* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (37 commits)
SH: catch negative denormal_subf1() retval in denormal_add()
sh: Fix DMAC base address for SH7709S
sh: update smc91x platform data for se7206.
sh: Stub in cpu_to_node() and friends for NUMA build.
sh: intc register modify fix
sh: no high level trigger on some sh3 cpus
sh: clean up sh7710 and sh7720 intc tables
sh: add interrupt ack code to sh3
sh: unify external irq pin code for sh3
sh-sci: avoid writing to nonexistent registers
sh-sci: sh7722 lacks scsptr registers
sh-sci: improve sh7722 support
sh: reset hardware from early printk
sh: drain and wait for early printk
sh: use sci_out() for early printk
sh: add memory resources to /proc/iomem
sh: add kernel bss resource
sh: fix sh7705 interrupt vector typo
sh: update smc91x platform data for se7722
sh: update smc91x platform data for MigoR
The file in drivers/rtc/rtc-ds1551.c uses "int" for flags. This can cause
hard to find bugs on some architectures. This patch converts the flags to use
"long" instead.
This bug was discovered by doing an allyesconfig make on the -rt kernel where
checks are done to ensure all flags are of size sizeof(long).
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Cc: Alessandro Zummo <a.zummo@towertech.it>
Cc: David Brownell <david-b@pacbell.net>
ioremap() and friends get the size information right, so force everything
to go through there.
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (179 commits)
ACPI: Fix acpi_processor_idle and idle= boot parameters interaction
acpi: fix section mismatch warning in pnpacpi
intel_menlo: fix build warning
ACPI: Cleanup: Remove unneeded, multiple local dummy variables
ACPI: video - fix permissions on some proc entries
ACPI: video - properly handle errors when registering proc elements
ACPI: video - do not store invalid entries in attached_array list
ACPI: re-name acpi_pm_ops to acpi_suspend_ops
ACER_WMI/ASUS_LAPTOP: fix build bug
thinkpad_acpi: fix possible NULL pointer dereference if kstrdup failed
ACPI: check a return value correctly in acpi_power_get_context()
#if 0 acpi/bay.c:eject_removable_drive()
eeepc-laptop: add hwmon fan control
eeepc-laptop: add backlight
eeepc-laptop: add base driver
ACPI: thinkpad-acpi: bump up version to 0.20
ACPI: thinkpad-acpi: fix selects in Kconfig
ACPI: thinkpad-acpi: use a private workqueue
ACPI: thinkpad-acpi: fluff really minor fix
ACPI: thinkpad-acpi: use uppercase for "LED" on user documentation
Fixed conflicts in drivers/acpi/video.c and drivers/misc/intel_menlow.c
manually.
Based on earlier work by Jon Smirl and Jochen Friedrich.
Update most new-style i2c drivers to use standard module aliasing
instead of the old driver_name/type driver matching scheme. I've
left the video drivers apart (except for SoC camera drivers) as
they're a bit more diffcult to deal with, they'll have their own
patch later.
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Jochen Friedrich <jochen@scram.de>
This patch allows new-style i2c chip drivers to have alias names using
the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this
point, the old i2c driver binding scheme (driver_name/type) is still
supported.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Some drivers have duplicated unlikely() macros. IS_ERR() already has
unlikely() in itself.
This patch cleans up such pointless code.
Signed-off-by: Hirofumi Nakagawa <hnakagawa@miraclelinux.com>
Acked-by: Jeff Garzik <jeff@garzik.org>
Cc: Paul Clements <paul.clements@steeleye.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: Carsten Otte <cotte@de.ibm.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.de>
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data
be setup before gluing PDE to main tree.
Signed-off-by: Denis V. Lunev <den@openvz.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Dmitry Torokhov <dtor@mail.ru>
Cc: Neil Brown <neilb@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
pnp_resource_table is going away soon, so use the more
generic public interfaces instead.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Acked-By: Rene Herman <rene.herman@gmail.com>
Signed-off-by: Len Brown <len.brown@intel.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
In current kernel if we want to set the alarm time, the absolute time the
seconds relative to 1970-01-01 00:00:00) should be written into
/sys/class/rtc/rtc0/wakealarm. It is not convenient.
