commit ecb4a353d3afd45b9bb30c85d03ee113a0589079 upstream.
The RTC_VL_READ ioctl reports the low battery condition. Still,
pcf8523_rtc_read_time() happily returns invalid dates in this case.
Check the battery health on pcf8523_rtc_read_time() to avoid that.
Reported-by: Erik Čuk <erik.cuk@domel.com>
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
Signed-off-by: Alexandre Belloni <alexandre.belloni@bootlin.com>
[ Upstream commit a652e00ee1233e251a337c28e18a1da59224e5ce ]
The IRQ is requested before the struct rtc is allocated and registered, but
this struct is used in the IRQ handler. This may lead to a NULL pointer
dereference.
Switch to devm_rtc_allocate_device/rtc_register_device to allocate the rtc
struct before requesting the IRQ.
[ Upstream commit cf612c5949aca2bd81a1e28688957c8149ea2693 ]
Manage the -EPROBE_DEFER error case for the wake IRQ.
Signed-off-by: Fabien Dessenne <fabien.dessenne@st.com>
Acked-by: Amelie Delaunay <amelie.delaunay@st.com>
[ Upstream commit f22b1ba15ee5785aa028384ebf77dd39e8e47b70 ]
The device's remove() attempts to shut down the delayed_work scheduled
on the kernel-global workqueue by calling flush_scheduled_work().
Unfortunately, flush_scheduled_work() does not prevent the delayed_work
from re-scheduling itself. The delayed_work might run after the device
has been removed, and touch the already de-allocated info structure.
This is a potential use-after-free.
Fix by calling cancel_delayed_work_sync() during remove(): this ensures
that the delayed work is properly cancelled, is no longer running, and
is not able to re-schedule itself.
This issue was detected with the help of Coccinelle.
Signed-off-by: Sven Van Asbroeck <TheSven73@gmail.com>
[ Upstream commit 882c5e552ffd06856de42261460f46e18319d259 ]
The DA9063AD doesn't support alarms on any seconds and its granularity is
the minute. Set uie_unsupported in that case.
Reported-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Reported-by: Geert Uytterhoeven <geert+renesas@glider.be>
Reviewed-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Tested-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Acked-by: Steve Twiss <stwiss.opensource@diasemi.com>
[ Upstream commit 15d82d22498784966df8e4696174a16b02cc1052 ]
When no alarm has been programmed on RSK-RZA1, an error message is
printed during boot:
rtc rtc0: invalid alarm value: 2019-03-14T255:255:255
sh_rtc_read_alarm_value() returns 0xff when querying a hardware alarm
field that is not enabled. __rtc_read_alarm() validates the received
alarm values, and fills in missing fields when needed.
While 0xff is handled fine for the year, month, and day fields, and
corrected as considered being out-of-range, this is not the case for the
hour, minute, and second fields, where -1 is expected for missing
fields.
Fix this by returning -1 instead, as this value is handled fine for all
fields.
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be>
[ Upstream commit d6752e185c3168771787a02dc6a55f32260943cc ]
If we encounter a failure during suspend where this RTC was programmed
to wakeup the system from suspend, but that wakeup couldn't be
configured because the system didn't support wakeup interrupts, we'll
run into the following warning:
Unbalanced IRQ 166 wake disable
WARNING: CPU: 7 PID: 3071 at kernel/irq/manage.c:669 irq_set_irq_wake+0x108/0x278
This happens because the suspend process isn't aborted when the RTC
fails to configure the wakeup IRQ. Instead, we continue suspending the
system and then another suspend callback fails the suspend process and
"unwinds" the previously suspended drivers by calling their resume
callbacks. When we get back to resuming this RTC driver, we'll call
disable_irq_wake() on an IRQ that hasn't been configured for wake.
Let's just fail suspend/resume here if we can't configure the system to
wake and the user has chosen to wakeup with this device. This fixes this
warning and makes the code more robust in case there are systems out
there that can't wakeup from suspend on this line but the user has
chosen to do so.
Cc: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Cc: Evan Green <evgreen@chromium.org>
Cc: Benson Leung <bleung@chromium.org>
Cc: Guenter Roeck <groeck@chromium.org>
Signed-off-by: Stephen Boyd <swboyd@chromium.org>
Acked-By: Benson Leung <bleung@chromium.org>
commit 3cc9ffbb1f51eb4320575a48e4805a8f52e0e26b upstream.
