path: root/drivers/s390/char/keyboard.c
2007-10-17unicode diacritics supportSamuel Thibault
There have been issues with non-latin1 diacritics and unicode. http://bugzilla.kernel.org/show_bug.cgi?id=7746 Git 759448f459234bfcf34b82471f0dba77a9aca498 `Kernel utf-8 handling' partly resolved it by adding conversion between diacritics and unicode. The patch below goes further by just turning diacritics into unicode, hence providing better future support. The kbd support can be fetched from http://bugzilla.kernel.org/attachment.cgi?id=12313 This was tested in all of latin1, latin9, latin2 and unicode with french and czech dead keys. Turn the kernel accent_table into unicode, and extend ioctls KDGKBDIACR and KDSKBDIACR into their equivalents KDGKBDIACRUC and KDSKBDIACR. New function int conv_uni_to_8bit(u32 uni) for converting unicode into 8bit _input_. No, we don't want to store the translation, as it is potentially sparse and large. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Cc: Jan Engelhardt <jengelh@gmx.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-05[S390] Get rid of a lot of sparse warnings.Heiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-06[S390] irq change build fixes.Heiko Carstens
2006-07-12[S390] Fix sparse warnings.Heiko Carstens
2006-04-11[PATCH] s390: invalid check after kzalloc()Peter Oberparleiter
Typo. After the call to kzalloc() for kdb->key_maps the test for NULL checks the wrong variable. Signed-off-by: Peter Oberparleiter <peter.oberparleiter@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] s390: kzalloc() conversion in drivers/s390Eric Sesterhenn
Convert all kmalloc + memset sequences in drivers/s390 to kzalloc usage. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] ebcdic do_kdsk_ioctl off-by-oneDavi Arnaut
Add a missing return check from strnlen_user and fixes a off-by-one when terminating the string with zero. Signed-off-by: Davi Arnaut <davi.arnaut@gmail.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: drivers/s390Jesper Juhl
This is the drivers/s390/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in drivers/s390/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Cornelia Huck <cohuck@de.ibm.com> Acked-by: Stefan Bader <Stefan.Bader@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