It is more reasonable to add the support for the alarm time relative to
current RTC time.(the unit is second)
For example:
If the RTC is required to generate alarm after 2 minutes, the following
will be OK.
echo +120 > /sys/class/rtc/rtc0/wakealarm
or echo +0x78 > /sys/class/rtc/rtc0/wakealarm
Signed-off-by: Zhao Yakui <yakui.zhao@intel.com>
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
rs5c_get_regs() currently uses rs5c->rtc->name for its debug printk when
i2c_transfer() fails, though it is used several times before the rtc dev
has been registered. The earliest we can get at the symbolic name is via
the i2c client's struct device, which can be handled by moving the first
rs5c_get_regs() until after the client pointer is assigned.
Make the needlessly global ds1511_rtc_{read,set}_time() static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Fix following warning:
WARNING: vmlinux.o(.data+0x253e28): Section mismatch in reference from the variable test_drv to the function .devexit.text:test_remove()
Fix by renaming the platfrom_driver variable from *_drv to *_driver
so modpost ignore the reference to an __devexit section.
Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it>
Cc: Herbert Valerio Riedel <hvr@gnu.org>
Kconfig tweaks to help reduce RTC configuration bugs, by avoiding
legacy RTC drivers when the generic RTC framework is enabled:
- If rtc-cmos is selected, disable the legacy rtc driver;
- When using generic RTC on x86, enable rtc-cmos by default;
- In the old "chardev RTC" section of Kconfig, add a comment
warning people off these (seven) legacy RTC drivers when
the generic framework is in use.
People can still use the legacy drivers if they want (or need) to.
This doesn't fix the broken dependencies for the legacy "CMOS" RTC driver.
Ideally it would be a full list of platforms where it works, not a partial
list of ones where it won't. Or better yet, it would depend on a
"HAVE_CMOS_RTC" flag defined by various platforms ... surely there's a
Kconfig style guideline lurking there.
Acked-by: Alessandro Zummo <a.zummo@towertech.it>
Fix bogus #include in rtc-pcf8583, so it compiles on platforms that
don't support PC clone RTCs. (Original issue noted by Adrian Bunk.)
Cc: Adrian Bunk <bunk@kernel.org>
Cc: <stable@kernel.org>
This adds support for periodic IRQs to the rtc-sh driver.
RTC_IRQP_READ/RTC_IRQP_SET are added, with a number of other fixes and
reordering across the rest of the code.
Signed-off-by: Angelo Castello <angelo.castello@st.com>
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
There is a bug in the function of cmos_set_alarm. RTC alarm time for October
can't be set correctly.
For October: 0x0A will be written into the RTC region (MONTH_ALARM) in current
kernel. But in fact 0x10 should be written. Wildcards are also not handled
correctly.
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf, the platform modalias is
prefixed with "platform:". Add MODULE_ALIAS() to the hotpluggable RTC
platform drivers, to re-enable module auto loading.
[dbrownell@users.sourceforge.net: more drivers, minor fix]
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Greg KH <greg@kroah.com>
rtc-s35390a uses BITREVERSE functions so it needs to select that config symbol
to ensure that the functions are built.
drivers/built-in.o: In function `s35390a_set_datetime':
linux-2.6.25-rc8-git7/drivers/rtc/rtc-s35390a.c:144: undefined reference to `byte_rev_table'
drivers/built-in.o: In function `s35390a_get_datetime':
linux-2.6.25-rc8-git7/drivers/rtc/rtc-s35390a.c:163: undefined reference to `byte_rev_table'
Updates to the at91sam9 rtt-as-rtc driver:
- Bugfix: IRQ enable bits need shifting before masking with status
- Platform code to initialize wakeup bits didn't get merged; cope
Cc: Justin Waters <justin.waters@timesys.com>
This adds basic get/set time support for the Seiko Instruments S-35390A.
This chip communicates using I2C and is used on the QNAP TS-109/TS-209 NAS
devices.