Add the missing adjustment of the month range on alarm reads from the
RTC, correcting an issue coming from commit 9c6dfed92c3e ("rtc: m41t80:
add alarm functionality"). The range is 1-12 for hardware and 0-11 for
`struct rtc_time', and is already correctly handled on alarm writes to
the RTC.
It was correct up until commit 48e9766726eb ("drivers/rtc/rtc-m41t80.c:
remove disabled alarm functionality") too, which removed the previous
implementation of alarm support.
Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org>
Fixes: 9c6dfed92c3e ("rtc: m41t80: add alarm functionality")
References: 48e9766726eb ("drivers/rtc/rtc-m41t80.c: remove disabled alarm functionality")
Cc: stable@vger.kernel.org # 4.7+
commit 0145b50566e7de5637e80ecba96c7f0e6fff1aad upstream.
Before this commit sensor_hub_input_attr_get_raw_value() failed to take
the signedness of 16 and 8 bit values into account, returning e.g.
65436 instead of -100 for the z-axis reading of an accelerometer.
This commit adds a new is_signed parameter to the function and makes all
callers pass the appropriate value for this.
While at it, this commit also fixes up some neighboring lines where
statements were needlessly split over 2 lines to improve readability.
Acked-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: <Stable@vger.kernel.org>
Signed-off-by: Jonathan Cameron <Jonathan.Cameron@huawei.com>
[ Upstream commit 9bde0afb7a906f1dabdba37162551565740b862d ]
pcf2127_i2c_gather_write() allocates memory as local variable
for i2c_master_send(), after finishing the master transfer,
the allocated memory should be freed. The kmemleak is reported:
unreferenced object 0xffff80231e7dba80 (size 64):
comm "hwclock", pid 27762, jiffies 4296880075 (age 356.944s)
hex dump (first 32 bytes):
03 00 12 03 19 02 11 13 00 80 98 18 00 00 ff ff ................
00 50 00 00 00 00 00 00 02 00 00 00 00 00 00 00 .P..............
backtrace:
[<ffff000008221398>] create_object+0xf8/0x278
[<ffff000008a96264>] kmemleak_alloc+0x74/0xa0
[<ffff00000821070c>] __kmalloc+0x1ac/0x348
[<ffff0000087ed1dc>] pcf2127_i2c_gather_write+0x54/0xf8
[<ffff0000085fd9d4>] _regmap_raw_write+0x464/0x850
[<ffff0000085fe3f4>] regmap_bulk_write+0x1a4/0x348
[<ffff0000087ed32c>] pcf2127_rtc_set_time+0xac/0xe8
[<ffff0000087eaad8>] rtc_set_time+0x80/0x138
[<ffff0000087ebfb0>] rtc_dev_ioctl+0x398/0x610
[<ffff00000823f2c0>] do_vfs_ioctl+0xb0/0x848
[<ffff00000823fae4>] SyS_ioctl+0x8c/0xa8
[<ffff000008083ac0>] el0_svc_naked+0x34/0x38
[<ffffffffffffffff>] 0xffffffffffffffff
Signed-off-by: Xulin Sun <xulin.sun@windriver.com>
[ Upstream commit fbb974ba693bbfb4e24a62181ef16d4e45febc37 ]
When there is no IRQ configured for the RTC, the rtc-cmos code does not
support alarms, all alarm rtc_ops fail with -EIO / -EINVAL.
The rtc-core expects a rtc driver which does not support rtc alarms to
not have alarm ops at all. Otherwise the wakealarm sysfs attr will read
as empty rather then returning an error, making it impossible for
userspace to find out beforehand if alarms are supported.
A system without an IRQ for the RTC before this patch:
[root@localhost ~]# cat /sys/class/rtc/rtc0/wakealarm
[root@localhost ~]#
After this patch:
cat: /sys/class/rtc/rtc0/wakealarm: No such file or directory
[root@localhost ~]#
This fixes gnome-session + systemd trying to use suspend-then-hibernate,
which causes systemd to abort the suspend when writing the RTC alarm fails.
BugLink: https://github.com/systemd/systemd/issues/9988
commit 7ce9a992ffde8ce93d5ae5767362a5c7389ae895 upstream.
Fix an issue with the 32-bit range error path in `rtc_hctosys' where no
error code is set and consequently the successful preceding call result
from `rtc_read_time' is propagated to `rtc_hctosys_ret'. This in turn
makes any subsequent call to `hctosys_show' incorrectly report in sysfs
that the system time has been set from this RTC while it has not.
