v2.6.34-rc1~38:
4c014e8 (rtc/mc13783: protect rtc {,un}registration by mc13783 lock)
Reported-by: Dan Carpenter <error27@gmail.com>
Commit 6992f5334995af474c2b58d010d08bc597f0f2fe ("sysfs: Use one lockdep
class per sysfs attribute.") introduced this requirement. First, at25
was fixed manually. Then, other occurences were found with coccinelle
and the following semantic patch. Results were reviewed and fixed up:
@ init @
identifier struct_name, bin;
struct struct_name {
struct bin_attribute bin;
@ main extends init @
expression E;
statement S;
identifier name, err;
struct struct_name *name;
- struct struct_name *name = NULL;
+ struct struct_name *name;
sysfs_bin_attr_init(&name->bin);
+ sysfs_bin_attr_init(&name->bin);
if (sysfs_create_bin_file(E, &name->bin))
S
err = sysfs_create_bin_file(E, &name->bin);
Cc: Eric W. Biederman <ebiederm@xmission.com>
Without this patch /sys/class/rtc/$CONFIG_RTC_HCTOSYS_DEVICE/hctosys
contains a 1 (meaning "This rtc was used to initialize the system clock")
even if reading the time at bootup failed.
Moreover change error handling in rtc_hctosys() to use goto and so reduce
the indention level.
MAX8925 is a PMIC that contains RTC component.
Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com>
Unlike the wm8350-custom code genirq nests enable and disable calls
so we can't just unconditionally mask or unmask the interrupt,
we need to remember the state we set and only mask or unmask when
there is a real change.
Cc: rtc-linux@googlegroups.com
To better match genirq.
The else part of the if statement is indented but does not have braces
around it. It clearly should since it uses clk_enable and clk_disable
which are supposed to balance.
Signed-off-by: James Hogan <james@albanarts.com>
Cc: Valentin Longchamp <valentin.longchamp@epfl.ch>
Cc: Sascha Hauer <s.hauer@pengutronix.de>
Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Luotao Fu <l.fu@pengutronix.de>
This is to protect from interrupt handlers using an unregistered rtc
device.
To assert that the reset irq is considered now before the rtc is
registered the corresponding status is checked before.
mc13783_ackirq, mc13783_unmask and mc13783_mask are deprecated, use the
drop in replacements with the nicer names.
The idr should be destroyed when the module is unloaded. Found with
kmemleak.
Signed-off-by: Aaro Koskinen <aaro.koskinen@nokia.com>
Cc: stable <stable@kernel.org>
The C99 specification states in section 6.11.5:
The placement of a storage-class specifier other than at the beginning of
the declaration specifiers in a declaration is an obsolescent feature.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Memset should be given the size of the structure, not the size of the
pointer.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
T *x;
expression E;
memset(x, E, sizeof(
x))
// </smpl>
The function pcf2123_remove is used only wrapped by __devexit_p so define
it using __devexit.
Cc: Christian Pellegrin <chripell@fsfe.org>
Cc: Chris Verges <chrisv@cyberswitching.com>
Fix issue with rtc device not getting unregistered in probe error path.
Use the devres managed resource functions in the probe routine to cleanup
the error path.
Use sysfs_{create/remove}_group to add/remove the sysfs files.
Reduces the text size by 132 bytes, increases data by 12 bytes:
- 937 124 0 1061 425 rtc-ep93xx.o
+ 805 136 0 941 3ad rtc-ep93xx.o