Signed-off-by: Byron Bradley <byron.bbradley@gmail.com>
Acked-by: Jean Delvare <khali@linux-fr.org>
Acked-by: David Brownell <david-b@pacbell.net>
Tested-by: Tim Ellis <tim@ngndg.com>
For the "cmos" RTC, have /proc/driver/rtc say whether HPET based IRQ
emulation is in effect. Given the problems we've had with this particular
hardware maldesign (and the fact that most BIOS code seems not to provide
the IRQ routing needed to use the saner HPET modes), this should help
troubleshooting.
Commit 75b6102257874a4ea796af686de2f72cfa0452f9 ("rtc: add support for
Epson RTC-9701JE V4") introduced the warning
drivers/rtc/rtc-r9701.c: In function `r9701_get_datetime':
drivers/rtc/rtc-r9701.c:74: warning: unused variable `time'
Signed-off-by: S.Çağlar Onur <caglar@pardus.org.tr>
AT91sam9 RTC support, primarily in the form of an RTT-as-RTC driver that was
extracted from 2.6.23-at91 patch and updated:
- Relies on now-merged platform updates, which associate the RTT
hardware address with each RTT and use the "at91_rtt" name.
- RTC framework related fixes and cleanups, notably:
* removed now-needless suspend/resume clock offset logic
* alarm read/write now respects the "enabled" flag
* suspend always disables update irqs
* shutdown (and startup) disables all irqs
- Misc cleanup:
* use dev_*() messaging
* add comments
* remove globals,
* ... etc
- Don't force use of RTT0 and GPBR0. Either resource may need
to be used for other purposes (like NO_HZ support).
- Update "AT91RM9200 RTC" Kconfig to allow it on SAM9RL chips
(it has both RTT and RTC).
Driver binding uses bus_find_device() to avoid needing any kind of "timer
library" code when there's more than one RTT module. (This timer can be used
as an RTC, to support NO_HZ operation, or potentially for other stuff. The
choice is a per-system policy.)
Cc: Michel Benoit <murpme@gmail.com>
Cc: Nicolas Ferre <nicolas.ferre@rfo.atmel.com>
Cc: Andrew Victor <linux@maxim.org.za>
Remove some more references to dev->power.power_state. That field is overdue
for removal, but we can't do that while it's still referenced in the kernel.
The only reason to update it was to make the /sys/devices/.../power/state
files (now removed) work better.
For DS140, clear the oscillator fault flag as needed.
Signed-off-by: Frederic RODO <f.rodo@til-technologies.fr>
[ And remove some "sparse" warnings. ]
Add support for the Epson RTC-9701JE SPI RTC device.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
That patch adds the RTC emulation of the HPET timer to the new RTC_DRV_CMOS.
The old drivers/char/rtc.ko driver had that functionality and it's important
on new systems.
[akpm@linux-foundation.org: unbreak alpha build]
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Cc: Andi Kleen <ak@suse.de>
Cc: john stultz <johnstul@us.ibm.com>
Cc: Robert Picco <Robert.Picco@hp.com>
- thus clearing out the need for spin locks
- add a small optimization for reading of the rtc field
Signed-off-by: Mike Frysinger <michael.frysinger@analog.com>
Signed-off-by: Bryan Wu <bryan.wu@analog.com>
Acked-by: Alessandro Zummo <alessandro.zummo@towertech.it>
field.
also, dont bother using memcpy since we can just do an assignment of the same structure.
that we have MMR filesystem in sysfs)
(struct platform_device*), so fix the irq handler
seconds, so lock our driver down to 1 Hz
Add RTC support for DS1511 RTC/WDT chip.
Signed-off-by: Andy Sharp <andy.sharp@onstor.com>
Start making the rtc-cmos alarm act more like a oneshot alarm by disabling
that alarm after its IRQ fires. (ACPI hooks are also needed.)
The Linux RTC framework has previously been a bit vague in this area, but
any other behavior is problematic and not very portable. RTCs with full
YYYY-MM-DD HH:MM[:SS] alarms won't have a problem here. Only ones with
partial match criteria, with the most visible example being the PC RTC, get
confused. (Because the criteria will match repeatedly.)
Update comments relating to that oneshot behavior and timezone handling.
(Timezones are another issue that's mostly visible with rtc-cmos. That's
because PCs often dual-boot MS-Windows, which likes its RTC to match local
wall-clock time instead of UTC.)