Set the error to ERANGE then if we can't express the result due to an
overflow.
Fixes: b3a5ac42ab18 ("rtc: hctosys: Ensure system time doesn't overflow time_t")
Cc: stable@vger.kernel.org # 4.17+
commit bc51098cdd9573bfdecfd02fc8ed474419d73ea0 upstream.
Fix a problem with commit 311ee9c151ad ("rtc: cmos: allow using ACPI for
RTC alarm instead of HPET") defining `use_acpi_alarm' module parameter
even for non-ACPI platforms, which ignore it. Wrap the definition into
#ifdef CONFIG_ACPI and use a static inline wrapper function, hardcoded
to return 0 and consequently optimized away for !ACPI, following the
existing pattern with HPET handling functions.
Fixes: 311ee9c151ad ("rtc: cmos: allow using ACPI for RTC alarm instead of HPET")
Cc: stable@vger.kernel.org # 4.18+
commit d197a253855d2d8e507a003880aab35c4e2473db upstream.
Fix a commit 311ee9c151ad ("rtc: cmos: allow using ACPI for RTC alarm
instead of HPET") `rtc-cmos' regression causing a link error:
drivers/rtc/rtc-cmos.o: In function `cmos_platform_probe':
rtc-cmos.c:(.init.text+0x33c): undefined reference to `hpet_rtc_interrupt'
rtc-cmos.c:(.init.text+0x3f4): undefined reference to `hpet_rtc_interrupt'
with non-ACPI platforms using this driver. The cause is the change of
the condition guarding the use of `hpet_rtc_interrupt'.
Previously it was a call to `is_hpet_enabled'. That function is static
inline and has a hardcoded 0 result for non-ACPI platforms, which imply
!HPET_EMULATE_RTC. Consequently the compiler optimized the whole block
away including the reference to `hpet_rtc_interrupt', which never made
it to the link stage.
Now the guarding condition is a call to `use_hpet_alarm', which is not
static inline and therefore the compiler may not be able to prove that
it actually always returns 0 for non-ACPI platforms. Consequently the
build breaks with an unsatisfied reference, because `hpet_rtc_interrupt'
is nowhere defined at link time.
Fix the problem by marking `use_hpet_alarm' inline. As the `inline'
keyword serves as an optimization hint rather than a requirement the
compiler is still free to choose whether inlining will be beneficial or
not for ACPI platforms.
commit 7dceef78f310f5351735060d78a1777c69606016 upstream.
Commit 51ed73eb998a1c79a2b0e9bed68f75a8a2c93b9b ("rtc: ds1340: Add support
for trickle charger.") breaks ds1339 wakealarm support by limiting
accessible registers. Fix this.
Fixes: 51ed73eb998a ("rtc: ds1340: Add support for trickle charger.")
Signed-off-by: Soeren Moch <smoch@web.de>
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux
Pull RTC updates from Alexandre Belloni:
"It is now possible to add custom sysfs attributes while avoiding a
possible race condition. Unused code has been removed resulting in a
nice reduction of the code base. And more drivers have been switched
to SPDX by their maintainers.
Summary:
Subsystem:
- new helpers to add custom sysfs attributes
- struct rtc_task removal along with rtc_irq_[un]register()
- rtc_irq_set_state and rtc_irq_set_freq are not exported anymore
Drivers:
- armada38x: reset after rtc power loss
- ds1307: now supports m41t11
- isl1208: now supports isl1219 and tamper detection
- pcf2127: internal SRAM support"
* tag 'rtc-4.19' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: (34 commits)
rtc: ds1307: simplify hwmon config
rtc: s5m: Add SPDX license identifier
rtc: maxim: Add SPDX license identifiers
rtc: isl1219: add device tree documentation
rtc: isl1208: set ev-evienb bit from device tree
rtc: isl1208: Add "evdet" interrupt source for isl1219
rtc: isl1208: add support for isl1219 with tamper detection
rtc: sysfs: facilitate attribute add to rtc device
rtc: remove struct rtc_task
char: rtc: remove task handling
rtc: pcf85063: preserve control register value between stop and start
rtc: sh: remove unused variable rtc_dev
rtc: unexport rtc_irq_set_*
rtc: simplify rtc_irq_set_state/rtc_irq_set_freq
rtc: remove irq_task and irq_task_lock
rtc: remove rtc_irq_register/rtc_irq_unregister
rtc: sh: remove dead code
rtc: sa1100: don't set PIE frequency
rtc: ds1307: support m41t11 variant
rtc: ds1307: fix data pointer to m41t0
We don't have to define an extra config symbol, IS_REACHABLE does
what we need. And having this config symbol just to save the few
bytes of hwmon support on non-DS3231 chips isn't worth it IMO
(especially as the symbol is set per default).