This adds a basic ds1302 RTC driver, which is basically a cleanup and move
of the in-tree SH SecureEdge5410 code (which is currently located in
arch/sh/board/snapgear/rtc.c) to drivers/rtc.
This aims to be a building block that the M32R and CRIS code can be worked
on top of, so we can get rid of drivers/char/ds1302.c and
arch/cris/arch-v10/drivers/ds1302.c respectively, though more work is
needed for this.
This makes rtc-cmos export its NVRAM, like several other RTC drivers.
It still works within the limits of the current CMOS_READ/CMOS_WRITE calls,
which don't understand how to access multiple register banks. The primary
impact of that limitation is that Linux can't access the uppermost 128
bytes of NVRAM on many systems.
Note that this isn't aiming to be a drop-in replacement for the legacy
/dev/nvram support. (Presumably that has real users, and isn't just
getting carried forward automatically?) Userspace handles more work:
- When userspace code updates NVRAM, that will need to include
updating any platform-specific checksums that may apply.
- No /proc/driver/nvram file will parse and display NVRAM data
according to whichever boot firmware your board expects.
Also minor pnp-related updates: update a comment, remove dead code.
Use is_power_of_2() macro for simplicity.
The rtc-pcf8583 driver is using the I2C_M_NOSTART flag but shouldn't. This
flag is only meant for broken chips and the PCF8583 RTC chip is not one of
these.
Add adds a warning if a potentially conflicting RTC option has been
selected and makes some other cosmetic fixes to the Kconfig.
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: (197 commits)
sh: add spi header and r2d platform data V3
sh: update r7780rp interrupt code
sh: remove consistent alloc stuff from the machine vector
sh: use declared coherent memory for dreamcast pci ethernet adapter
sh: declared coherent memory support V2
sh: Add support for SDK7780 board.
sh: constify function pointer tables
sh: Kill off -traditional for linker script.
cdrom: Add support for Sega Dreamcast GD-ROM.
sh: Kill off hs7751rvoip reference from arch/sh/Kconfig.
sh: Drop r7780rp_defconfig, use r7780mp_defconfig as kbuild default.
sh: Kill off dead HS771RVoIP board support.
sh: r7785rp: Fix up DECLARE_INTC_DESC() arg mismatch.
sh: r7785rp: Hook up the rest of the HL7785 FPGA IRQ vectors.
sh: r2d - enable sm501 usb host function
sh: remove voyagergx
sh: r2d - add lcd planel timings to sm501 platform data
sh: Add OHCI and UDC platform devices for SH7720.
sh: intc - remove default interrupt priority tables
sh: Correct pte size mismatch for X2 TLB.
* pxa-plat: (53 commits)
[ARM] 4762/1: Basic support for Toradex Colibri module
[ARM] pxa: fix mci_init functions returning -1
[ARM] 4737/1: Refactor corgi_lcd to improve readability + bugfix
[ARM] 4747/1: pcm027: support for pcm990 baseboard for phyCORE-PXA270
[ARM] 4746/1: pcm027: network support for phyCORE-PXA270
[ARM] 4745/1: pcm027: default configuration
[ARM] 4744/1: pcm027: add support for phyCORE-PXA270 CPU module
[NET] smc91x: Make smc91x use IRQ resource trigger flags
[ARM] pxa: add default config for littleton
[ARM] pxa: add basic support for Littleton (PXA3xx Form Factor Platform)
[ARM] 4664/1: Add basic support for HTC Magician PDA phones
[ARM] 4649/1: Base support for pxa-based Toshiba e-series PDAs.
[ARM] pxa: skip registers saving/restoring if entering standby mode
[ARM] pxa: fix PXA27x resume
[ARM] pxa: Avoid fiddling with CKEN register on suspend
[ARM] pxa: Add PXA3 standby code hooked into the IRQ wake scheme
[ARM] pxa: Add zylonite MFP wakeup configurations
[ARM] pxa: program MFPs for low power mode when suspending
[ARM] pxa: make MFP configuration processor independent
[ARM] pxa: remove un-used pxa3xx_mfp_set_xxx() functions
arch/arm/mach-pxa/ssp.c