Signed-off-by: Heiner Kallweit <hkallweit1@gmail.com>
Replace GPL v2.0+ license statement with SPDX license
identifier.
Signed-off-by: Krzysztof Kozlowski <krzk@kernel.org>
Replace GPL v2.0+ license statements with SPDX license
identifiers.
Add support to disable event in pull-up.
Signed-off-by: Denis Osterland <Denis.Osterland@diehl.com>
Add support for "evdet" named interrupt source.
The check if i2c client irq matches evdet irq is needed
for the case that there is only one interrupt named "evdet".
In this case i2c client code handles this like an unnamed
interrupt souce and assigns the value.
Reviewed-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
We add support for the ISL1219 chip that got an integrated tamper
detection function. This patch implements the feature by adding
an additional timestamp0 file to sysfs device path.
This file contains seconds since epoch, if an event occurred,
or is empty, if none occurred.
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
This patches addresses following problem:
rtc_allocate_device
devm_device_add_group <-- kernel oops / null pointer, because
sysfs entry does not yet exist
rtc_register_device
rc = devm_device_add_group
if (rc)
return rc; <-- forbidden to return error code
after device register
This patch adds rtc_add_group(s) functions.
The functions store the sum of attribute groups as device resource.
Include rtc_task members directly in rtc_timer member.
Fix a bug that caused the Control_1 register to get zeroed whenever the
RTC time is set. The problem occurred between stopping and starting the
RTC clock, wherein the return value of a successful I2C write function
would get written to the register.
Also update variables of the start and stop functions to be more
consistent with the rest of the driver.
Signed-off-by: Alvin Šipraga <alvin@airtame.com>
When building rtc-sh, rtc_dev isn't used in function __sh_rtc_periodic.
drivers/rtc/rtc-sh.c: In function ‘__sh_rtc_periodic’:
drivers/rtc/rtc-sh.c:146:21: warning: unused variable ‘rtc_dev’ [-Wunused-variable]
struct rtc_device *rtc_dev = rtc->rtc_dev;
Remove the declaration of rtc_dev to dispose the warning.
Fixes: ec623ff014c4 ("rtc: sh: remove dead code")
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
Make the rtc_irq_set interface internale to the RTC subsystem.
The PIE doesn't handle tasks anymore, remove the pointer from the
interface.
There is no way to set a periodic task anymore, remove task pointer and
lock.
The rtc_irq_* interface is not used from outside the RTC subsytem since
2016.
Since commit 80d4bb515b78 ("RTC: Cleanup rtc_class_ops->irq_set_state") and
commit 696160fec162 ("RTC: Cleanup rtc_class_ops->irq_set_freq()"),
sh_rtc_irq_set_state and sh_rtc_irq_set_freq are never called. Remove them
along with task handling.
It doesn't make sense to set the PIE frequency from the driver. Let
userspace do its job.
The m41t11 variant is very similar to the already supported m41t00 and
m41t0, but it has also 56 bytes of NVRAM.
Add it to driver taking into account NVRAM section.
Signed-off-by: Giulio Benetti <giulio.benetti@micronovasrl.com>
Reviewed-by: Rob Herring <robh@kernel.org>
data field points to m41t00, instead it should point to m41t0.
Driver works correctly because on both cases(m41t0 and m41t00) chip_desc
are equal.
Point to right enum m41t0 instead of m41t00.
We want the char-misc fixes in here as well.
getnstimeofday64() is just a wrapper around the ktime accessor, so
we should use that directly.
I considered using ktime_get_boottime_ts64() (to avoid leap second
problems) or ktime_get_real_seconds() (to simplify the calculation,
but in the end concluded that the existing interface is probably
the most appropriate in this case.
The offset needs to be added after reading the alarm value.
It also needs to be subtracted after the now < alarm test.
Tested-by: Jon Hunter <jonathanh@nvidia.com>
Pointer 'name' is being assigned but is never used hence it is redundant
and can be removed.
Cleans up clang warning:
warning: variable 'name' set but not used [-Wunused-but-set-variable]
Drop unnecessary register write-unlock around two read accesses.
Signed-off-by: Johan Hovold <johan@kernel.org>
For completeness re-lock the registers also in the power-off error path.
Make sure to deregister the pin controller in case rtc registration
fails.
Fixes: 57072758623f ("rtc: omap: switch to rtc_register_device")
Cc: stable <stable@vger.kernel.org> # 4.14
Cc: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Do not set the system power-off callback and omap power-off rtc pointer
until we're done setting up our device to avoid leaving stale pointers
around after a late probe error.
Fixes: 97ea1906b3c2 ("rtc: omap: Support ext_wakeup configuration")
Cc: stable <stable@vger.kernel.org> # 4.9
Cc: Marcin Niestroj <m.niestroj@grinn-global.com>
Cc: Tony Lindgren <tony@atomide.com>
Reviewed-by: Marcin Niestroj <m.niestroj@grinn-global.com>
The array pdev is local to the source and does not need to be in
global scope, so make it static.
Cleans up sparse warning:
symbol 'pdev' was not declared. Should it be static?
When the RTC block looses power it needs a reset sequence to make it
usable again. Otherwise, writes to the time register have no effect.
This reset sequence combines information from the mvebu_rtc driver in
the Marvell provided U-Boot, and the SolidRun provided U-Boot repo.
Tested on the Armada 388 based SolidRun Clearfog Base.
Acked-by: Gregory CLEMENT <gregory.clement@bootlin.com>
As pointed out in the added comment resetting the rtc also stops the
included watchdog. This is bad if the bootloader started the watchdog to
secure the boot process. So don't reset if the watchdog is running.
Acked-by: Guenter Roeck <linux@roeck-us.net>
The PCF2127 has 512 bytes of internal static RAM and this patch expands
the driver to access this memory.
In order to read correctly from asynchronously updated RTC registers,
it's necessary to read repeatedly until their values do not change from
read to read. It's also necessary to wait for three RTC clock ticks for
certain operations. There are no timeouts in this code and these
operations could possibly loop forever.
To avoid kernel hangs, put in timeouts.
The iMX7d can be configured to stop the SRTC on a tamper event, which
will lockup the kernel inside this driver as described above.
These hangs can happen when running under qemu, which doesn't emulate
the SNVS RTC, though currently the driver will refuse to load on qemu
due to a timeout in the driver probe method.
It could also happen if the SRTC block where somehow placed into reset
or the slow speed clock that drives the SRTC counter (but not the CPU)
were to stop.
The symptoms on a two core iMX7d are a work queue hang on
rtc_timer_do_work(), which eventually blocks a systemd fsnotify
operation that triggers a work queue flush, causing systemd to hang and
thus causing all services that should be started by systemd, like a
console getty, to fail to start or stop.
Also optimize the wait code to wait less. It only needs to wait for the
clock to advance three ticks, not to see it change three times.
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Shawn Guo <shawn.guo@linaro.org>
Cc: Bryan O'Donoghue <pure.logic@nexus-software.ie>
Signed-off-by: Trent Piepho <tpiepho@impinj.com>
When devm_ioremap fails, the lack of error-handling code may
cause unexpected results.
This patch adds error-handling code after calling devm_ioremap.
Signed-off-by: Zhouyang Jia <jiazhouyang09@gmail.com>
At over 4000 #includes, <linux/platform_device.h> is the 9th most
#included header file in the Linux kernel. It does not need
<linux/mod_devicetable.h>, so drop that header and explicitly add
<linux/mod_devicetable.h> to source files that need it.
4146 #include <linux/platform_device.h>
After this patch, there are 225 files that use <linux/mod_devicetable.h>,
for a reduction of around 3900 times that <linux/mod_devicetable.h>
does not have to be read & parsed.
225 #include <linux/mod_devicetable.h>
This patch was build-tested on 20 different arch-es.
It also makes these drivers SubmitChecklist#1 compliant.
Reported-by: kbuild test robot <lkp@intel.com> # drivers/media/platform/vimc/
Reported-by: kbuild test robot <lkp@intel.com> # drivers/pinctrl/pinctrl-u300.c
We should be returning "retval". The "mrst_rtc.rtc" variable is a valid
pointer.
Fixes: 32b41f93dcaf ("rtc: mrst: switch to devm functions")
